586,055 active members*
4,483 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Tool changer out of position scm record 220
Results 1 to 10 of 10
    May 2014
    45
    I put a tool in the wrong location on my carousel and bumped into an already chucked tool. Now my router says tool changer out of position. Any Ideas would be appreciated.
    thanks ben
    Re: Tool changer out of position scm record 220
    Did you try turning it off, then back on, and re-calibrate?
    Also, check if there's a proximity sensor on the carousel that may be damaged.
    May 2014
    45
    Thanks Gerry- I tried off/on re calibrate already... no dice. The carousel is stuck between positions and does not know where it is. I tried manual movements it does not turn. I am at a loss.
    Jan 2016
    5
    Hi did you ever get this problem solved? I have just done the same.
    May 2014
    45
    Quote Originally Posted by scottyreplay198 View Post
    Scotty, Try sending the carousel home with m code then recalibrate. Also do you have record 220?
    Jan 2016
    5
    Managed to sort by playing around with the limit switches. Yes i work with a 220.
    May 2014
    45
    The reason I ask is we bought a 220 with a bum drilling unit, we fixed the drill unit now need to find the proper servo pack. Question: Do you have drilling unit? If yes, could you you peek into the cabinet and tell me what your servopack reads. Should be a Yaskawa brand if still stock. Should be the pack that sits at tor right of the four. Scm wants to sell me a brandy new one for big bucks and is being tight lipped about it.
    Thanks Ben
    Jan 2016
    5
    Im not that clued up on the inner workings. We have a vertical drilling head and an aggregate drill thats never been used. I will have a look when I am back in after Easter and take some photos.
    May 2014
    45
    Thanks Scotty, Have a great and blessed Easter
    Ben
    Apr 2020
    Quote Originally Posted by Benaiah View Post
    thanks ben
    Have you still got 220 record text me on 07769295318 I work on them for 16 years
  1. How to set Sabre 750 VMC tool changer z-height position?
    By keith20mm in forum Cincinnati CNC
    Last Post: 01-19-2014, 08:45 PM
  2. Tool changer no basic position - DMU 50V
    By hiatec in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-04-2014, 04:18 AM
  3. Replies: 9
    Last Post: 03-22-2008, 05:44 AM
  4. Position Record ...Bad
    By thuffner3 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2004, 12:16 PM
