586,069 active members*
3,662 visitors online*
Results 1 to 6 of 6
    Jan 2014
    27
    Haas ST10 tool holders
    Hello, I'm in the process of buying a Haas ST10. I'm trying to purchase tools for this machine but I'm not sure what the square stick tool dimensions of this machine are? Any info would be great. Thanks.
    2932
    Re: Haas ST10 tool holders
    According to the Haas website, it's 3/4"
    [url=http://www.haascnc.com/mt_spec1.asp?id=ST-10&webID=2AXIS_STD_LATHE&CatID=Standard]Haas ST-10 | Haas Automation
    Jun 2008
    24
    I need to get a bigger cutoff tool but the Iscar/Hertel/walter ones I look at need the 25MM holder - all us St10 people have 19mm or .750
    can I just cut the bottom to .750 and will tool be on center?
    I need to cutoff 4.00 diameter and my current walter can only go 3.1 with 19mm shank
    Eddie D
    Pokeyboy Machine
    Nov 2010
    73
    ST10 with VDI toolholder and the type of tool holders VDI40 use tools with holders of 25 * 25. Although it is possible in the United States it is not.
    http://abamet.by/content/files/pdf/s...haas_st-10.pdf
    Identify the characteristics of the machine in Russian, but google will always help you.
    Mar 2005
    159
    I read that the VDI toolholder system is not as ridged as the BOT type tools. Is that correct?
    Mar 2005
    159
    ST-10 arrived and all the .75 tooling I purchased work great.
    I simply put the tool in, set some arbitrary depth, snugged it up and viola, it's cutting on center already!
    My first project is cutting some Delrin.
    In the past I would grind my own tools from HSS.. Nice and sharp, perfect for plastic.
    I can't imagine buying 3/4" HSS blanks to grind for my cutters.
    How would you do it? Use something like 3/8 or 1/2 and shim it to fit the 3/4 holder?
    Maybe there is some type of holder already on the market?
  1. Haas HL-2 Tool Holders
    By Alex VF in forum Haas Lathes
    Last Post: 04-06-2021, 02:05 PM
  2. EdgeCam post for Haas ST10 Lathe xzc
    By Johnnyboy in forum EdgeCam
    Last Post: 01-24-2012, 06:42 AM
  3. New Haas SL-30: Looking for Tool holders
    By HaasStudent in forum Haas Lathes
    Last Post: 10-05-2011, 11:48 PM
  4. Tool holders / Retention studs (BT40/HAAS)
    By cwtoyota in forum CNC Tooling
    Last Post: 01-19-2010, 05:43 PM
  5. Haas HL-4 info, help, manuals, and tool holders
    By bob1112 in forum Haas Mills
    Last Post: 05-25-2007, 02:39 AM
