586,121 active members*
3,758 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Added a 4th axis, having a strange issue with z axis.
Results 1 to 16 of 16
    Jun 2014
    49
    I recently constructed a 4th axis for my machine. I downloaded the deskproto trial and made some toolpaths. For the first part, I am testing the machine by roughing out a part from a 1 inch dowel, having it step down 1/16th at a time (I am just breaking the machine in). I zero out all of the axises (sp?), and align the z axis with the top of the dowel and set the DRO to .5, since the zero point is the center of the dowel (the dowel is 1 inch as measured to 1/1000). I set IJ to incremental, have 'use diameter for feedrate' checked and set the diameter to .001 as others have done to get around the speed issues.
    So the problem:
    When the z axis moves down for the first 1/16, it does so fine, runs parallel cuts and everything is fine. For the second step down, the tool path tells it to move another 1/16th down, the DRO reflects what the correct height would be, but the machine actually moves about .25 inches, ruining the part. I retried the toolpath having it just cut air, and it does this every time. Every subsequent step down seems like it is about 1/16th, it is just that second step down. The DRO reflects what the move should be, but not reality. I haven't had an issue with 3 axis operations before.
    edit: gecko g540 controller
    I am at a loss. Any ideas?
    Re: Added a 4th axis, having a strange issue with z axis.
    So the DRO shows 0.375, but the tool is at 0.1875?
    Is it losing steps in the Z axis?
    Jun 2014
    49
    Thanks for replying.
    The DRO shows .375 and it is in actuality around .1875. I don't think it is losing steps because It is coming coming down from .5, where the start of the job is. If anything it seems like it gains steps for that one movement. I've tried running this job a few times to see if there was something wrong with this particular part of my z axis, but it always happens.
    edit: I also tried configuring axis calibration for the z axis. It was dead on.
    15362
    manyhats2007
    Does your Config file look like this, are you using G90 in your program or G91, post your program may help to see what it is telling the control to do
    Mactec54
    Jun 2014
    49
    Thanks for the response. That is how I have my config setup. I am using g90.
    Here is the toolpath:
    https://www.dropbox.com/s/1ugx4xkfp0...1_Roughing.tap
    This is the line:
    N10040G1 X0.000 Z0.375
    at this point, it actually does move about .375 from the surface (z 0.5). Both before and after this move, when it moves in the z direction, it does so accurately.
    I appreciate the help, thanks.
    15362
    manyhats2007
    Just cut/paste the program, I could not open it like it is, if the center of your part is 0.0 ( 1" dia ) then this line of code will put the tool .375 up from the 0.0 the center of your part
    If the top of your part is 0.0 the tool will move up .375 above the part
    You may not have set the part 0.0 correct or you did not set the tool to the correct 0.0
    If you are doing simple 4 axes work, you don't have to set the part 0.0 in the center of the part, it can be to the top of the part, the same then for your tool setting, then all your cutting Z moves will be negative numbers,like G1X0.0Z-.0625 the next cut would be G1X0.0Z-.125
    Mactec54
    Jun 2014
    49
    That is the problem. I set the z axis so that the top of the part is .5, and hence zero is the center. The first roughing pass at .425 or so moves the correct distance (1/16th from the surface). But when it goes to move to .375 it moves much lower (around .2-.25 rather than .0625) Every subsequent move down is by the correct distance (plus the previous error, since the machine thinks it is at a different height than it is.
    The only thing I can think of is there is a g0 to .7 to clear the piece before it moves back down. Maybe it is missing steps here. I'll change it to G1 today and try again. Any other thoughts?
    Again, Thanks for looking into this.
    G17 G20 G40 G49 G64 G90 G94
    G0 X0.000 Z0.700 A0.000
    G1 Z0.512 F37.5
    G1 X0.435 Z0.475
    G1 X0.000 Z0.437
    G1 X0.555
    G1 X0.585 Z0.443
    G1 X0.615 Z0.448
    G1 X0.645 Z0.454
    N20G1 X0.675 Z0.453
    N30G1 X0.705 Z0.447
    N40G1 X0.735 Z0.437
    N50G1 X1.635
    N60G1 X1.665 Z0.449
    N70G1 X1.695 Z0.473
    N80G1 X1.725 Z0.479
    N90G1 X1.755 Z0.481
    N100G1 X1.785 Z0.480
    N110G1 X1.815 Z0.480
    N120G1 X1.845 Z0.482
    N130G1 X1.875 Z0.482
    N140G1 X1.905 Z0.475
    N150G1 X1.935 Z0.462
    N160G1 X1.965 Z0.438
    N170G1 X1.995 Z0.437
    N180G1 X2.750
    N190G1 A360.000
    N200G1 X1.995
    N210G1 X1.965 Z0.438
    N220G1 X1.935 Z0.462
    N230G1 X1.905 Z0.475
    N240G1 X1.875 Z0.482
    N250G1 X1.845 Z0.482
    N260G1 X1.815 Z0.480
    N270G1 X1.785 Z0.480
    N280G1 X1.755 Z0.481
    N290G1 X1.725 Z0.479
    N300G1 X1.695 Z0.473
    N310G1 X1.665 Z0.449
    N320G1 X1.635 Z0.437
    N330G1 X0.735
    N340G1 X0.705 Z0.447
    N350G1 X0.675 Z0.453
    N360G1 X0.645 Z0.454
    N370G1 X0.615 Z0.448
    N380G1 X0.585 Z0.443
    N390G1 X0.555 Z0.437
    N400G1 X0.000
    N410G1 A3.429
    N420G1 X0.555 F50.0
    N430G1 X0.585 Z0.443
    N440G1 X0.615 Z0.448
    N450G1 X0.645 Z0.454
    N460G1 X0.675 Z0.453
    N470G1 X0.705 Z0.447
    N480G1 X0.735 Z0.437
    N490G1 X1.635
    N500G1 X1.665 Z0.451
    N510G1 X1.695 Z0.475
    N520G1 X1.725 Z0.481
    N530G1 X1.755 Z0.482
    N540G1 X1.785 Z0.481
    N550G1 X1.815 Z0.482
    N560G1 X1.845 Z0.483
    N570G1 X1.875 Z0.483
    N580G1 X1.905 Z0.477
    N590G1 X1.935 Z0.464
    N600G1 X1.965 Z0.440
    N610G1 X1.995 Z0.437
    N620G1 X2.745
    N630G1 A356.571
    N640G1 X1.995
    N650G1 X1.965 Z0.440
    N660G1 X1.935 Z0.464
    N670G1 X1.905 Z0.477
    N680G1 X1.875 Z0.483
    N690G1 X1.845 Z0.483
    N700G1 X1.815 Z0.482
    N710G1 X1.785 Z0.481
    N720G1 X1.755 Z0.482
    N730G1 X1.725 Z0.481
    N740G1 X1.695 Z0.474
    N750G1 X1.665 Z0.451
    N760G1 X1.635 Z0.437
    N770G1 X0.735
    N780G1 X0.705 Z0.447
    N790G1 X0.675 Z0.453
    N800G1 X0.645 Z0.454
    N810G1 X0.615 Z0.448
    N820G1 X0.585 Z0.443
    N830G1 X0.555 Z0.437
    N840G1 X0.015
    N850G1 A6.857
    N860G1 X0.555
    N870G1 X0.585 Z0.443
    N880G1 X0.615 Z0.448
    N890G1 X0.645 Z0.454
    N900G1 X0.675 Z0.453
    N910G1 X0.705 Z0.447
    N920G1 X0.735 Z0.437
    N930G1 X1.635
    N940G1 X1.665 Z0.454
    N950G1 X1.695 Z0.478
    N960G1 X1.725 Z0.484
    N970G1 X1.755 Z0.486
    N980G1 X1.785 Z0.485
    N990G1 X1.815 Z0.485
    N1000G1 X1.845 Z0.487
    N1010G1 X1.875 Z0.487
    N1020G1 X1.905 Z0.480
    N1030G1 X1.935 Z0.467
    N1040G1 X1.965 Z0.443
    N1050G1 X1.995 Z0.437
    N1060G1 X2.715
    N1070G1 A353.143
    N1080G1 X1.995
    N1090G1 X1.965 Z0.443
    N1100G1 X1.935 Z0.467
    N1110G1 X1.905 Z0.480
    N1120G1 X1.875 Z0.487
    N1130G1 X1.845 Z0.487
    N1140G1 X1.815 Z0.485
    N1150G1 X1.785 Z0.485
    N1160G1 X1.755 Z0.486
    N1170G1 X1.725 Z0.484
    N1180G1 X1.695 Z0.478
    N1190G1 X1.665 Z0.454
    N1200G1 X1.635 Z0.437
    N1210G1 X0.735
    N1220G1 X0.705 Z0.447
    N1230G1 X0.675 Z0.453
    N1240G1 X0.645 Z0.454
    N1250G1 X0.615 Z0.448
    N1260G1 X0.585 Z0.443
    N1270G1 X0.555 Z0.437
    N1280G1 X0.045
    N1290G1 A10.286
    N1300G1 X0.555
    N1310G1 X0.585 Z0.443
    N1320G1 X0.615 Z0.448
    N1330G1 X0.645 Z0.454
    N1340G1 X0.675 Z0.453
    N1350G1 X0.705 Z0.447
    N1360G1 X0.735 Z0.437
    N1370G1 X1.605
    N1380G1 X1.635 Z0.440
    N1390G1 X1.665 Z0.457
    N1400G1 X1.695 Z0.481
    N1410G1 X1.725 Z0.487
    N1420G1 X1.755 Z0.488
    N1430G1 X1.785 Z0.487
    N1440G1 X1.845 Z0.487
    N1450G1 X1.875 Z0.488
    N1460G1 X1.905 Z0.481
    N1470G1 X1.935 Z0.471
    N1480G1 X1.965 Z0.447
    N1490G1 X1.995 Z0.437
    N1500G1 X2.685
    N1510G1 A349.714
    N1520G1 X1.995
    N1530G1 X1.965 Z0.447
    N1540G1 X1.935 Z0.471
    N1550G1 X1.905 Z0.481
    N1560G1 X1.875 Z0.488
    N1570G1 X1.845 Z0.487
    N1580G1 X1.785 Z0.487
    N1590G1 X1.755 Z0.488
    N1600G1 X1.725 Z0.487
    N1610G1 X1.695 Z0.481
    N1620G1 X1.665 Z0.457
    N1630G1 X1.635 Z0.440
    N1640G1 X1.605 Z0.437
    N1650G1 X0.735
    N1660G1 X0.705 Z0.447
    N1670G1 X0.675 Z0.453
    N1680G1 X0.645 Z0.454
    N1690G1 X0.615 Z0.448
    N1700G1 X0.585 Z0.443
    N1710G1 X0.555 Z0.437
    N1720G1 X0.075
    N1730G1 A13.714
    N1740G1 X0.555
    N1750G1 X0.585 Z0.443
    N1760G1 X0.615 Z0.448
    N1770G1 X0.645 Z0.454
    N1780G1 X0.675 Z0.453
    N1790G1 X0.705 Z0.447
    N1800G1 X0.735 Z0.437
    N1810G1 X1.605
    N1820G1 X1.635 Z0.441
    N1830G1 X1.665 Z0.450
    N1840G1 X1.695 Z0.474
    N1850G1 X1.725 Z0.480
    N1860G1 X1.755 Z0.481
    N1870G1 X1.785 Z0.480
    N1880G1 X1.815 Z0.480
    N1890G1 X1.845 Z0.479
    N1900G1 X1.875 Z0.480
    N1910G1 X1.905 Z0.476
    N1920G1 X1.935 Z0.470
    N1930G1 X1.965 Z0.446
    N1940G1 X1.995 Z0.437
    N1950G1 X2.655
    N1960G1 A346.286
    N1970G1 X1.995
    N1980G1 X1.965 Z0.446
    N1990G1 X1.935 Z0.470
    N2000G1 X1.905 Z0.476
    N2010G1 X1.875 Z0.480
    N2020G1 X1.845 Z0.479
    N2030G1 X1.815 Z0.480
    N2040G1 X1.785 Z0.480
    N2050G1 X1.755 Z0.481
    N2060G1 X1.725 Z0.480
    N2070G1 X1.695 Z0.474
    N2080G1 X1.665 Z0.450
    N2090G1 X1.635 Z0.441
    N2100G1 X1.605 Z0.437
    N2110G1 X0.735
    N2120G1 X0.705 Z0.447
    N2130G1 X0.675 Z0.453
    N2140G1 X0.645 Z0.454
    N2150G1 X0.615 Z0.448
    N2160G1 X0.585 Z0.443
    N2170G1 X0.555 Z0.437
    N2180G1 X0.105
    N2190G1 A17.143
    N2200G1 X0.555
    N2210G1 X0.585 Z0.443
    N2220G1 X0.615 Z0.448
    N2230G1 X0.645 Z0.454
    N2240G1 X0.675 Z0.453
    N2250G1 X0.705 Z0.447
    N2260G1 X0.735 Z0.437
    N2270G1 X1.635
    N2280G1 X1.665 Z0.440
    N2290G1 X1.695 Z0.467
    N2300G1 X1.725 Z0.473
    N2310G1 X1.815 Z0.473
    N2320G1 X1.845 Z0.467
    N2330G1 X1.875 Z0.473
    N2340G1 X1.905 Z0.468
    N2350G1 X1.935 Z0.461
    N2360G1 X1.965 Z0.437
    N2370G1 X2.625
    N2380G1 A342.857
    N2390G1 X1.965
    N2400G1 X1.935 Z0.461
    N2410G1 X1.905 Z0.468
    N2420G1 X1.875 Z0.473
    N2430G1 X1.845 Z0.467
    N2440G1 X1.815 Z0.473
    N2450G1 X1.725 Z0.473
    N2460G1 X1.695 Z0.466
    N2470G1 X1.665 Z0.440
    N2480G1 X1.635 Z0.437
    N2490G1 X0.735
    N2500G1 X0.705 Z0.447
    N2510G1 X0.675 Z0.453
    N2520G1 X0.645 Z0.454
    N2530G1 X0.615 Z0.448
    N2540G1 X0.585 Z0.443
    N2550G1 X0.555 Z0.437
    N2560G1 X0.135
    N2570G1 A20.571
    N2580G1 X0.555
    N2590G1 X0.585 Z0.443
    N2600G1 X0.615 Z0.448
    N2610G1 X0.645 Z0.454
    N2620G1 X0.675 Z0.453
    N2630G1 X0.705 Z0.447
    N2640G1 X0.735 Z0.437
    N2650G1 X1.665
    N2660G1 X1.695 F37.5
    N2670G1 X1.725 Z0.447
    N2680G1 X1.815 Z0.447
    N2690G1 X1.845 Z0.437
    N2700G1 X1.875 Z0.447
    N2710G1 X1.905 Z0.441
    N2720G1 X1.935 Z0.437
    N2730G1 X1.965
    N2740G1 X2.595 F50.0
    N2750G1 A339.429
    N2760G1 X1.965
    N2770G1 X1.935 F37.5
    N2780G1 X1.905 Z0.441
    N2790G1 X1.875 Z0.447
    N2800G1 X1.845 Z0.437
    N2810G1 X1.815 Z0.447
    N2820G1 X1.725 Z0.447
    N2830G1 X1.695 Z0.437
    N2840G1 X1.665
    N2850G1 X0.735 F50.0
    N2860G1 X0.705 Z0.447
    N2870G1 X0.675 Z0.453
    N2880G1 X0.645 Z0.454
    N2890G1 X0.615 Z0.448
    N2900G1 X0.585 Z0.443
    N2910G1 X0.555 Z0.437
    N2920G1 X0.165
    N2930G1 A24.000
    N2940G1 X0.555
    N2950G1 X0.585 Z0.443
    N2960G1 X0.615 Z0.448
    N2970G1 X0.645 Z0.454
    N2980G1 X0.675 Z0.453
    N2990G1 X0.705 Z0.447
    N3000G1 X0.735 Z0.437
    N3010G1 X2.565
    N3020G1 A336.000
    N3030G1 X0.735
    N3040G1 X0.705 Z0.447
    N3050G1 X0.675 Z0.453
    N3060G1 X0.645 Z0.454
    N3070G1 X0.615 Z0.448
    N3080G1 X0.585 Z0.443
    N3090G1 X0.555 Z0.437
    N3100G1 X0.195
    N3110G1 A27.429
    N3120G1 X0.555
    N3130G1 X0.585 Z0.443
    N3140G1 X0.615 Z0.448
    N3150G1 X0.645 Z0.454
    N3160G1 X0.675 Z0.453
    N3170G1 X0.705 Z0.447
    N3180G1 X0.735 Z0.437
    N3190G1 X2.535
    N3200G1 A332.571
    N3210G1 X0.735
    N3220G1 X0.705 Z0.447
    N3230G1 X0.675 Z0.453
    N3240G1 X0.645 Z0.454
    N3250G1 X0.615 Z0.448
    N3260G1 X0.585 Z0.443
    N3270G1 X0.555 Z0.437
    N3280G1 X0.225
    N3290G1 A30.857
    N3300G1 X0.555
    N3310G1 X0.585 Z0.443
    N3320G1 X0.615 Z0.448
    N3330G1 X0.645 Z0.454
    N3340G1 X0.675 Z0.453
    N3350G1 X0.705 Z0.447
    N3360G1 X0.735 Z0.437
    N3370G1 X2.505
    N3380G1 A329.143
    N3390G1 X0.735
    N3400G1 X0.705 Z0.447
    N3410G1 X0.675 Z0.453
    N3420G1 X0.645 Z0.454
    N3430G1 X0.615 Z0.448
    N3440G1 X0.585 Z0.443
    N3450G1 X0.555 Z0.437
    N3460G1 X0.255
    N3470G1 A34.286
    N3480G1 X0.555
    N3490G1 X0.585 Z0.443
    N3500G1 X0.615 Z0.448
    N3510G1 X0.645 Z0.454
    N3520G1 X0.675 Z0.453
    N3530G1 X0.705 Z0.447
    N3540G1 X0.735 Z0.437
    N3550G1 X2.475
    N3560G1 A325.714
    N3570G1 X0.735
    N3580G1 X0.705 Z0.447
    N3590G1 X0.675 Z0.453
    N3600G1 X0.645 Z0.454
    N3610G1 X0.615 Z0.448
    N3620G1 X0.585 Z0.443
    N3630G1 X0.555 Z0.437
    N3640G1 X0.285
    N3650G1 A37.714
    N3660G1 X0.555
    N3670G1 X0.585 Z0.443
    N3680G1 X0.615 Z0.448
    N3690G1 X0.645 Z0.454
    N3700G1 X0.675 Z0.453
    N3710G1 X0.705 Z0.447
    N3720G1 X0.735 Z0.437
    N3730G1 X2.445
    N3740G1 A322.286
    N3750G1 X0.735
    N3760G1 X0.705 Z0.447
    N3770G1 X0.675 Z0.453
    N3780G1 X0.645 Z0.454
    N3790G1 X0.615 Z0.448
    N3800G1 X0.585 Z0.443
    N3810G1 X0.555 Z0.437
    N3820G1 X0.315
    N3830G1 A41.143
    N3840G1 X0.555
    N3850G1 X0.585 Z0.443
    N3860G1 X0.615 Z0.448
    N3870G1 X0.645 Z0.454
    N3880G1 X0.675 Z0.453
    N3890G1 X0.705 Z0.447
    N3900G1 X0.735 Z0.437
    N3910G1 X2.415
    N3920G1 A318.857
    N3930G1 X0.735
    N3940G1 X0.705 Z0.447
    N3950G1 X0.675 Z0.453
    N3960G1 X0.645 Z0.454
    N3970G1 X0.615 Z0.448
    N3980G1 X0.585 Z0.443
    N3990G1 X0.555 Z0.437
    N4000G1 X0.345
    N4010G1 A44.571
    N4020G1 X0.555
    N4030G1 X0.585 Z0.443
    N4040G1 X0.615 Z0.448
    N4050G1 X0.645 Z0.454
    N4060G1 X0.675 Z0.453
    N4070G1 X0.705 Z0.447
    N4080G1 X0.735 Z0.437
    N4090G1 X2.385
    N4100G1 A315.429
    N4110G1 X0.735
    N4120G1 X0.705 Z0.447
    N4130G1 X0.675 Z0.453
    N4140G1 X0.645 Z0.454
    N4150G1 X0.615 Z0.448
    N4160G1 X0.585 Z0.443
    N4170G1 X0.555 Z0.437
    N4180G1 X0.375
    N4190G1 A48.000
    N4200G1 X0.555
    N4210G1 X0.585 Z0.443
    N4220G1 X0.615 Z0.448
    N4230G1 X0.645 Z0.454
    N4240G1 X0.675 Z0.453
    N4250G1 X0.705 Z0.447
    N4260G1 X0.735 Z0.437
    N4270G1 X2.355
    N4280G1 A312.000
    N4290G1 X0.735
    N4300G1 X0.705 Z0.447
    N4310G1 X0.675 Z0.453
    N4320G1 X0.645 Z0.454
    N4330G1 X0.615 Z0.448
    N4340G1 X0.585 Z0.443
    N4350G1 X0.555 Z0.437
    N4360G1 X0.405
    N4370G1 A51.429
    N4380G1 X0.555
    N4390G1 X0.585 Z0.443
    N4400G1 X0.615 Z0.448
    N4410G1 X0.645 Z0.454
    N4420G1 X0.675 Z0.453
    N4430G1 X0.705 Z0.447
    N4440G1 X0.735 Z0.437
    N4450G1 X2.325
    N4460G1 A308.571
    N4470G1 X0.735
    N4480G1 X0.705 Z0.447
    N4490G1 X0.675 Z0.453
    N4500G1 X0.645 Z0.454
    N4510G1 X0.615 Z0.448
    N4520G1 X0.585 Z0.443
    N4530G1 X0.555 Z0.437
    N4540G1 X0.435
    N4550G1 A54.857
    N4560G1 X0.555
    N4570G1 X0.585 Z0.443
    N4580G1 X0.615 Z0.448
    N4590G1 X0.645 Z0.454
    N4600G1 X0.675 Z0.453
    N4610G1 X0.705 Z0.447
    N4620G1 X0.735 Z0.437
    N4630G1 X2.295
    N4640G1 A305.143
    N4650G1 X0.735
    N4660G1 X0.705 Z0.447
    N4670G1 X0.675 Z0.453
    N4680G1 X0.645 Z0.454
    N4690G1 X0.615 Z0.448
    N4700G1 X0.585 Z0.443
    N4710G1 X0.555 Z0.437
    N4720G1 X0.465
    N4730G1 A58.286
    N4740G1 X0.555
    N4750G1 X0.585 Z0.443
    N4760G1 X0.615 Z0.448
    N4770G1 X0.645 Z0.454
    N4780G1 X0.675 Z0.453
    N4790G1 X0.705 Z0.447
    N4800G1 X0.735 Z0.437
    N4810G1 X2.265
    N4820G1 A301.714
    N4830G1 X0.735
    N4840G1 X0.705 Z0.447
    N4850G1 X0.675 Z0.453
    N4860G1 X0.645 Z0.454
    N4870G1 X0.615 Z0.448
    N4880G1 X0.585 Z0.443
    N4890G1 X0.555 Z0.437
    N4900G1 X0.495
    N4910G1 A61.714
    N4920G1 X0.555
    N4930G1 X0.585 Z0.443
    N4940G1 X0.615 Z0.448
    N4950G1 X0.645 Z0.454
    N4960G1 X0.675 Z0.453
    N4970G1 X0.705 Z0.447
    N4980G1 X0.735 Z0.437
    N4990G1 X2.235
    N5000G1 A298.286
    N5010G1 X0.735
    N5020G1 X0.705 Z0.447
    N5030G1 X0.675 Z0.453
    N5040G1 X0.645 Z0.454
    N5050G1 X0.615 Z0.448
    N5060G1 X0.585 Z0.443
    N5070G1 X0.555 Z0.437
    N5080G1 X0.525
    N5090G1 A65.143
    N5100G1 X0.555
    N5110G1 X0.585 Z0.443
    N5120G1 X0.615 Z0.448
    N5130G1 X0.645 Z0.454
    N5140G1 X0.675 Z0.453
    N5150G1 X0.705 Z0.447
    N5160G1 X0.735 Z0.437
    N5170G1 X2.205
    N5180G1 A294.857
    N5190G1 X0.735
    N5200G1 X0.705 Z0.447
    N5210G1 X0.675 Z0.453
    N5220G1 X0.645 Z0.454
    N5230G1 X0.615 Z0.448
    N5240G1 X0.585 Z0.443
    N5250G1 X0.555 Z0.437
    N5260G1 A68.571
    N5270G1 X0.585 Z0.443
    N5280G1 X0.615 Z0.448
    N5290G1 X0.645 Z0.454
    N5300G1 X0.675 Z0.453
    N5310G1 X0.705 Z0.447
    N5320G1 X0.735 Z0.437
    N5330G1 X2.175
    N5340G1 A291.429
    N5350G1 X0.735
    N5360G1 X0.705 Z0.447
    N5370G1 X0.675 Z0.453
    N5380G1 X0.645 Z0.454
    N5390G1 X0.615 Z0.448
    N5400G1 X0.585 Z0.443
    N5410G1 Z0.443 A72.000
    N5420G1 X0.615 Z0.448
    N5430G1 X0.645 Z0.454
    N5440G1 X0.675 Z0.453
    N5450G1 X0.705 Z0.447
    N5460G1 X0.735 Z0.437
    N5470G1 X2.145
    N5480G1 A288.000
    N5490G1 X0.735
    N5500G1 X0.705 Z0.447
    N5510G1 X0.675 Z0.453
    N5520G1 X0.645 Z0.454
    N5530G1 X0.615 Z0.448
    N5540G1 Z0.448 A75.429
    N5550G1 X0.645 Z0.454
    N5560G1 X0.675 Z0.453
    N5570G1 X0.705 Z0.447
    N5580G1 X0.735 Z0.437
    N5590G1 X2.115
    N5600G1 A284.571
    N5610G1 X0.735
    N5620G1 X0.705 Z0.447
    N5630G1 X0.675 Z0.453
    N5640G1 X0.645 Z0.454
    N5650G1 Z0.454 A78.857
    N5660G1 X0.675 Z0.453
    N5670G1 X0.705 Z0.447
    N5680G1 X0.735 Z0.437
    N5690G1 X2.085
    N5700G1 A281.143
    N5710G1 X0.735
    N5720G1 X0.705 Z0.447
    N5730G1 X0.675 Z0.453
    N5740G1 Z0.453 A82.286
    N5750G1 X0.705 Z0.447
    N5760G1 X0.735 Z0.437
    N5770G1 X2.055
    N5780G1 A277.714
    N5790G1 X0.735
    N5800G1 X0.705 Z0.447
    N5810G1 Z0.447 A85.714
    N5820G1 X0.735 Z0.437
    N5830G1 X2.025
    N5840G1 A274.286
    N5850G1 X0.735
    N5860G1 A89.143
    N5870G1 X1.995
    N5880G1 A174.857
    N5890G1 Z0.439 A178.286
    N5900G1 Z0.439 A181.714
    N5910G1 Z0.437 A185.143
    N5920G1 A270.857
    N5930G1 X0.765
    N5940G1 A92.571
    N5950G1 X1.965
    N5960G1 A168.000
    N5970G1 Z0.453 A171.429
    N5980G1 Z0.461 A174.857
    N5990G1 Z0.462 A178.286
    N6000G1 Z0.462 A181.714
    N6010G1 Z0.461 A185.143
    N6020G1 Z0.453 A188.571
    N6030G1 Z0.437 A192.000
    N6040G1 A267.429
    N6050G1 X0.795
    N6060G1 A96.000
    N6070G1 X1.935
    N6080G1 A168.000
    N6090G1 Z0.460 A171.429
    N6100G1 Z0.467 A174.857
    N6110G1 Z0.469 A178.286
    N6120G1 Z0.469 A181.714
    N6130G1 Z0.467 A185.143
    N6140G1 Z0.460 A188.571
    N6150G1 Z0.437 A192.000
    N6160G1 A264.000
