586,062 active members*
4,532 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma osp 7000, dual turret questions
Results 1 to 18 of 18
    Dec 2011
    94
    Hi, i was wondering if someone with okuma dual turret machines can give me an example of the G code they run, i walked into this position where i have about 15 lathes mostly osp 7000l's but a few are the osp 5000, and the old programmer up and quit, so now i have to figure all this out with no help, im trying to get some cam software working, i would just like to see how other people are coding for these machines, so if anyone could give me just some examples of putting the turrets in to hold mode and tool changes, it would be greatly appreciated. here is code that the previous programmer wrote. thank you for all your help.
    G13
    DEF WORK
    PS LC,[-46,0],[47,12]
    PS LC,[-46,0],[47,05],0
    END
    DRAW
    N1500 G13
    N1505 VCHKL=1.150
    N1510 VCHKD=.1 (CHUCK BARRIER)
    N1515 VCHKZ=-4.5660 (Z-3.4160)
    N1520 VCHKX=.1 (ACTUAL POSITION CHECK)
    N05 G13
    N10 M25
    N15 G50 S3800
    N20 DIA1 = .864 (O.D. FINISH SIZE)
    N25 DIA6 = 1.01 (FLG. O.D. SIZE)
    N30 DIA5 = .550 (ROUGH BORE SIZE)
    N35 ZZ01 = -3.166 (FINISH LENGTH)
    N40 ZZ02 = -2.283 (BODY LENGTH)
    N45 FSID = .6090 (FINISH BORE SIZE)
    N70 ZZ07 = -2.387 (OVERALL LENGTH MINUS SHORT BODY LENGTH)
    N75 G00 X10.0 Z1.0 T0101 M09 M42 M05 P05
    /N80 M01 M05 M09 P10 (O.D. HOLD)
    N100 G14
    N105 M25
    N110 DIA7 = -.5900 (ROUGH BORE SIZE)
    N115 DIA3 = -.6090 (I.D. FINISH SIZE)
    N120 ZZ03 = -3.166 (FINISH LENGTH)
    N125 G00 X10.0 Z15.0 T0707 M09 M42 M05 P05
    N130 X0.
    N135 Z15.
    N140 IF VTOPC NTOP (BAR FEED)
    N145 M77
    N150 M84 (FEED OUT BAR END)
    N155 M93
    N160 M83
    N165 M76 (BAR END DROP)
    N170 M92
    N175 M84
    N180 G00 Z1.0
    N185 M93
    N186 G04 F.5
    N190 G01 Z.050 F200. G94 (POSITION FOR NEW BAR)
    N195 G95 M83
    N200 G00 Z1.0
    N205 M101
    N210 X10.0 Z3.0 M92
    N215 GOTO N380
    NTOP
    N225 Z= ZZ03 - .050 M84 (BAR STOP POSTIONING)
    N230 M93
    N231 G04 F.1
    N235 G94 G01 Z.030 F200. (POSTION FOR NEXT PC)
    N240 G95 M83
    N245 G00 Z1.0
    N250 M101
    N255 X10.0 Z3.0 M92
    /N260 M01 M05 M09 P10
    N275 G13
    N280 X10.0 Z1.0 S3200 T0101 M08 M42 M03 P15
    N285 X=DIA6 + .325 Z.01
    N290 G01 X=DIA5 - .200 F.009 (ROUGH FACE)
    N295 G00 X=DIA1 + .020 Z.050 P20
    N300 G01 Z=ZZ02 + .003 F.009 P25 (ROUGH O.D. BODY)
    N335 X=DIA6 + .020
    N340 G01 Z=ZZ01 - .175 F.010 (ROUGH FLG. O.D.)
    N345 G00 X10.0 Z1.0
    N350 M00 M05 M09 P30
    N375 G14
    N380 G00 X10.0 Z6.0 S3200 T0404 M08 M42 M03 P15
    N385 X-.6480 Z3.0
    N390 Z.050 P20
    N391 G01 Z-.194 F.006 P25 (ROUGH CBORE)
    N392 X=DIA7
    N395 G01 Z=ZZ03 - .150 F.007 (ROUGH BORE)
    N400 G00 X=DIA7 + .015 Z1.0
    N405 X10.0 Z6.0
    N410 M00 M05 M09 P30
    N425 G13
    N440 G00 X10.0 Z1.0 S2500 T0505 M08 M42 M03 P35
    N445 X=DIA6 + .075 Z=ZZ02
    N450 G01 X.813 F.003 (RELIEF GROOVE NEXT TO FLG.)
