586,106 active members*
3,013 visitors online*
    May 2014
    7
    cutting backwards
    H folks instaled mach3 onmt 6040 gota fault the x axis cuts in reverse inscreen its correct when it cuts it is mirrored in reverse got to be a setting somwhere anyone got any clues
    Apr 2004
    5737
    Re: cutting backwards
    Go into Motor Outputs and change the X axis direction bit from low active to high (or vice-versa).
    Andrew Werby
    Website
  1. going backwards.
    By jestalavita in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2013, 09:15 AM
  2. Y axis is backwards ! help!
    By mattfurches in forum Haas Mills
    Last Post: 01-02-2013, 07:15 PM
  3. backwards G19
    By chippah in forum Vertical Mill, Lathe Project Log
    Last Post: 07-28-2010, 03:59 PM
  4. A Backwards request here...
    By Jasonixo in forum Employment Opportunity
    Last Post: 05-08-2006, 07:28 PM