    N6170G1 X0.825
    N6180G1 A99.429
    N6190G1 X1.905
    N6200G1 A168.000
    N6210G1 Z0.462 A171.429
    N6220G1 Z0.470 A174.857
    N6230G1 Z0.471 A178.286
    N6240G1 Z0.471 A181.714
    N6250G1 Z0.470 A185.143
    N6260G1 Z0.462 A188.571
    N6270G1 Z0.437 A192.000
    N6280G1 A260.571
    N6290G1 X0.855
    N6300G1 A102.857
    N6310G1 X1.875
    N6320G1 A168.000
    N6330G1 Z0.462 A171.429
    N6340G1 Z0.469 A174.857
    N6350G1 Z0.471 A178.286
    N6360G1 Z0.471 A181.714
    N6370G1 Z0.470 A185.143
    N6380G1 Z0.462 A188.571
    N6390G1 Z0.437 A192.000
    N6400G1 A257.143
    N6410G1 X0.885
    N6420G1 A106.286
    N6430G1 X1.845
    N6440G1 A164.571
    N6450G1 Z0.441 A168.000
    N6460G1 Z0.473 A171.429
    N6470G1 Z0.481 A174.857
    N6480G1 Z0.483 A178.286
    N6490G1 A181.714
    N6500G1 Z0.481 A185.143
    N6510G1 Z0.473 A188.571
    N6520G1 Z0.441 A192.000
    N6530G1 Z0.437 A195.429
    N6540G1 A253.714
    N6550G1 X0.915
    N6560G1 A109.714
    N6570G1 X1.815
    N6580G1 A164.571
    N6590G1 Z0.452 A168.000
    N6600G1 Z0.480 A171.429
    N6610G1 Z0.487 A174.857
    N6620G1 Z0.489 A178.286
    N6630G1 A181.714
    N6640G1 Z0.487 A185.143
    N6650G1 Z0.480 A188.571
    N6660G1 Z0.452 A192.000
    N6670G1 Z0.437 A195.429
    N6680G1 A250.286
    N6690G1 X0.945
    N6700G1 A113.143
    N6710G1 X1.785
    N6720G1 A164.571
    N6730G1 Z0.452 A168.000
    N6740G1 Z0.480 A171.429
    N6750G1 Z0.487 A174.857
    N6760G1 Z0.489 A178.286
    N6770G1 Z0.489 A181.714
    N6780G1 Z0.487 A185.143
    N6790G1 Z0.480 A188.571
    N6800G1 Z0.452 A192.000
    N6810G1 Z0.437 A195.429
    N6820G1 A246.857
    N6830G1 X0.975
    N6840G1 A116.571
    N6850G1 X1.755
    N6860G1 A164.571
    N6870G1 Z0.454 A168.000
    N6880G1 Z0.486 A171.429
    N6890G1 Z0.494 A174.857
    N6900G1 Z0.497 A178.286
    N6910G1 Z0.497 A181.714
    N6920G1 Z0.494 A185.143
    N6930G1 Z0.486 A188.571
    N6940G1 Z0.454 A192.000
    N6950G1 Z0.437 A195.429
    N6960G1 A243.429
    N6970G1 X1.005
    N6980G1 A195.429
    N6990G1 Z0.439 A192.000
    N7000G1 Z0.442 A188.571
    N7010G1 Z0.441 A185.143
    N7020G1 Z0.437 A181.714
    N7030G1 A178.286
    N7040G1 Z0.441 A174.857
    N7050G1 Z0.442 A171.429
    N7060G1 Z0.439 A168.000
    N7070G1 Z0.437 A164.571
    N7080G1 A120.000
    N7090G1 X1.725
    N7100G1 A164.571
    N7110G1 Z0.466 A168.000
    N7120G1 Z0.493 A171.429
    N7130G1 Z0.500 A174.857
    N7140G1 Z0.503 A178.286
    N7150G1 Z0.503 A181.714
    N7160G1 Z0.500 A185.143
    N7170G1 Z0.493 A188.571
    N7180G1 Z0.466 A192.000
    N7190G1 Z0.437 A195.429
    N7200G1 A240.000
    N7210G1 X1.035
    N7220G1 A202.286
    N7230G1 Z0.439 A198.857
    N7240G1 Z0.443 A195.429
    N7250G1 Z0.445 A192.000
    N7260G1 Z0.448 A188.571
    N7270G1 Z0.447 A185.143
    N7280G1 Z0.439 A181.714
    N7290G1 Z0.439 A178.286
    N7300G1 Z0.447 A174.857
    N7310G1 Z0.448 A171.429
    N7320G1 Z0.445 A168.000
    N7330G1 Z0.443 A164.571
    N7340G1 Z0.439 A161.143
    N7350G1 Z0.437 A157.714
    N7360G1 A123.429
    N7370G1 X1.695
    N7380G1 A164.571
    N7390G1 Z0.466 A168.000
    N7400G1 Z0.493 A171.429
    N7410G1 Z0.501 A174.857
    N7420G1 Z0.504 A178.286
    N7430G1 Z0.504 A181.714
    N7440G1 Z0.501 A185.143
    N7450G1 Z0.493 A188.571
    N7460G1 Z0.466 A192.000
    N7470G1 Z0.437 A195.429
    N7480G1 A236.571
    N7490G1 X1.065
    N7500G1 A202.286
    N7510G1 Z0.439 A198.857
    N7520G1 Z0.443 A195.429
    N7530G1 Z0.445 A192.000
    N7540G1 Z0.448 A188.571
    N7550G1 Z0.448 A185.143
    N7560G1 Z0.450 A181.714
    N7570G1 Z0.450 A178.286
    N7580G1 Z0.448 A174.857
    N7590G1 Z0.448 A171.429
    N7600G1 Z0.445 A168.000
    N7610G1 Z0.443 A164.571
    N7620G1 Z0.439 A161.143
    N7630G1 Z0.437 A157.714
    N7640G1 A126.857
    N7650G1 X1.665
    N7660G1 A164.571
    N7670G1 Z0.464 A168.000
    N7680G1 Z0.491 A171.429
    N7690G1 Z0.498 A174.857
    N7700G1 Z0.501 A178.286
    N7710G1 Z0.501 A181.714
    N7720G1 Z0.498 A185.143
    N7730G1 Z0.491 A188.571
    N7740G1 Z0.464 A192.000
    N7750G1 Z0.437 A195.429
    N7760G1 A233.143
    N7770G1 X1.095
    N7780G1 A195.429
    N7790G1 Z0.439 A192.000
    N7800G1 Z0.464 A188.571
    N7810G1 Z0.471 A185.143
    N7820G1 Z0.474 A181.714
    N7830G1 Z0.474 A178.286
    N7840G1 Z0.471 A174.857
    N7850G1 Z0.464 A171.429
    N7860G1 Z0.439 A168.000
    N7870G1 Z0.437 A164.571
    N7880G1 A130.286
    N7890G1 X1.635
    N7900G1 A164.571
    N7910G1 Z0.455 A168.000
    N7920G1 Z0.484 A171.429
    N7930G1 Z0.492 A174.857
    N7940G1 Z0.494 A178.286
    N7950G1 Z0.494 A181.714
    N7960G1 Z0.492 A185.143
    N7970G1 Z0.484 A188.571
    N7980G1 Z0.455 A192.000
    N7990G1 Z0.437 A195.429
    N8000G1 A229.714
    N8010G1 X1.125
    N8020G1 A195.429
    N8030G1 Z0.444 A192.000
    N8040G1 Z0.474 A188.571
    N8050G1 Z0.482 A185.143
    N8060G1 Z0.485 A181.714
    N8070G1 Z0.485 A178.286
    N8080G1 Z0.482 A174.857
    N8090G1 Z0.474 A171.429
    N8100G1 Z0.443 A168.000
    N8110G1 Z0.437 A164.571
    N8120G1 A133.714
    N8130G1 X1.605
    N8140G1 A164.571
    N8150G1 Z0.457 A168.000
    N8160G1 Z0.484 A171.429
    N8170G1 Z0.492 A174.857
    N8180G1 Z0.494 A178.286
    N8190G1 Z0.494 A181.714
    N8200G1 Z0.491 A185.143
    N8210G1 Z0.484 A188.571
    N8220G1 Z0.457 A192.000
    N8230G1 Z0.437 A195.429
    N8240G1 A226.286
    N8250G1 X1.155
    N8260G1 A195.429
    N8270G1 Z0.454 A192.000
    N8280G1 Z0.481 A188.571
    N8290G1 Z0.488 A185.143
    N8300G1 Z0.491 A181.714
    N8310G1 Z0.491 A178.286
    N8320G1 Z0.488 A174.857
    N8330G1 Z0.481 A171.429
    N8340G1 Z0.454 A168.000
    N8350G1 Z0.437 A164.571
    N8360G1 A137.143
    N8370G1 X1.575
    N8380G1 A164.571
    N8390G1 Z0.455 A168.000
    N8400G1 Z0.482 A171.429
    N8410G1 Z0.490 A174.857
    N8420G1 Z0.492 A178.286
    N8430G1 Z0.492 A181.714
    N8440G1 Z0.490 A185.143
    N8450G1 Z0.483 A188.571
    N8460G1 Z0.455 A192.000
    N8470G1 Z0.437 A195.429
    N8480G1 A222.857
    N8490G1 X1.185
    N8500G1 A195.429
    N8510G1 Z0.459 A192.000
    N8520G1 Z0.486 A188.571
    N8530G1 Z0.493 A185.143
    N8540G1 Z0.496 A181.714
    N8550G1 Z0.496 A178.286
    N8560G1 Z0.493 A174.857
    N8570G1 Z0.486 A171.429
    N8580G1 Z0.459 A168.000
    N8590G1 Z0.437 A164.571
    N8600G1 A140.571
    N8610G1 X1.545
    N8620G1 A164.571
    N8630G1 Z0.446 A168.000
    N8640G1 Z0.477 A171.429
    N8650G1 Z0.485 A174.857
    N8660G1 Z0.488 A178.286
    N8670G1 Z0.488 A181.714
    N8680G1 Z0.485 A185.143
    N8690G1 Z0.477 A188.571
    N8700G1 Z0.446 A192.000
    N8710G1 Z0.437 A195.429
    N8720G1 A219.429
    N8730G1 X1.215
    N8740G1 A195.429
    N8750G1 Z0.461 A192.000
    N8760G1 Z0.488 A188.571
    N8770G1 Z0.495 A185.143
    N8780G1 Z0.498 A181.714
    N8790G1 Z0.498 A178.286
    N8800G1 Z0.495 A174.857
    N8810G1 Z0.488 A171.429
    N8820G1 Z0.461 A168.000
    N8830G1 Z0.437 A164.571
    N8840G1 A144.000
    N8850G1 X1.515
    N8860G1 A164.571
    N8870G1 Z0.457 A168.000
    N8880G1 Z0.484 A171.429
    N8890G1 Z0.492 A174.857
    N8900G1 Z0.494 A178.286
    N8910G1 Z0.494 A181.714
    N8920G1 Z0.492 A185.143
    N8930G1 Z0.484 A188.571
    N8940G1 Z0.457 A192.000
    N8950G1 Z0.437 A195.429
    N8960G1 A216.000
    N8970G1 X1.245
    N8980G1 A195.429
    N8990G1 Z0.461 A192.000
    N9000G1 Z0.487 A188.571
    N9010G1 Z0.495 A185.143
    N9020G1 Z0.498 A181.714
    N9030G1 Z0.498 A178.286
    N9040G1 Z0.495 A174.857
    N9050G1 Z0.487 A171.429
    N9060G1 Z0.461 A168.000
    N9070G1 Z0.437 A164.571
    N9080G1 A147.429
    N9090G1 X1.485
    N9100G1 A164.571
    N9110G1 Z0.456 A168.000
    N9120G1 Z0.483 A171.429
    N9130G1 Z0.491 A174.857
    N9140G1 Z0.493 A178.286
    N9150G1 Z0.493 A181.714
    N9160G1 Z0.491 A185.143
    N9170G1 Z0.483 A188.571
    N9180G1 Z0.456 A192.000
    N9190G1 Z0.437 A195.429
    N9200G1 A212.571
    N9210G1 X1.275
    N9220G1 A195.429
    N9230G1 Z0.456 A192.000
    N9240G1 Z0.483 A188.571
    N9250G1 Z0.490 A185.143
    N9260G1 Z0.493 A181.714
    N9270G1 Z0.493 A178.286
    N9280G1 Z0.490 A174.857
    N9290G1 Z0.483 A171.429
    N9300G1 Z0.456 A168.000
    N9310G1 Z0.437 A164.571
    N9320G1 A150.857
    N9330G1 X1.455
    N9340G1 A164.571
    N9350G1 Z0.446 A168.000
    N9360G1 Z0.476 A171.429
    N9370G1 Z0.484 A174.857
    N9380G1 Z0.487 A178.286
    N9390G1 Z0.487 A181.714
    N9400G1 Z0.485 A185.143
    N9410G1 Z0.476 A188.571
    N9420G1 Z0.446 A192.000
    N9430G1 Z0.437 A195.429
    N9440G1 A209.143
    N9450G1 X1.305
    N9460G1 A195.429
    N9470G1 Z0.445 A192.000
    N9480G1 Z0.476 A188.571
    N9490G1 Z0.484 A185.143
    N9500G1 Z0.487 A181.714
    N9510G1 Z0.487 A178.286
    N9520G1 Z0.484 A174.857
    N9530G1 Z0.476 A171.429
    N9540G1 Z0.445 A168.000
    N9550G1 Z0.437 A164.571
    N9560G1 A154.286
    N9570G1 X1.425
    N9580G1 A164.571
    N9590G1 Z0.440 A168.000
    N9600G1 Z0.467 A171.429
    N9610G1 Z0.475 A174.857
    N9620G1 Z0.477 A178.286
    N9630G1 Z0.477 A181.714
    N9640G1 Z0.475 A185.143
    N9650G1 Z0.467 A188.571
    N9660G1 Z0.440 A192.000
    N9670G1 Z0.437 A195.429
    N9680G1 A205.714
    N9690G1 X1.335
    N9700G1 A192.000
    N9710G1 Z0.464 A188.571
    N9720G1 Z0.472 A185.143
    N9730G1 Z0.473 A181.714 F37.5
    N9740G1 Z0.473 A178.286
    N9750G1 Z0.472 A174.857
    N9760G1 Z0.464 A171.429 F50.0
    N9770G1 Z0.437 A168.000
    N9780G1 A157.714
    N9790G1 X1.395
    N9800G1 A168.000
    N9810G1 Z0.464 A171.429
    N9820G1 Z0.471 A174.857
    N9830G1 Z0.473 A178.286
    N9840G1 Z0.473 A181.714
    N9850G1 Z0.471 A185.143
    N9860G1 Z0.464 A188.571
    N9870G1 Z0.437 A192.000
    N9880G1 A202.286
    N9890G1 X1.365
    N9900G1 A192.000
    N9910G1 Z0.457 A188.571
    N9920G1 Z0.466 A185.143
    N9930G1 Z0.467 A181.714
    N9940G1 Z0.467 A178.286
    N9950G1 Z0.466 A174.857
    N9960G1 Z0.458 A171.429
    N9970G1 Z0.437 A168.000
    N9980G1 A161.143
    N9990G0 Z0.700
    N10000G0 X0.000 A0.000
    N10010G0 Z0.634
    N10020G1 Z0.437
    N10030G1 X0.375 Z0.406 F37.5
    N10050G1 X0.495
    N10060G1 X0.525 Z0.413
    N10070G1 X0.555 Z0.437 F50.0
    N10080G1 X0.585 Z0.443
    N10090G1 Z0.651
    N10100G1 X0.705
    N10110G1 Z0.447
    N10120G1 X0.735 Z0.423 F37.5
    N10130G1 X0.765 Z0.393
    N10140G1 X0.795 Z0.375
    N10150G1 X1.035
    N10160G1 X1.065 Z0.378
    N10170G1 X1.095 Z0.384
    N10180G1 X1.125 Z0.388
    N10190G1 X1.185 Z0.388
    N10200G1 X1.215 Z0.385
    N10210G1 X1.245 Z0.379
    N10220G1 X1.275 Z0.375
    N10230G1 X1.575
    N10240G1 X1.605 Z0.407
    N10250G1 X1.635 Z0.431 F50.0
    N10260G1 X1.665 Z0.449
    N10270G0 Z0.700
    N10280G0 X1.965
    N10290G0 Z0.635
    N10300G1 Z0.438
    N10310G1 X1.995 Z0.395 F37.5
    N10320G1 X2.025 Z0.375
    N10330G1 X2.750
    N10340G1 A360.000
    N10350G1 X2.025
    N10360G1 X1.995 Z0.395
    N10370G1 X1.965 Z0.438 F50.0
    N10380G0 Z0.700
    N10390G0 X1.665
    N10400G0 Z0.646
    N10410G1 Z0.449
    N10420G1 X1.635 Z0.431
    N10430G1 X1.605 Z0.407 F37.5
    N10440G1 X1.575 Z0.375
    N10450G1 X1.275
    N10460G1 X1.245 Z0.379
    N10470G1 X1.215 Z0.385
    N10480G1 X1.185 Z0.388
    N10490G1 X1.125 Z0.388
    N10500G1 X1.095 Z0.384
    N10510G1 X1.065 Z0.378
    N10520G1 X1.035 Z0.375
    N10530G1 X0.795
    N10540G1 X0.765 Z0.393
    N10550G1 X0.735 Z0.423
    N10560G1 X0.705 Z0.447 F50.0
    N10570G1 Z0.651
    N10580G1 X0.585
    N10590G1 Z0.443
    N10600G1 X0.555 Z0.437
    N10610G1 X0.525 Z0.413 F37.5
    N10620G1 X0.495 Z0.375
    N10630G1 X0.000
    N10640G1 A3.429
    N10650G1 X0.495 F50.0
    N10660G1 X0.525 Z0.413
    N10670G1 X0.555 Z0.437
    N10680G1 X0.585 Z0.443
    N10690G1 Z0.651
    N10700G1 X0.705
    N10710G1 Z0.447
    N10720G1 X0.735 Z0.423
    N10730G1 X0.765 Z0.393
    N10740G1 X0.795 Z0.375
    N10750G1 X1.035
    N10760G1 X1.065 Z0.377
    N10770G1 X1.095 Z0.383
    N10780G1 X1.125 Z0.387
    N10790G1 X1.185 Z0.387
    N10800G1 X1.215 Z0.384
    N10810G1 X1.245 Z0.378
    N10820G1 X1.275 Z0.375
    N10830G1 X1.575
    N10840G1 X1.605 Z0.408
    N10850G1 X1.635 Z0.432
    N10860G1 X1.665 Z0.451
    N10870G0 Z0.700
    N10880G0 X1.965
    N10890G0 Z0.637
    N10900G1 Z0.440
    N10910G1 X1.995 Z0.396
    N10920G1 X2.025 Z0.375
    N10930G1 X2.745
    N10940G1 A356.571
    N10950G1 X2.025
    N10960G1 X1.995 Z0.396
    N10970G1 X1.965 Z0.440
    N10980G0 Z0.700
    N10990G0 X1.665
    N11000G0 Z0.648
    N11010G1 Z0.451
    N11020G1 X1.635 Z0.432
    N11030G1 X1.605 Z0.408
    N11040G1 X1.575 Z0.375
    N11050G1 X1.275
    N11060G1 X1.245 Z0.378
    N11070G1 X1.215 Z0.384
    N11080G1 X1.185 Z0.387
    N11090G1 X1.125 Z0.387
    N11100G1 X1.095 Z0.383
    N11110G1 X1.065 Z0.377
    N11120G1 X1.035 Z0.375
    N11130G1 X0.795
    N11140G1 X0.765 Z0.393
    N11150G1 X0.735 Z0.423
    N11160G1 X0.705 Z0.447
    N11170G1 Z0.651
    N11180G1 X0.585
    N11190G1 Z0.443
    N11200G1 X0.555 Z0.437
    N11210G1 X0.525 Z0.413
    N11220G1 X0.495 Z0.375
    N11230G1 X0.015
    N11240G1 A6.857
    N11250G1 X0.495
    N11260G1 X0.525 Z0.413
    N11270G1 X0.555 Z0.437
    N11280G1 X0.585 Z0.443
    N11290G1 Z0.651
    N11300G1 X0.705
    N11310G1 Z0.447
    N11320G1 X0.735 Z0.423
    N11330G1 X0.765 Z0.393
    N11340G1 X0.795 Z0.375
    N11350G1 X1.065
    N11360G1 X1.095 Z0.380
    N11370G1 X1.125 Z0.383
    N11380G1 X1.185 Z0.383
    N11390G1 X1.215 Z0.379
    N11400G1 X1.245 Z0.375
    N11410G1 X1.575
    N11420G1 X1.605 Z0.412
    N11430G1 X1.635 Z0.436
    N11440G1 X1.665 Z0.454
    N11450G0 Z0.700
    N11460G0 X1.965
    N11470G0 Z0.640
    N11480G1 Z0.443
    N11490G1 X1.995 Z0.399
    N11500G1 X2.025 Z0.375
    N11510G1 X2.715
    N11520G1 A353.143
    N11530G1 X2.025
    N11540G1 X1.995 Z0.399
    N11550G1 X1.965 Z0.443
    N11560G0 Z0.700
    N11570G0 X1.665
    N11580G0 Z0.651
    N11590G1 Z0.454
    N11600G1 X1.635 Z0.436
    N11610G1 X1.605 Z0.412
    N11620G1 X1.575 Z0.375
    N11630G1 X1.245
    N11640G1 X1.215 Z0.379
    N11650G1 X1.185 Z0.383
    N11660G1 X1.125 Z0.383
    N11670G1 X1.095 Z0.380
    N11680G1 X1.065 Z0.375
    N11690G1 X0.795
    N11700G1 X0.765 Z0.393
    N11710G1 X0.735 Z0.423
    N11720G1 X0.705 Z0.447
    N11730G1 Z0.651
    N11740G1 X0.585
    N11750G1 Z0.443
    N11760G1 X0.555 Z0.437
    N11770G1 X0.525 Z0.413
    N11780G1 X0.495 Z0.375
    N11790G1 X0.045
    N11800G1 A10.286
    N11810G1 X0.495
    N11820G1 X0.525 Z0.413
    N11830G1 X0.555 Z0.437
    N11840G1 X0.585 Z0.443
    N11850G1 Z0.651
    N11860G1 X0.705
    N11870G1 Z0.447
    N11880G1 X0.735 Z0.423
    N11890G1 X0.765 Z0.393
    N11900G1 X0.795 Z0.375
    N11910G1 X1.065
    N11920G1 X1.095 Z0.376
    N11930G1 X1.125 Z0.379
    N11940G1 X1.155 Z0.379
    N11950G1 X1.185 Z0.378
    N11960G1 X1.215 Z0.375
    N11970G1 X1.575
    N11980G1 X1.605 Z0.416
    N11990G1 X1.635 Z0.440
    N12000G0 Z0.700
    N12010G0 X1.965
    N12020G0 Z0.644
    N12030G1 Z0.447
    N12040G1 X1.995 Z0.404
    N12050G1 X2.025 Z0.375
    N12060G1 X2.685
    N12070G1 A349.714
    N12080G1 X2.025
    N12090G1 X1.995 Z0.404
    N12100G1 X1.965 Z0.447
    N12110G0 Z0.700
    N12120G0 X1.635
    N12130G0 Z0.637
    N12140G1 Z0.440
    N12150G1 X1.605 Z0.416
    N12160G1 X1.575 Z0.375
    N12170G1 X1.215
    N12180G1 X1.185 Z0.378
    N12190G1 X1.155 Z0.379
    N12200G1 X1.125 Z0.379
    N12210G1 X1.095 Z0.376
    N12220G1 X1.065 Z0.375
    N12230G1 X0.795
    N12240G1 X0.765 Z0.393
    N12250G1 X0.735 Z0.423
    N12260G1 X0.705 Z0.447
    N12270G1 Z0.651
    N12280G1 X0.585
    N12290G1 Z0.443
    N12300G1 X0.555 Z0.437
    N12310G1 X0.525 Z0.413
    N12320G1 X0.495 Z0.375
    N12330G1 X0.075
    N12340G1 A13.714
    N12350G1 X0.495
    N12360G1 X0.525 Z0.413
    N12370G1 X0.555 Z0.437
    N12380G1 X0.585 Z0.443
    N12390G1 Z0.651
    N12400G1 X0.705
    N12410G1 Z0.447
    N12420G1 X0.735 Z0.423
    N12430G1 X0.765 Z0.393
    N12440G1 X0.795 Z0.375
    N12450G1 X1.575
    N12460G1 X1.605 Z0.418
    N12470G1 X1.635 Z0.441
    N12480G0 Z0.700
    N12490G0 X1.965
    N12500G0 Z0.643
    N12510G1 Z0.446
    N12520G1 X1.995 Z0.405
    N12530G1 X2.025 Z0.375
    N12540G1 X2.655
    N12550G1 A346.286
    N12560G1 X2.025
    N12570G1 X1.995 Z0.405
    N12580G1 X1.965 Z0.446
    N12590G0 Z0.700
    N12600G0 X1.635
    N12610G0 Z0.638
    N12620G1 Z0.441
    N12630G1 X1.605 Z0.417
    N12640G1 X1.575 Z0.375
    N12650G1 X0.795
    N12660G1 X0.765 Z0.393
    N12670G1 X0.735 Z0.423
    N12680G1 X0.705 Z0.447
    N12690G1 Z0.651
    N12700G1 X0.585
    N12710G1 Z0.443
    N12720G1 X0.555 Z0.437
    N12730G1 X0.525 Z0.413
    N12740G1 X0.495 Z0.375
    N12750G1 X0.105
    N12760G1 A17.143
    N12770G1 X0.495
    N12780G1 X0.525 Z0.413
    N12790G1 X0.555 Z0.437
    N12800G1 X0.585 Z0.443
    N12810G1 Z0.651
    N12820G1 X0.705
    N12830G1 Z0.447
    N12840G1 X0.735 Z0.423
    N12850G1 X0.765 Z0.393
    N12860G1 X0.795 Z0.375
    N12870G1 X1.575
    N12880G1 X1.605 Z0.405 F37.5
    N12890G1 X1.635 Z0.433
    N12900G1 X1.665 Z0.440 F50.0
    N12910G1 Z0.670
    N12920G1 X1.935
    N12930G1 Z0.461
    N12940G1 X1.965 Z0.433
    N12950G1 X1.995 Z0.392 F37.5
    N12960G1 X2.025 Z0.375
    N12970G1 X2.625 F50.0
    N12980G1 A342.857
    N12990G1 X2.025
    N13000G1 X1.995 Z0.392 F37.5
    N13010G1 X1.965 Z0.433
    N13020G1 X1.935 Z0.461 F50.0
    N13030G1 Z0.670
    N13040G1 X1.665
    N13050G1 Z0.440
    N13060G1 X1.635 Z0.433
    N13070G1 X1.605 Z0.405 F37.5
    N13080G1 X1.575 Z0.375
    N13090G1 X0.795 F50.0
    N13100G1 X0.765 Z0.393
    N13110G1 X0.735 Z0.423
    N13120G1 X0.705 Z0.447
    N13130G1 Z0.651
    N13140G1 X0.585
    N13150G1 Z0.443
    N13160G1 X0.555 Z0.437
    N13170G1 X0.525 Z0.413
    N13180G1 X0.495 Z0.375
    N13190G1 X0.135
    N13200G1 A20.571
    N13210G1 X0.495
    N13220G1 X0.525 Z0.413
    N13230G1 X0.555 Z0.437
    N13240G1 X0.585 Z0.443
    N13250G1 Z0.651
    N13260G1 X0.705
    N13270G1 Z0.447
    N13280G1 X0.735 Z0.423
    N13290G1 X0.765 Z0.393
    N13300G1 X0.795 Z0.375
    N13310G1 X1.575
    N13320G1 X1.605 F37.5
    N13330G1 X1.635 Z0.403
    N13340G1 X1.665 Z0.414
    N13350G1 X1.695 Z0.436
    N13360G1 X1.725 Z0.447 F50.0
    N13370G1 Z0.644
    N13380G1 X1.815
    N13390G1 Z0.447
    N13400G1 X1.845 Z0.436
    N13410G1 X1.875 Z0.447
    N13420G1 X1.905 Z0.441
    N13430G1 X1.935 Z0.430
    N13440G1 X1.965 Z0.403 F37.5
    N13450G1 X1.995 Z0.375
    N13460G1 X2.025
    N13470G1 X2.595 F50.0
    N13480G1 A339.429
    N13490G1 X2.025
    N13500G1 X1.995 F37.5
    N13510G1 X1.965 Z0.403
    N13520G1 X1.935 Z0.430
    N13530G1 X1.905 Z0.441 F50.0
    N13540G1 X1.875 Z0.447
    N13550G1 X1.845 Z0.436
    N13560G1 X1.815 Z0.447
    N13570G1 Z0.644
    N13580G1 X1.725
    N13590G1 Z0.447
    N13600G1 X1.695 Z0.436
    N13610G1 X1.665 Z0.414 F37.5
    N13620G1 X1.635 Z0.402
    N13630G1 X1.605 Z0.375
    N13640G1 X1.575
    N13650G1 X0.795 F50.0
    N13660G1 X0.765 Z0.393
    N13670G1 X0.735 Z0.423
    N13680G1 X0.705 Z0.447
    N13690G1 Z0.651
    N13700G1 X0.585
    N13710G1 Z0.443
    N13720G1 X0.555 Z0.437
    N13730G1 X0.525 Z0.413
    N13740G1 X0.495 Z0.375
    N13750G1 X0.165
    N13760G1 A24.000
    N13770G1 X0.495
    N13780G1 X0.525 Z0.413
    N13790G1 X0.555 Z0.437
    N13800G1 X0.585 Z0.443
    N13810G1 Z0.651