    N455 X.803 F.001
    N460 X=DIA1 -.015 F.005
    N465 G02 X=DIA1 + .002 Z=ZZ02 + .0085 K.0085
    N530 G00 X4.0
    N535 X10.0 Z1.0
    Jun 2008
    372
    Re: Okuma osp 7000, dual turret questions
    The program looks OK, basically it is a "smart" parametric program that uses variables
    G13 is top turret
    G14 is the bottom turret.
    Both turrets have the same coordinate axis so there fore can run the same Gcode. You can run normal Gcode if you wish
    Feb 2009
    6028
    And p codes are timing codes. The only other thing you need to worry about is G110 and G111, those are for constant surface footage, a and b turret respectively.
    Sent from my G-Tab Quantum using Tapatalk
    Oct 2009
    114
    My opinion is to try writing a simple program.
    G13
    G50 S1000
    .use P codes
    G14 (B Turret doing nothing)
    M02
    .Then same program for B turret but A is doing nothing.
    You can learn with alarms.
    But If IGF available then everything easy.
    Dec 2011
    94
    Thanks for all the advise guys, MCR-B II, what is IGF? i have been working out the bugs with my post processor, we are running bobcam, i believe i finally have a good program, i will know tomorrow for sure, 1 other thing i wanted to ask about, is are you guys familiar with using a taper bank? basically he was using the common variables, the operators would input the amount of taper into the common variables page, and then he would call that up with a diameter variable ex dia4 = dia3 + AA04, AA04 is the common variable the operator puts in, not sure how to incorporate that in to cam, just wondered if anyone has used it this way, i never have
    Mar 2009
    1982
    IGF is an interactive dialog style Okuma software for part program creation. Complicated Okuma machinetools are equipped with IGF by default. What happens if you push the IGF button on OSP?
    Feb 2009
    6028
    By the time the 7000 came out, it was 1 touch IGF and pretty sure it was a pricy option on almost all the machines.
    Dec 2011
    94
    it must have been an option because none of our machines have it, it would be awesome if they did! for some reason i keep getting a plus axis over variable alarm on the XA, i will post some code maybe you guys can help me out, cause it doesn't make any sense to me and all the tools are touched off,
    Ok here is code i generated from bobcad, on the id groove rough op i get a over plus variable on line 5016, even though it runs the top part of the code fine, and i put all the finishes together and it ran through with no problems, maybe there is something i am not seeing. any advise is much appreciated
    $05274.MIN%
    ( PROGRAM NUMBER: 00100)
    ( PROGRAM START - TURNING CYCLES )
    ( PROGRAM NAME: 05274.MIN)
    ( POST: OKUMA OSP7000L )
    ( DATE: MON. 05/12/2014)
    ( TIME: 09:52AM)
    N01 G18 G20 G80 G90 G99
    G14
    N02 G00 X15. Z5.0 S500 T0101 M03 P05
    /N03 M01 M05 M09 P15 (ID HOLD)
    (Machine Setup - 1 Face Rough )
    (TOOL #2 )
    G13
    N06 G00 X15. Z5.0 S500 T0202 M03 P05
    N11 G50 S1000
    N16 G97 S500 M08
    N21 G00 X12.5 Z1.0
    N26 Z0.
