586,308 active members*
3,840 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Profiling on a curved surface
    Nov 2005
    938
    Well, the youngest announced her Sr (High School) project was due in a couple of days and she wanted to make a longboard (skateboard). Nothing like procrastination
    So I drew something up in Rhino3D to her design and ran into a very minor problem which I would love to find an answer to.
    As you can see in the attached gif the board is drawn on a curved surface (yellow line). When I tried to set up an outside profile using 2-1/2 D profiling I got the typical profile cuts all parallel to the x-y plane (which was enough to get me through this project). What I was hoping for was the profile cuts to follow the yellow curve in 3D.
    I tried 3D offset profiling and curve machining from the 3D menu and those didn't help either, they followed the curve, but I couldn't set the depth of the z cuts.
    When I get into more advanced projects this type of profiling a 3D curve will become more important to me.
    Any suggestions on how to proceed with this. What am I missing here.
    Thank you,
    Steven
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
    Mar 2010
    99
    Re: Profiling on a curved surface
    Keep in mind - almost all 2D processes working at xy plane only. It's ignoring surfaces and working at vectors only
    All 3D tp working on surfaces or meshes, using vectors as boundary.
    If you need to work on edge of this surface, you have to trim it first.
  1. Curved Surface
    By crolee in forum Mastercam
    Last Post: 12-09-2012, 11:46 PM
  2. Making a curved surface
    By Megaplow in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-19-2011, 03:52 AM
  3. 2d pocketing along a curved surface?
    By cgjeff in forum Visual Mill
    Last Post: 11-18-2010, 02:01 AM
  4. Cutter for curved surface?
    By flash319 in forum DIY CNC Router Table Machines
    Last Post: 09-03-2010, 03:36 AM
  5. Engraving a curved surface?
    By wyobmf in forum Rhino 3D
    Last Post: 05-29-2007, 03:13 PM
