586,075 active members*
4,098 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > CNC pocket in glass - poor edge finish
    May 2014
    Question CNC pocket in glass - poor edge finish
    Hi All,
    I'm trying to machine a rectangular pocket in glass. The problem I'm having is that the rectangle's perimeter is chipped along the edge (see picture below). I'm using this mirror for optical purposes, so the edge finish is important.
    Attachment 236234
    Right now I'm using a diamond coated endmill - perhaps there is a better tool for the job? Here are my machining parameters:
    Material: soda lime float glass
    Tool: diamond coated carbide endmill, 1/32" diameter, 4F (Niagra Cutter #DIA430)
    CNC parameters
    • 3000 RPM
    • feed = 1 in/min
    • cut depth = 1/64"
    Any ideas? This is my first shot at machining glass, and I'm only making a handful of these for prototype purposes.
    Thanks!
    Apr 2004
    5737
    Re: CNC pocket in glass - poor edge finish
    I don't think those are the right endmills for glass. Diamond-coated carbide tools take a much more aggressive cut, and are meant for relatively soft but abrasive materials like graphite, where the material quickly dulls a normal endmill. For glass, you want an abrasive tool. You can get diamond-plated cylinders ( a rod coated with diamond particles) inexpensively, or for more money, get sintered diamond tools that last a lot longer. But if you're just doing a few of these, the cheap ones might work. They usually come a little fatter, but you can probably find 1/32" diameter if you look around. Here's a place to start: Diamond Carving Points - Kingsley North Use them with plenty of water.
    Andrew Werby
    Website
    May 2014
    Quote Originally Posted by awerby View Post
    Hi awerby,
    Thanks, I thought there should be a better tool for cutting brittle materials. Do you have any advice on machining guidelines? Tool engagement, RPM etc.
    Apr 2004
    5737
    Spin the tool as fast as you can - if 3000 RPM isn't as fast as you can go.Use flood coolant. Try the feedrate settings you've been using, which seem pretty conservative; step over about 1/5 of the tool diameter. A bigger diameter tool will go faster, but your corners will be rounder. You might try roughing with a 1/8" tool and save your 1/32" for a finish pass.
    Andrew Werby
    Website
  1. Poor Finish on new machine
    By J Monty in forum Knee Vertical Mills
    Last Post: 04-11-2013, 01:23 AM
  2. poor edge finish on v carved plywood
    By gateman in forum DIY CNC Router Table Machines
    Last Post: 04-22-2012, 05:40 AM
  3. Poor finish
    By LLDesigns in forum Benchtop Machines
    Last Post: 07-02-2011, 01:56 AM
  4. poor surface finish
    By sinha_nsit in forum CNC Tooling
    Last Post: 02-17-2010, 04:48 AM
  5. Poor surface finish
    By pmsmichelle in forum Mastercam
    Last Post: 02-05-2010, 03:54 PM
