586,471 active members*
3,767 visitors online*
Results 1 to 7 of 7
    Jun 2013
    10
    Home questions
    Do I need limit switches to set up a home position on mach 3?
    Sent from my WP8 920 Tapatalk
    Jan 2013
    630
    Re: Home questions
    Yes. They can be one and the same. Add your switches for the home positions and then use the soft limits within Mach3 if you don't want to put limit switches at the other end of the travel on each axis.
    Re: Home questions
    You can put one switch in the middle of the axis and triggers at the ends and have one switch to be your home and limits also.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2009
    4415
    Re: Home questions
    It really depends on the accuracy you require. You could run each axis against its physical stop, hit ref all. This would be a pretty repeatable location only varying by a partial rotation of the stepper. From there you could choose a location for your G28. Test it with an indicator, see just how close it really is, repeatably.
    A lazy man does it twice.
    Jun 2013
    10
    Re: Home questions
    I ordered switches. The travel on this thing makes me somewhat nervous anyway without a failsafe.
    Nov 2009
    4415
    Re: Home questions
    Switches are the way to go. Fail safe might not be the word I would use. More predictable maybe.
    Jun 2013
    10
    Re: Home questions
    That does sound better.
  1. Home Switch Questions?
    By DistortedDesign in forum CNC Machine Related Electronics
    Last Post: 06-19-2013, 12:10 AM
  2. 4x4 home built with pics and some questions
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 02-06-2012, 07:41 AM
  3. Stop and home switches questions
    By coloradonewbie in forum DIY CNC Router Table Machines
    Last Post: 12-01-2009, 05:16 AM
  4. Home made furnace questions
    By MidFloridaTech in forum Casting Metals
    Last Post: 09-21-2008, 06:50 AM
  5. New guy questions home position
    By washingtondude in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-19-2006, 03:46 AM
