586,123 active members*
3,426 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > CNC Lathe with "Virtual" y-axis. Reliable ?
Results 1 to 7 of 7
    May 2014
    6
    Good afternoon everybody !
    My company decided to change it's conventional lathes to CNC lathes, so this is "new" technology to us.
    One of our options is an IT600 Index-Traub lathe. We need a machine with an y-axis and this is where our doubts begin.
    This machine has an "interpolated" y-axis, which means that the y-axis will come as a result of the movement of the main spindle and the movement of the toolholder equiped with a driven tool. I need to drill holes and make screws with it (as small as M2 screws).
    Is this system reliable? Is it harder to program it ? Are there any limitations that i should consider ?
    May 2014
    6
    Re: CNC Lathe with "Virtual" y-axis. Reliable ?
    anyone?
    Feb 2007
    711
    I think that is called a C axis? I believe it has most of the capabilities of a real Y axis, but there are some situations where you could only use a Y.
    I guess it depends on the part you are trying to make.
    Feb 2009
    6028
    It does depend on the parts. Even cutting a slot on the face will leave small whiteness marks where the c axis reverses. May or may not be a problem with your parts.
    Sent from my G-Tab Quantum using Tapatalk
    Sep 2006
    607
    I have milled out a 50mm deep, 42mm wide hexagon spline (both male and female part) on a lathe with a "virtual" y axis to a h6/H6 (16µ) tolerance. The variation from the center of the surface to the edges were so small that I had trouble measuring any difference. This is a job I have done multiple times now and I can hold that tolerance without much trouble, so I would say that it does a good enough job of it.
    This was done on a Doosan puma 280LM, but I have used a Index machine before and I was impressed by the quality of those machines. One of the Index machines actually had a real Y axis while the other used the C axis.
    There are a few things you can't do, like cutting a slot on a workpiece perpendicular to the C axis or cutting a off-center slot from the C axis. I have wished I had a real Y axis too many times to count, so if you have a choice, get one with a real Y axis!
    May 2014
    6
    Quote Originally Posted by alan_3301 View Post
    Exactly! it is called a C axis !
    - - - Updated - - -
    Quote Originally Posted by underthetire View Post
    Thank you for your reply !
    May 2014
    6
    Quote Originally Posted by The Blight View Post
    Yes! This is EXACTLY what bothered me about this C axis. I suspected that there might be some things that i wouldn't be able to do without a real y axis !Here in Brazil those machines are EXPENSIVE and it would be terrible for us not be able to turn a part in the future because of this (the difference in price between the lathe i mentioned and others with the real y axis is not expressive). Your reply helped me A LOT my friend ! Thank you !!!!!
  1. "Virtual" y-axis of Index machine. Should i buy it ?
    By net.ricardo in forum Uncategorised WoodWorking Machines
    Last Post: 06-08-2014, 01:11 AM
  2. Replies: 17
    Last Post: 02-22-2014, 06:58 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Inactive "Virtual CNC Mill"
    By expart in forum BobCad-Cam
    Last Post: 08-19-2010, 09:23 PM
  5. setting up a lathe "A" axis
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 07-20-2009, 10:26 PM
