Originally Posted by
JavaDog
Almost forgot to mention, when I bought the Servos it was recommended to run with a 2:1 ratio...so I am assuming that is correct.
Almost every servo manufacturer has free sizing programs Like Kollmorgen for example, but nobody seems to bother using them.
All you need to do is plug in your systems design and required feed/speeds etc.
It seems most build their machine, buy the motors and then wonder if they are the correct size.
Al.
Albert E.
