586,655 active members*
3,457 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > U100L number of offsets
Results 1 to 6 of 6
    Oct 2005
    332
    Question U100L number of offsets
    Hello. My U100L control have 32 available offsets that are currently not enough for me. At least 64 offsets are necessary so that I can keep my tools well defined.
    This is a limitation of the control or can they be easy added?
    Thank you
    Aug 2011
    420
    Re: U100L number of offsets
    I think, this is an optional spec and you must purchase it with new software set.
    Mar 2009
    1982
    how many tools you have on your lathe at once?
    you can save and load tool descriptions via file
    Oct 2005
    332
    At the same time about 18 offsets, but it is often I change tools (maybe 4 times per day).
    It would be ok for me that the GCode for a job could carry the tool definition (offset, radius, ...), but I do not know if that is possible on the U100L.
    Thank you
    Aug 2011
    2517
    you can set tool geometry offsets from a program using User Task system variables.
    VTOFX [1] = 123.456
    VTOFZ [1] = 123.456
    the 1 in brackets is the tool offset number
    similarly for tool nose radius....
    VNSRX [1]=0.8
    VNSRZ [1]=0.8
    More system variables are listed in one of the Special Functions Manuals that deals with User Task.
    Oct 2005
    332
    How! If this works on my machine then all is solved as my tools never leave the VDI holder, therefor I can manage a database on my CAM and add that information in the Gcode, without the need to change the tooltable before a job.
    Many thanks fordav11 !
  1. OSP U100L
    By fomaz in forum Okuma
    Last Post: 02-09-2024, 09:10 PM
  2. Okuma LB300///OSP U100L
    By iffe123 in forum Okuma
    Last Post: 08-25-2023, 04:30 PM
  3. RS232 Setting Problem win OSP-U100L???
    By bfrawley in forum Okuma
    Last Post: 02-28-2023, 08:53 PM
  4. u100L backlash compensation
    By duivenhok in forum Okuma
    Last Post: 08-19-2014, 09:58 AM
  5. Replies: 1
    Last Post: 01-14-2011, 01:20 AM