    N13820G1 X0.705
    N13830G1 Z0.447
    N13840G1 X0.735 Z0.423
    N13850G1 X0.765 Z0.393
    N13860G1 X0.795 Z0.375
    N13870G1 X1.605
    N13880G1 X1.635 Z0.393
    N13890G1 X1.665 Z0.405
    N13900G1 X1.695 Z0.407 F37.5
    N13910G1 X1.905 Z0.407
    N13920G1 X1.935 Z0.396
    N13930G1 X1.965 Z0.382
    N13940G1 X1.995 Z0.375
    N13950G1 X2.565 F50.0
    N13960G1 A336.000
    N13970G1 X1.995
    N13980G1 X1.965 Z0.382 F37.5
    N13990G1 X1.935 Z0.396
    N14000G1 X1.905 Z0.407
    N14010G1 X1.695 Z0.407
    N14020G1 X1.665 Z0.405
    N14030G1 X1.635 Z0.393 F50.0
    N14040G1 X1.605 Z0.375
    N14050G1 X0.795
    N14060G1 X0.765 Z0.393
    N14070G1 X0.735 Z0.423
    N14080G1 X0.705 Z0.447
    N14090G1 Z0.651
    N14100G1 X0.585
    N14110G1 Z0.443
    N14120G1 X0.555 Z0.437
    N14130G1 X0.525 Z0.413
    N14140G1 X0.495 Z0.375
    N14150G1 X0.195
    N14160G1 A27.429
    N14170G1 X0.495
    N14180G1 X0.525 Z0.413
    N14190G1 X0.555 Z0.437
    N14200G1 X0.585 Z0.443
    N14210G1 Z0.651
    N14220G1 X0.705
    N14230G1 Z0.447
    N14240G1 X0.735 Z0.423
    N14250G1 X0.765 Z0.393
    N14260G1 X0.795 Z0.375
    N14270G1 X1.605
    N14280G1 X1.965 F37.5
    N14290G1 X2.535 F50.0
    N14300G1 A332.571
    N14310G1 X1.965
    N14320G1 X1.605 F37.5
    N14330G1 X0.795 F50.0
    N14340G1 X0.765 Z0.393
    N14350G1 X0.735 Z0.423
    N14360G1 X0.705 Z0.447
    N14370G1 Z0.651
    N14380G1 X0.585
    N14390G1 Z0.443
    N14400G1 X0.555 Z0.437
    N14410G1 X0.525 Z0.413
    N14420G1 X0.495 Z0.375
    N14430G1 X0.225
    N14440G1 A30.857
    N14450G1 X0.495
    N14460G1 X0.525 Z0.413
    N14470G1 X0.555 Z0.437
    N14480G1 X0.585 Z0.443
    N14490G1 Z0.651
    N14500G1 X0.705
    N14510G1 Z0.447
    N14520G1 X0.735 Z0.423
    N14530G1 X0.765 Z0.393
    N14540G1 X0.795 Z0.375
    N14550G1 X2.505
    N14560G1 A329.143
    N14570G1 X0.795
    N14580G1 X0.765 Z0.393
    N14590G1 X0.735 Z0.423
    N14600G1 X0.705 Z0.447
    N14610G1 Z0.651
    N14620G1 X0.585
    N14630G1 Z0.443
    N14640G1 X0.555 Z0.437
    N14650G1 X0.525 Z0.413
    N14660G1 X0.495 Z0.375
    N14670G1 X0.255
    N14680G1 A34.286
    N14690G1 X0.495
    N14700G1 X0.525 Z0.413
    N14710G1 X0.555 Z0.437
    N14720G1 X0.585 Z0.443
    N14730G1 Z0.651
    N14740G1 X0.705
    N14750G1 Z0.447
    N14760G1 X0.735 Z0.423
    N14770G1 X0.765 Z0.393
    N14780G1 X0.795 Z0.375
    N14790G1 X2.475
    N14800G1 A325.714
    N14810G1 X0.795
    N14820G1 X0.765 Z0.393
    N14830G1 X0.735 Z0.423
    N14840G1 X0.705 Z0.447
    N14850G1 Z0.651
    N14860G1 X0.585
    N14870G1 Z0.443
    N14880G1 X0.555 Z0.437
    N14890G1 X0.525 Z0.413
    N14900G1 X0.495 Z0.375
    N14910G1 X0.285
    N14920G1 A37.714
    N14930G1 X0.495
    N14940G1 X0.525 Z0.413
    N14950G1 X0.555 Z0.437
    N14960G1 X0.585 Z0.443
    N14970G1 Z0.651
    N14980G1 X0.705
    N14990G1 Z0.447
    N15000G1 X0.735 Z0.423
    N15010G1 X0.765 Z0.393
    N15020G1 X0.795 Z0.375
    N15030G1 X2.445
    N15040G1 A322.286
    N15050G1 X0.795
    N15060G1 X0.765 Z0.393
    N15070G1 X0.735 Z0.423
    N15080G1 X0.705 Z0.447
    N15090G1 Z0.651
    N15100G1 X0.585
    N15110G1 Z0.443
    N15120G1 X0.555 Z0.437
    N15130G1 X0.525 Z0.413
    N15140G1 X0.495 Z0.375
    N15150G1 X0.315
    N15160G1 A41.143
    N15170G1 X0.495
    N15180G1 X0.525 Z0.413
    N15190G1 X0.555 Z0.437
    N15200G1 X0.585 Z0.443
    N15210G1 Z0.651
    N15220G1 X0.705
    N15230G1 Z0.447
    N15240G1 X0.735 Z0.423
    N15250G1 X0.765 Z0.393
    N15260G1 X0.795 Z0.375
    N15270G1 X2.415
    N15280G1 A318.857
    N15290G1 X0.795
    N15300G1 X0.765 Z0.393
    N15310G1 X0.735 Z0.423
    N15320G1 X0.705 Z0.447
    N15330G1 Z0.651
    N15340G1 X0.585
    N15350G1 Z0.443
    N15360G1 X0.555 Z0.437
    N15370G1 X0.525 Z0.413
    N15380G1 X0.495 Z0.375
    N15390G1 X0.345
    N15400G1 A44.571
    N15410G1 X0.495
    N15420G1 X0.525 Z0.413
    N15430G1 X0.555 Z0.437
    N15440G1 X0.585 Z0.443
    N15450G1 Z0.651
    N15460G1 X0.705
    N15470G1 Z0.447
    N15480G1 X0.735 Z0.423
    N15490G1 X0.765 Z0.393
    N15500G1 X0.795 Z0.375
    N15510G1 X2.385
    N15520G1 A315.429
    N15530G1 X0.795
    N15540G1 X0.765 Z0.393
    N15550G1 X0.735 Z0.423
    N15560G1 X0.705 Z0.447
    N15570G1 Z0.651
    N15580G1 X0.585
    N15590G1 Z0.443
    N15600G1 X0.555 Z0.437
    N15610G1 X0.525 Z0.413
    N15620G1 X0.495 Z0.375
    N15630G1 X0.375
    N15640G1 A48.000
    N15650G1 X0.495
    N15660G1 X0.525 Z0.413
    N15670G1 X0.555 Z0.437
    N15680G1 X0.585 Z0.443
    N15690G1 Z0.651
    N15700G1 X0.705
    N15710G1 Z0.447
    N15720G1 X0.735 Z0.423
    N15730G1 X0.765 Z0.393
    N15740G1 X0.795 Z0.375
    N15750G1 X2.355
    N15760G1 A312.000
    N15770G1 X0.795
    N15780G1 X0.765 Z0.393
    N15790G1 X0.735 Z0.423
    N15800G1 X0.705 Z0.447
    N15810G1 Z0.651
    N15820G1 X0.585
    N15830G1 Z0.443
    N15840G1 X0.555 Z0.437
    N15850G1 X0.525 Z0.413
    N15860G1 X0.495 Z0.375
    N15870G1 X0.405
    N15880G1 A51.429
    N15890G1 X0.495
    N15900G1 X0.525 Z0.413
    N15910G1 X0.555 Z0.437
    N15920G1 X0.585 Z0.443
    N15930G1 Z0.651
    N15940G1 X0.705
    N15950G1 Z0.447
    N15960G1 X0.735 Z0.423
    N15970G1 X0.765 Z0.393
    N15980G1 X0.795 Z0.375
    N15990G1 X2.325
    N16000G1 A308.571
    N16010G1 X0.795
    N16020G1 X0.765 Z0.393
    N16030G1 X0.735 Z0.423
    N16040G1 X0.705 Z0.447
    N16050G1 Z0.651
    N16060G1 X0.585
    N16070G1 Z0.443
    N16080G1 X0.555 Z0.437
    N16090G1 X0.525 Z0.413
    N16100G1 X0.495 Z0.375
    N16110G1 X0.435
    N16120G1 A54.857
    N16130G1 X0.495
    N16140G1 X0.525 Z0.413
    N16150G1 X0.555 Z0.437
    N16160G1 X0.585 Z0.443
    N16170G1 Z0.651
    N16180G1 X0.705
    N16190G1 Z0.447
    N16200G1 X0.735 Z0.423
    N16210G1 X0.765 Z0.393
    N16220G1 X0.795 Z0.375
    N16230G1 X2.295
    N16240G1 A305.143
    N16250G1 X0.795
    N16260G1 X0.765 Z0.393
    N16270G1 X0.735 Z0.423
    N16280G1 X0.705 Z0.447
    N16290G1 Z0.651
    N16300G1 X0.585
    N16310G1 Z0.443
    N16320G1 X0.555 Z0.437
    N16330G1 X0.525 Z0.413
    N16340G1 X0.495 Z0.375
    N16350G1 X0.465
    N16360G1 A58.286
    N16370G1 X0.495
    N16380G1 X0.525 Z0.413
    N16390G1 X0.555 Z0.437
    N16400G1 X0.585 Z0.443
    N16410G1 Z0.651
    N16420G1 X0.705
    N16430G1 Z0.447
    N16440G1 X0.735 Z0.423
    N16450G1 X0.765 Z0.393
    N16460G1 X0.795 Z0.375
    N16470G1 X2.265
    N16480G1 A301.714
    N16490G1 X0.795
    N16500G1 X0.765 Z0.393
    N16510G1 X0.735 Z0.423
    N16520G1 X0.705 Z0.447
    N16530G1 Z0.651
    N16540G1 X0.585
    N16550G1 Z0.443
    N16560G1 X0.555 Z0.437
    N16570G1 X0.525 Z0.413
    N16580G1 X0.495 Z0.375
    N16590G1 A298.286 F37.5
    N16600G1 A61.714 F50.0
    N16610G1 X0.525 Z0.413
    N16620G1 X0.555 Z0.437
    N16630G1 X0.585 Z0.443
    N16640G1 Z0.651
    N16650G1 X0.705
    N16660G1 Z0.447
    N16670G1 X0.735 Z0.423
    N16680G1 X0.765 Z0.393
    N16690G1 X0.795 Z0.375
    N16700G1 X2.235
    N16710G1 A298.286
    N16720G1 X0.795
    N16730G1 X0.765 Z0.393
    N16740G1 X0.735 Z0.423
    N16750G1 X0.705 Z0.447
    N16760G1 Z0.651
    N16770G1 X0.585
    N16780G1 Z0.443
    N16790G1 X0.555 Z0.437
    N16800G1 X0.525 Z0.413
    N16810G1 Z0.413 A294.857 F37.5
    N16820G1 Z0.413 A253.714 F50.0
    N16830G1 Z0.413 A65.143
    N16840G1 X0.555 Z0.437
    N16850G1 X0.585 Z0.443
    N16860G1 Z0.651
    N16870G1 X0.705
    N16880G1 Z0.447
    N16890G1 X0.735 Z0.423
    N16900G1 X0.765 Z0.393
    N16910G1 X0.795 Z0.375
    N16920G1 X2.205
    N16930G1 A294.857
    N16940G1 X0.795
    N16950G1 X0.765 Z0.393
    N16960G1 X0.735 Z0.423
    N16970G1 X0.705 Z0.447
    N16980G1 Z0.651
    N16990G1 X0.585
    N17000G1 Z0.443
    N17010G1 X0.555 Z0.437
    N17020G1 Z0.437 A68.571
    N17030G1 X0.585 Z0.443
    N17040G1 Z0.651
    N17050G1 X0.705
    N17060G1 Z0.447
    N17070G1 X0.735 Z0.423
    N17080G1 X0.765 Z0.393
    N17090G1 X0.795 Z0.375
    N17100G1 X2.175
    N17110G1 A291.429
    N17120G1 X0.795
    N17130G1 X0.765 Z0.393
    N17140G1 X0.735 Z0.423
    N17150G1 X0.705 Z0.447
    N17160G0 Z0.700
    N17170G0 A72.000
    N17180G0 Z0.644
    N17190G1 Z0.447
    N17200G1 X0.735 Z0.423
    N17210G1 X0.765 Z0.393
    N17220G1 X0.795 Z0.375
    N17230G1 X2.145
    N17240G1 A288.000
    N17250G1 X0.795
    N17260G1 X0.765 Z0.393
    N17270G1 X0.735 Z0.423
    N17280G1 X0.705 Z0.447
    N17290G0 Z0.700
    N17300G0 A75.429
    N17310G0 Z0.644
    N17320G1 Z0.447
    N17330G1 X0.735 Z0.423
    N17340G1 X0.765 Z0.393
    N17350G1 X0.795 Z0.375
    N17360G1 X2.115
    N17370G1 A171.429
    N17380G1 Z0.387 A174.857
    N17390G1 Z0.387 A185.143
    N17400G1 Z0.375 A188.571
    N17410G1 A284.571
    N17420G1 X0.795
    N17430G1 X0.765 Z0.393
    N17440G1 X0.735 Z0.423
    N17450G1 X0.705 Z0.447
    N17460G0 Z0.700
    N17470G0 A78.857
    N17480G0 Z0.644
    N17490G1 Z0.447
    N17500G1 X0.735 Z0.423
    N17510G1 X0.765 Z0.393
    N17520G1 X0.795 Z0.375
    N17530G1 X2.085
    N17540G1 A168.000
    N17550G1 Z0.402 A171.429
    N17560G1 Z0.411 A174.857
    N17570G1 Z0.411 A185.143
    N17580G1 Z0.402 A188.571
    N17590G1 Z0.375 A192.000
    N17600G1 A281.143
    N17610G1 X0.795
    N17620G1 X0.765 Z0.393
    N17630G1 X0.735 Z0.423
    N17640G1 X0.705 Z0.447
    N17650G0 Z0.700
    N17660G0 A82.286
    N17670G0 Z0.644
    N17680G1 Z0.447
    N17690G1 X0.735 Z0.423
    N17700G1 X0.765 Z0.393
    N17710G1 X0.795 Z0.375
    N17720G1 X2.055
    N17730G1 A164.571
    N17740G1 Z0.397 A168.000
    N17750G1 Z0.413 A171.429
    N17760G1 Z0.421 A174.857
    N17770G1 Z0.421 A178.286
    N17780G1 Z0.422 A181.714
    N17790G1 Z0.421 A185.143
    N17800G1 Z0.413 A188.571
    N17810G1 Z0.397 A192.000
    N17820G1 Z0.375 A195.429
    N17830G1 A277.714
    N17840G1 X0.795
    N17850G1 X0.765 Z0.393
    N17860G1 X0.735 Z0.423
    N17870G1 X0.705 Z0.447
    N17880G0 Z0.700
    N17890G0 A85.714
    N17900G0 Z0.644
    N17910G1 Z0.447
    N17920G1 X0.735 Z0.423
    N17930G1 X0.765 Z0.393
    N17940G1 X0.795 Z0.375
    N17950G1 X2.025
    N17960G1 A161.143
    N17970G1 Z0.384 A164.571
    N17980G1 Z0.404 A168.000
    N17990G1 Z0.420 A171.429
    N18000G1 Z0.427 A174.857
    N18010G1 Z0.428 A178.286
    N18020G1 Z0.428 A181.714
    N18030G1 Z0.427 A185.143
    N18040G1 Z0.420 A188.571
    N18050G1 Z0.404 A192.000
    N18060G1 Z0.384 A195.429
    N18070G1 Z0.375 A198.857
    N18080G1 A274.286
    N18090G1 X0.795
    N18100G1 X0.765 Z0.393
    N18110G1 X0.735 Z0.423
    N18120G1 Z0.423 A89.143 F37.5
    N18130G1 X0.765 Z0.393 F50.0
    N18140G1 X0.795 Z0.375
    N18150G1 X1.995
    N18160G1 A161.143
    N18170G1 Z0.388 A164.571
    N18180G1 Z0.406 A168.000
    N18190G1 Z0.425 A171.429
    N18200G1 Z0.437 A174.857
    N18210G1 Z0.439 A178.286
    N18220G1 Z0.439 A181.714
    N18230G1 Z0.437 A185.143
    N18240G1 Z0.425 A188.571
    N18250G1 Z0.406 A192.000
    N18260G1 Z0.388 A195.429
    N18270G1 Z0.375 A198.857
    N18280G1 A270.857
    N18290G1 X0.795
    N18300G1 X0.765 Z0.393
    N18310G1 Z0.393 A257.143 F37.5
    N18320G1 Z0.393 A92.571
    N18330G1 X0.795 Z0.375 F50.0
    N18340G1 X1.965
    N18350G1 A161.143
    N18360G1 Z0.389 A164.571
    N18370G1 Z0.421 A168.000
    N18380G1 Z0.453 A171.429
    N18390G1 Z0.659
    N18400G1 A188.571
    N18410G1 Z0.453
    N18420G1 Z0.421 A192.000
    N18430G1 Z0.389 A195.429
    N18440G1 Z0.375 A198.857
    N18450G1 A267.429
    N18460G1 X0.795
    N18470G1 A96.000 F37.5
    N18480G1 X1.935 F50.0
    N18490G1 A161.143
    N18500G1 Z0.389 A164.571
    N18510G1 Z0.433 A168.000
    N18520G1 Z0.460 A171.429
    N18530G1 Z0.666
    N18540G1 A188.571
    N18550G1 Z0.460
    N18560G1 Z0.433 A192.000
    N18570G1 Z0.389 A195.429
    N18580G1 Z0.375 A198.857
    N18590G1 A264.000
    N18600G1 X0.825
    N18610G1 A99.429
    N18620G1 X1.905
    N18630G1 A161.143
    N18640G1 Z0.391 A164.571
    N18650G1 Z0.435 A168.000
    N18660G1 Z0.462 A171.429
    N18670G1 Z0.668
    N18680G1 A188.571
    N18690G1 Z0.462
    N18700G1 Z0.435 A192.000
    N18710G1 Z0.391 A195.429
    N18720G1 Z0.375 A198.857
    N18730G1 A260.571
    N18740G1 X0.855
    N18750G1 A102.857
    N18760G1 X1.875
    N18770G1 A161.143
    N18780G1 Z0.402 A164.571
    N18790G1 Z0.435 A168.000
    N18800G1 Z0.462 A171.429
    N18810G1 Z0.668
    N18820G1 A188.571
    N18830G1 Z0.462
    N18840G1 Z0.435 A192.000
    N18850G1 Z0.402 A195.429
    N18860G1 Z0.375 A198.857
    N18870G1 A257.143
    N18880G1 X0.885
    N18890G1 A106.286
    N18900G1 X1.845
    N18910G1 A161.143
    N18920G1 Z0.402 A164.571
    N18930G1 Z0.441 A168.000
    N18940G1 Z0.680
    N18950G1 A192.000
    N18960G1 Z0.441
    N18970G1 Z0.402 A195.429
    N18980G1 Z0.375 A198.857
    N18990G1 A253.714
    N19000G1 X0.915
    N19010G1 A109.714
    N19020G1 X1.815
    N19030G1 A161.143
    N19040G1 Z0.402 A164.571
    N19050G1 Z0.452 A168.000
    N19060G1 Z0.686
    N19070G1 A192.000
    N19080G1 Z0.452
    N19090G1 Z0.402 A195.429
    N19100G1 Z0.375 A198.857
    N19110G1 A250.286
    N19120G1 X0.945
    N19130G1 A209.143
    N19140G1 Z0.384 A205.714
    N19150G1 Z0.392 A202.286
    N19160G1 Z0.398 A198.857
    N19170G1 Z0.403 A195.429
    N19180G1 Z0.405 A192.000
    N19190G1 Z0.407 A188.571
    N19200G1 Z0.407 A185.143
    N19210G1 Z0.397 A181.714
    N19220G1 Z0.397 A178.286
    N19230G1 Z0.407 A174.857
    N19240G1 Z0.407 A171.429
    N19250G1 Z0.405 A168.000
    N19260G1 Z0.403 A164.571
    N19270G1 Z0.398 A161.143
    N19280G1 Z0.392 A157.714
    N19290G1 Z0.384 A154.286
    N19300G1 Z0.375 A150.857
    N19310G1 A113.143
    N19320G1 X1.785
    N19330G1 A161.143
    N19340G1 Z0.396 A164.571
    N19350G1 Z0.452 A168.000
    N19360G1 Z0.686
    N19370G1 A192.000
    N19380G1 Z0.452
    N19390G1 Z0.396 A195.429
    N19400G1 Z0.375 A198.857
    N19410G1 A246.857
    N19420G1 X0.975
    N19430G1 A219.429
    N19440G1 Z0.382 A216.000
    N19450G1 Z0.392 A212.571
    N19460G1 Z0.401 A209.143
    N19470G1 Z0.409 A205.714
    N19480G1 Z0.416 A202.286
    N19490G1 Z0.422 A198.857
    N19500G1 Z0.426 A195.429
    N19510G1 Z0.428 A192.000
    N19520G1 Z0.431 A188.571
    N19530G1 Z0.430 A185.143
    N19540G1 Z0.422 A181.714
    N19550G1 Z0.422 A178.286
    N19560G1 Z0.430 A174.857
    N19570G1 Z0.431 A171.429
    N19580G1 Z0.428 A168.000
    N19590G1 Z0.426 A164.571
    N19600G1 Z0.422 A161.143
    N19610G1 Z0.416 A157.714
    N19620G1 Z0.409 A154.286
    N19630G1 Z0.401 A150.857
    N19640G1 Z0.392 A147.429
    N19650G1 Z0.382 A144.000
    N19660G1 Z0.375 A140.571
    N19670G1 A116.571
    N19680G1 X1.755
    N19690G1 A161.143
    N19700G1 Z0.402 A164.571
    N19710G1 Z0.454 A168.000
    N19720G1 Z0.694
    N19730G1 A192.000
    N19740G1 Z0.454
    N19750G1 Z0.402 A195.429
    N19760G1 Z0.375 A198.857
    N19770G1 A243.429
    N19780G1 X1.005
    N19790G1 A222.857
    N19800G1 Z0.379 A219.429
    N19810G1 Z0.391 A216.000
    N19820G1 Z0.401 A212.571
    N19830G1 Z0.411 A209.143
    N19840G1 Z0.419 A205.714
    N19850G1 Z0.426 A202.286
    N19860G1 Z0.433 A198.857
    N19870G1 Z0.437 A195.429
    N19880G1 Z0.439 A192.000
    N19890G1 Z0.639
    N19900G1 A185.143
    N19910G1 Z0.441
    N19920G1 Z0.433 A181.714
    N19930G1 Z0.433 A178.286
    N19940G1 Z0.441 A174.857
    N19950G1 Z0.639
    N19960G1 A168.000
    N19970G1 Z0.439
    N19980G1 Z0.437 A164.571
    N19990G1 Z0.433 A161.143
    N20000G1 Z0.426 A157.714
    N20010G1 Z0.419 A154.286
    N20020G1 Z0.411 A150.857
    N20030G1 Z0.401 A147.429
    N20040G1 Z0.391 A144.000
    N20050G1 Z0.379 A140.571
    N20060G1 Z0.375 A137.143
    N20070G1 A120.000
    N20080G1 X1.725
    N20090G1 A161.143
    N20100G1 Z0.402 A164.571
    N20110G1 Z0.466 A168.000
    N20120G1 Z0.700
    N20130G1 A192.000
    N20140G1 Z0.466
    N20150G1 Z0.402 A195.429
    N20160G1 Z0.375 A198.857
    N20170G1 A240.000
    N20180G1 X1.035
    N20190G1 A222.857
    N20200G1 Z0.386 A219.429
    N20210G1 Z0.398 A216.000
    N20220G1 Z0.408 A212.571
    N20230G1 Z0.418 A209.143
    N20240G1 Z0.426 A205.714
    N20250G1 Z0.433 A202.286
    N20260G1 Z0.439 A198.857
    N20270G1 Z0.645
    N20280G1 A161.143
    N20290G1 Z0.439
    N20300G1 Z0.433 A157.714
    N20310G1 Z0.426 A154.286
    N20320G1 Z0.418 A150.857
    N20330G1 Z0.408 A147.429
    N20340G1 Z0.398 A144.000
    N20350G1 Z0.386 A140.571
    N20360G1 Z0.375 A137.143
    N20370G1 A123.429
    N20380G1 X1.695
    N20390G1 A161.143
    N20400G1 Z0.402 A164.571
    N20410G1 Z0.466 A168.000
    N20420G0 Z0.700
    N20430G0 A192.000
    N20440G0 Z0.634
    N20450G1 Z0.466
    N20460G1 Z0.402 A195.429
    N20470G1 Z0.375 A198.857
    N20480G1 A236.571
    N20490G1 X1.065
    N20500G1 A222.857
    N20510G1 Z0.386 A219.429
    N20520G1 Z0.398 A216.000
    N20530G1 Z0.408 A212.571
    N20540G1 Z0.418 A209.143
    N20550G1 Z0.426 A205.714
    N20560G1 Z0.433 A202.286
    N20570G1 Z0.439 A198.857
    N20580G1 Z0.647
    N20590G1 A161.143
    N20600G1 Z0.439
    N20610G1 Z0.433 A157.714
    N20620G1 Z0.426 A154.286
    N20630G1 Z0.418 A150.857
    N20640G1 Z0.408 A147.429
    N20650G1 Z0.398 A144.000
    N20660G1 Z0.386 A140.571
    N20670G1 Z0.375 A137.143
    N20680G1 A126.857
    N20690G1 X1.665
    N20700G1 A161.143
    N20710G1 Z0.391 A164.571
    N20720G1 Z0.464 A168.000
    N20730G1 Z0.698
    N20740G1 A192.000
    N20750G1 Z0.464
    N20760G1 Z0.391 A195.429
    N20770G1 Z0.375 A198.857
    N20780G1 A233.143
    N20790G1 X1.095
    N20800G1 A222.857
    N20810G1 Z0.382 A219.429
    N20820G1 Z0.392 A216.000
    N20830G1 Z0.402 A212.571
    N20840G1 Z0.411 A209.143
    N20850G1 Z0.419 A205.714
    N20860G1 Z0.426 A202.286
    N20870G1 Z0.433 A198.857
    N20880G1 Z0.437 A195.429
    N20890G1 Z0.439 A192.000
    N20900G1 Z0.671
    N20910G1 A168.000
    N20920G1 Z0.439
    N20930G1 Z0.437 A164.571
    N20940G1 Z0.433 A161.143
    N20950G1 Z0.426 A157.714
    N20960G1 Z0.419 A154.286
    N20970G1 Z0.411 A150.857
    N20980G1 Z0.402 A147.429
    N20990G1 Z0.392 A144.000
    N21000G1 Z0.382 A140.571
    N21010G1 Z0.375 A137.143
    N21020G1 A130.286
    N21030G1 X1.635
    N21040G1 A161.143
    N21050G1 Z0.402 A164.571
    N21060G1 Z0.455 A168.000
    N21070G1 Z0.691
    N21080G1 A192.000
    N21090G1 Z0.455
    N21100G1 Z0.402 A195.429
    N21110G1 Z0.375 A198.857
    N21120G1 A229.714
    N21130G1 X1.125
    N21140G1 A219.429
    N21150G1 Z0.385 A216.000
    N21160G1 Z0.395 A212.571
    N21170G1 Z0.403 A209.143
    N21180G1 Z0.410 A205.714
    N21190G1 Z0.418 A202.286
    N21200G1 Z0.423 A198.857
    N21210G1 Z0.427 A195.429
    N21220G1 Z0.444 A192.000
    N21230G1 Z0.681
    N21240G1 A168.000
    N21250G1 Z0.443
    N21260G1 Z0.427 A164.571
    N21270G1 Z0.423 A161.143
    N21280G1 Z0.418 A157.714
    N21290G1 Z0.410 A154.286
    N21300G1 Z0.403 A150.857
    N21310G1 Z0.395 A147.429
    N21320G1 Z0.385 A144.000
    N21330G1 Z0.375 A140.571
    N21340G1 A133.714
    N21350G1 X1.605
    N21360G1 A161.143
    N21370G1 Z0.402 A164.571
    N21380G1 Z0.457 A168.000
    N21390G1 Z0.690
    N21400G1 A192.000
    N21410G1 Z0.457
    N21420G1 Z0.402 A195.429
    N21430G1 Z0.375 A198.857
    N21440G1 A226.286
    N21450G1 X1.155
    N21460G1 A216.000
    N21470G1 Z0.379 A212.571 F37.5
    N21480G1 Z0.386 A209.143
    N21490G1 Z0.393 A205.714
