586,597 active members*
3,322 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Die holder made on My diy cnc machine :)
    Nov 2012
    43
    G'day all!
    Thought i would post my homemade die holder made on my homemade cnc machine.
    I have one of those cheap tap n die sets, cost me all of around $35 AU, anyhoo they thread soft metals fine but the die holders are very flimsy.
    Broke it pretty early on so figured i would just wizz one up on the cnc, needless to say came out nicely
    I had picked up a bunch of 6061 scrap from the boatbuilders and used a bit of 12mm to make the die holder with.
    Quickly drew a design in bobcad and away we went.
    Cut with my sole remaining 1/8" 2 flute bit at a conservative 0.5mm doc and 1300mm/min feed.
    It measures 80mm x 50mm and i tapped a m5 thread on one side for a set screw to retain the die and as i had some 5/16 all-thread handy I tapped a hole in each end for handles and sleeved some ally tube over.
    Feb 2007
    711
    Re: Die holder made on My diy cnc machine :)
    very nice. I have a broken die holder from a cheap set. Now I have to make one for myself.
    Thanks!
    Apr 2006
    3498
    Creativity at it best..Thanks for sharing
    http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
    http://my-diysolarwind.blogspot.com/
    Nov 2012
    43
    Glad you guys liked it
    Cleaned up the dxf so thought I may as well share it.
    I made this one out of 12mm thick 6061 scrap, the die pocket is 9mm deep ( you can alter depth to suit, my dies are about 8mm thick) and the round hole is obviously a pocket thru the material.
    You will obviously have to drill and tap the set screw and handle holes manually on a drill press, i used m5 for the set screw (had one on hand) and 5/16" for the handles ( again, had some on hand )
    Oh and cut with 1/8" endmill so it would get into the rounded parts of the die corners ( I put them in so i didn't have to try file the inside corners)
    Enjoy :cheers:
    heh also a pic of why aluminium tube handles probably weren't the greatest idea haha
    Jun 2012
    817
    Quote Originally Posted by baskarz View Post
    Nothing an anodizing tank won't fix. Nice job.
  1. Replies: 0
    Last Post: 11-27-2012, 04:19 PM
  2. CNC machine torch holder
    By AbachBua in forum Waterjet General Topics
    Last Post: 01-02-2008, 03:21 PM
  3. machine torch holder
    By Erick Davidson in forum Waterjet General Topics
    Last Post: 06-11-2006, 06:32 AM
