586,556 active members*
3,498 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > I need a 4 axis mill and 3 axis lathe controller dynamotion + kflops?
    Sep 2012
    108
    hi,
    Not sure who can answer this but some questions.
    Will the software take gcode and output motor controls like mach 3 without any kind of c programing skills?
    Can the software handel starting mid program.
    Is their lathe functions like css.
    Can i use modbus for spindel control
    will it work with gecko 540s?
    average time to instal and setup to running gcodes from knowing nothing of the dynamotion system. hours days or weeks?
    i am very interested in an industrial solution as i have had enough of mach 3 and its crazy software.
    thanks
    C
    May 2006
    4047
    Re: I need a 4 axis mill and 3 axis lathe controller dynamotion + kflops?
    Hi charlieslasher,
    Normally very little C Programming is required. All the programs for converting GCode to Motion and so forth already exist. The C Programming required is for system initialization and to define the configuration of your system. If you don't know anything about programming you will probably find this very difficult.
    One of the more complex programming requirements is for ModBus in KFLOP. Some of our Users have connected ModBus to the PC and commanded simple on/off and speed scripts from the PC which is somewhat simpler. However for CSS the spindle control should be real-time and this is only possible by connecting the ModBus directly to KFLOP. It sounds like this may be too complicated for you - especially if you are in a rush. You might Download our software, run KMotion.exe, using the C Programs Screen, and open the RS232/Modbus Examples.
    Here is a CSS video:
    This is never really a good idea. We have a "Set Next Statement" option that performs a reverse search for the more recent position, feedrate, mode and so forth. It is not flawless. See:
    G Code Screen
    Yes - you will need to make a cable.
    I would budget weeks given you don't know how to spell our name and you have two relatively difficult tasks added on top of everything else - Modbus and CSS
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Looking for Advise/help -Setting up a new 3-axis CNC Mill Melb-SE: Stuck w/Controller
    By ExoticEl in forum Australia, New Zealand Club House
    Last Post: 11-19-2011, 08:55 AM
  2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  3. looking for a 2 axis controller for 7x12 lathe
    By nymachinist in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2006, 04:00 AM