    N21500G1 Z0.399 A202.286
    N21510G1 Z0.403 A198.857
    N21520G1 Z0.406 A195.429
    N21530G1 Z0.454 A192.000
    N21540G1 Z0.688 F50.0
    N21550G1 A168.000
    N21560G1 Z0.454
    N21570G1 Z0.406 A164.571 F37.5
    N21580G1 Z0.403 A161.143
    N21590G1 Z0.399 A157.714
    N21600G1 Z0.393 A154.286
    N21610G1 Z0.386 A150.857
    N21620G1 Z0.379 A147.429
    N21630G1 Z0.375 A144.000
    N21640G1 A137.143 F50.0
    N21650G1 X1.575
    N21660G1 A161.143
    N21670G1 Z0.398 A164.571
    N21680G1 Z0.455 A168.000
    N21690G1 Z0.689
    N21700G1 A192.000
    N21710G1 Z0.455
    N21720G1 Z0.400 A195.429
    N21730G1 Z0.375 A198.857
    N21740G1 A222.857
    N21750G1 X1.185
    N21760G1 A209.143
    N21770G1 A205.714 F37.5
    N21780G1 Z0.375 A202.286
    N21790G1 Z0.379 A198.857
    N21800G1 Z0.400 A195.429
    N21810G1 Z0.459 A192.000 F50.0
    N21820G1 Z0.693
    N21830G1 A168.000
    N21840G1 Z0.459
    N21850G1 Z0.400 A164.571
    N21860G1 Z0.379 A161.143 F37.5
    N21870G1 Z0.375 A157.714
    N21880G1 Z0.375 A150.857
    N21890G1 A140.571 F50.0
    N21900G1 X1.545
    N21910G1 A161.143
    N21920G1 Z0.402 A164.571
    N21930G1 Z0.446 A168.000
    N21940G1 Z0.684
    N21950G1 A192.000
    N21960G1 Z0.446
    N21970G1 Z0.402 A195.429
    N21980G1 Z0.375 A198.857
    N21990G1 A219.429
    N22000G1 X1.215
    N22010G1 A198.857
    N22020G1 Z0.401 A195.429
    N22030G1 Z0.461 A192.000
    N22040G1 Z0.695
    N22050G1 A168.000
    N22060G1 Z0.461
    N22070G1 Z0.401 A164.571
    N22080G1 Z0.375 A161.143
    N22090G1 A144.000
    N22100G1 X1.515
    N22110G1 A161.143
    N22120G1 Z0.402 A164.571
    N22130G1 Z0.457 A168.000
    N22140G1 Z0.691
    N22150G1 A192.000
    N22160G1 Z0.457
    N22170G1 Z0.402 A195.429
    N22180G1 Z0.375 A198.857
    N22190G1 A216.000
    N22200G1 X1.245
    N22210G1 A198.857
    N22220G1 Z0.402 A195.429
    N22230G1 Z0.461 A192.000
    N22240G1 Z0.695
    N22250G1 A168.000
    N22260G1 Z0.461
    N22270G1 Z0.402 A164.571
    N22280G1 Z0.375 A161.143
    N22290G1 A147.429
    N22300G1 X1.485
    N22310G1 A161.143
    N22320G1 Z0.397 A164.571
    N22330G1 Z0.456 A168.000
    N22340G1 Z0.690
    N22350G1 A192.000
    N22360G1 Z0.456
    N22370G1 Z0.397 A195.429
    N22380G1 Z0.375 A198.857
    N22390G1 A212.571
    N22400G1 X1.275
    N22410G1 A198.857
    N22420G1 Z0.402 A195.429
    N22430G1 Z0.456 A192.000
    N22440G1 Z0.690
    N22450G1 A168.000
    N22460G1 Z0.456
    N22470G1 Z0.402 A164.571
    N22480G1 Z0.375 A161.143
    N22490G1 A150.857
    N22500G1 X1.455
    N22510G1 A161.143
    N22520G1 Z0.402 A164.571
    N22530G1 Z0.446 A168.000
    N22540G1 Z0.683
    N22550G1 A192.000
    N22560G1 Z0.446
    N22570G1 Z0.402 A195.429
    N22580G1 Z0.375 A198.857
    N22590G1 A209.143
    N22600G1 X1.305
    N22610G1 A198.857
    N22620G1 Z0.402 A195.429
    N22630G1 Z0.445 A192.000
    N22640G1 Z0.684
    N22650G1 A168.000
    N22660G1 Z0.445
    N22670G1 Z0.402 A164.571
    N22680G1 Z0.375 A161.143
    N22690G1 A154.286
    N22700G1 X1.425
    N22710G1 A161.143
    N22720G1 Z0.402 A164.571
    N22730G1 Z0.440 A168.000
    N22740G1 Z0.673
    N22750G1 A192.000
    N22760G1 Z0.440
    N22770G1 Z0.402 A195.429
    N22780G1 Z0.375 A198.857
    N22790G1 A205.714
    N22800G1 X1.335
    N22810G1 A198.857
    N22820G1 Z0.402 A195.429
    N22830G1 Z0.437 A192.000
    N22840G1 Z0.464 A188.571
    N22850G1 Z0.670
    N22860G1 A171.429
    N22870G1 Z0.464
    N22880G1 Z0.437 A168.000
    N22890G1 Z0.402 A164.571
    N22900G1 Z0.375 A161.143
    N22910G1 A157.714
    N22920G1 X1.395
    N22930G1 A161.143
    N22940G1 Z0.402 A164.571
    N22950G1 Z0.437 A168.000
    N22960G1 Z0.464 A171.429
    N22970G1 Z0.669
    N22980G1 A188.571
    N22990G1 Z0.464
    N23000G1 Z0.437 A192.000
    N23010G1 Z0.402 A195.429
    N23020G1 Z0.375 A198.857
    N23030G1 A202.286
    N23040G1 X1.365
    N23050G1 A198.857
    N23060G1 Z0.402 A195.429
    N23070G1 Z0.430 A192.000
    N23080G1 Z0.457 A188.571
    N23090G1 Z0.664
    N23100G1 A171.429
    N23110G1 Z0.458
    N23120G1 Z0.430 A168.000
    N23130G1 Z0.402 A164.571
    N23140G1 Z0.375 A161.143
    N23150G0 Z0.700
    N23160G0 X0.000 A0.000
    N23170G0 Z0.572
    N23180G1 Z0.375
    N23190G1 X0.375 Z0.344 F37.5
    N23200G1 X0.000 Z0.313
    N23210G1 X0.495
    N23220G1 X0.525 Z0.413 F50.0
    N23230G1 Z0.651
    N23240G1 X0.765
    N23250G1 Z0.393
    N23260G1 X0.795 Z0.343 F37.5
    N23270G1 X0.825 Z0.331
    N23280G1 X0.855 Z0.337
    N23290G1 X0.885 Z0.341
    N23300G1 X0.915 Z0.345
    N23310G1 X0.945 Z0.345
    N23320G1 X0.975 Z0.341
    N23330G1 X1.005 Z0.359
    N23340G1 X1.035 Z0.371 F50.0
    N23350G1 X1.065 Z0.378
    N23360G1 Z0.585
    N23370G1 X1.245
    N23380G1 Z0.379
    N23390G1 X1.275 Z0.373
    N23400G1 X1.305 Z0.364
    N23410G1 X1.335 Z0.353 F37.5
    N23420G1 X1.365 Z0.339
    N23430G1 X1.395 Z0.323
    N23440G1 X1.425 Z0.313
    N23450G1 X1.545
    N23460G1 X1.575 Z0.339
    N23470G1 X1.605 Z0.407 F50.0
    N23480G0 Z0.700
    N23490G0 X1.995
    N23500G0 Z0.591
    N23510G1 Z0.395
    N23520G1 X2.025 Z0.340 F37.5
    N23530G1 X2.055 Z0.313
    N23540G1 X2.750
    N23550G1 A360.000
    N23560G1 X2.055
    N23570G1 X2.025 Z0.340
    N23580G1 X1.995 Z0.395 F50.0
    N23590G0 Z0.700
    N23600G0 X1.605
    N23610G0 Z0.604
    N23620G1 Z0.407
    N23630G1 X1.575 Z0.339 F37.5
    N23640G1 X1.545 Z0.313
    N23650G1 X1.425
    N23660G1 X1.395 Z0.323
    N23670G1 X1.365 Z0.339
    N23680G1 X1.335 Z0.353
    N23690G1 X1.305 Z0.364 F50.0
    N23700G1 X1.275 Z0.373
    N23710G1 X1.245 Z0.379
    N23720G1 Z0.585
    N23730G1 X1.065
    N23740G1 Z0.378
    N23750G1 X1.035 Z0.371
    N23760G1 X1.005 Z0.359 F37.5
    N23770G1 X0.975 Z0.341
    N23780G1 X0.945 Z0.345
    N23790G1 X0.915 Z0.345
    N23800G1 X0.885 Z0.341
    N23810G1 X0.855 Z0.337
    N23820G1 X0.825 Z0.331
    N23830G1 X0.795 Z0.343
    N23840G1 X0.765 Z0.393 F50.0
    N23850G1 Z0.651
    N23860G1 X0.525
    N23870G1 Z0.413
    N23880G1 X0.495 Z0.313 F37.5
    N23890G1 X0.000
    N23900G1 A3.429
    N23910G1 X0.495 F50.0
    N23920G1 X0.525 Z0.413
    N23930G1 Z0.651
    N23940G1 X0.765
    N23950G1 Z0.393
    N23960G1 X0.795 Z0.343
    N23970G1 X0.825 Z0.331
    N23980G1 X0.855 Z0.337
    N23990G1 X0.885 Z0.341
    N24000G1 X0.915 Z0.345
    N24010G1 X0.945 Z0.345
    N24020G1 X0.975 Z0.340
    N24030G1 X1.005 Z0.358
    N24040G1 X1.035 Z0.370
    N24050G1 X1.065 Z0.377
    N24060G1 Z0.584
    N24070G1 X1.245
    N24080G1 Z0.378
    N24090G1 X1.275 Z0.371
    N24100G1 X1.305 Z0.363
    N24110G1 X1.335 Z0.351
    N24120G1 X1.365 Z0.337
    N24130G1 X1.395 Z0.321
    N24140G1 X1.425 Z0.313
    N24150G1 X1.545
    N24160G1 X1.575 Z0.340
    N24170G1 X1.605 Z0.408
    N24180G0 Z0.700
    N24190G0 X1.995
    N24200G0 Z0.593
    N24210G1 Z0.396
    N24220G1 X2.025 Z0.341
    N24230G1 X2.055 Z0.313
    N24240G1 X2.745
    N24250G1 A356.571
    N24260G1 X2.055
    N24270G1 X2.025 Z0.341
    N24280G1 X1.995 Z0.396
    N24290G0 Z0.700
    N24300G0 X1.605
    N24310G0 Z0.605
    N24320G1 Z0.408
    N24330G1 X1.575 Z0.340
    N24340G1 X1.545 Z0.313
    N24350G1 X1.425
    N24360G1 X1.395 Z0.321
    N24370G1 X1.365 Z0.337
    N24380G1 X1.335 Z0.351
    N24390G1 X1.305 Z0.363
    N24400G1 X1.275 Z0.371
    N24410G1 X1.245 Z0.378
    N24420G1 Z0.584
    N24430G1 X1.065
    N24440G1 Z0.377
    N24450G1 X1.035 Z0.370
    N24460G1 X1.005 Z0.358
    N24470G1 X0.975 Z0.340
    N24480G1 X0.945 Z0.345
    N24490G1 X0.915 Z0.345
    N24500G1 X0.885 Z0.341
    N24510G1 X0.855 Z0.337
    N24520G1 X0.825 Z0.331
    N24530G1 X0.795 Z0.343
    N24540G1 X0.765 Z0.393
    N24550G1 Z0.651
    N24560G1 X0.525
    N24570G1 Z0.413
    N24580G1 X0.495 Z0.313
    N24590G1 X0.015
    N24600G1 A6.857
    N24610G1 X0.495
    N24620G1 X0.525 Z0.413
    N24630G1 Z0.651
    N24640G1 X0.765
    N24650G1 Z0.393
    N24660G1 X0.795 Z0.343
    N24670G1 X0.825 Z0.331
    N24680G1 X0.855 Z0.337
    N24690G1 X0.885 Z0.341
    N24700G1 X0.915 Z0.345
    N24710G1 X0.945 Z0.345
    N24720G1 X0.975 Z0.339
    N24730G1 X1.005 Z0.356
    N24740G1 X1.035 Z0.367
    N24750G1 X1.065 Z0.374
    N24760G1 X1.095 Z0.380
    N24770G1 Z0.580
    N24780G1 X1.215
    N24790G1 Z0.379
    N24800G1 X1.245 Z0.373
    N24810G1 X1.275 Z0.367
    N24820G1 X1.305 Z0.358
    N24830G1 X1.335 Z0.346
    N24840G1 X1.365 Z0.332
    N24850G1 X1.395 Z0.316
    N24860G1 X1.425 Z0.313
    N24870G1 X1.545
    N24880G1 X1.575 Z0.343
    N24890G1 X1.605 Z0.412
    N24900G0 Z0.700
    N24910G0 X1.995
    N24920G0 Z0.596
    N24930G1 Z0.399
    N24940G1 X2.025 Z0.344
    N24950G1 X2.055 Z0.313
    N24960G1 X2.715
    N24970G1 A353.143
    N24980G1 X2.055
    N24990G1 X2.025 Z0.344
    N25000G1 X1.995 Z0.399
    N25010G0 Z0.700
    N25020G0 X1.605
    N25030G0 Z0.609
    N25040G1 Z0.412
    N25050G1 X1.575 Z0.343
    N25060G1 X1.545 Z0.313
    N25070G1 X1.425
    N25080G1 X1.395 Z0.316
    N25090G1 X1.365 Z0.332
    N25100G1 X1.335 Z0.346
    N25110G1 X1.305 Z0.358
    N25120G1 X1.275 Z0.367
    N25130G1 X1.245 Z0.373
    N25140G1 X1.215 Z0.379
    N25150G1 Z0.580
    N25160G1 X1.095
    N25170G1 Z0.380
    N25180G1 X1.065 Z0.374
    N25190G1 X1.035 Z0.367
    N25200G1 X1.005 Z0.356
    N25210G1 X0.975 Z0.339
    N25220G1 X0.945 Z0.345
    N25230G1 X0.915 Z0.345
    N25240G1 X0.885 Z0.341
    N25250G1 X0.855 Z0.337
    N25260G1 X0.825 Z0.331
    N25270G1 X0.795 Z0.343
    N25280G1 X0.765 Z0.393
    N25290G1 Z0.651
    N25300G1 X0.525
    N25310G1 Z0.413
    N25320G1 X0.495 Z0.313
    N25330G1 X0.045
    N25340G1 A10.286
    N25350G1 X0.495
    N25360G1 X0.525 Z0.413
    N25370G1 Z0.651
    N25380G1 X0.765
    N25390G1 Z0.393
    N25400G1 X0.795 Z0.343
    N25410G1 X0.825 Z0.331
    N25420G1 X0.855 Z0.337
    N25430G1 X0.885 Z0.341
    N25440G1 X0.915 Z0.345
    N25450G1 X0.945 Z0.345
    N25460G1 X0.975 Z0.339
    N25470G1 X1.005 Z0.353
    N25480G1 X1.035 Z0.364
    N25490G1 X1.065 Z0.370
    N25500G1 X1.095 Z0.376
    N25510G1 Z0.576
    N25520G1 X1.185
    N25530G1 Z0.378
    N25540G1 X1.215 Z0.374
    N25550G1 X1.245 Z0.368
    N25560G1 X1.275 Z0.362
    N25570G1 X1.305 Z0.352
    N25580G1 X1.335 Z0.341
    N25590G1 X1.365 Z0.327
    N25600G1 X1.395 Z0.313
    N25610G1 X1.545
    N25620G1 X1.575 Z0.347
    N25630G1 X1.605 Z0.416
    N25640G0 Z0.700
    N25650G0 X1.995
    N25660G0 Z0.601
    N25670G1 Z0.404
    N25680G1 X2.025 Z0.348
    N25690G1 X2.055 Z0.313
    N25700G1 X2.685
    N25710G1 A349.714
    N25720G1 X2.055
    N25730G1 X2.025 Z0.348
    N25740G1 X1.995 Z0.404
    N25750G0 Z0.700
    N25760G0 X1.605
    N25770G0 Z0.613
    N25780G1 Z0.416
    N25790G1 X1.575 Z0.347
    N25800G1 X1.545 Z0.313
    N25810G1 X1.395
    N25820G1 X1.365 Z0.327
    N25830G1 X1.335 Z0.341
    N25840G1 X1.305 Z0.352
    N25850G1 X1.275 Z0.362
    N25860G1 X1.245 Z0.368
    N25870G1 X1.215 Z0.374
    N25880G1 X1.185 Z0.378
    N25890G1 Z0.576
    N25900G1 X1.095
    N25910G1 Z0.376
    N25920G1 X1.065 Z0.370
    N25930G1 X1.035 Z0.364
    N25940G1 X1.005 Z0.353
    N25950G1 X0.975 Z0.339
    N25960G1 X0.945 Z0.345
    N25970G1 X0.915 Z0.345
    N25980G1 X0.885 Z0.341
    N25990G1 X0.855 Z0.337
    N26000G1 X0.825 Z0.331
    N26010G1 X0.795 Z0.343
    N26020G1 X0.765 Z0.393
    N26030G1 Z0.651
    N26040G1 X0.525
    N26050G1 Z0.413
    N26060G1 X0.495 Z0.313
    N26070G1 X0.075
    N26080G1 A13.714
    N26090G1 X0.495
    N26100G1 X0.525 Z0.413
    N26110G1 Z0.651
    N26120G1 X0.765
    N26130G1 Z0.393
    N26140G1 X0.795 Z0.343
    N26150G1 X0.825 Z0.331
    N26160G1 X0.855 Z0.337
    N26170G1 X0.885 Z0.341
    N26180G1 X0.915 Z0.345
    N26190G1 X0.945 Z0.345
    N26200G1 X0.975 Z0.339
    N26210G1 X1.005 Z0.349
    N26220G1 X1.035 Z0.359
    N26230G1 X1.065 Z0.366
    N26240G1 X1.095 Z0.372
    N26250G1 X1.125 Z0.374
    N26260G1 X1.155 Z0.374
    N26270G1 X1.185 Z0.373
    N26280G1 X1.215 Z0.369
    N26290G1 X1.245 Z0.362
    N26300G1 X1.275 Z0.356
    N26310G1 X1.305 Z0.346
    N26320G1 X1.335 Z0.335
    N26330G1 X1.365 Z0.321
    N26340G1 X1.395 Z0.313
    N26350G1 X1.545
    N26360G1 X1.575 Z0.348
    N26370G1 X1.605 Z0.418
    N26380G0 Z0.700
    N26390G0 X1.995
    N26400G0 Z0.601
    N26410G1 Z0.405
    N26420G1 X2.025 Z0.349
    N26430G1 X2.055 Z0.313
    N26440G1 X2.655
    N26450G1 A346.286
    N26460G1 X2.055
    N26470G1 X2.025 Z0.349
    N26480G1 X1.995 Z0.405
    N26490G0 Z0.700
    N26500G0 X1.605
    N26510G0 Z0.614
    N26520G1 Z0.417
    N26530G1 X1.575 Z0.348
    N26540G1 X1.545 Z0.313
    N26550G1 X1.395
    N26560G1 X1.365 Z0.321
    N26570G1 X1.335 Z0.335
    N26580G1 X1.305 Z0.346
    N26590G1 X1.275 Z0.356
    N26600G1 X1.245 Z0.362
    N26610G1 X1.215 Z0.369
    N26620G1 X1.185 Z0.373
    N26630G1 X1.155 Z0.374
    N26640G1 X1.125 Z0.374
    N26650G1 X1.095 Z0.372
    N26660G1 X1.065 Z0.366
    N26670G1 X1.035 Z0.359
    N26680G1 X1.005 Z0.349
    N26690G1 X0.975 Z0.339
    N26700G1 X0.945 Z0.345
    N26710G1 X0.915 Z0.345
    N26720G1 X0.885 Z0.341
    N26730G1 X0.855 Z0.337
    N26740G1 X0.825 Z0.331
    N26750G1 X0.795 Z0.343
    N26760G1 X0.765 Z0.393
    N26770G1 Z0.651
    N26780G1 X0.525
    N26790G1 Z0.413
    N26800G1 X0.495 Z0.313
    N26810G1 X0.105
    N26820G1 A17.143
    N26830G1 X0.495
    N26840G1 X0.525 Z0.413
    N26850G1 Z0.651
    N26860G1 X0.765
    N26870G1 Z0.393
    N26880G1 X0.795 Z0.343
    N26890G1 X0.825 Z0.331
    N26900G1 X0.855 Z0.337
    N26910G1 X0.885 Z0.341
    N26920G1 X0.915 Z0.345
    N26930G1 X0.945 Z0.345
    N26940G1 X0.975 Z0.339
    N26950G1 X1.005 Z0.345
    N26960G1 X1.035 Z0.354
    N26970G1 X1.065 Z0.360
    N26980G1 X1.095 Z0.366
    N26990G1 X1.125 Z0.368
    N27000G1 X1.155 Z0.368
    N27010G1 X1.185 Z0.366
    N27020G1 X1.215 Z0.362
    N27030G1 X1.245 Z0.356
    N27040G1 X1.275 Z0.349
    N27050G1 X1.305 Z0.340
    N27060G1 X1.335 Z0.328
    N27070G1 X1.365 Z0.315
    N27080G1 X1.395 Z0.313
    N27090G1 X1.545
    N27100G1 X1.575 Z0.340
    N27110G1 X1.605 Z0.405
    N27120G0 Z0.700
    N27130G0 X1.995
    N27140G0 Z0.589
    N27150G1 Z0.392
    N27160G1 X2.025 Z0.336
    N27170G1 X2.055 Z0.313
    N27180G1 X2.625
    N27190G1 A342.857
    N27200G1 X2.055
    N27210G1 X2.025 Z0.336
    N27220G1 X1.995 Z0.392
    N27230G0 Z0.700
    N27240G0 X1.605
    N27250G0 Z0.602
    N27260G1 Z0.405
    N27270G1 X1.575 Z0.340
    N27280G1 X1.545 Z0.313
    N27290G1 X1.395
    N27300G1 X1.365 Z0.315
    N27310G1 X1.335 Z0.328
    N27320G1 X1.305 Z0.340
    N27330G1 X1.275 Z0.349
    N27340G1 X1.245 Z0.356
    N27350G1 X1.215 Z0.362
    N27360G1 X1.185 Z0.366
    N27370G1 X1.155 Z0.368
    N27380G1 X1.125 Z0.368
    N27390G1 X1.095 Z0.366
    N27400G1 X1.065 Z0.360
    N27410G1 X1.035 Z0.354
    N27420G1 X1.005 Z0.345
    N27430G1 X0.975 Z0.339
    N27440G1 X0.945 Z0.345
    N27450G1 X0.915 Z0.345
    N27460G1 X0.885 Z0.341
    N27470G1 X0.855 Z0.337
    N27480G1 X0.825 Z0.331
    N27490G1 X0.795 Z0.343
    N27500G1 X0.765 Z0.393
    N27510G1 Z0.651
    N27520G1 X0.525
    N27530G1 Z0.413
    N27540G1 X0.495 Z0.313
    N27550G1 X0.135
    N27560G1 A20.571
    N27570G1 X0.495
    N27580G1 X0.525 Z0.413
    N27590G1 Z0.651
    N27600G1 X0.765
    N27610G1 Z0.393
    N27620G1 X0.795 Z0.343
    N27630G1 X0.825 Z0.331
    N27640G1 X0.855 Z0.337
    N27650G1 X0.885 Z0.341
    N27660G1 X0.915 Z0.345
    N27670G1 X0.945 Z0.345
    N27680G1 X0.975 Z0.339
    N27690G1 X1.005 Z0.339
    N27700G1 X1.035 Z0.348
    N27710G1 X1.065 Z0.354
    N27720G1 X1.095 Z0.359
    N27730G1 X1.125 Z0.361
    N27740G1 X1.155 Z0.361
    N27750G1 X1.185 Z0.360
    N27760G1 X1.215 Z0.356
    N27770G1 X1.245 Z0.350
    N27780G1 X1.275 Z0.343
    N27790G1 X1.305 Z0.334
    N27800G1 X1.335 Z0.322
    N27810G1 X1.365 Z0.313
    N27820G1 X1.545
    N27830G1 X1.575 Z0.334
    N27840G1 X1.605 Z0.374
    N27850G1 X1.635 Z0.403
    N27860G0 Z0.700
    N27870G0 X1.965
    N27880G0 Z0.600
    N27890G1 Z0.403
    N27900G1 X1.995 Z0.375
    N27910G1 X2.025 Z0.333
    N27920G1 X2.055 Z0.313
    N27930G1 X2.595
    N27940G1 A339.429
    N27950G1 X2.055
    N27960G1 X2.025 Z0.333
    N27970G1 X1.995 Z0.375
    N27980G1 X1.965 Z0.403
    N27990G0 Z0.700
    N28000G0 X1.635
    N28010G0 Z0.599
    N28020G1 Z0.402
    N28030G1 X1.605 Z0.372
    N28040G1 X1.575 Z0.334
    N28050G1 X1.545 Z0.313
    N28060G1 X1.365
    N28070G1 X1.335 Z0.322
    N28080G1 X1.305 Z0.334
    N28090G1 X1.275 Z0.343
    N28100G1 X1.245 Z0.350
    N28110G1 X1.215 Z0.356
    N28120G1 X1.185 Z0.360
    N28130G1 X1.155 Z0.361
    N28140G1 X1.125 Z0.361
    N28150G1 X1.095 Z0.359
    N28160G1 X1.065 Z0.354
    N28170G1 X1.035 Z0.348
    N28180G1 X1.005 Z0.339
    N28190G1 X0.975 Z0.339
    N28200G1 X0.945 Z0.345
    N28210G1 X0.915 Z0.345
    N28220G1 X0.885 Z0.341
    N28230G1 X0.855 Z0.337
    N28240G1 X0.825 Z0.331
    N28250G1 X0.795 Z0.343
    N28260G1 X0.765 Z0.393
    N28270G1 Z0.651
    N28280G1 X0.525
    N28290G1 Z0.413
    N28300G1 X0.495 Z0.313
    N28310G1 X0.165
    N28320G1 A24.000
    N28330G1 X0.495
    N28340G1 X0.525 Z0.413
    N28350G1 Z0.651
    N28360G1 X0.765
    N28370G1 Z0.393
    N28380G1 X0.795 Z0.343
    N28390G1 X0.825 Z0.331
    N28400G1 X0.855 Z0.337
    N28410G1 X0.885 Z0.341
    N28420G1 X0.915 Z0.345
    N28430G1 X0.945 Z0.345
    N28440G1 X0.975 Z0.339
    N28450G1 X1.005 Z0.333
    N28460G1 X1.035 Z0.341
    N28470G1 X1.065 Z0.348
    N28480G1 X1.095 Z0.353
    N28490G1 X1.125 Z0.355
    N28500G1 X1.155 Z0.355
    N28510G1 X1.185 Z0.353
    N28520G1 X1.215 Z0.349
    N28530G1 X1.245 Z0.343
    N28540G1 X1.275 Z0.336
    N28550G1 X1.305 Z0.327
    N28560G1 X1.335 Z0.316
    N28570G1 X1.365 Z0.313
    N28580G1 X1.545
    N28590G1 X1.575 F37.5
    N28600G1 X1.605 Z0.331
    N28610G1 X1.635 Z0.393
    N28620G0 Z0.700
    N28630G0 X1.965
    N28640G0 Z0.579
    N28650G1 Z0.382 F50.0
    N28660G1 X1.995 Z0.331 F37.5
    N28670G1 X2.025 Z0.313
    N28680G1 X2.055
    N28690G1 X2.565 F50.0
    N28700G1 A336.000
    N28710G1 X2.055
    N28720G1 X2.025 F37.5
    N28730G1 X1.995 Z0.331
    N28740G1 X1.965 Z0.382
    N28750G0 Z0.700
    N28760G0 X1.635
    N28770G0 Z0.590
    N28780G1 Z0.393 F50.0
    N28790G1 X1.605 Z0.331 F37.5
    N28800G1 X1.575 Z0.313
    N28810G1 X1.545
    N28820G1 X1.365 F50.0
    N28830G1 X1.335 Z0.316
    N28840G1 X1.305 Z0.327
    N28850G1 X1.275 Z0.336
    N28860G1 X1.245 Z0.343
    N28870G1 X1.215 Z0.349
    N28880G1 X1.185 Z0.353
    N28890G1 X1.155 Z0.355
    N28900G1 X1.125 Z0.355
    N28910G1 X1.095 Z0.353
    N28920G1 X1.065 Z0.348
    N28930G1 X1.035 Z0.341
    N28940G1 X1.005 Z0.333
    N28950G1 X0.975 Z0.339
    N28960G1 X0.945 Z0.345
    N28970G1 X0.915 Z0.345
    N28980G1 X0.885 Z0.341
    N28990G1 X0.855 Z0.337
    N29000G1 X0.825 Z0.331
    N29010G1 X0.795 Z0.343
    N29020G1 X0.765 Z0.393
    N29030G1 Z0.651
    N29040G1 X0.525
    N29050G1 Z0.413
    N29060G1 X0.495 Z0.313
    N29070G1 X0.195
    N29080G1 A27.429
    N29090G1 X0.495
    N29100G1 X0.525 Z0.413
    N29110G1 Z0.651
    N29120G1 X0.765
    N29130G1 Z0.393
    N29140G1 X0.795 Z0.343
    N29150G1 X0.825 Z0.331
    N29160G1 X0.855 Z0.337
    N29170G1 X0.885 Z0.341
    N29180G1 X0.915 Z0.345
    N29190G1 X0.945 Z0.345
    N29200G1 X0.975 Z0.339
    N29210G1 X1.005 Z0.327
