586,832 active members*
3,362 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > How to control a dc motor/actuator with a g540 drive? step and direction?
    Sep 2012
    108
    How can i control a dc non stepper motor/actuator with a g540 drive? i want to control forwards and reverse to open and close a collet chuck on a lathe. Not a wood machine but someone here might have an idea.
    i have read a bit about a h bridge but still not sure whats the easiest way. I have 2 spare axis and one spare relay output.
    Mar 2007
    2083
    Re: How to control a dc motor/actuator with a g540 drive? step and direction?
    Hi
    a picture of your actuator and the existing collet mechanism will help
    I'd use a 2 pole relay to power the motor to open and close the collet
    with a limit switch to switch off the motor once the collet is closed and another when open
    to save the G540 relay output for something else
    I can't think of an easy way to use the step / direction signals to control a DC motor
    unless you used a stepper motor to operate some switches
    or an electronic control circuit if you break into the printer cable to connect to the step / direction pins for an unused axis
    (a C4 dual relay board is one possibility or may be C41 and PWM DC speed control if you need to control the motor speed
    john
Name:	relay collet control.jpg
    Sep 2012
    108
    Quote Originally Posted by john-100 View Post
    Hi
    Will get some photos Its leaver rotary motion of 70deg to open close a collet.
    i didnt think of this. This could work, but it also isnt very simple its a motor to turn on a motor. Maybe belt reduction drive strait of a stepper motor to rotate the shaft of the collet closer. Would need to check the torque
    john
    thanks for your ideas.
  1. Replies: 4
    Last Post: 09-10-2013, 04:52 AM
  2. Linear Motor, Actuator, Servo Drive, Motion Control Products
    By juliangoal in forum Linear and Rotary Motion
    Last Post: 06-28-2013, 08:48 AM
  3. Can EMC2 control lathe spindle with Step/Direction Drive?
    By Mike Nash in forum LinuxCNC (formerly EMC2)
    Last Post: 03-16-2010, 10:18 PM
  4. step and direction control for opto22 servo drive
    By drewgarth in forum Servo Motors / Drives
    Last Post: 05-21-2006, 07:31 PM
