586,035 active members*
3,693 visitors online*
Results 1 to 6 of 6
    Feb 2014
    4
    Tolerance Using G64
    Hello All,
    I have just recently started using the code G64. We always used G61 and our Komo was super slow. We have a lot of nothces and cut outs and it was Horrible to watch it crawl through those. Anyhow, in trying to set the tolerance...I went into my code and added the P0.001 after the G64 code.Apparently my Fanuc OM controller didnt understand it as I received an error. Is there any other way to set the tolerance using G64 so my parts are a bit more accurate? They arent bad now but could be better.
    Dec 2008
    3109
    Re: Tolerance Using G64
    G61 is "Exact stop mode", meaning that the programmed motion of the machine must go to that point before continuing to the next line of code. Yes it will make a machine go a lot slower
    G64 is just a cancel of the G61 modal condition
    G9 is a one shot "exact stop" for that line of code
    These codes do not have "extra" address parameters to make them "adjustable" (ie P )
    You would normally run a program in normal machining mode, and manually insert a G61 in the program where you want the machine to do an exact stop
    You may need to add an option to the machine ie "tolerance control" .... or use a lower feedrate at the critical areas
    found this thru google --- link
    Feb 2014
    4
    The post processor uses G61. If your saying G9 is normal cutting mode...I could try that. Is that the normal cutting mode?
    Dec 2008
    3109
    Quote Originally Posted by audreys View Post
    No, that is not what I said
    G61 is "exact stop mode" ON & is modal until it is turned off
    G64 is OFF, or normal machining mode
    G9 is a "mini" version of G61, G9 works only on the line of code that it is stated on
    Modal means it stays active until a code in the same group is programmed
    ie G0 is in the same group as G1 G2 G3,
    G40, G41 G42 is another group.
    - A code from one group will not alter another in a different group
    If you don't have the option for HSM ( high speed machining ) or Tolerance control, then your only real choices are to either lower the feedrate, &/or alter some parameters to tighten the machine up, in how it's axis drives react when finishing a line of code and starting the next
    - some controls call it an "in-position" tolerance. It is how accurately the machine slows the drives down for ending one line of code before starting the next line. You may need to study the parameter manual
    Feb 2014
    4
    Sorry about that misunderstanding. This is the deal. I changed our programs to G64 code because it was so much faster. We were cutting parts out of a 4x8 sheet of plywood that would take about 20 minutes. Changing the code cut that time in half. I told the assemblers if they had issues to let me know. Instantly they did. interesting thing is, when I ran it using the g61 code, the results were the same, only the parts weren't as smooth. Guessing I just need to tighten up my tolerances in my cam software and that should solve the problem.
    Nov 2013
    10
    G64 is not a(mode), it is a cancel command for the modal command g61(exact stop) like a g80 for a drilling cycle.
  1. holding tolerance
    By CLATHAM in forum EDM Discussion General Topics
    Last Post: 10-04-2012, 10:12 AM
  2. 1/4-20 Tap Tolerance
    By xander18 in forum MetalWork Discussion
    Last Post: 10-04-2011, 10:14 PM
  3. ISO Tolerance Help?
    By Billet Sean in forum MetalWork Discussion
    Last Post: 06-18-2008, 01:04 AM
  4. Q: Tolerance - How much is to much?
    By Deviant in forum Mechanical Calculations/Engineering Design
    Last Post: 03-28-2007, 09:23 PM
  5. tolerance
    By heilcnc in forum Benchtop Machines
    Last Post: 04-29-2006, 02:31 PM