    N31 G01 X10.5 F.006
    N36 G00 Z5.0
    N37 G00 X15.0 Z10.0
    N41 M01 M05 M09 P15
    (Machine Setup - 1 OD Rough )
    (TOOL #2 )
    G13
    N55 G00 X15. Z10. S300 T0202 M03 P20
    N60 G50 S1000
    N65 G97 S300 M08
    N70 G00 X12.7625 Z.05
    N75 X12.5625
    N80 G42 G01 X12.4625 Z0. F.008
    N85 Z-5.315 F.008
    N90 X12.5625 Z-5.265 F.008
    N95 G00 Z.05
    N100 X12.4625
    N105 G01 X12.3625 Z0. F.008
    N110 Z-4.915 F.008
    N115 X12.456 F.008
    N120 Z-5.315 F.008
    N125 X12.556 Z-5.265 F.008
    N130 G00 Z.05
    N135 X12.3625
    N140 G01 X12.2625 Z0. F.008
    N145 Z-4.915 F.008
    N150 X12.3625 F.008
    N155 X12.4625 Z-4.865 F.008
    N160 G00 Z.05
    N165 X12.2625
    N170 G01 X12.1625 Z0. F.008
    N175 Z-.1476 F.008
    N180 X12.21 Z-.2362 F.008
    N185 Z-4.915 F.008
    N190 X12.2625 F.008
    N195 X12.3625 Z-4.865 F.008
    N200 G00 Z.05
    N205 X12.1834
    N210 G01 X12.0834 Z0. F.008
    N215 X12.1625 Z-.1476 F.008
    N220 X12.2625 Z-.0976 F.008
    N225 G00 X12.756
    N230 Z-5.1863
    N235 G01 X12.556 F.008
    N240 G01 X12.356 Z-5.2863 F.008
    N245 Z-5.315 F.008
    N250 X12.456 Z-5.265 F.008
    N255 G00 Z-5.2363
    N260 G01 X12.2985 Z-5.315 F.008
    N265 X12.3985 Z-5.265 F.008
    N270 G00 X15.
    N275 Z10.
    N280
    N285 M01 M05 M09 P30
    (Machine Setup - 1 ID Rough )
    (TOOL #2 )
    G14
    N295 G00 X15. Z10. S300 T0202 M03 P20
    N300 G50 S1000
    N305 G97 S300 M08
    N310 G00 X10.64 Z.1
    N315 Z.05
    N320 G41 G01 X10.74 Z0. F.008
    N325 Z-5.315 F.008
    N330 X10.64 Z-5.265 F.008
    N335 G00 Z.05
    N340 X10.68
    N345 G01 X10.78 Z0. F.008
    N350 Z-5.315 F.008
    N355 X10.68 Z-5.265 F.008
    N360 G00 Z.05
    N365 X10.712
    N370 G01 X10.812 Z0. F.008
    N375 Z-5.315 F.008
    N380 X10.712 Z-5.265 F.008
    N385 G00 X10.598
    N390 Z10.
    N395 X15.
    N400
    N606 M01 M05 M09 P30
    (OD GROOVE ROUGH TOOL #6)
    G13
    N616 G00 X15. Z10. S300 T0606 M03 P40
    N621 G50 S1000
    N626 G97 S300 M08
    N631 G00 X12.7625 Z-2.3429
    N636 X12.5225
    N641 G01 Z-3.6415 F.006
    N646 X12.6225 Z-3.5915 F.006
    N651 G00 Z-2.3429
    N656 X12.4825
    N661 G01 Z-3.6415 F.006
    N666 X12.5825 Z-3.5915 F.006
    N671 G00 Z-2.3429
    N676 X12.4425
    N681 G01 Z-3.6415 F.006
    N686 X12.5425 Z-3.5915 F.006
    N691 G00 Z-2.3429
    N696 X12.4025
    N701 G01 Z-3.6415 F.006
    N706 X12.5025 Z-3.5915 F.006
    N711 G00 Z-2.3429
    N716 X12.3625
    N721 G01 Z-3.6415 F.006
    N726 X12.4625 Z-3.5915 F.006
    N731 G00 Z-2.3429
    N736 X12.3225
    N741 G01 Z-3.6415 F.006
    N746 X12.4225 Z-3.5915 F.006
    N751 G00 Z-2.3429
    N756 X12.2825
    N761 G01 Z-3.6415 F.006
    N766 X12.3825 Z-3.5915 F.006
    N771 G00 Z-2.3429
    N776 X12.2425
    N781 G01 Z-3.6415 F.006
    N786 X12.3425 Z-3.5915 F.006
    N791 G00 Z-2.3429
    N796 X12.2025
