586,119 active members*
3,400 visitors online*
    Oct 2007
    25
    K2 enable button not working
    I have been running my kg1414 for about a week, and this morning when I was starting everything up, the enable button did not work . The control box is getting a signal from the button, but the axis numbers flash green for a second and then go back to yellow. Tried with all the motors disconnected and inputs/outputs disconnected, and still no change. The encoder positions are updating when I push the button, but everything remains disabled.
    Any ideas?
    Oct 2007
    25
    Re: K2 enable button not working
    Fixed! Kevin at K2 did some troubleshooting for me and we figured out my estop was not responding. I was able to fix it and I am up and running again. Thanks Kevin!
  1. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  2. ESC Button not Working...
    By dneisler in forum Mach Software (ArtSoft software)
    Last Post: 03-24-2013, 02:09 AM
  3. How do i enable LPT3
    By GUIDOSAN in forum Machines running Mach Software
    Last Post: 04-07-2012, 04:22 PM
  4. Enable how????
    By mjhooo8 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-13-2008, 07:27 AM
