I would like to design a nice little 4th axis indexing fixture that has a worm and worm-gear connected to a nema23 motor; unfortunately, my knowledge of gears and gear terminology is limited! I know the indexing is done in degrees, but should I design it for 1, 10, and 100th of a degree or make it deg, minutes, seconds of a degree? Each of these designs will require a different gear set, at least I think so? Which one do they use in Europe?
What pitch would I need for each design?
McMaster Carr has their worm gears listed in 6,8,10,12 pitch, all with 14.5° pressure angles.
Also, each pitch has a list with the number of teeth. I suppose the number of teeth would control the divisions of degrees.
Am I going in the right direction?
Challenging but confusing!
Eric