    N801 G01 Z-3.6415 F.006
    N806 X12.3025 Z-3.5915 F.006
    N811 G00 Z-2.3429
    N816 X12.2
    N821 G01 X12.1625 F.006
    N826 Z-3.6415 F.006
    N831 X12.2 F.006
    N836 X12.3 Z-3.5915 F.006
    N841 G00 Z-2.3429
    N846 X12.1625
    N851 G01 X12.1225 F.006
    N856 Z-3.6415 F.006
    N861 X12.1625 F.006
    N866 X12.2625 Z-3.5915 F.006
    N871 G00 Z-2.3429
    N876 X12.1225
    N881 G01 X12.0825 F.006
    N886 Z-3.6415 F.006
    N891 X12.1225 F.006
    N896 X12.2225 Z-3.5915 F.006
    N901 G00 Z-2.3429
    N906 X12.0825
    N911 G01 X12.0425 F.006
    N916 Z-3.6415 F.006
    N921 X12.0825 F.006
    N926 X12.1825 Z-3.5915 F.006
    N931 G00 Z-2.3429
    N936 X12.0425
    N941 G01 X12.0085 F.006
    N946 Z-3.6415 F.006
    N951 X12.0425 F.006
    N956 X12.1425 Z-3.5915 F.006
    N961 G00 X15.0
    N966 Z10.0
    N971
    N976
    N981 M01 M05 M09 P50
    (Machine Setup - 1 ID GROOVE ROUGH )
    (TOOL #5 )
    G14
    N5001 G00 X15.0 Z10.0 S300 T0505 M03 P40
    N5006 G50 S1000
    N5011 G97 S300 M08
    N5016 G00 X10.64 Z.1
    N5021 Z-1.5642
    N5026 G01 X10.74 Z-1.6142 F.005
    N5031 Z-2.7166 F.005
    N5036 X10.64 Z-2.6666 F.005
    N5041 G00 Z-1.5642
    N5046 X10.68
    N5051 G01 X10.78 Z-1.6142 F.005
    N5056 Z-2.7166 F.005
    N5061 X10.68 Z-2.6666 F.005
    N5066 G00 Z-1.5642
    N5071 X10.72
    N5076 G01 X10.82 Z-1.6142 F.005
    N5081 Z-2.7166 F.005
    N5086 X10.72 Z-2.6666 F.005
    N5091 G00 Z-1.5642
    N5096 X10.726
    N5101 G01 X10.826 Z-1.6142 F.005
    N5106 X10.86 Z-1.6776 F.005
    N5111 Z-2.6532 F.005
    N5116 X10.826 Z-2.7166 F.005
    N5121 X10.726 Z-2.6666 F.005
    N5126 G00 Z-1.6276
    N5131 X10.76
    N5136 G01 X10.86 Z-1.6776 F.005
    N5141 X10.9 Z-1.7523 F.005
    N5146 Z-2.5785 F.005
    N5151 X10.86 Z-2.6532 F.005
    N5156 X10.76 Z-2.6032 F.005
    N5161 G00 Z-1.7023
    N5166 X10.8
    N5171 G01 X10.9 Z-1.7523 F.005
    N5176 X10.9104 Z-1.7717 F.005
    N5181 X10.94 F.005
    N5186 Z-2.5591 F.005
    N5191 X10.9104 F.005
    N5196 X10.9 Z-2.5785 F.005
    N5201 X10.8 Z-2.5285 F.005
    N5206 G00 Z-1.7717
    N5211 X10.94
    N5216 G01 X10.98 F.005
    N5221 Z-2.5591 F.005
    N5226 X10.94 F.005
    N5231 X10.84 Z-2.5091 F.005
    N5236 G00 Z-1.7717
    N5241 X10.98
    N5246 G01 X11.0174 F.005
    N5251 X11.02 F.005
    N5256 Z-2.5591 F.005
    N5261 X11.0174 F.005
    N5266 X10.98 F.005
    N5271 X10.88 Z-2.5091 F.005
    N5276 G00 Z-1.7717
    N5281 X11.02
    N5286 G03 X11.06 Z-1.778 K-.0012 I-.039 F.005
    N5291 G01 Z-2.5528 F.005
    N5296 G03 X11.02 Z-2.5591 K-.0212 I.0327 F.005
    N5301 G01 X10.92 Z-2.5091 F.005
    N5306 G00 Z-1.778
    N5311 X11.06
    N5316 G03 X11.0962 Z-1.8111 K-.0213 I-.0332 F.005
    N5321 G01 Z-2.5197 F.005
    N5326 G03 X11.06 Z-2.5528 K-.0394 I0. F.005
    N5331 G01 X10.96 Z-2.5028 F.005
    N5336 G00 X10.598
    N5341 Z5.0
    N5346 X15.
