Originally Posted by
ger21
I forgot about the feedrate part.
No, you don't increase rpm as you decrease feedrate. You use the chipload chart to calculate rpm based on feedrate, or calculate feedrate based on rpm.
Their chart is sort of useless, since it doesn't tell you what rpm they're using. Based on the chipload, though, I'm guessing their using 18,000 rpm for their chart.
Based on the chip load, then yes, you should be between 16-32ipm at 8000 rpm. I'm not sure that you have enough rigidity for 1/8" deep cuts. I'd maybe try .03" until you get the hang of it. With deep cuts, any slop in the machine will snap the bit instantly.
I would not try to drill aluminum with a router bit, especially a 1 flute. Use a short 1/8" drill bit instead, you'll get much better results.
