586,061 active members*
4,456 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > MAZAK MAZATROL T-1 ALARM 130 SPINDLE RUN INHIBIT
Results 1 to 6 of 6
    Feb 2013
    13
    130 Spindle Rotate Inhibit - YouTube
    Hi Guys! kind of a newbie to lathes, we have this MAZAK Slant Turn 15 YEAR 1981, we have had it for 10 years approximately and we have never got it to work, a little story about it:
    My Dad bought it in Chicago, we saw it working, when my guys were getting it in a truck, the relay door came off, 3 or 4 relays were smashed, story short we got them and hooked up the machine when we got it here in the shop.
    It had a CPU DOWN, cause batteries failed, i got it to Mitsubishi Chicago (the boards) they fixed it, i installed all the parameters that came with the lathe, this a couple of years back, almost everything works fine BUT the spindle, i can JOG the spindle, up to 35 RPM, but when i hit SPINDLE START the 130 spindle run inhibit alarm appears, in manual or auto mode, there is something not letting me run the spindle.
    It has a HOWA foot activated hydraulic chuck, it doesn't need air, it has all the hydraulic pressures correct, no alarms, it doesn't have a door interlock on the door, just the alarm when i try to run the spindle, im trying to fix it cause we need another lathe working in the shop, we have left this issue sit for too long, any input will be greatly appreciated, i have a video of the alarm, the link is at the top, and these are the safety devices on the machine, but i cant seem to find neither, thanks again.
    Attachment 236446
    Jul 2010
    62
    Re: MAZAK MAZATROL T-1 ALARM 130 SPINDLE RUN INHIBIT
    Have you tried adjusting proximity switches on chuck cylinder or disconnecting them ?.
    ALGUNA AYUDA
    TENGO EL MISMO ERROR SOLO QUE NO TENGO EL DIAGRAMA ELECTRICO DE ALGUNAS SEÑALES DE MICRO SWITCH, COMO ES EL DE TAIL BODY,EL SPLINDLE TAIL , EL MICRO DE LA PUERTA DE CIERRE. ASI TAMBIEN EL MICRO DEL PEDAL DEL CHUCK.
    Y HASTA QUE NO PONGA ESTAS SEÑALES ES POR ELLO SU APOYO PARA EL MANUAL DE DIAGRAMAS ELECTRICOS O QUE PUEDO HACER.
    GRACIAS POR SU AYUDA.
    hola buen dia una pregunta si quedo; me podrias pasar el tip ya que sucede lo mismo que tu.
    saludos
    ayuda MAZAK MAZATROL T-1 ALARMA 130 INHIBIR MARCHA DEL HUSILLO
    alguien sabe sobre esta alarma???
  1. Mazak QT-20 spindle inhibit alarm
    By Manuseymour in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-01-2021, 05:29 PM
  2. Mazak Mazatrol Probe Alarm 3086?
    By Rocketnsam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-15-2011, 02:36 AM
  3. Mazak integrex 200-IV mazatrol matrix alarm 1281
    By bor32 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-02-2010, 07:59 AM
  4. Mazak Mazatrol Control M1 -- Spindle Alarm
    By stephen21in in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2009, 02:46 PM
  5. Inhibit spindle alarm
    By bigbobr in forum Fadal
    Last Post: 02-15-2008, 06:38 PM