    N5351 M01 M05 M09 P50
    (Machine Setup - 1 OD Groove Finish )
    (TOOL #4 )
    G13
    N5356 G00 X15. Z5.0 S300 T0404 M03 P60
    N5361 G50 S1000
    N5366 G97 S300 M08
    N5371 G00 X12.7625 Z-3.7115
    N5376 X12.3
    N5381 G01 X12.2 Z-3.6615 F.005
    N5386 X11.9685 F.005
    N5391 Z-2.3233 F.005
    N5396 G00 X12.3
    N5401 Z-2.2729
    N5406 G01 X12.2 Z-2.3229 F.005
    N5411 X11.9685 F.005
    N5416 Z-2.3233 F.005
    N5421 G00 X15.
    N5426 Z5.0
    N5431 M01 M05 M09 P70
    (Machine Setup - 1 ID GROOVE Finish )
    (TOOL #5 )
    G14
    N5436 G00 X15. Z5.0 S300 T0505 M03 P60
    N5441 G50 S1000
    N5446 G97 S300 M08
    N5451 G00 X12.7625 Z.1
    N5456 X10.698
    N5461 Z-1.5642
    N5466 X10.732
    N5471 G01 X10.832 Z-1.6142 F.005
    N5476 X10.9164 Z-1.7717 F.005
    N5481 X11.0234 F.005
    N5486 G03 X11.1022 Z-1.8111 K0. I-.0394 F.005
    N5491 G01 Z-2.5197 F.005
    N5496 G03 X11.0234 Z-2.5591 K-.0394 I0. F.005
    N5501 G01 X10.9164 F.005
    N5506 X10.832 Z-2.7166 F.005
    N5511 X10.732 Z-2.6666 F.005
    N5516 G00 Z5.0
    N5521 X15.
    N5526 M01 M05 M09 P70
    (Machine Setup - 1 OD Finish )
    (TOOL #6 )
    G13
    N5531 G00 X15. Z8. S500 T0606 M03 P80
    N5536 G50 S1000
    N5541 G97 S500 M08
    N5546 G00 X12.7625 Z.05
    N5551 X12.1734
    N5556 G01 X12.0734 Z0. F.005
    N5561 X12.2 Z-.2362 F.005
    N5566 Z-4.915 F.005
    N5571 X12.446 F.005
    N5576 Z-5.2363 F.005
    N5581 X12.2185 Z-5.35 F.005
    N5586 X12.3185 Z-5.3 F.005
    N5591 G00 X15.
    N5596 Z8.
    N5601 M01 M05 M09 P90
    (Machine Setup - 1 ID Basic Finish )
    (TOOL #6 )
    G14
    N5606 G00 X15. Z5.0 S500 T0606 M03 P80
    N5611 G50 S1000
    N5616 G97 S500 M08
    N5621 G00 X12.7625 Z.1
    N5626 X10.698
    N5631 Z.05
    N5636 X10.8586
    N5641 G01 X10.9586 Z0. F.005
    N5646 X10.832 Z-.2362 F.005
    N5651 Z-5.0788 F.005
    N5656 X10.9773 Z-5.35 F.005
    N5661 X10.8773 Z-5.3 F.005
    N5666 G00 Z5.1634
    N5671 M01 M05 M09 P90
    (Machine Setup - 1 Cutoff )
    (TOOL #12 )
    G13
    N5676 G00 X15. Z8. S200 T1212 M03 P95
    N5681 G50 S1000
    N5686 G97 S300 M08
    N5691 G00 X12.7625 Z-5.44
    N5696 G01 X10.5586 F.005
    N5701 G00 X15.
