586,471 active members*
3,314 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Slice spiral ignores my boundaries
    Jun 2008
    262
    Hellooo,
    I have a roughed out circular pocket. I have a complex shape at the bottom I need to cut. I have jig grinding to be done on the walls of the pocket so I don't want to cut them.
    I'm using Slice Spiral. I've defined the Geometry. I've put an arc with the proper radius so the tool does not cut the wall. I've defined this as the Boundary (in 2 places in the Cam Tree)
    The toolpath always ignores the boundary. Isn't it supposed to tell the tool exactly where it's bound???
    I'd greatly appreciate any help.
    Nelson
    i build the braces that keep american teeth straight......tick tick tick
    Jun 2008
    262
    Re: Slice spiral ignores my boundaries
    nevermind
    this is really annoying. It's working now.
    the pocket is 1.8 inch dia. I got frustrated and drew a .75" dia. arc and set it as the boundary a while ago.....with a .25 inch mill the toolpath should have been smaller...it was still milling the whole solid. Even without setting the Linking on Boundary to Follow......that was an hour ago.
    Now I tried setting it to Retract and drew my original desired boundary......Now It Works......I've got over a week time in this chunk of steel and I'm nervous. It did not follow the boundary when I tried it.
    YGWYPF
    Thanks !
  1. HAAS tool room mill ignores G52
    By DingoHammer in forum Haas Mills
    Last Post: 05-16-2012, 02:18 PM
  2. Line Boundaries
    By eliot15 in forum GibbsCAM
    Last Post: 08-17-2011, 10:54 AM
  3. Mach ignores limit switches
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 03-16-2011, 08:59 AM
  4. Boundaries - Tool contact areas
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-04-2010, 01:14 AM
  5. new guy needs help. how to set tool boundaries
    By sinuuar in forum FeatureCAM CAD/CAM
    Last Post: 06-02-2009, 12:32 PM
