586,113 active members*
3,118 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC50 COUNTER WEIGHT CHAIN
    Oct 2007
    74
    Hello everyone, I have an older BMC50 (one of the blue Max 3 386 platform models) and the counter weight chain has stretched some over the years. As it makes a long Z stroke and the head gets
    close to the table the chain will POP as the link come over the sprocket. I want to order new chain but am not sure what the correct pitch is for that chain. We have tried to measure it and the readings are all over the place. If anyone might have the info on the chains I would really appreciate it.
    John
    Jun 2008
    1104
    Re: BMC50 COUNTER WEIGHT CHAIN
    If I remember correctly, they are RS50 chains.
    Feb 2009
    6028
    And make sure you get new bearings for the sprockets. We had those come apart once.
    sent from me
    Oct 2007
    74
    Thanks for the information. That helps greatly.
  1. Counter weight for spindle?
    By mickelsen in forum Maintenance DIY Discussion
    Last Post: 02-07-2012, 06:56 PM
  2. Mill Drill Z axis Counter Weight
    By Need TECH Help! in forum Benchtop Machines
    Last Post: 12-03-2011, 10:32 PM
  3. Vertical mill counter weight chains
    By BJSwart in forum Maintenance DIY Discussion
    Last Post: 09-21-2011, 10:07 PM
  4. locking down head and counter weight on 15XT
    By diemaker76 in forum Fadal
    Last Post: 03-13-2009, 02:38 PM
  5. Counter weight
    By David Russell in forum Fadal
    Last Post: 10-03-2008, 03:59 PM