    N29220G1 X1.035 Z0.335
    N29230G1 X1.065 Z0.342
    N29240G1 X1.095 Z0.346
    N29250G1 X1.125 Z0.348
    N29260G1 X1.155 Z0.348
    N29270G1 X1.185 Z0.346
    N29280G1 X1.215 Z0.342
    N29290G1 X1.245 Z0.335
    N29300G1 X1.275 Z0.328
    N29310G1 X1.305 Z0.320
    N29320G1 X1.335 Z0.313
    N29330G1 X1.575
    N29340G1 X1.605 F37.5
    N29350G1 X1.635 Z0.322
    N29360G1 X1.935 Z0.322
    N29370G1 X1.965 Z0.321
    N29380G1 X1.995 Z0.313
    N29390G1 X2.025
    N29400G1 X2.535 F50.0
    N29410G1 A332.571
    N29420G1 X2.025
    N29430G1 X1.995 F37.5
    N29440G1 X1.965 Z0.321
    N29450G1 X1.935 Z0.322
    N29460G1 X1.635 Z0.322
    N29470G1 X1.605 Z0.313
    N29480G1 X1.575
    N29490G1 X1.335 F50.0
    N29500G1 X1.305 Z0.320
    N29510G1 X1.275 Z0.328
    N29520G1 X1.245 Z0.335
    N29530G1 X1.215 Z0.342
    N29540G1 X1.185 Z0.346
    N29550G1 X1.155 Z0.348
    N29560G1 X1.125 Z0.348
    N29570G1 X1.095 Z0.346
    N29580G1 X1.065 Z0.342
    N29590G1 X1.035 Z0.335
    N29600G1 X1.005 Z0.327
    N29610G1 X0.975 Z0.339
    N29620G1 X0.945 Z0.345
    N29630G1 X0.915 Z0.345
    N29640G1 X0.885 Z0.341
    N29650G1 X0.855 Z0.337
    N29660G1 X0.825 Z0.331
    N29670G1 X0.795 Z0.343
    N29680G1 X0.765 Z0.393
    N29690G1 Z0.651
    N29700G1 X0.525
    N29710G1 Z0.413
    N29720G1 X0.495 Z0.313
    N29730G1 X0.225
    N29740G1 A30.857
    N29750G1 X0.495
    N29760G1 X0.525 Z0.413
    N29770G1 Z0.651
    N29780G1 X0.765
    N29790G1 Z0.393
    N29800G1 X0.795 Z0.343
    N29810G1 X0.825 Z0.331
    N29820G1 X0.855 Z0.337
    N29830G1 X0.885 Z0.341
    N29840G1 X0.915 Z0.345
    N29850G1 X0.945 Z0.345
    N29860G1 X0.975 Z0.339
    N29870G1 X1.005 Z0.321
    N29880G1 X1.035 Z0.328
    N29890G1 X1.065 Z0.335
    N29900G1 X1.095 Z0.339
    N29910G1 X1.125 Z0.340
    N29920G1 X1.155 Z0.340
    N29930G1 X1.185 Z0.338
    N29940G1 X1.215 Z0.334
    N29950G1 X1.245 Z0.327
    N29960G1 X1.275 Z0.320
    N29970G1 X1.305 Z0.313
    N29980G1 X2.505
    N29990G1 A329.143
    N30000G1 X1.305
    N30010G1 X1.275 Z0.320
    N30020G1 X1.245 Z0.327
    N30030G1 X1.215 Z0.334
    N30040G1 X1.185 Z0.338
    N30050G1 X1.155 Z0.340
    N30060G1 X1.125 Z0.340
    N30070G1 X1.095 Z0.339
    N30080G1 X1.065 Z0.335
    N30090G1 X1.035 Z0.328
    N30100G1 X1.005 Z0.321
    N30110G1 X0.975 Z0.339
    N30120G1 X0.945 Z0.345
    N30130G1 X0.915 Z0.345
    N30140G1 X0.885 Z0.341
    N30150G1 X0.855 Z0.337
    N30160G1 X0.825 Z0.331
    N30170G1 X0.795 Z0.343
    N30180G1 X0.765 Z0.393
    N30190G1 Z0.651
    N30200G1 X0.525
    N30210G1 Z0.413
    N30220G1 X0.495 Z0.313
    N30230G1 X0.255
    N30240G1 A34.286
    N30250G1 X0.495
    N30260G1 X0.525 Z0.413
    N30270G1 Z0.651
    N30280G1 X0.765
    N30290G1 Z0.393
    N30300G1 X0.795 Z0.343
    N30310G1 X0.825 Z0.331
    N30320G1 X0.855 Z0.337
    N30330G1 X0.885 Z0.341
    N30340G1 X0.915 Z0.345
    N30350G1 X0.945 Z0.345
    N30360G1 X0.975 Z0.339
    N30370G1 X1.005 Z0.315
    N30380G1 X1.035 Z0.321
    N30390G1 X1.065 Z0.328
    N30400G1 X1.095 Z0.331
    N30410G1 X1.125 Z0.332
    N30420G1 X1.155 Z0.332
    N30430G1 X1.185 Z0.330
    N30440G1 X1.215 Z0.326
    N30450G1 X1.245 Z0.319
    N30460G1 X1.275 Z0.313
    N30470G1 X2.475
    N30480G1 A325.714
    N30490G1 X1.275
    N30500G1 X1.245 Z0.319
    N30510G1 X1.215 Z0.326
    N30520G1 X1.185 Z0.330
    N30530G1 X1.155 Z0.332
    N30540G1 X1.125 Z0.332
    N30550G1 X1.095 Z0.331
    N30560G1 X1.065 Z0.328
    N30570G1 X1.035 Z0.321
    N30580G1 X1.005 Z0.315
    N30590G1 X0.975 Z0.339
    N30600G1 X0.945 Z0.345
    N30610G1 X0.915 Z0.345
    N30620G1 X0.885 Z0.341
    N30630G1 X0.855 Z0.337
    N30640G1 X0.825 Z0.331
    N30650G1 X0.795 Z0.343
    N30660G1 X0.765 Z0.393
    N30670G1 Z0.651
    N30680G1 X0.525
    N30690G1 Z0.413
    N30700G1 X0.495 Z0.313
    N30710G1 X0.285
    N30720G1 A37.714
    N30730G1 X0.495
    N30740G1 X0.525 Z0.413
    N30750G1 Z0.651
    N30760G1 X0.765
    N30770G1 Z0.393
    N30780G1 X0.795 Z0.343
    N30790G1 X0.825 Z0.331
    N30800G1 X0.855 Z0.337
    N30810G1 X0.885 Z0.341
    N30820G1 X0.915 Z0.345
    N30830G1 X0.945 Z0.345
    N30840G1 X0.975 Z0.339
    N30850G1 X1.005 Z0.315
    N30860G1 X1.035 Z0.314
    N30870G1 X1.065 Z0.320
    N30880G1 X1.095 Z0.323
    N30890G1 X1.125 Z0.324
    N30900G1 X1.155 Z0.323
    N30910G1 X1.185 Z0.321
    N30920G1 X1.215 Z0.317
    N30930G1 X1.245 Z0.313
    N30940G1 X2.445
    N30950G1 A322.286
    N30960G1 X1.245
    N30970G1 X1.215 Z0.317
    N30980G1 X1.185 Z0.321
    N30990G1 X1.155 Z0.323
    N31000G1 X1.125 Z0.324
    N31010G1 X1.095 Z0.323
    N31020G1 X1.065 Z0.320
    N31030G1 X1.035 Z0.314
    N31040G1 X1.005 Z0.315
    N31050G1 X0.975 Z0.339
    N31060G1 X0.945 Z0.345
    N31070G1 X0.915 Z0.345
    N31080G1 X0.885 Z0.341
    N31090G1 X0.855 Z0.337
    N31100G1 X0.825 Z0.331
    N31110G1 X0.795 Z0.343
    N31120G1 X0.765 Z0.393
    N31130G1 Z0.651
    N31140G1 X0.525
    N31150G1 Z0.413
    N31160G1 X0.495 Z0.313
    N31170G1 X0.315
    N31180G1 A41.143
    N31190G1 X0.495
    N31200G1 X0.525 Z0.413
    N31210G1 Z0.651
    N31220G1 X0.765
    N31230G1 Z0.393
    N31240G1 X0.795 Z0.343
    N31250G1 X0.825 Z0.331
    N31260G1 X0.855 Z0.337
    N31270G1 X0.885 Z0.341
    N31280G1 X0.915 Z0.345
    N31290G1 X0.945 Z0.345
    N31300G1 X0.975 Z0.339
    N31310G1 X1.005 Z0.315
    N31320G1 X1.035 Z0.313
    N31330G1 X1.065 Z0.313
    N31340G1 X1.095 Z0.316
    N31350G1 X1.155 Z0.316
    N31360G1 X1.185 Z0.313
    N31370G1 X2.415 Z0.313
    N31380G1 A318.857
    N31390G1 X1.185 Z0.313
    N31400G1 X1.155 Z0.316
    N31410G1 X1.095 Z0.316
    N31420G1 X1.065 Z0.313
    N31430G1 X1.035 Z0.313
    N31440G1 X1.005 Z0.315
    N31450G1 X0.975 Z0.339
    N31460G1 X0.945 Z0.345
    N31470G1 X0.915 Z0.345
    N31480G1 X0.885 Z0.341
    N31490G1 X0.855 Z0.337
    N31500G1 X0.825 Z0.331
    N31510G1 X0.795 Z0.343
    N31520G1 X0.765 Z0.393
    N31530G1 Z0.651
    N31540G1 X0.525
    N31550G1 Z0.413
    N31560G1 X0.495 Z0.313
    N31570G1 X0.345
    N31580G1 A44.571
    N31590G1 X0.495
    N31600G1 X0.525 Z0.413
    N31610G1 Z0.651
    N31620G1 X0.765
    N31630G1 Z0.393
    N31640G1 X0.795 Z0.343
    N31650G1 X0.825 Z0.331
    N31660G1 X0.855 Z0.337
    N31670G1 X0.885 Z0.341
    N31680G1 X0.915 Z0.345
    N31690G1 X0.945 Z0.345
    N31700G1 X0.975 Z0.339
    N31710G1 X1.005 Z0.315
    N31720G1 X1.035 Z0.313
    N31730G1 X2.385
    N31740G1 A315.429
    N31750G1 X1.035
    N31760G1 X1.005 Z0.315
    N31770G1 X0.975 Z0.339
    N31780G1 X0.945 Z0.345
    N31790G1 X0.915 Z0.345
    N31800G1 X0.885 Z0.341
    N31810G1 X0.855 Z0.337
    N31820G1 X0.825 Z0.331
    N31830G1 X0.795 Z0.343
    N31840G1 X0.765 Z0.393
    N31850G1 Z0.651
    N31860G1 X0.525
    N31870G1 Z0.413
    N31880G1 X0.495 Z0.313
    N31890G1 X0.375
    N31900G1 A48.000
    N31910G1 X0.495
    N31920G1 X0.525 Z0.413
    N31930G1 Z0.651
    N31940G1 X0.765
    N31950G1 Z0.393
    N31960G1 X0.795 Z0.343
    N31970G1 X0.825 Z0.331
    N31980G1 X0.855 Z0.337
    N31990G1 X0.885 Z0.341
    N32000G1 X0.915 Z0.345
    N32010G1 X0.945 Z0.345
    N32020G1 X0.975 Z0.339
    N32030G1 X1.005 Z0.315
    N32040G1 X1.035 Z0.313
    N32050G1 X2.355
    N32060G1 A312.000
    N32070G1 X1.035
    N32080G1 X1.005 Z0.315
    N32090G1 X0.975 Z0.339
    N32100G1 X0.945 Z0.345
    N32110G1 X0.915 Z0.345
    N32120G1 X0.885 Z0.341
    N32130G1 X0.855 Z0.337
    N32140G1 X0.825 Z0.331
    N32150G1 X0.795 Z0.343
    N32160G1 X0.765 Z0.393
    N32170G1 Z0.651
    N32180G1 X0.525
    N32190G1 Z0.413
    N32200G1 X0.495 Z0.313
    N32210G1 X0.405
    N32220G1 A51.429
    N32230G1 X0.495
    N32240G1 X0.525 Z0.413
    N32250G1 Z0.651
    N32260G1 X0.765
    N32270G1 Z0.393
    N32280G1 X0.795 Z0.343
    N32290G1 X0.825 Z0.331
    N32300G1 X0.855 Z0.337
    N32310G1 X0.885 Z0.341
    N32320G1 X0.915 Z0.345
    N32330G1 X0.945 Z0.345
    N32340G1 X0.975 Z0.339
    N32350G1 X1.005 Z0.315
    N32360G1 X1.035 Z0.313
    N32370G1 X2.325
    N32380G1 A308.571
    N32390G1 X1.035
    N32400G1 X1.005 Z0.315
    N32410G1 X0.975 Z0.339
    N32420G1 X0.945 Z0.345
    N32430G1 X0.915 Z0.345
    N32440G1 X0.885 Z0.341
    N32450G1 X0.855 Z0.337
    N32460G1 X0.825 Z0.331
    N32470G1 X0.795 Z0.343
    N32480G1 X0.765 Z0.393
    N32490G1 Z0.651
    N32500G1 X0.525
    N32510G1 Z0.413
    N32520G1 X0.495 Z0.313
    N32530G1 X0.435
    N32540G1 A54.857
    N32550G1 X0.495
    N32560G1 X0.525 Z0.413
    N32570G1 Z0.651
    N32580G1 X0.765
    N32590G1 Z0.393
    N32600G1 X0.795 Z0.343
    N32610G1 X0.825 Z0.331
    N32620G1 X0.855 Z0.337
    N32630G1 X0.885 Z0.341
    N32640G1 X0.915 Z0.345
    N32650G1 X0.945 Z0.345
    N32660G1 X0.975 Z0.339
    N32670G1 X1.005 Z0.315
    N32680G1 X1.035 Z0.313
    N32690G1 X2.295
    N32700G1 A305.143
    N32710G1 X1.035
    N32720G1 X1.005 Z0.315
    N32730G1 X0.975 Z0.339
    N32740G1 X0.945 Z0.345
    N32750G1 X0.915 Z0.345
    N32760G1 X0.885 Z0.341
    N32770G1 X0.855 Z0.337
    N32780G1 X0.825 Z0.331
    N32790G1 X0.795 Z0.343
    N32800G1 X0.765 Z0.393
    N32810G1 Z0.651
    N32820G1 X0.525
    N32830G1 Z0.413
    N32840G1 X0.495 Z0.313
    N32850G1 X0.465
    N32860G1 A58.286
    N32870G1 X0.495
    N32880G1 X0.525 Z0.413
    N32890G1 Z0.651
    N32900G1 X0.765
    N32910G1 Z0.393
    N32920G1 X0.795 Z0.343
    N32930G1 X0.825 Z0.331
    N32940G1 X0.855 Z0.337
    N32950G1 X0.885 Z0.341
    N32960G1 X0.915 Z0.345
    N32970G1 X0.945 Z0.345
    N32980G1 X0.975 Z0.339
    N32990G1 X1.005 Z0.315
    N33000G1 X1.035 Z0.313
    N33010G1 X2.265
    N33020G1 A301.714
    N33030G1 X1.035
    N33040G1 X1.005 Z0.315
    N33050G1 X0.975 Z0.339
    N33060G1 X0.945 Z0.345
    N33070G1 X0.915 Z0.345
    N33080G1 X0.885 Z0.341
    N33090G1 X0.855 Z0.337
    N33100G1 X0.825 Z0.331
    N33110G1 X0.795 Z0.343
    N33120G1 X0.765 Z0.393
    N33130G1 Z0.651
    N33140G1 X0.525
    N33150G1 Z0.413
    N33160G1 X0.495 Z0.313
    N33170G1 A298.286 F37.5
    N33180G1 A61.714 F50.0
    N33190G1 X0.525 Z0.413
    N33200G1 Z0.651
    N33210G1 X0.765
    N33220G1 Z0.393
    N33230G1 X0.795 Z0.343
    N33240G1 X0.825 Z0.331
    N33250G1 X0.855 Z0.337
    N33260G1 X0.885 Z0.341
    N33270G1 X0.915 Z0.345
    N33280G1 X0.945 Z0.345
    N33290G1 X0.975 Z0.339
    N33300G1 X1.005 Z0.315
    N33310G1 X1.035 Z0.313
    N33320G1 X2.235
    N33330G1 A298.286
    N33340G1 X1.035
    N33350G1 X1.005 Z0.315
    N33360G1 X0.975 Z0.339
    N33370G1 X0.945 Z0.345
    N33380G1 X0.915 Z0.345
    N33390G1 X0.885 Z0.341
    N33400G1 X0.855 Z0.337
    N33410G1 X0.825 Z0.331
    N33420G1 X0.795 Z0.343
    N33430G1 X0.765 Z0.393
    N33440G0 Z0.700
    N33450G0 A65.143
    N33460G0 Z0.590
    N33470G1 Z0.393
    N33480G1 X0.795 Z0.343
    N33490G1 X0.825 Z0.331
    N33500G1 X0.855 Z0.337
    N33510G1 X0.885 Z0.341
    N33520G1 X0.915 Z0.345
    N33530G1 X0.945 Z0.345
    N33540G1 X0.975 Z0.339
    N33550G1 X1.005 Z0.315
    N33560G1 X1.035 Z0.313
    N33570G1 X2.205
    N33580G1 A294.857
    N33590G1 X1.035
    N33600G1 X1.005 Z0.315
    N33610G1 X0.975 Z0.339
    N33620G1 X0.945 Z0.345
    N33630G1 X0.915 Z0.345
    N33640G1 X0.885 Z0.341
    N33650G1 X0.855 Z0.337
    N33660G1 X0.825 Z0.331
    N33670G1 X0.795 Z0.343
    N33680G1 X0.765 Z0.393
    N33690G0 Z0.700
    N33700G0 A68.571
    N33710G0 Z0.590
    N33720G1 Z0.393
    N33730G1 X0.795 Z0.343
    N33740G1 X0.825 Z0.331
    N33750G1 X0.855 Z0.337
    N33760G1 X0.885 Z0.341
    N33770G1 X0.915 Z0.345
    N33780G1 X0.945 Z0.345
    N33790G1 X0.975 Z0.339
    N33800G1 X1.005 Z0.315
    N33810G1 X1.035 Z0.313
    N33820G1 X2.175
    N33830G1 A164.571
    N33840G1 Z0.329 A168.000
    N33850G1 Z0.334 A171.429
    N33860G1 Z0.347 A174.857
    N33870G1 Z0.347 A185.143
    N33880G1 Z0.334 A188.571
    N33890G1 Z0.329 A192.000
    N33900G1 Z0.313 A195.429
    N33910G1 A291.429
    N33920G1 X1.035
    N33930G1 X1.005 Z0.315
    N33940G1 X0.975 Z0.339
    N33950G1 X0.945 Z0.345
    N33960G1 X0.915 Z0.345
    N33970G1 X0.885 Z0.341
    N33980G1 X0.855 Z0.337
    N33990G1 X0.825 Z0.331
    N34000G1 X0.795 Z0.343
    N34010G1 X0.765 Z0.393
    N34020G0 Z0.700
    N34030G0 A72.000
    N34040G0 Z0.590
    N34050G1 Z0.393
    N34060G1 X0.795 Z0.343
    N34070G1 X0.825 Z0.331
    N34080G1 X0.855 Z0.337
    N34090G1 X0.885 Z0.341
    N34100G1 X0.915 Z0.345
    N34110G1 X0.945 Z0.345
    N34120G1 X0.975 Z0.339
    N34130G1 X1.005 Z0.315
    N34140G1 X1.035 Z0.313
    N34150G1 X2.145
    N34160G1 A161.143
    N34170G1 Z0.328 A164.571
    N34180G1 Z0.357 A168.000
    N34190G1 Z0.362 A171.429
    N34200G1 Z0.371 A174.857
    N34210G1 Z0.371 A185.143
    N34220G1 Z0.362 A188.571
    N34230G1 Z0.357 A192.000
    N34240G1 Z0.328 A195.429
    N34250G1 Z0.313 A198.857
    N34260G1 A288.000
    N34270G1 X1.035
    N34280G1 X1.005 Z0.315
    N34290G1 X0.975 Z0.339
    N34300G1 X0.945 Z0.345
    N34310G1 X0.915 Z0.345
    N34320G1 X0.885 Z0.341
    N34330G1 X0.855 Z0.337
    N34340G1 X0.825 Z0.331
    N34350G1 X0.795 Z0.343
    N34360G1 X0.765 Z0.393
    N34370G0 Z0.700
    N34380G0 A75.429
    N34390G0 Z0.590
    N34400G1 Z0.393
    N34410G1 X0.795 Z0.343
    N34420G1 X0.825 Z0.331
    N34430G1 X0.855 Z0.337
    N34440G1 X0.885 Z0.341
    N34450G1 X0.915 Z0.345
    N34460G1 X0.945 Z0.345
    N34470G1 X0.975 Z0.339
    N34480G1 X1.005 Z0.315
    N34490G1 X1.035 Z0.313
    N34500G1 X2.115
    N34510G1 A144.000
    N34520G1 Z0.317 A147.429
    N34530G1 Z0.322 A150.857
    N34540G1 Z0.330 A154.286
    N34550G1 Z0.331 A157.714
    N34560G1 Z0.329 A161.143
    N34570G1 Z0.339 A164.571
    N34580G1 Z0.367 A168.000
    N34590G1 Z0.374 A171.429
    N34600G1 Z0.387 A174.857
    N34610G1 Z0.584
    N34620G1 A185.143
    N34630G1 Z0.387
    N34640G1 Z0.374 A188.571
    N34650G1 Z0.367 A192.000
    N34660G1 Z0.339 A195.429
    N34670G1 Z0.329 A198.857
    N34680G1 Z0.331 A202.286
    N34690G1 Z0.330 A205.714
    N34700G1 Z0.322 A209.143
    N34710G1 Z0.317 A212.571
    N34720G1 Z0.313 A216.000
    N34730G1 A284.571
    N34740G1 X1.035
    N34750G1 X1.005 Z0.315
    N34760G1 X0.975 Z0.339
    N34770G1 X0.945 Z0.345
    N34780G1 X0.915 Z0.345
    N34790G1 X0.885 Z0.341
    N34800G1 X0.855 Z0.337
    N34810G1 X0.825 Z0.331
    N34820G1 X0.795 Z0.343
    N34830G1 X0.765 Z0.393
    N34840G0 Z0.700
    N34850G0 A78.857
    N34860G0 Z0.590
    N34870G1 Z0.393
    N34880G1 X0.795 Z0.343
    N34890G1 X0.825 Z0.331
    N34900G1 X0.855 Z0.337
    N34910G1 X0.885 Z0.341
    N34920G1 X0.915 Z0.345
    N34930G1 X0.945 Z0.345
    N34940G1 X0.975 Z0.339
    N34950G1 X1.005 Z0.315
    N34960G1 X1.035 Z0.313
    N34970G1 X2.085
    N34980G1 A144.000
    N34990G1 Z0.324 A147.429
    N35000G1 Z0.329 A150.857
    N35010G1 Z0.337 A154.286
    N35020G1 Z0.337 A157.714
    N35030G1 Z0.335 A161.143
    N35040G1 Z0.363 A164.571
    N35050G1 Z0.374 A168.000
    N35060G1 Z0.402 A171.429
    N35070G1 Z0.608
    N35080G1 A188.571
    N35090G1 Z0.402
    N35100G1 Z0.374 A192.000
    N35110G1 Z0.363 A195.429
    N35120G1 Z0.335 A198.857
    N35130G1 Z0.337 A202.286
    N35140G1 Z0.337 A205.714
    N35150G1 Z0.329 A209.143
    N35160G1 Z0.324 A212.571
    N35170G1 Z0.313 A216.000
    N35180G1 A281.143
    N35190G1 X1.035
    N35200G1 X1.005 Z0.315
    N35210G1 X0.975 Z0.339
    N35220G1 X0.945 Z0.345
    N35230G1 X0.915 Z0.345
    N35240G1 X0.885 Z0.341
    N35250G1 X0.855 Z0.337
    N35260G1 X0.825 Z0.331
    N35270G1 X0.795 Z0.343
    N35280G1 X0.765 Z0.393
    N35290G0 Z0.700
    N35300G0 A82.286
    N35310G0 Z0.590
    N35320G1 Z0.393
    N35330G1 X0.795 Z0.343
    N35340G1 X0.825 Z0.331
    N35350G1 X0.855 Z0.337
    N35360G1 X0.885 Z0.341
    N35370G1 X0.915 Z0.345
    N35380G1 X0.945 Z0.345
    N35390G1 X0.975 Z0.339
    N35400G1 X1.005 Z0.315
    N35410G1 X1.035 Z0.313
    N35420G1 X2.055
    N35430G1 Z0.313 A144.000
    N35440G1 Z0.326 A147.429
    N35450G1 Z0.333 A150.857
    N35460G1 Z0.340 A154.286
    N35470G1 Z0.341 A157.714
    N35480G1 Z0.339 A161.143
    N35490G1 Z0.374 A164.571
    N35500G1 Z0.397 A168.000
    N35510G1 Z0.618
    N35520G1 A192.000
    N35530G1 Z0.397
    N35540G1 Z0.374 A195.429
    N35550G1 Z0.339 A198.857
    N35560G1 Z0.341 A202.286
    N35570G1 Z0.340 A205.714
    N35580G1 Z0.333 A209.143
    N35590G1 Z0.326 A212.571
    N35600G1 Z0.313 A216.000
    N35610G1 Z0.313 A277.714
    N35620G1 X1.035
    N35630G1 X1.005 Z0.315
    N35640G1 X0.975 Z0.339
    N35650G1 X0.945 Z0.345
    N35660G1 X0.915 Z0.345
    N35670G1 X0.885 Z0.341
    N35680G1 X0.855 Z0.337
    N35690G1 X0.825 Z0.331
    N35700G1 X0.795 Z0.343
    N35710G1 X0.765 Z0.393
    N35720G0 Z0.700
    N35730G0 A85.714
    N35740G0 Z0.590
    N35750G1 Z0.393
    N35760G1 X0.795 Z0.343
    N35770G1 X0.825 Z0.331
    N35780G1 X0.855 Z0.337
    N35790G1 X0.885 Z0.341
    N35800G1 X0.915 Z0.345
    N35810G1 X0.945 Z0.345
    N35820G1 X0.975 Z0.339
    N35830G1 X1.005 Z0.315
    N35840G1 X1.035 Z0.313
    N35850G1 X2.025
    N35860G1 Z0.313 A144.000
    N35870G1 Z0.326 A147.429
    N35880G1 Z0.332 A150.857
    N35890G1 Z0.339 A154.286
    N35900G1 Z0.340 A157.714
    N35910G1 Z0.337 A161.143
    N35920G1 Z0.384 A164.571
    N35930G1 Z0.625
    N35940G1 A195.429
    N35950G1 Z0.384
    N35960G1 Z0.337 A198.857
    N35970G1 Z0.340 A202.286
    N35980G1 Z0.339 A205.714
    N35990G1 Z0.332 A209.143
    N36000G1 Z0.326 A212.571
    N36010G1 Z0.313 A216.000
    N36020G1 Z0.313 A274.286
    N36030G1 X1.035
    N36040G1 X1.005 Z0.315
    N36050G1 X0.975 Z0.339
    N36060G1 X0.945 Z0.345
    N36070G1 X0.915 Z0.345
    N36080G1 X0.885 Z0.341
    N36090G1 X0.855 Z0.337
    N36100G1 X0.825 Z0.331
    N36110G1 X0.795 Z0.343
    N36120G1 X0.765 Z0.393
    N36130G0 Z0.700
    N36140G0 A89.143
    N36150G0 Z0.590
    N36160G1 Z0.393
    N36170G1 X0.795 Z0.343
    N36180G1 X0.825 Z0.331
    N36190G1 X0.855 Z0.337
    N36200G1 X0.885 Z0.341
    N36210G1 X0.915 Z0.345
    N36220G1 X0.945 Z0.345
    N36230G1 X0.975 Z0.339
    N36240G1 X1.005 Z0.315
    N36250G1 X1.035 Z0.313
    N36260G1 X1.995
    N36270G1 Z0.313 A144.000
    N36280G1 Z0.323 A147.429
    N36290G1 Z0.327 A150.857
    N36300G1 Z0.333 A154.286
    N36310G1 Z0.334 A157.714
    N36320G1 Z0.331 A161.143
    N36330G1 Z0.388 A164.571
    N36340G1 Z0.636
    N36350G1 A195.429
    N36360G1 Z0.388
    N36370G1 Z0.331 A198.857
    N36380G1 Z0.334 A202.286
    N36390G1 Z0.333 A205.714
    N36400G1 Z0.327 A209.143
    N36410G1 Z0.323 A212.571
    N36420G1 Z0.313 A216.000
    N36430G1 Z0.313 A270.857
    N36440G1 X1.035
    N36450G1 X1.005 Z0.315
    N36460G1 X0.975 Z0.339
    N36470G1 X0.945 Z0.345
    N36480G1 X0.915 Z0.345
    N36490G1 X0.885 Z0.341
    N36500G1 X0.855 Z0.337
    N36510G1 X0.825 Z0.331
    N36520G1 X0.795 Z0.343
    N36530G1 X0.765 Z0.393
    N36540G0 Z0.700
    N36550G0 A92.571
    N36560G0 Z0.590
    N36570G1 Z0.393
    N36580G1 X0.795 Z0.343
    N36590G1 X0.825 Z0.331
    N36600G1 X0.855 Z0.337
    N36610G1 X0.885 Z0.341
    N36620G1 X0.915 Z0.345
    N36630G1 X0.945 Z0.345
    N36640G1 X0.975 Z0.339
    N36650G1 X1.005 Z0.315
    N36660G1 X1.035 Z0.313
    N36670G1 X1.965
    N36680G1 A144.000
    N36690G1 Z0.317 A147.429
    N36700G1 Z0.321 A150.857
    N36710G1 Z0.326 A154.286
    N36720G1 Z0.326 A157.714
    N36730G1 Z0.324 A161.143
    N36740G1 Z0.389 A164.571
