586,102 active members*
2,485 visitors online*
    Jul 2006
    5
    Angry parameter list
    I hanve a hitachi-seiki lathe with fanuc 6t controls on it. I change the parameter for the rs232 baud rate and now my spindle want stop turning in the m03 direction. I think i might have change a wrong number some where.The m05,m02,m30 commands want stop it but the controls see it.When i power up the machine the spindle starts turning slowly in the m03 direction.Can anybody help me on this?
    Thanks Doug
    Mar 2006
    1625
    did you program a speed (S2000)
    Jul 2006
    5
    mike
    I can change the speed up and down. if i change it up then down to s1 rpm the spindle will stop for a few seconds, then i can m04 the spind and run the speeds up and down. When i do that and m05 the spindle stops and reverse direction.Then manual spindle stop button don't work either. the only way right now to stop it is to power down. I have down loaded a cycle program but it all want fit and i was also thinking about deleteing it out just becaus it don't have a m30 command in it.What do you think?
    Thanks Doug
    24221
    Do you not have the original parameters to load back in?
    Al.
    Albert E.
    Feb 2008
    5
    i think the problem not come from parameter, have you ready check i/o signal from diagnostic page and check all signal has completed.:wee:
