Bulltear Industries and Plasmaland.com are proud to announce the Star-Lab series of CNC machines
*Super speed 175ipm Z axis
*Z axis features solid mounted torch backplate
*Gun drilled Z axis rails
*Hardened and chromed Z axis rails
*Precision stainless steel 3/4" Z axis screw with zero maintenance
*Ethernet/USB connectivity
*Dual drive X axis for no pause tracking
*Mark IV super high speed torch height control
1. No corner dives
2. No torch dip
3. Super fast response
4. Precision torch height tracking (even at high speeds)
*Mag-Lok magnetic torch breakaway system
*Huge linear rails on X axis with spring loaded wiper = no maintenance
*Superb motion from accurately machined precision components
*2 auxillary tool pockets on the Z axis
*2 extra PC relays and 2 extra 110V 7.5amp relays
*XIX 620 oz big shaft steppers
*XSX 500 oz servo motors with planetary gearboxes
*T-rail (no exposed bolt hole hardened true profile linear rail)
*New gantry design allows the maximum capacity in X-Y and Z axis
*New gantry also allows the wiring a minimal exposure to UV light
*Industries massive cable carrier allows full torch weaving without removal and lots of room for extras
*High speed plasma capabilities (cut to 400ipm)
*Solid mounted and qualified to our precision standard extra large and heavy duty gear rack on all axis (No springs)
*High frequency compatibility (130-400amps)
*Extra cable lengths
*Plug and play with Hypertherm's 45-65-85-105-125 Powermax lineup
*Complete software (Cad/Cam/Controller)
*Windows 7 (even laptop)
*Hand controller
*1 year warrantee on electronics
*2 year warrantee on electronics
Table frames
XIX-XSX machines feature a 3x3 fully welded boxed tube steel frame powdercoated with 1/2" thick steel feet and 3/4" leveling bolts. Each frame comes qualified from our layout tables. Water pans may range from 3" depth up to 6" depth depending on amperage.
Pics