    N36750G1 Z0.659
    N36760G1 A195.429
    N36770G1 Z0.389
    N36780G1 Z0.324 A198.857
    N36790G1 Z0.326 A202.286
    N36800G1 Z0.326 A205.714
    N36810G1 Z0.321 A209.143
    N36820G1 Z0.317 A212.571
    N36830G1 Z0.313 A216.000
    N36840G1 A267.429
    N36850G1 X1.035
    N36860G1 X1.005 Z0.315
    N36870G1 X0.975 Z0.339
    N36880G1 X0.945 Z0.345
    N36890G1 X0.915 Z0.345
    N36900G1 X0.885 Z0.341
    N36910G1 X0.855 Z0.337
    N36920G1 X0.825 Z0.331
    N36930G1 X0.795 Z0.343
    N36940G1 Z0.343 A219.429 F37.5
    N36950G1 Z0.343 A96.000
    N36960G1 X0.825 Z0.331 F50.0
    N36970G1 X0.855 Z0.337
    N36980G1 X0.885 Z0.341
    N36990G1 X0.915 Z0.345
    N37000G1 X0.945 Z0.345
    N37010G1 X0.975 Z0.339
    N37020G1 X1.005 Z0.315
    N37030G1 X1.035 Z0.313
    N37040G1 X1.935
    N37050G1 A147.429
    N37060G1 Z0.314 A150.857
    N37070G1 Z0.314 A154.286 F37.5
    N37080G1 Z0.313 A157.714
    N37090G1 Z0.323 A161.143
    N37100G1 Z0.389 A164.571 F50.0
    N37110G1 Z0.666
    N37120G1 A195.429
    N37130G1 Z0.389
    N37140G1 Z0.323 A198.857
    N37150G1 Z0.313 A202.286 F37.5
    N37160G1 Z0.314 A205.714
    N37170G1 Z0.314 A209.143
    N37180G1 Z0.313 A212.571 F50.0
    N37190G1 A264.000
    N37200G1 X1.035
    N37210G1 X1.005 Z0.315
    N37220G1 X0.975 Z0.339
    N37230G1 X0.945 Z0.345
    N37240G1 X0.915 Z0.345
    N37250G1 X0.885 Z0.341
    N37260G1 X0.855 Z0.337
    N37270G1 X0.825 Z0.331
    N37280G1 Z0.331 A99.429
    N37290G1 X0.855 Z0.337
    N37300G1 X0.885 Z0.341
    N37310G1 X0.915 Z0.345
    N37320G1 X0.945 Z0.345
    N37330G1 X0.975 Z0.339
    N37340G1 X1.005 Z0.315
    N37350G1 X1.035 Z0.313
    N37360G1 X1.905
    N37370G1 A154.286
    N37380G1 Z0.317 A157.714
    N37390G1 Z0.324 A161.143
    N37400G1 Z0.391 A164.571
    N37410G1 Z0.668
    N37420G1 A195.429
    N37430G1 Z0.391
    N37440G1 Z0.324 A198.857
    N37450G1 Z0.317 A202.286
    N37460G1 Z0.313 A205.714
    N37470G1 A260.571
    N37480G1 X1.035
    N37490G1 X1.005 Z0.315
    N37500G1 X0.975 Z0.339
    N37510G1 X0.945 Z0.345
    N37520G1 X0.915 Z0.345
    N37530G1 X0.885 Z0.341
    N37540G1 X0.855 Z0.337
    N37550G1 Z0.337 A102.857
    N37560G1 X0.885 Z0.341
    N37570G1 X0.915 Z0.345
    N37580G1 X0.945 Z0.345
    N37590G1 X0.975 Z0.339
    N37600G1 X1.005 Z0.315
    N37610G1 X1.035 Z0.313
    N37620G1 X1.875
    N37630G1 A150.857
    N37640G1 Z0.315 A154.286
    N37650G1 Z0.321 A157.714
    N37660G1 Z0.326 A161.143
    N37670G1 Z0.402 A164.571
    N37680G1 Z0.668
    N37690G1 A195.429
    N37700G1 Z0.402
    N37710G1 Z0.326 A198.857
    N37720G1 Z0.321 A202.286
    N37730G1 Z0.315 A205.714
    N37740G1 Z0.313 A209.143
    N37750G1 A257.143
    N37760G1 X1.035
    N37770G1 X1.005 Z0.315
    N37780G1 X0.975 Z0.339
    N37790G1 X0.945 Z0.345
    N37800G1 X0.915 Z0.345
    N37810G1 X0.885 Z0.341
    N37820G1 Z0.341 A106.286
    N37830G1 X0.915 Z0.345
    N37840G1 X0.945 Z0.345
    N37850G1 X0.975 Z0.339
    N37860G1 X1.005 Z0.315
    N37870G1 X1.035 Z0.313
    N37880G1 X1.845
    N37890G1 A150.857
    N37900G1 Z0.319 A154.286
    N37910G1 Z0.325 A157.714
    N37920G1 Z0.331 A161.143
    N37930G1 Z0.402 A164.571
    N37940G1 Z0.680
    N37950G1 A195.429
    N37960G1 Z0.402
    N37970G1 Z0.331 A198.857
    N37980G1 Z0.325 A202.286
    N37990G1 Z0.319 A205.714
    N38000G1 Z0.313 A209.143
    N38010G1 A253.714
    N38020G1 X1.035
    N38030G1 X1.005 Z0.315
    N38040G1 X0.975 Z0.339
    N38050G1 X0.945 Z0.345
    N38060G1 X0.915 Z0.345
    N38070G1 Z0.345 A205.714
    N38080G1 Z0.348 A202.286
    N38090G1 Z0.352 A198.857
    N38100G1 Z0.355 A195.429
    N38110G1 Z0.356 A192.000
    N38120G1 Z0.358 A188.571
    N38130G1 Z0.358 A185.143
    N38140G1 Z0.353 A181.714
    N38150G1 Z0.353 A178.286
    N38160G1 Z0.358 A174.857
    N38170G1 Z0.358 A171.429
    N38180G1 Z0.356 A168.000
    N38190G1 Z0.355 A164.571
    N38200G1 Z0.352 A161.143
    N38210G1 Z0.348 A157.714
    N38220G1 Z0.345 A154.286
    N38230G1 Z0.345 A109.714
    N38240G1 X0.945 Z0.345
    N38250G1 X0.975 Z0.339
    N38260G1 X1.005 Z0.315
    N38270G1 X1.035 Z0.313
    N38280G1 X1.815
    N38290G1 A147.429
    N38300G1 Z0.315 A150.857
    N38310G1 Z0.323 A154.286
    N38320G1 Z0.329 A157.714
    N38330G1 Z0.335 A161.143
    N38340G1 Z0.402 A164.571
    N38350G1 Z0.686
    N38360G1 A195.429
    N38370G1 Z0.402
    N38380G1 Z0.335 A198.857
    N38390G1 Z0.329 A202.286
    N38400G1 Z0.323 A205.714
    N38410G1 Z0.315 A209.143
    N38420G1 Z0.313 A212.571
    N38430G1 A250.286
    N38440G1 X1.035
    N38450G1 X1.005 Z0.315
    N38460G1 X0.975 Z0.339
    N38470G1 X0.945 Z0.345
    N38480G1 Z0.345 A219.429
    N38490G1 Z0.354 A216.000
    N38500G1 Z0.364 A212.571
    N38510G1 Z0.375 A209.143
    N38520G1 Z0.384 A205.714
    N38530G0 Z0.700
    N38540G0 A154.286
    N38550G0 Z0.572
    N38560G1 Z0.384
    N38570G1 Z0.375 A150.857
    N38580G1 Z0.364 A147.429
    N38590G1 Z0.354 A144.000
    N38600G1 Z0.345 A140.571
    N38610G1 Z0.345 A113.143
    N38620G1 X0.975 Z0.339
    N38630G1 X1.005 Z0.315
    N38640G1 X1.035 Z0.313
    N38650G1 X1.785
    N38660G1 A147.429
    N38670G1 Z0.318 A150.857
    N38680G1 Z0.326 A154.286
    N38690G1 Z0.333 A157.714
    N38700G1 Z0.338 A161.143
    N38710G1 Z0.396 A164.571
    N38720G1 Z0.686
    N38730G1 A195.429
    N38740G1 Z0.396
    N38750G1 Z0.338 A198.857
    N38760G1 Z0.333 A202.286
    N38770G1 Z0.326 A205.714
    N38780G1 Z0.318 A209.143
    N38790G1 Z0.313 A212.571
    N38800G1 A246.857
    N38810G1 X1.035
    N38820G1 X1.005 Z0.315
    N38830G1 X0.975 Z0.339
    N38840G1 Z0.339 A229.714
    N38850G1 Z0.349 A226.286
    N38860G1 Z0.360 A222.857
    N38870G1 Z0.371 A219.429
    N38880G1 Z0.382 A216.000
    N38890G0 Z0.700
    N38900G0 A144.000
    N38910G0 Z0.572
    N38920G1 Z0.382
    N38930G1 Z0.371 A140.571
    N38940G1 Z0.360 A137.143
    N38950G1 Z0.349 A133.714
    N38960G1 Z0.339 A130.286
    N38970G1 Z0.339 A116.571
    N38980G1 X1.005 Z0.315
    N38990G1 X1.035 Z0.313
    N39000G1 X1.755
    N39010G1 A147.429
    N39020G1 Z0.320 A150.857
    N39030G1 Z0.328 A154.286
    N39040G1 Z0.335 A157.714
    N39050G1 Z0.340 A161.143
    N39060G1 Z0.402 A164.571
    N39070G1 Z0.694
    N39080G1 A195.429
    N39090G1 Z0.402
    N39100G1 Z0.340 A198.857
    N39110G1 Z0.335 A202.286
    N39120G1 Z0.328 A205.714
    N39130G1 Z0.320 A209.143
    N39140G1 Z0.313 A212.571
    N39150G1 A243.429
    N39160G1 X1.035
    N39170G1 X1.005 Z0.315
    N39180G1 Z0.315 A240.000 F37.5
    N39190G1 Z0.325 A236.571
    N39200G1 Z0.334 A233.143
    N39210G1 Z0.345 A229.714 F50.0
    N39220G1 Z0.355 A226.286
    N39230G1 Z0.367 A222.857
    N39240G1 Z0.379 A219.429
    N39250G0 Z0.700
    N39260G0 A140.571
    N39270G0 Z0.572
    N39280G1 Z0.379
    N39290G1 Z0.367 A137.143
    N39300G1 Z0.355 A133.714
    N39310G1 Z0.345 A130.286
    N39320G1 Z0.334 A126.857
    N39330G1 Z0.325 A123.429 F37.5
    N39340G1 Z0.315 A120.000
    N39350G1 X1.035 Z0.320 F50.0
    N39360G1 X1.065 Z0.320
    N39370G1 X1.095 Z0.318
    N39380G1 X1.125 Z0.313
    N39390G1 X1.725
    N39400G1 A147.429
    N39410G1 Z0.321 A150.857
    N39420G1 Z0.329 A154.286
    N39430G1 Z0.336 A157.714
    N39440G1 Z0.341 A161.143
    N39450G1 Z0.402 A164.571
    N39460G1 Z0.700
    N39470G1 A195.429
    N39480G1 Z0.402
    N39490G1 Z0.341 A198.857
    N39500G1 Z0.336 A202.286
    N39510G1 Z0.329 A205.714
    N39520G1 Z0.321 A209.143
    N39530G1 Z0.313 A212.571
    N39540G1 A240.000
    N39550G1 X1.125
    N39560G1 X1.095 Z0.318
    N39570G1 X1.065 Z0.320
    N39580G1 X1.035 Z0.320
    N39590G1 Z0.330 A236.571
    N39600G1 Z0.340 A233.143
    N39610G1 Z0.351 A229.714
    N39620G1 Z0.362 A226.286
    N39630G1 Z0.374 A222.857
    N39640G1 Z0.386 A219.429
    N39650G0 Z0.700
    N39660G0 A140.571
    N39670G0 Z0.572
    N39680G1 Z0.386
    N39690G1 Z0.374 A137.143
    N39700G1 Z0.362 A133.714
    N39710G1 Z0.351 A130.286
    N39720G1 Z0.340 A126.857
    N39730G1 Z0.330 A123.429
    N39740G1 X1.065 Z0.330
    N39750G1 X1.095 Z0.328
    N39760G1 X1.125 Z0.321
    N39770G1 X1.155 Z0.313
    N39780G1 X1.695 Z0.313
    N39790G1 A147.429
    N39800G1 Z0.322 A150.857
    N39810G1 Z0.329 A154.286
    N39820G1 Z0.336 A157.714
    N39830G1 Z0.342 A161.143
    N39840G1 Z0.402 A164.571
    N39850G0 Z0.700
    N39860G0 A195.429
    N39870G0 Z0.572
    N39880G1 Z0.402
    N39890G1 Z0.342 A198.857
    N39900G1 Z0.336 A202.286
    N39910G1 Z0.329 A205.714
    N39920G1 Z0.322 A209.143
    N39930G1 Z0.313 A212.571
    N39940G1 A236.571
    N39950G1 X1.155 Z0.313
    N39960G1 X1.125 Z0.321
    N39970G1 X1.095 Z0.328
    N39980G1 X1.065 Z0.330
    N39990G1 Z0.340 A233.143
    N40000G1 Z0.351 A229.714
    N40010G1 Z0.362 A226.286
    N40020G1 Z0.374 A222.857
    N40030G1 Z0.386 A219.429
    N40040G0 Z0.700
    N40050G0 A140.571
    N40060G0 Z0.572
    N40070G1 Z0.386
    N40080G1 Z0.374 A137.143
    N40090G1 Z0.362 A133.714
    N40100G1 Z0.351 A130.286
    N40110G1 Z0.340 A126.857
    N40120G1 X1.095 Z0.338
    N40130G1 X1.125 Z0.331
    N40140G1 X1.155 Z0.322
    N40150G1 X1.185 Z0.313
    N40160G1 X1.665
    N40170G1 A147.429
    N40180G1 Z0.322 A150.857
    N40190G1 Z0.329 A154.286
    N40200G1 Z0.336 A157.714
    N40210G1 Z0.341 A161.143
    N40220G1 Z0.391 A164.571
    N40230G1 Z0.698
    N40240G1 A195.429
    N40250G1 Z0.391
    N40260G1 Z0.341 A198.857
    N40270G1 Z0.336 A202.286
    N40280G1 Z0.329 A205.714
    N40290G1 Z0.322 A209.143
    N40300G1 Z0.313 A212.571
    N40310G1 A233.143
    N40320G1 X1.185
    N40330G1 X1.155 Z0.322
    N40340G1 X1.125 Z0.331
    N40350G1 X1.095 Z0.338
    N40360G1 Z0.348 A229.714
    N40370G1 Z0.359 A226.286
    N40380G1 Z0.370 A222.857
    N40390G1 Z0.382 A219.429
    N40400G0 Z0.700
    N40410G0 A140.571
    N40420G0 Z0.572
    N40430G1 Z0.382
    N40440G1 Z0.370 A137.143
    N40450G1 Z0.359 A133.714
    N40460G1 Z0.348 A130.286
    N40470G1 X1.125 Z0.341
    N40480G1 X1.155 Z0.332
    N40490G1 X1.185 Z0.319
    N40500G1 X1.215 Z0.313
    N40510G1 X1.635
    N40520G1 A147.429
    N40530G1 Z0.321 A150.857
    N40540G1 Z0.329 A154.286
    N40550G1 Z0.335 A157.714
    N40560G1 Z0.341 A161.143
    N40570G1 Z0.402 A164.571
    N40580G1 Z0.691
    N40590G1 A195.429
    N40600G1 Z0.402
    N40610G1 Z0.341 A198.857
    N40620G1 Z0.335 A202.286
    N40630G1 Z0.329 A205.714
    N40640G1 Z0.321 A209.143
    N40650G1 Z0.313 A212.571
    N40660G1 A229.714
    N40670G1 X1.215
    N40680G1 X1.185 Z0.319
    N40690G1 X1.155 Z0.332
    N40700G1 X1.125 Z0.341
    N40710G1 Z0.352 A226.286
    N40720G1 Z0.363 A222.857
    N40730G1 Z0.375 A219.429
    N40740G1 Z0.385 A216.000
    N40750G0 Z0.700
    N40760G0 A144.000
    N40770G0 Z0.572
    N40780G1 Z0.385
    N40790G1 Z0.375 A140.571
    N40800G1 Z0.363 A137.143
    N40810G1 Z0.352 A133.714
    N40820G1 X1.155 Z0.342
    N40830G1 X1.185 Z0.328
    N40840G1 X1.215 Z0.313
    N40850G1 X1.605
    N40860G1 A147.429
    N40870G1 Z0.319 A150.857
    N40880G1 Z0.327 A154.286
    N40890G1 Z0.333 A157.714
    N40900G1 Z0.339 A161.143
    N40910G1 Z0.402 A164.571
    N40920G1 Z0.690
    N40930G1 A195.429
    N40940G1 Z0.402
    N40950G1 Z0.339 A198.857
    N40960G1 Z0.333 A202.286
    N40970G1 Z0.327 A205.714
    N40980G1 Z0.319 A209.143
    N40990G1 Z0.313 A212.571
    N41000G1 A226.286
    N41010G1 X1.215
    N41020G1 X1.185 Z0.328
    N41030G1 X1.155 Z0.342
    N41040G1 Z0.352 A222.857
    N41050G1 Z0.362 A219.429 F37.5
    N41060G1 Z0.371 A216.000
    N41070G1 Z0.379 A212.571 F50.0
    N41080G0 Z0.700
    N41090G0 A147.429
    N41100G0 Z0.572
    N41110G1 Z0.379
    N41120G1 Z0.371 A144.000
    N41130G1 Z0.362 A140.571 F37.5
    N41140G1 Z0.352 A137.143
    N41150G1 X1.185 Z0.336 F50.0
    N41160G1 X1.215 Z0.319
    N41170G1 X1.245 Z0.313
    N41180G1 X1.575
    N41190G1 A147.429
    N41200G1 Z0.317 A150.857
    N41210G1 Z0.325 A154.286
    N41220G1 Z0.330 A157.714
    N41230G1 Z0.336 A161.143
    N41240G1 Z0.398 A164.571
    N41250G1 Z0.689
    N41260G1 A195.429
    N41270G1 Z0.400
    N41280G1 Z0.336 A198.857
    N41290G1 Z0.330 A202.286
    N41300G1 Z0.325 A205.714
    N41310G1 Z0.317 A209.143
    N41320G1 Z0.313 A212.571
    N41330G1 A222.857
    N41340G1 X1.245
    N41350G1 X1.215 Z0.319
    N41360G1 X1.185 Z0.336
    N41370G1 Z0.344 A219.429 F37.5
    N41380G1 Z0.352 A216.000
    N41390G1 Z0.358 A212.571
    N41400G1 Z0.365 A209.143
    N41410G1 Z0.371 A205.714 F50.0
    N41420G1 Z0.375 A202.286
    N41430G0 Z0.700
    N41440G0 A157.714
    N41450G0 Z0.572
    N41460G1 Z0.375
    N41470G1 Z0.371 A154.286
    N41480G1 Z0.365 A150.857
    N41490G1 Z0.358 A147.429 F37.5
    N41500G1 Z0.352 A144.000
    N41510G1 Z0.344 A140.571
    N41520G1 X1.215 Z0.326 F50.0
    N41530G1 X1.245 Z0.313
    N41540G1 X1.545
    N41550G1 A147.429
    N41560G1 Z0.315 A150.857
    N41570G1 Z0.322 A154.286
    N41580G1 Z0.327 A157.714
    N41590G1 Z0.333 A161.143
    N41600G1 Z0.402 A164.571
    N41610G1 Z0.684
    N41620G1 A195.429
    N41630G1 Z0.402
    N41640G1 Z0.333 A198.857
    N41650G1 Z0.327 A202.286
    N41660G1 Z0.322 A205.714
    N41670G1 Z0.315 A209.143
    N41680G1 Z0.313 A212.571
    N41690G1 A219.429
    N41700G1 X1.245
    N41710G1 X1.215 Z0.326
    N41720G1 Z0.332 A216.000 F37.5
    N41730G1 Z0.338 A212.571
    N41740G1 Z0.344 A209.143
    N41750G1 Z0.349 A205.714
    N41760G1 Z0.352 A202.286
    N41770G1 Z0.355 A198.857
    N41780G1 Z0.401 A195.429
    N41790G1 Z0.695 F50.0
    N41800G1 A164.571
    N41810G1 Z0.401
    N41820G1 Z0.355 A161.143 F37.5
    N41830G1 Z0.352 A157.714
    N41840G1 Z0.349 A154.286
    N41850G1 Z0.344 A150.857
    N41860G1 Z0.338 A147.429
    N41870G1 Z0.332 A144.000
    N41880G1 X1.245 Z0.315 F50.0
    N41890G1 X1.275 Z0.313
    N41900G1 X1.515
    N41910G1 A150.857
    N41920G1 Z0.319 A154.286
    N41930G1 Z0.324 A157.714
    N41940G1 Z0.330 A161.143
    N41950G1 Z0.402 A164.571
    N41960G1 Z0.691
    N41970G1 A195.429
    N41980G1 Z0.402
    N41990G1 Z0.330 A198.857
    N42000G1 Z0.324 A202.286
    N42010G1 Z0.319 A205.714
    N42020G1 Z0.313 A209.143
    N42030G1 A216.000
    N42040G1 X1.275
    N42050G1 X1.245 Z0.315
    N42060G1 Z0.321 A212.571 F37.5
    N42070G1 Z0.325 A209.143
    N42080G1 Z0.329 A205.714
    N42090G1 Z0.332 A202.286
    N42100G1 Z0.334 A198.857
    N42110G1 Z0.402 A195.429
    N42120G1 Z0.695 F50.0
    N42130G1 A164.571
    N42140G1 Z0.402
    N42150G1 Z0.334 A161.143 F37.5
    N42160G1 Z0.332 A157.714
    N42170G1 Z0.329 A154.286
    N42180G1 Z0.325 A150.857
    N42190G1 Z0.321 A147.429
    N42200G1 X1.275 Z0.313 F50.0
    N42210G1 X1.485
    N42220G1 A150.857
    N42230G1 Z0.315 A154.286
    N42240G1 Z0.321 A157.714
    N42250G1 Z0.326 A161.143
    N42260G1 Z0.397 A164.571
    N42270G1 Z0.690
    N42280G1 A195.429
    N42290G1 Z0.397
    N42300G1 Z0.326 A198.857
    N42310G1 Z0.321 A202.286
    N42320G1 Z0.315 A205.714
    N42330G1 Z0.313 A209.143
    N42340G1 A212.571
    N42350G1 X1.275
    N42360G1 A209.143 F37.5
    N42370G1 Z0.315 A205.714
    N42380G1 Z0.318 A202.286
    N42390G1 Z0.324 A198.857
    N42400G1 Z0.402 A195.429 F50.0
    N42410G1 Z0.690
    N42420G1 A164.571
    N42430G1 Z0.402
    N42440G1 Z0.324 A161.143
    N42450G1 Z0.318 A157.714 F37.5
    N42460G1 Z0.315 A154.286
    N42470G1 Z0.313 A150.857
    N42480G1 X1.455 F50.0
    N42490G1 A154.286
    N42500G1 Z0.317 A157.714
    N42510G1 Z0.323 A161.143
    N42520G1 Z0.402 A164.571
    N42530G1 Z0.683
    N42540G1 A195.429
    N42550G1 Z0.402
    N42560G1 Z0.323 A198.857
    N42570G1 Z0.317 A202.286
    N42580G1 Z0.313 A205.714
    N42590G1 A209.143
    N42600G1 X1.305
    N42610G1 A202.286
    N42620G1 Z0.324 A198.857
    N42630G1 Z0.402 A195.429
    N42640G1 Z0.684
    N42650G1 A164.571
    N42660G1 Z0.402
    N42670G1 Z0.324 A161.143
    N42680G1 Z0.313 A157.714
    N42690G1 A154.286
    N42700G1 X1.425
    N42710G1 Z0.314 A157.714
    N42720G1 Z0.324 A161.143
    N42730G1 Z0.402 A164.571
    N42740G1 Z0.673
    N42750G1 A195.429
    N42760G1 Z0.402
    N42770G1 Z0.324 A198.857
    N42780G1 Z0.314 A202.286
    N42790G1 Z0.313 A205.714
    N42800G1 X1.335
    N42810G1 A202.286
    N42820G1 Z0.324 A198.857
    N42830G1 Z0.402 A195.429
    N42840G1 Z0.670
    N42850G1 A164.571
    N42860G1 Z0.402
    N42870G1 Z0.324 A161.143
    N42880G1 Z0.313 A157.714
    N42890G1 X1.395
    N42900G1 Z0.324 A161.143
    N42910G1 Z0.402 A164.571
    N42920G1 Z0.669
    N42930G1 A195.429
    N42940G1 Z0.402
    N42950G1 Z0.324 A198.857
    N42960G1 Z0.313 A202.286
    N42970G1 X1.365
    N42980G1 Z0.324 A198.857
    N42990G1 Z0.402 A195.429
    N43000G1 Z0.664
    N43010G1 A164.571
    N43020G1 Z0.402
    N43030G1 Z0.324 A161.143
    N43040G0 Z0.700
    N43050G0 X0.000 A0.000
    N43060G0 Z0.509
    N43070G1 Z0.313
    N43080G1 X0.375 Z0.281 F37.5
    N43090G1 X0.000 Z0.250
    N43100G1 X0.495
    N43110G1 X0.525 Z0.413 F50.0
    N43120G0 Z0.700
    N43130G0 X1.395
    N43140G0 Z0.519
    N43150G1 Z0.323
    N43160G1 X1.425 Z0.304
    N43170G1 X1.455 Z0.282 F37.5
    N43180G1 X1.485 Z0.259
    N43190G1 X1.515 Z0.250
    N43200G1 X1.545
    N43210G1 X1.575 Z0.339 F50.0
    N43220G0 Z0.700
    N43230G0 X2.025
    N43240G0 Z0.536
    N43250G1 Z0.340
    N43260G1 X2.055 Z0.274 F37.5
    N43270G1 X2.085 Z0.250
    N43280G1 X2.750
    N43290G1 A360.000
    N43300G1 X2.085
    N43310G1 X2.055 Z0.274
    N43320G1 X2.025 Z0.340 F50.0
    N43330G0 Z0.700
    N43340G0 X1.575
    N43350G0 Z0.536
    N43360G1 Z0.339
    N43370G1 X1.545 Z0.250 F37.5
    N43380G1 X1.515
    N43390G1 X1.485 Z0.259
    N43400G1 X1.455 Z0.282
    N43410G1 X1.425 Z0.304 F50.0
    N43420G1 X1.395 Z0.323
    N43430G0 Z0.700
    N43440G0 X0.525
    N43450G0 Z0.610
    N43460G1 Z0.413
    N43470G1 X0.495 Z0.250 F37.5
    N43480G1 X0.000
    N43490G1 A3.429
    N43500G1 X0.495 F50.0
    N43510G1 X0.525 Z0.413
    N43520G0 Z0.700
    N43530G0 X1.395
    N43540G0 Z0.518
    N43550G1 Z0.321
    N43560G1 X1.425 Z0.302
    N43570G1 X1.455 Z0.281
    N43580G1 X1.485 Z0.258
    N43590G1 X1.515 Z0.250
    N43600G1 X1.545
    N43610G1 X1.575 Z0.340
    N43620G0 Z0.700
    N43630G0 X2.025
    N43640G0 Z0.538
    N43650G1 Z0.341
    N43660G1 X2.055 Z0.275
    N43670G1 X2.085 Z0.250
    N43680G1 X2.745
    N43690G1 A356.571
    N43700G1 X2.085
    N43710G1 X2.055 Z0.275
    N43720G1 X2.025 Z0.341
    N43730G0 Z0.700
    N43740G0 X1.575
    N43750G0 Z0.537
    N43760G1 Z0.340
    N43770G1 X1.545 Z0.250
    N43780G1 X1.515
    N43790G1 X1.485 Z0.258
    N43800G1 X1.455 Z0.281
    N43810G1 X1.425 Z0.302
    N43820G1 X1.395 Z0.321
    N43830G0 Z0.700
    N43840G0 X0.525
    N43850G0 Z0.610
    N43860G1 Z0.413
    N43870G1 X0.495 Z0.250
    N43880G1 X0.015
    N43890G1 A6.857
    N43900G1 X0.495
    N43910G1 X0.525 Z0.413
    N43920G0 Z0.700
    N43930G0 X1.395
    N43940G0 Z0.513
    N43950G1 Z0.316
    N43960G1 X1.425 Z0.297
    N43970G1 X1.455 Z0.276
    N43980G1 X1.485 Z0.253
    N43990G1 X1.515 Z0.250
    N44000G1 X1.545
    N44010G1 X1.575 Z0.343
    N44020G0 Z0.700
    N44030G0 X2.025
    N44040G0 Z0.541
    N44050G1 Z0.344
    N44060G1 X2.055 Z0.274
    N44070G1 X2.085 Z0.250
    N44080G1 X2.715
    N44090G1 A353.143
    N44100G1 X2.085
    N44110G1 X2.055 Z0.274
    N44120G1 X2.025 Z0.344
