586,119 active members*
3,586 visitors online*
Page 1 of 8 123
Results 1 to 20 of 155
    Feb 2005
    829
    CRP4848 Nema 34 Build
    Well my JoesCNC2006 is gone. Picked up and moved to its new home this morning.
    Sent off an email CNC Routerparts for CRP4848 with pro rack instead of the normal rack and clamps setup.
    We will be getting that paid for hopefully as soon as tomarrow.
    Here is the planned table, built out of timberstrand lumber. For those that don't know what timberstrand is, think OSB lumber. Meaning very stable, little expansion contraction. Basically Dimensionally perfect and straight lumber.
    Feb 2005
    829
    Re: CRP4848 Nema 34 Build
    New machine is ordered!
    Feb 2005
    829
    Well bought 136 pounds of Timber Strand lumber, essentially OSB lumber, for the table. Thats 8 12ft peiced of 2x4.
    Very stable, little to zero expansion contract, and near perfect dimensionality.
    Apr 2012
    75
    Just looking at the frame, I'd suggest skinning the sides with plywood or beefing up your gussets. That gantry is pretty massive, and all the accelerations and decelerations put some racking loads in the front to back direction.
    Feb 2005
    829
    That is always an option vbgraves. There is a frame down the middle, and with the plywood on top and that frame should resist racking pretty good. Can always change it
    Feb 2005
    829
    So it took awhile but we now have a 60amp subpanel in the garage, and enough power to run my new cncrouter. We started assembly and I want to paint the non-mating, non-precision surfaces of the steel rail and rack. I know from emailing Ahren that the powdercoat on the parts is Cardinal RD02 Red. Does anyone know what the closest spray paint that matches that is?
    Feb 2005
    829
    No one has any tips on the red spray paint?
    Meanwhile catching up on some assembly pictures.
    Picture one is the table frame itself, at this stage it was still able to twist around a vertical axis.
    Picture two is the table with its plywood top on, at this point pushing on one corner results in zero deflection, and will just spin the table around in place.
    Picture three is the start of assembly of the machine table itself. So many t-nuts and regular nuts. Much loctite used so far!
    Feb 2004
    1086
    Hi Nick,
    Base is looking great! Cardinal sells a spray paint version of the RD-02. I think it's about $8 / bottle. You can find a local dealer here:
    Cardinal Paint: Contact Cardinal
    You don't really need to use loctite on most of the extrusion connections, as the drop angles on the extrusion serve as a locking feature. You do want to use loctite on the rack and pinion motor pulleys when you get to these, but otherwise it's not really needed.
    Best regards,
    Ahren
    CNCRouterParts
    Best regards,
    Ahren
    CNCRouterParts
    Feb 2005
    829
    Got an email quote from Cardinal in Vancouver Washington. They want $20 for a can of matching spray paint!! I think I may go with a different color, or just find a close match at Ace Hardware.
    As far as loctite on all the nuts/bolts, I am a belt and suspenders kind of guy. I don't want anything coming loose.
    Feb 2005
    829
    So finally unboxed the rails and rack, and found that I had received the standard rack units instead of the ordered PRO style racks.
    Got on the phone with Cory at CRP and the correct PRO rack units will be shipping out tomarrow.
    Feb 2005
    829
    Progress!!
    After painting the rails last night, we have them and the main gantry beam bolted to the machine! And most importantly, the carriages all hit the bumpers at the front of the machine at the same time! So it looks like it is pretty square.
    I will get a better picture tonight, the sunlight outside was causing my camera to take dark pictures.
    What color did you end up using for the rails???
    Feb 2005
    829
    I took one of the risers down to Ace Hardware, and found a rustoleum gloss paint that is nearly a perfect match. $5 a can, and used one can so far. May need one more to paint the non rack part of the gear rack.
    My risers are bolted down so I'm not able to bring them along, do you recall the exact color???
    Feb 2005
    829
    I do not, unbolt one of the bumper mounts.
    LOL. I made my own and painted them black! Looks like a reconnaissance mission to Ace is on tap for later!
    Feb 2005
    829
    lol, I will try to go out and see what color it is during break from work. but I do not believe it actualy said on the can. not anywhere that I saw anyway.
    I found it, Sunrise Red.
    Feb 2005
    829
    So as part of building the machine, we are adding more power to the garage/shop area. Part of that is a 20amp 220v circuit for the air compressor, and eventually a real spindle for the cnc router. I have been having problems figuring out the wiring for the spindle VFD. I think I only need Red/Black/Ground for the VFD is that correct?
    Yes, that should be correct.
Page 1 of 8 123
  1. Starting New CRP4848 build
    By rwskinner in forum Avid CNC
    Last Post: 08-09-2014, 01:51 PM
  2. Build Planning CRP4848
    By nlancaster in forum Avid CNC
    Last Post: 04-01-2014, 12:56 AM
  3. New CRP4848 Build from Central Texas
    By TurnTex in forum Avid CNC
    Last Post: 10-01-2013, 10:40 PM
  4. CRP4848 Build has begun
    By Silver-Fox in forum Open Source CNC Machine Designs
    Last Post: 12-27-2012, 03:18 PM
