586,121 active members*
3,575 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > why the laser not line up (cutting original point does not meet end point)
    Hi everyone
    Recently we had a customer has a problem with his laser:
    When he cut anything with rounded corners or circles the laser will not line up. See below photo.
    Attachment 237940
    we tried to help him solve the problem by following steps:
    This fault should be caused by X-axis out of plumb with Y-axis.
    Please check the gears of Y-axis like below pictures, just pull the belt and check if the gears are loosen or not,
    if yes, please fix them. and test your machine again.
    Attachment 237944
    If still not ok, please cut a square with 150x150mm size, and measure the two diagonal lines are equal or not,
    Attachment 237946
    If they are not equal and even more than 0.5mm D-value,
    then we have to readjust the X-axis and Y-axis mechanical part to make them vertical.
    Attachment 237952
    If the belt/gear are tight enough, or the fault still there after fixed, or the gears are not able to be fixed.
    if anyone has any suggestion for these steps or for other possibilities,
    please give us advice,
    thanks in advance.
    and for more troubleshooting lessons:
    Troubleshooting List
    www.thunderlaser.com
    Apr 2008
    204
    Re: why the laser not line up (cutting original point does not meet end point)
    After checking belt tension, checking pulleys that they are well secured, belt for burns/wear, it could either be the resolution/tuning of the motor is off or you have a motor that is missing steps would be my two cents worth.
    Quote Originally Posted by davy182 View Post
    thanks so much for your nice suggestion, dear Davy
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. Reestablishing original datum point when scaling
    By Southbend Sam in forum Dolphin CAD/CAM
    Last Post: 12-20-2013, 08:16 PM
  3. line out start point
    By kendo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-26-2010, 01:00 AM
  4. Line tangent through point
    By mastercamguru in forum Mastercam
    Last Post: 12-07-2008, 01:26 AM
  5. Line Smoothing, point /line no identification
    By dz1 in forum Visual Basic
    Last Post: 12-15-2007, 12:03 PM