    N44130G0 Z0.700
    N44140G0 X1.575
    N44150G0 Z0.540
    N44160G1 Z0.343
    N44170G1 X1.545 Z0.250
    N44180G1 X1.515
    N44190G1 X1.485 Z0.253
    N44200G1 X1.455 Z0.276
    N44210G1 X1.425 Z0.297
    N44220G1 X1.395 Z0.316
    N44230G0 Z0.700
    N44240G0 X0.525
    N44250G0 Z0.610
    N44260G1 Z0.413
    N44270G1 X0.495 Z0.250
    N44280G1 X0.045
    N44290G1 A10.286
    N44300G1 X0.495
    N44310G1 X0.525 Z0.413
    N44320G0 Z0.700
    N44330G0 X1.365
    N44340G0 Z0.524
    N44350G1 Z0.327
    N44360G1 X1.395 Z0.311
    N44370G1 X1.425 Z0.292
    N44380G1 X1.455 Z0.271
    N44390G1 X1.485 Z0.250
    N44400G1 X1.545
    N44410G1 X1.575 Z0.347
    N44420G0 Z0.700
    N44430G0 X2.025
    N44440G0 Z0.545
    N44450G1 Z0.348
    N44460G1 X2.055 Z0.262
    N44470G1 X2.085 Z0.250
    N44480G1 X2.685
    N44490G1 A349.714
    N44500G1 X2.085
    N44510G1 X2.055 Z0.262
    N44520G1 X2.025 Z0.348
    N44530G0 Z0.700
    N44540G0 X1.575
    N44550G0 Z0.544
    N44560G1 Z0.347
    N44570G1 X1.545 Z0.250
    N44580G1 X1.485
    N44590G1 X1.455 Z0.271
    N44600G1 X1.425 Z0.292
    N44610G1 X1.395 Z0.311
    N44620G1 X1.365 Z0.327
    N44630G0 Z0.700
    N44640G0 X0.525
    N44650G0 Z0.610
    N44660G1 Z0.413
    N44670G1 X0.495 Z0.250
    N44680G1 X0.075
    N44690G1 A13.714
    N44700G1 X0.495
    N44710G1 X0.525 Z0.413
    N44720G0 Z0.700
    N44730G0 X1.365
    N44740G0 Z0.518
    N44750G1 Z0.321
    N44760G1 X1.395 Z0.305
    N44770G1 X1.425 Z0.287
    N44780G1 X1.455 Z0.266
    N44790G1 X1.485 Z0.250
    N44800G1 X1.545
    N44810G1 X1.575 Z0.348
    N44820G0 Z0.700
    N44830G0 X2.025
    N44840G0 Z0.546
    N44850G1 Z0.349
    N44860G1 X2.055 Z0.256
    N44870G1 X2.085 Z0.250
    N44880G1 X2.655
    N44890G1 A346.286
    N44900G1 X2.085
    N44910G1 X2.055 Z0.256
    N44920G1 X2.025 Z0.349
    N44930G0 Z0.700
    N44940G0 X1.575
    N44950G0 Z0.545
    N44960G1 Z0.348
    N44970G1 X1.545 Z0.250
    N44980G1 X1.485
    N44990G1 X1.455 Z0.266
    N45000G1 X1.425 Z0.287
    N45010G1 X1.395 Z0.305
    N45020G1 X1.365 Z0.321
    N45030G0 Z0.700
    N45040G0 X0.525
    N45050G0 Z0.610
    N45060G1 Z0.413
    N45070G1 X0.495 Z0.250
    N45080G1 X0.105
    N45090G1 A17.143
    N45100G1 X0.495
    N45110G1 X0.525 Z0.413
    N45120G0 Z0.700
    N45130G0 X1.365
    N45140G0 Z0.512
    N45150G1 Z0.315
    N45160G1 X1.395 Z0.299
    N45170G1 X1.425 Z0.281
    N45180G1 X1.455 Z0.261
    N45190G1 X1.485 Z0.250
    N45200G1 X1.545
    N45210G1 X1.575 Z0.340
    N45220G0 Z0.700
    N45230G0 X2.025
    N45240G0 Z0.533
    N45250G1 Z0.336
    N45260G1 X2.055 Z0.250
    N45270G1 X2.625
    N45280G1 A342.857
    N45290G1 X2.055
    N45300G1 X2.025 Z0.336
    N45310G0 Z0.700
    N45320G0 X1.575
    N45330G0 Z0.536
    N45340G1 Z0.340
    N45350G1 X1.545 Z0.250
    N45360G1 X1.485
    N45370G1 X1.455 Z0.261
    N45380G1 X1.425 Z0.281
    N45390G1 X1.395 Z0.299
    N45400G1 X1.365 Z0.315
    N45410G0 Z0.700
    N45420G0 X0.525
    N45430G0 Z0.610
    N45440G1 Z0.413
    N45450G1 X0.495 Z0.250
    N45460G1 X0.135
    N45470G1 A20.571
    N45480G1 X0.495
    N45490G1 X0.525 Z0.413
    N45500G0 Z0.700
    N45510G0 X1.335
    N45520G0 Z0.519
    N45530G1 Z0.322
    N45540G1 X1.365 Z0.309
    N45550G1 X1.395 Z0.293
    N45560G1 X1.425 Z0.275
    N45570G1 X1.455 Z0.256
    N45580G1 X1.485 Z0.250
    N45590G1 X1.545
    N45600G1 X1.575 Z0.334
    N45610G0 Z0.700
    N45620G0 X2.025
    N45630G0 Z0.530
    N45640G1 Z0.333
    N45650G1 X2.055 Z0.250
    N45660G1 X2.595
    N45670G1 A339.429
    N45680G1 X2.055
    N45690G1 X2.025 Z0.333
    N45700G0 Z0.700
    N45710G0 X1.575
    N45720G0 Z0.531
    N45730G1 Z0.334
    N45740G1 X1.545 Z0.250
    N45750G1 X1.485
    N45760G1 X1.455 Z0.256
    N45770G1 X1.425 Z0.275
    N45780G1 X1.395 Z0.293
    N45790G1 X1.365 Z0.309
    N45800G1 X1.335 Z0.322
    N45810G0 Z0.700
    N45820G0 X0.525
    N45830G0 Z0.610
    N45840G1 Z0.413
    N45850G1 X0.495 Z0.250
    N45860G1 X0.165
    N45870G1 A24.000
    N45880G1 X0.495
    N45890G1 X0.525 Z0.413
    N45900G0 Z0.700
    N45910G0 X1.335
    N45920G0 Z0.513
    N45930G1 Z0.316
    N45940G1 X1.365 Z0.302
    N45950G1 X1.395 Z0.287
    N45960G1 X1.425 Z0.270
    N45970G1 X1.455 Z0.251
    N45980G1 X1.485 Z0.250
    N45990G1 X1.545
    N46000G1 X1.575 F37.5
    N46010G1 X1.605 Z0.331
    N46020G0 Z0.700
    N46030G0 X1.995
    N46040G0 Z0.528
    N46050G1 Z0.331 F50.0
    N46060G1 X2.025 Z0.281 F37.5
    N46070G1 X2.055 Z0.250
    N46080G1 X2.565 F50.0
    N46090G1 A336.000
    N46100G1 X2.055
    N46110G1 X2.025 Z0.281 F37.5
    N46120G1 X1.995 Z0.331
    N46130G0 Z0.700
    N46140G0 X1.605
    N46150G0 Z0.528
    N46160G1 Z0.331 F50.0
    N46170G1 X1.575 Z0.250 F37.5
    N46180G1 X1.545
    N46190G1 X1.485 F50.0
    N46200G1 X1.455 Z0.251
    N46210G1 X1.425 Z0.270
    N46220G1 X1.395 Z0.287
    N46230G1 X1.365 Z0.302
    N46240G1 X1.335 Z0.316
    N46250G0 Z0.700
    N46260G0 X0.525
    N46270G0 Z0.610
    N46280G1 Z0.413
    N46290G1 X0.495 Z0.250
    N46300G1 X0.195
    N46310G1 A27.429
    N46320G1 X0.495
    N46330G1 X0.525 Z0.413
    N46340G0 Z0.700
    N46350G0 X1.305
    N46360G0 Z0.516
    N46370G1 Z0.320
    N46380G1 X1.335 Z0.309
    N46390G1 X1.365 Z0.296
    N46400G1 X1.395 Z0.281
    N46410G1 X1.425 Z0.264
    N46420G1 X1.455 Z0.250
    N46430G1 X1.575
    N46440G1 X1.605 Z0.311
    N46450G1 X1.635 Z0.322
    N46460G0 Z0.700
    N46470G0 X1.965
    N46480G0 Z0.518
    N46490G1 Z0.321
    N46500G1 X1.995 Z0.310
    N46510G1 X2.025 Z0.252 F37.5
    N46520G1 X2.055 Z0.250
    N46530G1 X2.535 F50.0
    N46540G1 A332.571
    N46550G1 X2.055
    N46560G1 X2.025 Z0.252 F37.5
    N46570G1 X1.995 Z0.309
    N46580G1 X1.965 Z0.321 F50.0
    N46590G0 Z0.700
    N46600G0 X1.635
    N46610G0 Z0.519
    N46620G1 Z0.322
    N46630G1 X1.605 Z0.311
    N46640G1 X1.575 Z0.250
    N46650G1 X1.455
    N46660G1 X1.425 Z0.264
    N46670G1 X1.395 Z0.281
    N46680G1 X1.365 Z0.296
    N46690G1 X1.335 Z0.309
    N46700G1 X1.305 Z0.320
    N46710G0 Z0.700
    N46720G0 X0.525
    N46730G0 Z0.610
    N46740G1 Z0.413
    N46750G1 X0.495 Z0.250
    N46760G1 X0.225
    N46770G1 A30.857
    N46780G1 X0.495
    N46790G1 X0.525 Z0.413
    N46800G0 Z0.700
    N46810G0 X1.275
    N46820G0 Z0.517
    N46830G1 Z0.320
    N46840G1 X1.305 Z0.312
    N46850G1 X1.335 Z0.301
    N46860G1 X1.365 Z0.289
    N46870G1 X1.395 Z0.274
    N46880G1 X1.425 Z0.258
    N46890G1 X1.455 Z0.250
    N46900G1 X1.575
    N46910G1 X1.605 F37.5
    N46920G1 X1.635 Z0.269
    N46930G1 X1.665 Z0.281
    N46940G1 X1.935 Z0.281
    N46950G1 X1.965 Z0.276
    N46960G1 X1.995 Z0.265
    N46970G1 X2.025 Z0.250
    N46980G1 X2.505 F50.0
    N46990G1 A329.143
    N47000G1 X2.025
    N47010G1 X1.995 Z0.265 F37.5
    N47020G1 X1.965 Z0.276
    N47030G1 X1.935 Z0.281
    N47040G1 X1.665 Z0.281
    N47050G1 X1.635 Z0.269
    N47060G1 X1.605 Z0.250
    N47070G1 X1.575
    N47080G1 X1.455 F50.0
    N47090G1 X1.425 Z0.258
    N47100G1 X1.395 Z0.274
    N47110G1 X1.365 Z0.289
    N47120G1 X1.335 Z0.301
    N47130G1 X1.305 Z0.312
    N47140G1 X1.275 Z0.320
    N47150G0 Z0.700
    N47160G0 X0.525
    N47170G0 Z0.610
    N47180G1 Z0.413
    N47190G1 X0.495 Z0.250
    N47200G1 X0.255
    N47210G1 A34.286
    N47220G1 X0.495
    N47230G1 X0.525 Z0.413
    N47240G0 Z0.700
    N47250G0 X1.245
    N47260G0 Z0.516
    N47270G1 Z0.319
    N47280G1 X1.275 Z0.312
    N47290G1 X1.305 Z0.304
    N47300G1 X1.335 Z0.294
    N47310G1 X1.365 Z0.281
    N47320G1 X1.395 Z0.268
    N47330G1 X1.425 Z0.252
    N47340G1 X1.455 Z0.250
    N47350G1 X1.605
    N47360G1 X1.695 F37.5
    N47370G1 X1.725 Z0.252
    N47380G1 X1.965 Z0.252
    N47390G1 X1.995 Z0.250
    N47400G1 X2.025
    N47410G1 X2.475 F50.0
    N47420G1 A325.714
    N47430G1 X2.025
    N47440G1 X1.995 F37.5
    N47450G1 X1.965 Z0.252
    N47460G1 X1.725 Z0.252
    N47470G1 X1.695 Z0.250
    N47480G1 X1.605
    N47490G1 X1.455 F50.0
    N47500G1 X1.425 Z0.252
    N47510G1 X1.395 Z0.268
    N47520G1 X1.365 Z0.281
    N47530G1 X1.335 Z0.294
    N47540G1 X1.305 Z0.304
    N47550G1 X1.275 Z0.312
    N47560G1 X1.245 Z0.319
    N47570G0 Z0.700
    N47580G0 X0.525
    N47590G0 Z0.610
    N47600G1 Z0.413
    N47610G1 X0.495 Z0.250
    N47620G1 X0.285
    N47630G1 A37.714
    N47640G1 X0.495
    N47650G1 X0.525 Z0.413
    N47660G0 Z0.700
    N47670G0 X1.215
    N47680G0 Z0.514
    N47690G1 Z0.317
    N47700G1 X1.245 Z0.311
    N47710G1 X1.275 Z0.304
    N47720G1 X1.305 Z0.296
    N47730G1 X1.335 Z0.286
    N47740G1 X1.365 Z0.274
    N47750G1 X1.395 Z0.261
    N47760G1 X1.425 Z0.250
    N47770G1 X2.445
    N47780G1 A322.286
    N47790G1 X1.425
    N47800G1 X1.395 Z0.261
    N47810G1 X1.365 Z0.274
    N47820G1 X1.335 Z0.286
    N47830G1 X1.305 Z0.296
    N47840G1 X1.275 Z0.304
    N47850G1 X1.245 Z0.311
    N47860G1 X1.215 Z0.317
    N47870G0 Z0.700
    N47880G0 X0.525
    N47890G0 Z0.610
    N47900G1 Z0.413
    N47910G1 X0.495 Z0.250
    N47920G1 X0.315
    N47930G1 A41.143
    N47940G1 X0.495
    N47950G1 X0.525 Z0.413
    N47960G0 Z0.700
    N47970G0 X1.005
    N47980G0 Z0.512
    N47990G1 Z0.315
    N48000G1 X1.035 Z0.307
    N48010G1 X1.065 Z0.313
    N48020G1 Z0.513
    N48030G1 X1.185
    N48040G1 Z0.313
    N48050G1 X1.215 Z0.309
    N48060G1 X1.245 Z0.303
    N48070G1 X1.275 Z0.296
    N48080G1 X1.305 Z0.288
    N48090G1 X1.335 Z0.278
    N48100G1 X1.365 Z0.267
    N48110G1 X1.395 Z0.254
    N48120G1 X1.425 Z0.250
    N48130G1 X2.415
    N48140G1 A318.857
    N48150G1 X1.425
    N48160G1 X1.395 Z0.254
    N48170G1 X1.365 Z0.267
    N48180G1 X1.335 Z0.278
    N48190G1 X1.305 Z0.288
    N48200G1 X1.275 Z0.296
    N48210G1 X1.245 Z0.303
    N48220G1 X1.215 Z0.309
    N48230G1 X1.185 Z0.313
    N48240G1 Z0.513
    N48250G1 X1.065
    N48260G1 Z0.313
    N48270G1 X1.035 Z0.307
    N48280G1 X1.005 Z0.315
    N48290G0 Z0.700
    N48300G0 X0.525
    N48310G0 Z0.610
    N48320G1 Z0.413
    N48330G1 X0.495 Z0.250
    N48340G1 X0.345
    N48350G1 A44.571
    N48360G1 X0.495
    N48370G1 X0.525 Z0.413
    N48380G0 Z0.700
    N48390G0 X1.005
    N48400G0 Z0.512
    N48410G1 Z0.315
    N48420G1 X1.035 Z0.301
    N48430G1 X1.065 Z0.306
    N48440G1 X1.095 Z0.308
    N48450G1 X1.125 Z0.309
    N48460G1 X1.155 Z0.308
    N48470G1 X1.185 Z0.306
    N48480G1 X1.215 Z0.301
    N48490G1 X1.245 Z0.295
    N48500G1 X1.275 Z0.288
    N48510G1 X1.305 Z0.280
    N48520G1 X1.335 Z0.271
    N48530G1 X1.365 Z0.260
    N48540G1 X1.395 Z0.250
    N48550G1 X2.385
    N48560G1 A315.429
    N48570G1 X1.395
    N48580G1 X1.365 Z0.260
    N48590G1 X1.335 Z0.271
    N48600G1 X1.305 Z0.280
    N48610G1 X1.275 Z0.288
    N48620G1 X1.245 Z0.295
    N48630G1 X1.215 Z0.301
    N48640G1 X1.185 Z0.306
    N48650G1 X1.155 Z0.308
    N48660G1 X1.125 Z0.309
    N48670G1 X1.095 Z0.308
    N48680G1 X1.065 Z0.306
    N48690G1 X1.035 Z0.301
    N48700G1 X1.005 Z0.315
    N48710G0 Z0.700
    N48720G0 X0.525
    N48730G0 Z0.610
    N48740G1 Z0.413
    N48750G1 X0.495 Z0.250
    N48760G1 X0.375
    N48770G1 A48.000
    N48780G1 X0.495
    N48790G1 X0.525 Z0.413
    N48800G0 Z0.700
    N48810G0 X1.005
    N48820G0 Z0.512
    N48830G1 Z0.315
    N48840G1 X1.035 Z0.295
    N48850G1 X1.065 Z0.299
    N48860G1 X1.095 Z0.301
    N48870G1 X1.125 Z0.301
    N48880G1 X1.155 Z0.300
    N48890G1 X1.185 Z0.298
    N48900G1 X1.215 Z0.293
    N48910G1 X1.245 Z0.287
    N48920G1 X1.275 Z0.280
    N48930G1 X1.305 Z0.273
    N48940G1 X1.335 Z0.263
    N48950G1 X1.365 Z0.253
    N48960G1 X1.395 Z0.250
    N48970G1 X2.355
    N48980G1 A312.000
    N48990G1 X1.395
    N49000G1 X1.365 Z0.253
    N49010G1 X1.335 Z0.263
    N49020G1 X1.305 Z0.273
    N49030G1 X1.275 Z0.280
    N49040G1 X1.245 Z0.287
    N49050G1 X1.215 Z0.293
    N49060G1 X1.185 Z0.298
    N49070G1 X1.155 Z0.300
    N49080G1 X1.125 Z0.301
    N49090G1 X1.095 Z0.301
    N49100G1 X1.065 Z0.299
    N49110G1 X1.035 Z0.295
    N49120G1 X1.005 Z0.315
    N49130G0 Z0.700
    N49140G0 X0.525
    N49150G0 Z0.610
    N49160G1 Z0.413
    N49170G1 X0.495 Z0.250
    N49180G1 X0.405
    N49190G1 A51.429
    N49200G1 X0.495
    N49210G1 X0.525 Z0.413
    N49220G0 Z0.700
    N49230G0 X1.005
    N49240G0 Z0.512
    N49250G1 Z0.315
    N49260G1 X1.035 Z0.289
    N49270G1 X1.065 Z0.293
    N49280G1 X1.095 Z0.294
    N49290G1 X1.155 Z0.294
    N49300G1 X1.185 Z0.291
    N49310G1 X1.215 Z0.287
    N49320G1 X1.245 Z0.280
    N49330G1 X1.275 Z0.273
    N49340G1 X1.305 Z0.266
    N49350G1 X1.335 Z0.257
    N49360G1 X1.365 Z0.250
    N49370G1 X2.325
    N49380G1 A308.571
    N49390G1 X1.365
    N49400G1 X1.335 Z0.257
    N49410G1 X1.305 Z0.266
    N49420G1 X1.275 Z0.273
    N49430G1 X1.245 Z0.280
    N49440G1 X1.215 Z0.287
    N49450G1 X1.185 Z0.291
    N49460G1 X1.155 Z0.294
    N49470G1 X1.095 Z0.294
    N49480G1 X1.065 Z0.293
    N49490G1 X1.035 Z0.289
    N49500G1 X1.005 Z0.315
    N49510G0 Z0.700
    N49520G0 X0.525
    N49530G0 Z0.610
    N49540G1 Z0.413
    N49550G1 X0.495 Z0.250
    N49560G1 X0.435
    N49570G1 A54.857
    N49580G1 X0.495
    N49590G1 X0.525 Z0.413
    N49600G0 Z0.700
    N49610G0 X1.005
    N49620G0 Z0.512
    N49630G1 Z0.315
    N49640G1 X1.035 Z0.285
    N49650G1 X1.065 Z0.288
    N49660G1 X1.095 Z0.289
    N49670G1 X1.125 Z0.289
    N49680G1 X1.155 Z0.288
    N49690G1 X1.185 Z0.285
    N49700G1 X1.215 Z0.280
    N49710G1 X1.245 Z0.274
    N49720G1 X1.275 Z0.267
    N49730G1 X1.305 Z0.259
    N49740G1 X1.335 Z0.250
    N49750G1 X2.295 Z0.250
    N49760G1 A305.143
    N49770G1 X1.335 Z0.250
    N49780G1 X1.305 Z0.259
    N49790G1 X1.275 Z0.267
    N49800G1 X1.245 Z0.274
    N49810G1 X1.215 Z0.280
    N49820G1 X1.185 Z0.285
    N49830G1 X1.155 Z0.288
    N49840G1 X1.125 Z0.289
    N49850G1 X1.095 Z0.289
    N49860G1 X1.065 Z0.288
    N49870G1 X1.035 Z0.285
    N49880G1 X1.005 Z0.315
    N49890G0 Z0.700
    N49900G0 X0.525
    N49910G0 Z0.610
    N49920G1 Z0.413
    N49930G1 X0.495 Z0.250
    N49940G1 X0.465
    N49950G1 A58.286
    N49960G1 X0.495
    N49970G1 X0.525 Z0.413
    N49980G0 Z0.700
    N49990G0 X1.005
    N50000G0 Z0.512
    N50010G1 Z0.315
    N50020G1 X1.035 Z0.280
    N50030G1 X1.065 Z0.283
    N50040G1 X1.125 Z0.283
    N50050G1 X1.155 Z0.282
    N50060G1 X1.185 Z0.278
    N50070G1 X1.215 Z0.273
    N50080G1 X1.245 Z0.267
    N50090G1 X1.275 Z0.260
    N50100G1 X1.305 Z0.253
    N50110G1 X1.335 Z0.250
    N50120G1 X2.265
    N50130G1 A301.714
    N50140G1 X1.335
    N50150G1 X1.305 Z0.253
    N50160G1 X1.275 Z0.260
    N50170G1 X1.245 Z0.267
    N50180G1 X1.215 Z0.273
    N50190G1 X1.185 Z0.278
    N50200G1 X1.155 Z0.282
    N50210G1 X1.125 Z0.283
    N50220G1 X1.065 Z0.283
    N50230G1 X1.035 Z0.280
    N50240G1 X1.005 Z0.315
    N50250G0 Z0.700
    N50260G0 X0.525
    N50270G0 Z0.610
    N50280G1 Z0.413
    N50290G1 X0.495 Z0.250
    N50300G1 A298.286 F37.5
    N50310G1 A61.714 F50.0
    N50320G1 X0.525 Z0.413
    N50330G0 Z0.700
    N50340G0 X1.005
    N50350G0 Z0.512
    N50360G1 Z0.315
    N50370G1 X1.035 Z0.276
    N50380G1 X1.065 Z0.278
    N50390G1 X1.125 Z0.278
    N50400G1 X1.155 Z0.276
    N50410G1 X1.185 Z0.272
    N50420G1 X1.215 Z0.267
    N50430G1 X1.245 Z0.261
    N50440G1 X1.275 Z0.254
    N50450G1 X1.305 Z0.250
    N50460G1 X2.235
    N50470G1 A164.571
    N50480G1 Z0.253 A168.000
    N50490G1 Z0.259 A171.429
    N50500G1 Z0.268 A174.857
    N50510G1 Z0.268 A185.143
    N50520G1 Z0.261 A188.571
    N50530G1 Z0.253 A192.000
    N50540G1 Z0.250 A195.429
    N50550G1 A298.286
    N50560G1 X1.305
    N50570G1 X1.275 Z0.254
    N50580G1 X1.245 Z0.261
    N50590G1 X1.215 Z0.267
    N50600G1 X1.185 Z0.272
    N50610G1 X1.155 Z0.276
    N50620G1 X1.125 Z0.278
    N50630G1 X1.065 Z0.278
    N50640G1 X1.035 Z0.276
    N50650G1 X1.005 Z0.315
    N50660G0 Z0.700
    N50670G0 A65.143
    N50680G0 Z0.512
    N50690G1 Z0.315
    N50700G1 X1.035 Z0.273
    N50710G1 X1.065 Z0.275
    N50720G1 X1.095 Z0.275
    N50730G1 X1.125 Z0.274
    N50740G1 X1.155 Z0.272
    N50750G1 X1.185 Z0.268
    N50760G1 X1.215 Z0.262
    N50770G1 X1.245 Z0.256
    N50780G1 X1.275 Z0.250
    N50790G1 X2.205
    N50800G1 A161.143
    N50810G1 Z0.271 A164.571
    N50820G1 Z0.281 A168.000
    N50830G1 Z0.283 A171.429
    N50840G1 Z0.291 A174.857
    N50850G1 Z0.292 A178.286
    N50860G1 Z0.292 A185.143
    N50870G1 Z0.285 A188.571
    N50880G1 Z0.281 A192.000
    N50890G1 Z0.271 A195.429
    N50900G1 Z0.250 A198.857
    N50910G1 A294.857
    N50920G1 X1.275
    N50930G1 X1.245 Z0.256
    N50940G1 X1.215 Z0.262
    N50950G1 X1.185 Z0.268
    N50960G1 X1.155 Z0.272
    N50970G1 X1.125 Z0.274
    N50980G1 X1.095 Z0.275
    N50990G1 X1.065 Z0.275
    N51000G1 X1.035 Z0.273
    N51010G1 X1.005 Z0.315
    N51020G0 Z0.700
    N51030G0 A68.571
    N51040G0 Z0.512
    N51050G1 Z0.315
    N51060G1 X1.035 Z0.270
    N51070G1 X1.065 Z0.272
    N51080G1 X1.095 Z0.272
    N51090G1 X1.125 Z0.271
    N51100G1 X1.155 Z0.268
    N51110G1 X1.185 Z0.264
    N51120G1 X1.215 Z0.258
    N51130G1 X1.245 Z0.252
    N51140G1 X1.275 Z0.250
    N51150G1 X2.175
    N51160G1 A157.714
    N51170G1 Z0.263 A161.143
    N51180G1 Z0.284 A164.571
    N51190G1 Z0.329 A168.000
    N51200G1 Z0.544
    N51210G1 A192.000
    N51220G1 Z0.329
    N51230G1 Z0.284 A195.429
    N51240G1 Z0.263 A198.857
    N51250G1 Z0.250 A202.286
    N51260G1 A291.429
    N51270G1 X1.275
    N51280G1 X1.245 Z0.252
    N51290G1 X1.215 Z0.258
    N51300G1 X1.185 Z0.264
    N51310G1 X1.155 Z0.268
    N51320G1 X1.125 Z0.271
    N51330G1 X1.095 Z0.272
    N51340G1 X1.065 Z0.272
    N51350G1 X1.035 Z0.270
    N51360G1 X1.005 Z0.315
    N51370G0 Z0.700
    N51380G0 A72.000
    N51390G0 Z0.512
    N51400G1 Z0.315
    N51410G1 X1.035 Z0.268
    N51420G1 X1.065 Z0.269
    N51430G1 X1.095 Z0.269
    N51440G1 X1.125 Z0.268
    N51450G1 X1.155 Z0.265
    N51460G1 X1.185 Z0.261
    N51470G1 X1.215 Z0.255
    N51480G1 X1.245 Z0.250
    N51490G1 X2.145
    N51500G1 A137.143
    N51510G1 Z0.263 A140.571
    N51520G1 Z0.277 A144.000
    N51530G1 Z0.289 A147.429
    N51540G1 Z0.296 A150.857
    N51550G1 Z0.307 A154.286
    N51560G1 Z0.307 A157.714
    N51570G1 Z0.305 A161.143
    N51580G1 Z0.328 A164.571
    N51590G1 Z0.568
    N51600G1 A195.429
    N51610G1 Z0.328
    N51620G1 Z0.305 A198.857
    N51630G1 Z0.307 A202.286
    N51640G1 Z0.307 A205.714
    N51650G1 Z0.296 A209.143
    N51660G1 Z0.289 A212.571
    N51670G1 Z0.277 A216.000
    N51680G1 Z0.262 A219.429
    N51690G1 Z0.250 A222.857
    N51700G1 A288.000
    N51710G1 X1.245
    N51720G1 X1.215 Z0.255
    N51730G1 X1.185 Z0.261
    N51740G1 X1.155 Z0.265
    N51750G1 X1.125 Z0.268
    N51760G1 X1.095 Z0.269
    N51770G1 X1.065 Z0.269
    N51780G1 X1.035 Z0.268
    N51790G1 X1.005 Z0.315
    N51800G0 Z0.700
    N51810G0 A75.429
    N51820G0 Z0.512
    N51830G1 Z0.315
    N51840G1 X1.035 Z0.266
    N51850G1 X1.065 Z0.267
    N51860G1 X1.095 Z0.267
    N51870G1 X1.125 Z0.266
    N51880G1 X1.155 Z0.263
    N51890G1 X1.185 Z0.258
    N51900G1 X1.215 Z0.252
    N51910G1 X1.245 Z0.250
    N51920G1 X2.115
    N51930G1 Z0.250 A133.714
    N51940G1 Z0.267 A137.143
    N51950G1 Z0.291 A140.571
    N51960G1 Z0.305 A144.000
    N51970G1 Z0.317 A147.429
    N51980G0 Z0.700
    N51990G0 A212.571
    N52000G0 Z0.509
    N52010G1 Z0.317
