586,100 active members*
2,592 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Making BT30 end mill tool holders at home. How bad is this idea?
Results 1 to 8 of 8
    Mar 2014
    1131
    I'm thinking to make some tool holders for my BT30 spindle with my CNC lathe. Accuracy is not a problem. I and the lathe can handle this. However I'm not able to grind the taper for a nice finish because I don't have a grinding attachment on the lathe. Is this a problem? Though, finishing results of my lathe is not bad at all.
    So, is grinding on a tool holder cone a must?
    Jun 2013
    42
    Re: Making BT30 end mill tool holders at home. How bad is this idea?
    I wouldn’t bother. You can buy them for $20-30 of aliexpress.
    Mar 2014
    1131
    By "some" I actually meant "lots of". I need about 20 tool holders because I have only 1 right now. So 20 tool holders + shipping will cost a bunch of money. Would you still buy or make?
    Jun 2013
    42
    I would spend more time making money than trying to make consistent tool holders.
    Mar 2014
    1131
    I see your point but I'm a hobbyist. I don't make money with my machines.
    Sep 2005
    1195
    Your cnc lathe can do it precisely, why not give a try. If you purchase a lot of BT30, the problem is shipping cost maybe too expensive. I maybe do it too in my spare time if I have done retrofitting my cnc lathe.
    Dec 2008
    3109
    What RPM would you be running them at ?
    any speeds above 8000 need to be accurately balanced. plus you need to maintain a very high accuracy between taper and the bore that holds the cutters. I would guess that turned holders would be a little sloppy and used to a max RPM of say
    your cutters would also fail quickly as they would not run quite true & will cut oversize.
    I wouldn't purchase 20 holders... get 5 see how they perform.
    say
    1 face mill holder
    1 drill chuck
    3 er16 collet + collets ( holds up to 10mm cutters)
    you could manufacture the sidelock holders as required
    Dec 2011
    155
    Call me crazy, but I was going to attempt a shrink fit solid " bushing" to fit in my PC router in place of a collet. I figured I can machine it all in one setup on the lathe and ream the Id to accurate size for shrink fit. If it works, I would not have to measure tool height every time i change it. You could always get a used toolpost grinder. I found a Dumore grinder for 200 buck on ebay that needed a little TLC, now i can grind pretty decent. Could probably machine, heat treat, grind on the cheap if thats something you think you'd enjoy doing.
  1. Need help shopping BT30 holders and studs
    By ATRepair in forum Haas Mills
    Last Post: 05-12-2018, 06:16 AM
  2. Old thread on making tool holders, thought it was interesting.
    By johnyac in forum Tormach Personal CNC Mill
    Last Post: 08-13-2013, 04:57 AM
  3. BT30 holders 1/2X13 thread
    By 9 1/2 in forum Bridgeport / Hardinge Mills
    Last Post: 07-08-2008, 06:16 AM
