586,089 active members*
3,821 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Alibre to Dolphin PM3D export plug in
    Jul 2008
    340
    The UK web site has a page that features a plug in for Alibre to export Alibre parts to PM3D. I recently purchased Dolphin PRO. I also have Geomagic design which is the latest version of Alibre. Try as I might I can not get the plug in to install or run. Support told me it should just be there and work.
    Has anyone gotten the PM3D plug in to work with Geomagic Design?
    -Freeman
    Sent from my Xoom using Tapatalk
    CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
    Feb 2005
    24
    Re: Alibre to Dolphin PM3D export plug in
    For me I just saved the part in Alibre as an iges, then launched PM3D then opened the iges file.
    To see if you have PM3D installed, look for the pm3d.exe
    C:\Program Files (x86)\PM3D is where mine was loaded.
    I now have a shortcut on my desktop for it.
    Jul 2008
    340
    Quote Originally Posted by Mueller View Post
    I have done the same and it works fine. The only advantage the plug in would have is eliminating the export step, which would be useful.
    -Freeman
    Feb 2007
    413
    Hello,
    I have attached a file that explains how to get the Alibre add-on to work with Geomagic.
    This is a temporary fix until we have new version of the installer that works with Goemagic and Alibre.
    ATB
    Andre
  1. New export to Gcode plug-in for Inkscape
    By Var in forum OpenSource Software
    Last Post: 12-31-2013, 04:29 PM
  2. Tormach: Export Alibre Assembly into Sprutcam?
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 11-03-2011, 09:26 PM
  3. Dolphin CAM w/Alibre integration
    By harley4ever in forum Uncategorised CAD Discussion
    Last Post: 06-20-2011, 09:18 PM
  4. Alibre Export to POV-Ray SDL
    By spiked3 in forum Uncategorised CAD Discussion
    Last Post: 11-13-2009, 03:47 AM
  5. Corel Draw x3 Export to dwg - import to ALibre Design - not editable
    By cnc_gary in forum Uncategorised CAD Discussion
    Last Post: 09-29-2007, 04:34 PM
