586,069 active members*
3,484 visitors online*
Results 1 to 2 of 2
    May 2014
    Ball screw number step
    I need an explanation. I purchased a controller kit fom HOBBYCNC with 3 205 oz stepper motors. Can some one explain how the stepper motors relate to the ball screw. I ordered Ball screws from over seas for a wood router i want to build . But have no idea as to the NUMBER STEP 1-4 ?
    Jan 2010
    2141
    Re: Ball screw number step
    I'm not certain that I understand your question.
    The ball screw will have a specific pitch, for example 10 turns per inch (which means that one complete revolution of the screw will advance the nut by one tenth of an inch), or perhaps a metric rating such as 5mm advance per turn.
    Typical stepper motors will have 200 steps per revolution (when the single-step mode is used). If the driver is set up for half-stepping, then it will take 400 steps to do a single revolution. Similarly, with one quarter microstepping, it will take 800 steps per revolution.
    So, based on the stepper motor steps per revolution and the ball screw's pitch, you can figure out the linear travel of the ball screw nut for one step of the motor.
  1. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  2. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  3. roller screw versus ball screw.
    By Paraprop in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 10:21 AM
  4. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
