586,108 active members*
3,143 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Whats wrong in these pics
Results 1 to 19 of 19
    Oct 2009
    56
    Hi all
    Either I'm missing something in 25 yrs manual machining conversion to cnc just lately or they have this wrong
    If you use Advanced rough > leads you have PLUNGE or you tick check box for centre cutting tool and get RAMP etc.
    My point you can't plunge with a NON centre cutting tool
    P.S. I wonder if this was fixed in Build 1335
    The more I learn, the more I find there is to learn
    Regards Nick
    Mar 2010
    1852
    Re: Whats wrong in these pics
    Okay, don't go and get all logical on us here!!!!!!
    Just wish the people who programmed this stuff consulted with and actual machinists on this and other software.
    Well, everyone needs a laugh once in a while.
    Apr 2008
    1577
    Yeah, I think they still have that screwed up in 1335. I'm just glad I don't need the check mark button for either one to be easily selected. If I would have had to check the box for center cutting just so I could select the ramp option it would be annoying quickly.
    I would not be surprised if no one has reported it.
    Apr 2006
    3498
    In woodworking and soft plastic we do plunge like this
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    In some materials and/or for some jobs one may wish to run a roughing feature to shift the majority of the waste utilising a centre-cutting tool, I've used plunge in roughing passes for wood, wax and plastic, better to have the option than not,
    - Nick
    Oct 2009
    56
    Quote Originally Posted by magicniner View Post
    - Nick
    Hi magicniner Khalid I think you may be missing my point I have no problem plunging a center cutting tool but in this feature plunging is default try plunging a non center cutting 63mm insert face mill
    into any thing :nono:
    Regards Nick
    Apr 2006
    3498
    Okay..your concern is right.. However, you can plunge that tool (63mm) but keep the plunge feed turtle-slow ... But at higher feed you can damage the tool/workpiece/spindle/machine...never ever try
    Quote Originally Posted by Ozcad View Post
    Yeah, that would be interesting but whatever the default it would be wrong for most of the people some of the time and for some of the people most of the time ;-)
    The reason I missed your point is that I think about and actively choose the tool entry method and parameters for each feature, as appropriate for the job, material and tooling.
    The solution to this for people that need one is not the default favoured option of any individual or group, the solution is no default at all and a mandatory choice between the available options before they can move on,
    Regards,
    Nick
    Quote Originally Posted by Khalid View Post
    You can plunge an inserted face mill?
    I've got plenty of water, do you do the wine trick too? ;-)
    Apr 2006
    3498
    No
    Mar 2012
    1570
    Ozcad,
    It may not be clear based on the images in the tool path wizard, but the application of the tool path does align with what you've learned over you 27 years.
    This is what the help files have to say on this topic.
    Attachment 235408
    BobCAD-CAM V26 Help System
    If you un check center cutting tool even though the entry is set to plunge, in this case it means to start off the work piece. I've created a short video to help clear up how this feature works. If there are any additional questions on this topic please let me know.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    On a lighter side
    Hello Nick,
    So I talked with development and suggested we use the following image in the 3 axis tool path wizard for advance milling leads options.
    Attachment 235516
    Do you think this image would better explain how you thought this feature works?
    Al DePoalo
    Apr 2009
    3376
    Re: On a lighter side
    Quote Originally Posted by aldepoalo View Post
    Hello Nick,
    Attachment 235516
    YUP,,,,
    Apr 2008
    1577
    That's a great tip Al. I guess I've misunderstood what it meant all this time.
    I just played around with it a bit and NOW it suddenly works just like I'd expect it Thanks for clearing that up.
    Oct 2009
    56
    Hi Al thanks for the time taken for the video it explains a lot :idea:
    Regards Nick
    Mar 2010
    1852
    Hello Nick,
    Attachment 235516
    The video was great, but is that new picture an endmill and hair or smoke?
    Dec 2008
    4548
    Hello Nick,
    Maybe we could get the option to set our own images for the operations...
    I would use this one:
    Aug 2012
    621
    Perfect for either <Skin> or <Extrude Curve>.
    Luke
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Apr 2009
    3376
    Quote Originally Posted by Trotline View Post
    Luke
    Or "Equal Distance Offset"
    But for plunging,this pic says it all
  1. whats wrong?
    By zowex in forum Stepper Motors / Drives
    Last Post: 01-15-2012, 10:33 PM
  2. Can someone look at this file, and tell me whats wrong?
    By blakemachine in forum Mastercam
    Last Post: 07-30-2009, 05:35 AM
  3. whats wrong with my computer?
    By keebler303 in forum Computers / Desktops / Networking
    Last Post: 11-30-2006, 12:28 AM
  4. Whats wrong with this freaking rectifier part II
    By Noah in forum CNC Machine Related Electronics
    Last Post: 07-09-2004, 02:41 AM
