Re: Saving Home Configuration
You need to Ref All Home every time.
On general config (bottom right) learn to use persistent settings. On screen 1 turn on soft limits.
When turning off, move machine near the limit switches. Then referencing is just a short distance to move at the slower pace it uses.
You can have reference point anywhere that is convenient. Not just at the far corner.
Make a simple program moving Z to a safe position, then move to home position.
-- this assumes the machine is referenced.--
G54 (your home position G59P1)
G0 Z50 (or some where safe)
G0 X0 Y0
M30
Fixture save? If you have zeroed or set any of the DROs you will get this message.
Probably stored at G59P1 .. look at the top right on main screen for the G59 setting.
On screen 2 this is the work offset number. It can store offsets from 1 to 250. Learn to use it. It is your best friend. Also see offsets screen (Alt-5)
