586,103 active members*
3,214 visitors online*
Thread: import DXF
    Aug 2004
    73
    import DXF
    Hi all,
    I try to import DXF file to FC but I can't set up the stock for the geometrys,
    please help, I use FC 2006
    thank you
    Sep 2003
    363
    If you are having trouble with the import wizard hit the finish button. Click on the stock when the stock window opens you can shift the stock + or – in XYZ. You can also change the size and the material.
    Gary
