586,112 active members*
3,047 visitors online*
    Feb 2013
    26
    Fanuc DNC with Ethernet
    Dear Experts
    I am using DNC option via serial RS-232.. How can i use DNC function through Ethernet.
    Jan 2011
    350
    Re: Fanuc DNC with Ethernet
    If you want specifics, tell us what control you exactly have and I'll post more specific instructions.
    For Fanuc 16 and 18, it is:
    1. Setup your FTP server and verify FTP communication is all good.
    2.Then, after loading program in data server hard disk, you can either
    i) load program in memory (for small programs)
    or:
    ii) Use M198P#### in MDI or in a program in memory mode to call a program in data server. (a function we use for large programs)
    For Fanuc 0i, you can easily setup your FTP as well but I never tried using the M198 function on these controls since memory is quite large already I just load it in memory but I would think M198 is used in the same way as for older controls will double-check for you if that's the control you have. Also I think for 21i and so on, procedure is identical. Also control has direct access to the FTP shared folder for 0i controls.
    Cheers.
    It is must be have DATA SERVER function support.
    Aug 2003
    21
    We are using small devices Moxa Embedded Device Servers NE-4110S - Embedded RS-232 Serial Device Server (10/100 Mbps, 115.2 Kbps max.)
    to connect our CNCs to network.
    If you've any qustion, you are welcome to ask [email protected]
    With kindest regards, Igor Kozlov
  1. Ethernet Fanuc 18i-TB
    By ProToZyKo in forum Fanuc
    Last Post: 03-14-2019, 02:42 AM
  2. connecting to fanuc via ethernet
    By beartrax in forum Mori Seiki lathes
    Last Post: 08-27-2012, 04:50 PM
  3. Fanuc 18i MB ethernet networking
    By Wheel in forum Fanuc
    Last Post: 01-14-2009, 06:11 AM
  4. Replies: 2
    Last Post: 08-22-2008, 12:20 AM
  5. Fadal w/Fanuc DNC over the Ethernet
    By AllDone in forum Fadal
    Last Post: 11-30-2007, 04:35 PM
