586,103 active members*
3,028 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Speeding up spindle from 3500rpm to 6000rpm J325
Results 1 to 12 of 12
    Dec 2010
    46
    Okay so I've got my new sheave made and balanced to make my spindle turn 6000rpm, does anyone know what else has to be done to make the screen read 6000rpm? Any help would be greatly appreciated, Thanks
    Feb 2009
    6028
    Re: Speeding up spindle from 3500rpm to 6000rpm J325
    Pretty sure you need a new PIC chip to do that conversion. Bob at ZPS would know.
    Sent from my G-Tab Quantum using Tapatalk
    Feb 2007
    85
    feel like making a 2nd sheave I have been looking an Ametric has one in their catalog but its a 12-14week wait. Ain't nobody go no time fo that.
    BTW how did you balance your sheave? Or did you have someone else do it?
    Dec 2010
    46
    I had it made at a machine shop on a cnc lathe then had my buddy balance it on his crank balancer, I can get you the shops number if you want it, they still have the drawings.
    Feb 2007
    85
    That might be cool. I have a buddy that could help me make the sheave as he is going to be making a couple for an RF45 conversion so he can get 5-6k on the spindle. Might just have him kick one out for me at the same time. Did you make yours to work with a taper lock type thing or was it a direct fit to the motor shaft? I never thought about using a crank balancer to balance the pulley. Good idea.
    Dec 2010
    46
    Thanks! And yes made it fit the taper lock bushing that's on the old sheave, I still need to call dynapath so I can change my display to 6000rpm
    Feb 2007
    85
    I don't think Dynapath would be able to do that. I would talk to ZPS or whomever is now doing all of the Tree parts. They would probably have the info you seek. Might even have it for cheap. I called Dynapath about upgrading my memory for 64kb to whatever I could get as a lot of my programs are just over the max I can have on there, and they told me it would be like $500 or more to get the 128kb memory. I think i will stick with drip feeding for now.
    Dec 2010
    46
    Quote Originally Posted by sortafast View Post
    Dynapath has always helped me with problems, I had to get a whole new set of boards for my mill when I got it and they walked me right thru everything changing chip sending my pic tables to the chips and everything.
    Feb 2007
    85
    Quote Originally Posted by red zilla View Post
    Did you ever get the speed thing sorted out? also what diameter were/are your pulleys? I just did my calculations again and I think I am off a bit and am trying to sort it all out. I have been really dragging my feet about the whole RPM thing and am going to try to get on it in the next week or 2.
    Feb 2007
    85
    never mind. Got the pulley situated and my machine is now running at 6k. Going to have a go at some parts with it tonight to see what it can do. Hooray for more SFM!
    Nov 2013
    6
    Did you end up having to have anything else changed to get the 6000rpm out of it, besides the pulley? I recently purchased a 3500rpm J325
    Feb 2007
    85
    Quote Originally Posted by pianoman8t8 View Post
    Pulley, belt, and then you have to run a jumper wire in the cabinet to get the control to read the 6k input on your programs. But its all relatively simple to do.
  1. J325 Spindle acting up
    By Stuff-Builder in forum Tree
    Last Post: 02-12-2013, 02:52 AM
  2. J 325 6000rpm spindle
    By red zilla in forum Tree
    Last Post: 08-01-2012, 10:07 PM
  3. 4000-6000rpm Spindle Run In.
    By behindpropeller in forum Haas Mills
    Last Post: 03-25-2011, 03:45 PM
  4. Starting the spindle - J325
    By MadPickinSkills in forum Tree
    Last Post: 01-26-2011, 02:22 AM
  5. J325 Spindle repeatability
    By ramsey321 in forum Tree
    Last Post: 01-22-2011, 11:17 PM
