I'm sorta new to cnc, and I had a few questions.
At my school we have a Supermax YCM30 cnc milling machine, and it been sitting in a room with noone using it for probably the past 6-8 years now, and I wan't to get it back up and running to use it.
The machine is in really nice condition and it looks like it was hardley ever used even though its from 1985. It uses an Allen Bradley Bandit III to control the servos. I can't figure out how to get anything working on the machine, and it says I need a password, which no one at the school knows. First question is does anyone know if the company that makes the bandit III and if it's still in buisness and how to contact them?
I can turn on the monitor on, and select a bunch of options like manual control and it shows a digital read out with resolution of .0001, and it has electronic jog etc, but I can't get the spindle motor on to use it manualy and I can't get the servos to jog.
That raises the next question. Is there a way I can test the servo motors out without going through the servo drives? The servos say
"Danctics 500oz/in dc brush servo motor 100v max, 10amps, and 30 puluse amps. " I'm not sure if the servo drives are bad or not, so I need a way to see if the servos even work. Does anyone have any options on this?
I was also thinking of just maybe updating the whole system with new servo drives using the same servos(if they work) and use a pc instead of the bandit software. We use autodesk inventor and solid works at my school which I use to design parts, and I have a copy of mastercam which I have been learing to use already (alot easier than what i though it would be to make g-code), and Mach3 or 4 would probably be a good program to run the machine on. My next question is if I do end up going this route, what type of servo drives would you all recomend I use?
I attached a file of what the bandit III control looks like.
Please if anyone could give me some help, I would greatly appreciate it.
-Jason
