Just as the title says....in Mach 3 I only see primary axis options of X,Y Z and slaved axes A,B,C.
I need to slave A axis to B Axis.
Can this be done?
TIA!
Justin in AZ
Can this be done?
TIA!
Justin in AZ
Can you rename your X as B? Although your gcode would need to reflect that. You could try sending the same step and direction signals to both drives.
Ger21,
Thanks for responding....
Verrrry smart man you are!
I will change output pins in MACH from X to A, and my A to X, change my keymapping, then reflect the change in my postprocessor.
Thanks so much!!!
Regards,
Justin
