PRESS RELEASE - June 8, 2014 - ECYPH LLC announces Hardware and Software solution for Android RS232 Terminal
ECYPH LLC announces a complete Software and Hardware Terminal solution for Android. This is significant news for anyone purchasing an Android, since at present no other company offers a compact one piece serial cable solution for Android. With the free FTDI Terminal program software that comes with the cable, you can fully utilize the cable to connect with RS232 Seral Port equipment. FTDI is a specific type of USB adapter chip which we use in our cables. This free Terminal program works with FTDI chips.
Here are some details about the Terminal program.
FTDI USB to UART COM Port Utility
This utility is for use with FTDI USB to UART devices. The utility provides a terminal emulation function for use on Android devices. The Android system must use Android OS version 3.2 or later and provide a USB host port.
Features
* The application will open automatically when you plug in supported FTDI device controller like FT232R, FT245R, FT232H, FT2232D, FT2232H, FT4232H and FT230X, FT231X...
* It supports FTDI USB TTL Serial, USB RS232 and USB Hi-Speed cables.
* Suitable for use on any Android platform with Android v3.2 and later versions.
* Provide general terminal UART utility; easily adaptable to a console function.
* Support CTS/RTS, DTR/DSR and XOFF/XON Flow controls.
* Support Baud from 300 to 921600.
* Save file and Send file functions support XModem, YModem and ZModem file transfer protocols.
* USB Plug and Play.
* USB 2.0 Full Speed compatible.
To find out more information including where to find this free program and a link to the Manual, log in to ECYPH LLC at www.pcables.com.
