586,052 active members*
4,360 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > How to stop "Generating Tool Path" pita
Results 1 to 6 of 6
    Dec 2006
    302
    Sometimes, and far too often, Mach3 will stop at a line of code and report that it is "Generating Tool Path" and not continue until the path has been generated. It will do this for every line of code. I hit cancel and it will go to the next line of code then do it again.
    How can I make this annoying process go away?
    John
    Jul 2011
    297
    Re: How to stop "Generating Tool Path" pita
    I have never seen that happen before...
    wonder if it doesn't like a specific line of code or something?
    or maybe a certain order or something?
    Dec 2006
    302
    Doesn't seem to relate to any specific line, it happens randomly. Yesterday I was running a proven code and it just happened. I had to shut everything down and re-start, then AOk.
    Mar 2010
    8
    On the "Diagnostics" screen, there is a button called "Toolpath On/Off". That worked for me.
    Dan
    Dec 2006
    302
    Dan,
    Thanks. That should work. I messed with the "button" under the tool path display w/o effect. I'll try your technique next time.
    John
    Jan 2016
    The "optional block skip" can cause this. It has to rebuild when it skips a block.
  1. Replies: 8
    Last Post: 05-11-2014, 09:15 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 05:35 PM
  4. scary problem "generating numbers"
    By Daniel Boone in forum Fadal
    Last Post: 06-26-2010, 06:50 PM
  5. Generating "axis" from imported STP file...
    By mcphill in forum Solidworks
    Last Post: 06-24-2010, 05:54 PM
