True Inch lathes? Gear change reverse or lever? anyone have the scoop on this?
Hi all!
I am looking for my first small lathe and I hear weight is the best feature but what about the two lathe makers that toot TRUE INCH lead screws and true inch dials such as Microlux 7x14(90LBS)and Lathmaster 8x14 (190LBS) how important is true inch? and how are you guys getting around this with the other lathes like the HF's 9x20 (230LBS)or Grizzlys 9x19(300LBS)
Also some have a lever on the rear of the headstock which engages the carriage feed in neutral, forward, or reverse gear such as the Microlux; BUT on some you have to change gears, such as the lathmaster, not sure about the 9x20 HF's or Grizzlys anyone know if these have a lever reverse or is it a gear swap??
Any opinions on the (China made) 9 x 20 Birmingham YCL920BD?
By the way I am also looking for a used old USA machine as well
http://www.dreamtone.org/cnc/Mechanical_Design.JPG