    N5706 Z8. P105
    N5711 M24 P110
    N5716 G80
    N5721
    N5726
    N5731 M01 M05 M09
    ( CATCH TOOL #10)
    G14
    N5732 G00 X15.0 Z8.0 S200 T1010 M03 P95
    N5733 G00 X0.0
    N5734 G00 Z2.0
    N5735 G00 Z-5.0
    N5736 G00 Z1.0 P105
    N5737 M24 P110
    N5759 M02
    N5760 M30
    Dec 2011
    94
    The alarm i get is 2286-11, it makes no sense to me, cause i can hack the program up and parts of it will work fine, even with almost the exact same positioning,
    Jun 2008
    372
    What line does it stop at?
    Dec 2011
    94
    LINE 5016
    Aug 2011
    2517
    that alarm means there is at least one X/Z in the program that is bigger than the variable limit.
    in your case it is a PLUS variable limit. so either Z+ something or X+ something is too big.
    either increase the variable limits or decrease the X/Z sizes in the program
    Dec 2011
    94
    i believe i figured it out today, once i took out the tool comp G42 and G41 it seemed to work, a little background on what im doing, i am trying to go off of the former programmers code, and i noticed that he would always send the machines to X25.0 Z10.0 for tool change, and we also have newer Geno okumas single turret with the osp200L and programming like that works fine no problem, i even use tool comp on those machines and it works fine, at the beginning of this thread i posted code from the former programmer, so you can see what im working off of, is there a special way to use tool comp on the dual turret machines? and thanks for your help fordav11
    Jun 2008
    372
    If you use G41/G42 you will need to tell the machine which nose radius offset to use, so the offset call will be T020202
    Aug 2011
    2517
    if G41/G42 is the cause of the alarm, to fix the problem you need to put a G40 (tool nose radius comp cancel) at the end of the last rapid movement of the tool or somewhere where tool nose radius compensation is no longer required.
    So for example......
    N270 G00 X15. G40
    also, if you are using CAM software and POST'ing code you don't need to use TNR comp you can just give it the nose radius and it will work it out and auto-generate correct g-code with the TNR comp included. That way you don't have to worry about it causing other issues and it's one less thing to check on the offset page.
    regardless, you should ALWAYS cancel a G41/G42 at the end of each tool section before moving onto the next tool otherwise you may encounter undesirable results.
    budgieW:
    on my OSP7000L the tool radius is selected with the last 2 digits of the 4-digit tool number and the radius number is typed in the offset page at the end in the R column. T020202 does not work on my machine but my machine only has the most basic capability (no IGF, no TLM, 30M memory etc).
    I have seen programs with Txxxxxx (6 digits) where tool nose radius comp was not being used so I figured it's for something else like tool life management or something?
    Dec 2011
    94
    Ok fordav11 so you are saying i don't really have to use the G41/42 as long as i have the TNR filled out on the offset page at the machine? it seems to be working ok with just straight G code no G41/42, i always seem to have some issues with chamfer size but i imagine that is the software, i will try the 6 digit tool line Txxxxxx and see if that does anything
    Dec 2011
    94
    I changed the tool format to T xxxxxx and then it would take the G41/42, so i got that figured out
    Dec 2011
    94
    what format is the stock displayed
    DEF WORK
    END
    DRAW
    can someone tell me how this works? i am guessing that it is metric, this is just something i copied from the former programmer, thanks again for all your help guys
  1. Okuma OSP 7000 alarm 978-21
    By cnc1979 in forum Okuma
    Last Post: 03-30-2020, 12:26 AM
  2. Okuma dual turret lathes
    By kawman in forum BobCad-Cam
    Last Post: 04-23-2014, 07:02 PM
  3. multicam 7000 dual head
    By CNCMad_Monkey87 in forum Multicam Machines
    Last Post: 09-04-2013, 03:25 PM
  4. Okuma OSP 7000 lathe
    By cbrannam in forum Okuma
    Last Post: 02-22-2013, 03:45 AM
  5. okuma dual turret with osp E100L control
    By brybry0104 in forum Okuma
    Last Post: 07-10-2012, 06:51 PM