    N52020G1 Z0.305 A216.000
    N52030G1 Z0.291 A219.429
    N52040G1 Z0.267 A222.857
    N52050G1 Z0.251 A226.286
    N52060G1 Z0.250 A229.714
    N52070G1 A284.571
    N52080G1 X1.245
    N52090G1 X1.215 Z0.252
    N52100G1 X1.185 Z0.258
    N52110G1 X1.155 Z0.263
    N52120G1 X1.125 Z0.266
    N52130G1 X1.095 Z0.267
    N52140G1 X1.065 Z0.267
    N52150G1 X1.035 Z0.266
    N52160G1 X1.005 Z0.315
    N52170G0 Z0.700
    N52180G0 A78.857
    N52190G0 Z0.512
    N52200G1 Z0.315
    N52210G1 X1.035 Z0.265
    N52220G1 X1.065 Z0.266
    N52230G1 X1.095 Z0.266
    N52240G1 X1.125 Z0.265
    N52250G1 X1.155 Z0.261
    N52260G1 X1.185 Z0.256
    N52270G1 X1.215 Z0.250
    N52280G1 X2.085 Z0.250
    N52290G1 A126.857
    N52300G1 Z0.264 A130.286
    N52310G1 Z0.273 A133.714
    N52320G1 Z0.283 A137.143
    N52330G1 Z0.298 A140.571
    N52340G1 Z0.312 A144.000
    N52350G1 Z0.324 A147.429
    N52360G0 Z0.700
    N52370G0 A212.571
    N52380G0 Z0.509
    N52390G1 Z0.324
    N52400G1 Z0.312 A216.000
    N52410G1 Z0.297 A219.429
    N52420G1 Z0.283 A222.857
    N52430G1 Z0.273 A226.286
    N52440G1 Z0.264 A229.714
    N52450G1 Z0.250 A233.143
    N52460G1 A281.143
    N52470G1 X1.215 Z0.250
    N52480G1 X1.185 Z0.256
    N52490G1 X1.155 Z0.261
    N52500G1 X1.125 Z0.265
    N52510G1 X1.095 Z0.266
    N52520G1 X1.065 Z0.266
    N52530G1 X1.035 Z0.265
    N52540G1 X1.005 Z0.315
    N52550G0 Z0.700
    N52560G0 A82.286
    N52570G0 Z0.512
    N52580G1 Z0.315
    N52590G1 X1.035 Z0.265
    N52600G1 X1.065 Z0.266
    N52610G1 X1.095 Z0.265
    N52620G1 X1.125 Z0.263
    N52630G1 X1.155 Z0.260
    N52640G1 X1.185 Z0.255
    N52650G1 X1.215 Z0.250
    N52660G1 X2.055
    N52670G1 A123.429
    N52680G1 Z0.256 A126.857
    N52690G1 Z0.271 A130.286
    N52700G1 Z0.280 A133.714
    N52710G1 Z0.290 A137.143
    N52720G1 Z0.301 A140.571
    N52730G1 Z0.313 A144.000
    N52740G0 Z0.700
    N52750G0 A216.000
    N52760G0 Z0.509
    N52770G1 Z0.313
    N52780G1 Z0.301 A219.429
    N52790G1 Z0.290 A222.857
    N52800G1 Z0.280 A226.286
    N52810G1 Z0.271 A229.714
    N52820G1 Z0.256 A233.143
    N52830G1 Z0.250 A236.571
    N52840G1 A277.714
    N52850G1 X1.215
    N52860G1 X1.185 Z0.255
    N52870G1 X1.155 Z0.260
    N52880G1 X1.125 Z0.263
    N52890G1 X1.095 Z0.265
    N52900G1 X1.065 Z0.266
    N52910G1 X1.035 Z0.265
    N52920G1 X1.005 Z0.315
    N52930G0 Z0.700
    N52940G0 A85.714
    N52950G0 Z0.512
    N52960G1 Z0.315
    N52970G1 X1.035 Z0.266
    N52980G1 X1.065 Z0.267
    N52990G1 X1.095 Z0.266
    N53000G1 X1.125 Z0.264
    N53010G1 X1.155 Z0.260
    N53020G1 X1.185 Z0.254
    N53030G1 X1.215 Z0.250
    N53040G1 X2.025
    N53050G1 A120.000
    N53060G1 Z0.256 A123.429
    N53070G1 Z0.263 A126.857
    N53080G1 Z0.271 A130.286
    N53090G1 Z0.280 A133.714
    N53100G1 Z0.290 A137.143
    N53110G1 Z0.301 A140.571
    N53120G1 Z0.313 A144.000
    N53130G0 Z0.700
    N53140G0 A216.000
    N53150G0 Z0.509
    N53160G1 Z0.313
    N53170G1 Z0.301 A219.429
    N53180G1 Z0.290 A222.857
    N53190G1 Z0.280 A226.286
    N53200G1 Z0.271 A229.714
    N53210G1 Z0.263 A233.143
    N53220G1 Z0.256 A236.571
    N53230G1 Z0.250 A240.000
    N53240G1 A274.286
    N53250G1 X1.215
    N53260G1 X1.185 Z0.254
    N53270G1 X1.155 Z0.260
    N53280G1 X1.125 Z0.264
    N53290G1 X1.095 Z0.266
    N53300G1 X1.065 Z0.267
    N53310G1 X1.035 Z0.266
    N53320G1 X1.005 Z0.315
    N53330G0 Z0.700
    N53340G0 A89.143
    N53350G0 Z0.512
    N53360G1 Z0.315
    N53370G1 X1.035 Z0.268
    N53380G1 X1.095 Z0.268
    N53390G1 X1.125 Z0.265
    N53400G1 X1.155 Z0.261
    N53410G1 X1.185 Z0.255
    N53420G1 X1.215 Z0.250
    N53430G1 X1.995
    N53440G1 A120.000
    N53450G1 Z0.256 A123.429
    N53460G1 Z0.263 A126.857
    N53470G1 Z0.271 A130.286
    N53480G1 Z0.277 A133.714
    N53490G1 Z0.290 A137.143
    N53500G1 Z0.301 A140.571
    N53510G1 Z0.313 A144.000
    N53520G0 Z0.700
    N53530G0 A216.000
    N53540G0 Z0.509
    N53550G1 Z0.313
    N53560G1 Z0.301 A219.429
    N53570G1 Z0.290 A222.857
    N53580G1 Z0.277 A226.286
    N53590G1 Z0.271 A229.714
    N53600G1 Z0.263 A233.143
    N53610G1 Z0.256 A236.571
    N53620G1 Z0.250 A240.000
    N53630G1 A270.857
    N53640G1 X1.215
    N53650G1 X1.185 Z0.255
    N53660G1 X1.155 Z0.261
    N53670G1 X1.125 Z0.265
    N53680G1 X1.095 Z0.268
    N53690G1 X1.035 Z0.268
    N53700G1 X1.005 Z0.315
    N53710G0 Z0.700
    N53720G0 A92.571
    N53730G0 Z0.512
    N53740G1 Z0.315
    N53750G1 X1.035 Z0.270
    N53760G1 X1.065 Z0.271
    N53770G1 X1.095 Z0.270
    N53780G1 X1.125 Z0.267
    N53790G1 X1.155 Z0.262
    N53800G1 X1.185 Z0.256
    N53810G1 X1.215 Z0.250
    N53820G1 X1.965
    N53830G1 A120.000
    N53840G1 Z0.255 A123.429
    N53850G1 Z0.258 A126.857
    N53860G1 Z0.271 A130.286
    N53870G1 Z0.280 A133.714
    N53880G1 Z0.290 A137.143
    N53890G1 Z0.301 A140.571
    N53900G1 Z0.310 A144.000
    N53910G1 Z0.317 A147.429
    N53920G0 Z0.700
    N53930G0 A212.571
    N53940G0 Z0.509
    N53950G1 Z0.317
    N53960G1 Z0.310 A216.000
    N53970G1 Z0.301 A219.429
    N53980G1 Z0.290 A222.857
    N53990G1 Z0.280 A226.286
    N54000G1 Z0.271 A229.714
    N54010G1 Z0.258 A233.143
    N54020G1 Z0.255 A236.571
    N54030G1 Z0.250 A240.000
    N54040G1 A267.429
    N54050G1 X1.215
    N54060G1 X1.185 Z0.256
    N54070G1 X1.155 Z0.262
    N54080G1 X1.125 Z0.267
    N54090G1 X1.095 Z0.270
    N54100G1 X1.065 Z0.271
    N54110G1 X1.035 Z0.270
    N54120G1 X1.005 Z0.315
    N54130G0 Z0.700
    N54140G0 A96.000
    N54150G0 Z0.512
    N54160G1 Z0.315
    N54170G1 X1.035 Z0.273
    N54180G1 X1.065 Z0.274
    N54190G1 X1.095 Z0.273
    N54200G1 X1.125 Z0.270
    N54210G1 X1.155 Z0.265
    N54220G1 X1.185 Z0.259
    N54230G1 X1.215 Z0.252
    N54240G1 X1.245 Z0.250
    N54250G1 X1.935
    N54260G1 A120.000
    N54270G1 Z0.256 A123.429
    N54280G1 Z0.263 A126.857
    N54290G1 Z0.271 A130.286
    N54300G1 Z0.280 A133.714
    N54310G1 Z0.290 A137.143
    N54320G1 Z0.294 A140.571
    N54330G1 Z0.304 A144.000
    N54340G1 Z0.307 A147.429
    N54350G1 Z0.314 A150.857
    N54360G0 Z0.700
    N54370G0 A209.143
    N54380G0 Z0.509
    N54390G1 Z0.314
    N54400G1 Z0.307 A212.571
    N54410G1 Z0.304 A216.000
    N54420G1 Z0.294 A219.429
    N54430G1 Z0.290 A222.857
    N54440G1 Z0.280 A226.286
    N54450G1 Z0.271 A229.714
    N54460G1 Z0.263 A233.143
    N54470G1 Z0.256 A236.571
    N54480G1 Z0.250 A240.000
    N54490G1 A264.000
    N54500G1 X1.245
    N54510G1 X1.215 Z0.252
    N54520G1 X1.185 Z0.259
    N54530G1 X1.155 Z0.265
    N54540G1 X1.125 Z0.270
    N54550G1 X1.095 Z0.273
    N54560G1 X1.065 Z0.274
    N54570G1 X1.035 Z0.273
    N54580G1 X1.005 Z0.315
    N54590G0 Z0.700
    N54600G0 A99.429
    N54610G0 Z0.512
    N54620G1 Z0.315
    N54630G1 X1.035 Z0.277
    N54640G1 X1.095 Z0.277
    N54650G1 X1.125 Z0.273
    N54660G1 X1.155 Z0.268
    N54670G1 X1.185 Z0.262
    N54680G1 X1.215 Z0.254
    N54690G1 X1.245 Z0.250
    N54700G1 X1.905
    N54710G1 A120.000
    N54720G1 Z0.256 A123.429
    N54730G1 Z0.263 A126.857
    N54740G1 Z0.271 A130.286
    N54750G1 Z0.274 A133.714
    N54760G1 Z0.283 A137.143
    N54770G1 Z0.287 A140.571
    N54780G1 Z0.295 A144.000
    N54790G1 Z0.297 A147.429
    N54800G1 Z0.303 A150.857
    N54810G1 Z0.311 A154.286
    N54820G1 Z0.317 A157.714
    N54830G0 Z0.700
    N54840G0 A202.286
    N54850G0 Z0.509
    N54860G1 Z0.317
    N54870G1 Z0.311 A205.714
    N54880G1 Z0.303 A209.143
    N54890G1 Z0.297 A212.571
    N54900G1 Z0.295 A216.000
    N54910G1 Z0.287 A219.429
    N54920G1 Z0.283 A222.857
    N54930G1 Z0.274 A226.286
    N54940G1 Z0.271 A229.714
    N54950G1 Z0.263 A233.143
    N54960G1 Z0.256 A236.571
    N54970G1 Z0.250 A240.000
    N54980G1 A260.571
    N54990G1 X1.245
    N55000G1 X1.215 Z0.254
    N55010G1 X1.185 Z0.262
    N55020G1 X1.155 Z0.268
    N55030G1 X1.125 Z0.273
    N55040G1 X1.095 Z0.277
    N55050G1 X1.035 Z0.277
    N55060G1 X1.005 Z0.315
    N55070G0 Z0.700
    N55080G0 A102.857
    N55090G0 Z0.512
    N55100G1 Z0.315
    N55110G1 X1.035 Z0.282
    N55120G1 X1.065 Z0.282
    N55130G1 X1.095 Z0.281
    N55140G1 X1.125 Z0.277
    N55150G1 X1.155 Z0.271
    N55160G1 X1.185 Z0.265
    N55170G1 X1.215 Z0.258
    N55180G1 X1.245 Z0.250
    N55190G1 X1.875
    N55200G1 A120.000
    N55210G1 Z0.252 A123.429
    N55220G1 Z0.258 A126.857
    N55230G1 Z0.264 A130.286
    N55240G1 Z0.267 A133.714
    N55250G1 Z0.275 A137.143
    N55260G1 Z0.277 A140.571
    N55270G1 Z0.287 A144.000
    N55280G1 Z0.298 A147.429
    N55290G1 Z0.307 A150.857
    N55300G1 Z0.315 A154.286
    N55310G0 Z0.700
    N55320G0 A205.714
    N55330G0 Z0.509
    N55340G1 Z0.315
    N55350G1 Z0.307 A209.143
    N55360G1 Z0.298 A212.571
    N55370G1 Z0.287 A216.000
    N55380G1 Z0.277 A219.429
    N55390G1 Z0.275 A222.857
    N55400G1 Z0.267 A226.286
    N55410G1 Z0.264 A229.714
    N55420G1 Z0.258 A233.143
    N55430G1 Z0.252 A236.571
    N55440G1 Z0.250 A240.000
    N55450G1 A257.143
    N55460G1 X1.245
    N55470G1 X1.215 Z0.258
    N55480G1 X1.185 Z0.265
    N55490G1 X1.155 Z0.271
    N55500G1 X1.125 Z0.277
    N55510G1 X1.095 Z0.281
    N55520G1 X1.065 Z0.282
    N55530G1 X1.035 Z0.282
    N55540G1 X1.005 Z0.315
    N55550G0 Z0.700
    N55560G0 A106.286
    N55570G0 Z0.512
    N55580G1 Z0.315
    N55590G1 X1.035 Z0.288
    N55600G1 X1.065 Z0.288
    N55610G1 X1.095 Z0.287
    N55620G1 X1.125 Z0.282
    N55630G1 X1.155 Z0.276
    N55640G1 X1.185 Z0.269
    N55650G1 X1.215 Z0.261
    N55660G1 X1.245 Z0.253
    N55670G1 X1.275 Z0.250
    N55680G1 X1.845
    N55690G1 A120.000
    N55700G1 Z0.251 A123.429
    N55710G1 Z0.255 A126.857
    N55720G1 Z0.256 A130.286
    N55730G1 Z0.256 A133.714
    N55740G1 Z0.266 A137.143
    N55750G1 Z0.279 A140.571
    N55760G1 Z0.291 A144.000
    N55770G1 Z0.301 A147.429
    N55780G1 Z0.311 A150.857
    N55790G1 Z0.319 A154.286
    N55800G0 Z0.700
    N55810G0 A205.714
    N55820G0 Z0.509
    N55830G1 Z0.319
    N55840G1 Z0.311 A209.143
    N55850G1 Z0.301 A212.571
    N55860G1 Z0.291 A216.000
    N55870G1 Z0.279 A219.429
    N55880G1 Z0.266 A222.857
    N55890G1 Z0.256 A226.286
    N55900G1 Z0.256 A229.714
    N55910G1 Z0.255 A233.143
    N55920G1 Z0.251 A236.571
    N55930G1 Z0.250 A240.000
    N55940G1 A253.714
    N55950G1 X1.275
    N55960G1 X1.245 Z0.253
    N55970G1 X1.215 Z0.261
    N55980G1 X1.185 Z0.269
    N55990G1 X1.155 Z0.276
    N56000G1 X1.125 Z0.282
    N56010G1 X1.095 Z0.287
    N56020G1 X1.065 Z0.288
    N56030G1 X1.035 Z0.288
    N56040G1 X1.005 Z0.315
    N56050G0 Z0.700
    N56060G0 A109.714
    N56070G0 Z0.512
    N56080G1 Z0.315
    N56090G1 X1.035 Z0.295
    N56100G1 X1.065 Z0.295
    N56110G1 X1.095 Z0.294
    N56120G1 X1.125 Z0.289
    N56130G1 X1.155 Z0.282
    N56140G1 X1.185 Z0.274
    N56150G1 X1.215 Z0.266
    N56160G1 X1.245 Z0.257
    N56170G1 X1.275 Z0.250
    N56180G1 X1.815
    N56190G1 A120.000
    N56200G1 Z0.251 A123.429
    N56210G1 Z0.255 A126.857
    N56220G1 Z0.256 A130.286
    N56230G1 Z0.256 A133.714
    N56240G1 Z0.269 A137.143
    N56250G1 Z0.282 A140.571
    N56260G1 Z0.294 A144.000
    N56270G1 Z0.305 A147.429
    N56280G1 Z0.315 A150.857
    N56290G0 Z0.700
    N56300G0 A209.143
    N56310G0 Z0.509
    N56320G1 Z0.315
    N56330G1 Z0.305 A212.571
    N56340G1 Z0.294 A216.000
    N56350G1 Z0.282 A219.429
    N56360G1 Z0.269 A222.857
    N56370G1 Z0.256 A226.286
    N56380G1 Z0.256 A229.714
    N56390G1 Z0.255 A233.143
    N56400G1 Z0.251 A236.571
    N56410G1 Z0.250 A240.000
    N56420G1 A250.286
    N56430G1 X1.275
    N56440G1 X1.245 Z0.257
    N56450G1 X1.215 Z0.266
    N56460G1 X1.185 Z0.274
    N56470G1 X1.155 Z0.282
    N56480G1 X1.125 Z0.289
    N56490G1 X1.095 Z0.294
    N56500G1 X1.065 Z0.295
    N56510G1 X1.035 Z0.295
    N56520G1 X1.005 Z0.315
    N56530G0 Z0.700
    N56540G0 A113.143
    N56550G0 Z0.512
    N56560G1 Z0.315
    N56570G1 X1.035 Z0.303
    N56580G1 X1.065 Z0.303
    N56590G1 X1.095 Z0.301
    N56600G1 X1.125 Z0.296
    N56610G1 X1.155 Z0.289
    N56620G1 X1.185 Z0.281
    N56630G1 X1.215 Z0.271
    N56640G1 X1.245 Z0.261
    N56650G1 X1.275 Z0.252
    N56660G1 X1.305 Z0.250
    N56670G1 X1.785
    N56680G1 A120.000
    N56690G1 Z0.251 A123.429
    N56700G1 Z0.255 A126.857
    N56710G1 Z0.256 A130.286
    N56720G1 Z0.259 A133.714
    N56730G1 Z0.272 A137.143
    N56740G1 Z0.285 A140.571
    N56750G1 Z0.297 A144.000
    N56760G1 Z0.308 A147.429
    N56770G1 Z0.318 A150.857
    N56780G0 Z0.700
    N56790G0 A209.143
    N56800G0 Z0.509
    N56810G1 Z0.318
    N56820G1 Z0.308 A212.571
    N56830G1 Z0.297 A216.000
    N56840G1 Z0.285 A219.429
    N56850G1 Z0.272 A222.857
    N56860G1 Z0.259 A226.286
    N56870G1 Z0.256 A229.714
    N56880G1 Z0.255 A233.143
    N56890G1 Z0.251 A236.571
    N56900G1 Z0.250 A240.000
    N56910G1 A246.857
    N56920G1 X1.305
    N56930G1 X1.275 Z0.252
    N56940G1 X1.245 Z0.261
    N56950G1 X1.215 Z0.271
    N56960G1 X1.185 Z0.281
    N56970G1 X1.155 Z0.289
    N56980G1 X1.125 Z0.296
    N56990G1 X1.095 Z0.301
    N57000G1 X1.065 Z0.303
    N57010G1 X1.035 Z0.303
    N57020G1 X1.005 Z0.315
    N57030G0 Z0.700
    N57040G0 A116.571
    N57050G0 Z0.512
    N57060G1 Z0.315
    N57070G1 X1.035 Z0.311
    N57080G1 X1.065 Z0.311
    N57090G1 X1.095 Z0.309
    N57100G1 X1.125 Z0.303
    N57110G1 X1.155 Z0.297
    N57120G1 X1.185 Z0.288
    N57130G1 X1.215 Z0.277
    N57140G1 X1.245 Z0.266
    N57150G1 X1.275 Z0.256
    N57160G1 X1.305 Z0.250
    N57170G1 X1.755
    N57180G1 A120.000
    N57190G1 Z0.251 A123.429
    N57200G1 Z0.255 A126.857
    N57210G1 Z0.255 A130.286
    N57220G1 Z0.262 A133.714
    N57230G1 Z0.275 A137.143
    N57240G1 Z0.287 A140.571
    N57250G1 Z0.300 A144.000
    N57260G1 Z0.311 A147.429
    N57270G1 Z0.320 A150.857
    N57280G0 Z0.700
    N57290G0 A209.143
    N57300G0 Z0.509
    N57310G1 Z0.320
    N57320G1 Z0.311 A212.571
    N57330G1 Z0.300 A216.000
    N57340G1 Z0.287 A219.429
    N57350G1 Z0.275 A222.857
    N57360G1 Z0.262 A226.286
    N57370G1 Z0.255 A229.714
    N57380G1 Z0.255 A233.143
    N57390G1 Z0.251 A236.571
    N57400G1 Z0.250 A240.000
    N57410G1 A243.429
    N57420G1 X1.305
    N57430G1 X1.275 Z0.256
    N57440G1 X1.245 Z0.266
    N57450G1 X1.215 Z0.277
    N57460G1 X1.185 Z0.288
    N57470G1 X1.155 Z0.297
    N57480G1 X1.125 Z0.303
    N57490G1 X1.095 Z0.309
    N57500G1 X1.065 Z0.311
    N57510G1 X1.035 Z0.311
    N57520G1 X1.005 Z0.315
    N57530G0 Z0.700
    N57540G0 X1.095 A120.000
    N57550G0 Z0.515
    N57560G1 Z0.318
    N57570G1 X1.125 Z0.312
    N57580G1 X1.155 Z0.305
    N57590G1 X1.185 Z0.295
    N57600G1 X1.215 Z0.284
    N57610G1 X1.245 Z0.272
    N57620G1 X1.275 Z0.262
    N57630G1 X1.305 Z0.253
    N57640G1 X1.335 Z0.250
    N57650G1 X1.725
    N57660G1 Z0.251 A123.429
    N57670G1 Z0.252 A126.857
    N57680G1 Z0.252 A130.286
    N57690G1 Z0.264 A133.714
    N57700G1 Z0.276 A137.143
    N57710G1 Z0.289 A140.571
    N57720G1 Z0.301 A144.000
    N57730G1 Z0.312 A147.429
    N57740G1 Z0.321 A150.857
    N57750G0 Z0.700
    N57760G0 A209.143
    N57770G0 Z0.509
    N57780G1 Z0.321
    N57790G1 Z0.312 A212.571
    N57800G1 Z0.301 A216.000
    N57810G1 Z0.289 A219.429
    N57820G1 Z0.276 A222.857
    N57830G1 Z0.264 A226.286
    N57840G1 Z0.252 A229.714
    N57850G1 Z0.252 A233.143
    N57860G1 Z0.251 A236.571
    N57870G1 Z0.250 A240.000
    N57880G1 X1.335
    N57890G1 X1.305 Z0.253
    N57900G1 X1.275 Z0.262
    N57910G1 X1.245 Z0.272
    N57920G1 X1.215 Z0.284
    N57930G1 X1.185 Z0.295
    N57940G1 X1.155 Z0.305
    N57950G1 X1.125 Z0.312
    N57960G1 X1.095 Z0.318
    N57970G0 Z0.700
    N57980G0 X1.155 A123.429
    N57990G0 Z0.510
    N58000G1 Z0.313
    N58010G1 X1.185 Z0.303
    N58020G1 X1.215 Z0.290
    N58030G1 X1.245 Z0.278
    N58040G1 X1.275 Z0.267
    N58050G1 X1.305 Z0.259
    N58060G1 X1.335 Z0.253
    N58070G1 X1.365 Z0.250
    N58080G1 X1.695
    N58090G1 A126.857
    N58100G1 Z0.252 A130.286
    N58110G1 Z0.265 A133.714
    N58120G1 Z0.277 A137.143
    N58130G1 Z0.290 A140.571
    N58140G1 Z0.301 A144.000
    N58150G1 Z0.312 A147.429
    N58160G1 Z0.322 A150.857
    N58170G0 Z0.700
    N58180G0 A209.143
    N58190G0 Z0.509
    N58200G1 Z0.322
    N58210G1 Z0.312 A212.571
    N58220G1 Z0.301 A216.000
    N58230G1 Z0.290 A219.429
    N58240G1 Z0.277 A222.857
    N58250G1 Z0.265 A226.286
    N58260G1 Z0.252 A229.714
    N58270G1 Z0.250 A233.143
    N58280G1 A236.571
    N58290G1 X1.365
    N58300G1 X1.335 Z0.253
    N58310G1 X1.305 Z0.259
    N58320G1 X1.275 Z0.267
    N58330G1 X1.245 Z0.278
    N58340G1 X1.215 Z0.290
    N58350G1 X1.185 Z0.303
    N58360G1 X1.155 Z0.313
    N58370G0 Z0.700
    N58380G0 A126.857
    N58390G0 Z0.519
    N58400G1 Z0.322
    N58410G1 X1.185 Z0.311
    N58420G1 X1.215 Z0.297
    N58430G1 X1.245 Z0.284
    N58440G1 X1.275 Z0.273
    N58450G1 X1.305 Z0.265
    N58460G1 X1.335 Z0.259
    N58470G1 X1.365 Z0.255
    N58480G1 X1.395 Z0.252
    N58490G1 X1.425 Z0.250
    N58500G1 X1.665 Z0.250
    N58510G1 Z0.254 A130.286
    N58520G1 Z0.266 A133.714
    N58530G1 Z0.278 A137.143
    N58540G1 Z0.290 A140.571
    N58550G1 Z0.301 A144.000
    N58560G1 Z0.312 A147.429
    N58570G1 Z0.322 A150.857
    N58580G0 Z0.700
    N58590G0 A209.143
    N58600G0 Z0.509
    N58610G1 Z0.322
    N58620G1 Z0.312 A212.571
    N58630G1 Z0.301 A216.000
    N58640G1 Z0.290 A219.429
    N58650G1 Z0.278 A222.857
    N58660G1 Z0.266 A226.286
    N58670G1 Z0.254 A229.714
    N58680G1 Z0.250 A233.143
    N58690G1 X1.425 Z0.250
    N58700G1 X1.395 Z0.252
    N58710G1 X1.365 Z0.255
    N58720G1 X1.335 Z0.259
    N58730G1 X1.305 Z0.265
    N58740G1 X1.275 Z0.273
    N58750G1 X1.245 Z0.284
    N58760G1 X1.215 Z0.297
    N58770G1 X1.185 Z0.311
    N58780G1 X1.155 Z0.322
    N58790G0 Z0.700
    N58800G0 X1.185 A130.286
    N58810G0 Z0.516
    N58820G1 Z0.319
    N58830G1 X1.215 Z0.305
    N58840G1 X1.245 Z0.291
    N58850G1 X1.275 Z0.279
    N58860G1 X1.305 Z0.271
    N58870G1 X1.335 Z0.266
    N58880G1 X1.365 Z0.262
    N58890G1 X1.395 Z0.260
    N58900G1 X1.425 Z0.258
    N58910G1 X1.455 Z0.257
    N58920G1 X1.485 Z0.256
    N58930G1 X1.515 Z0.256
    N58940G1 X1.545 Z0.255
    N58950G1 X1.605 Z0.255
    N58960G1 X1.635 Z0.254
    N58970G1 Z0.266 A133.714
    N58980G1 Z0.278 A137.143
    N58990G1 Z0.290 A140.571
    N59000G1 Z0.301 A144.000
    N59010G1 Z0.312 A147.429
    N59020G1 Z0.321 A150.857
    N59030G0 Z0.700
    N59040G0 A209.143
    N59050G0 Z0.509
    N59060G1 Z0.321
    N59070G1 Z0.312 A212.571
    N59080G1 Z0.301 A216.000
    N59090G1 Z0.290 A219.429
    N59100G1 Z0.278 A222.857
    N59110G1 Z0.266 A226.286
    N59120G1 Z0.254 A229.714
    N59130G1 X1.605 Z0.255
    N59140G1 X1.545 Z0.255
    N59150G1 X1.515 Z0.256
    N59160G1 X1.485 Z0.256
    N59170G1 X1.455 Z0.257
    N59180G1 X1.425 Z0.258
    N59190G1 X1.395 Z0.260
    N59200G1 X1.365 Z0.262
    N59210G1 X1.335 Z0.266
    N59220G1 X1.305 Z0.271
    N59230G1 X1.275 Z0.279
    N59240G1 X1.245 Z0.291
    N59250G1 X1.215 Z0.305
    N59260G1 X1.185 Z0.319
    N59270G0 Z0.700
    N59280G0 A133.714
    N59290G0 Z0.525
    N59300G1 Z0.328
    N59310G1 X1.215 Z0.312
    N59320G1 X1.245 Z0.297
    N59330G1 X1.275 Z0.285
    N59340G1 X1.305 Z0.277
    N59350G1 X1.335 Z0.272
    N59360G1 X1.365 Z0.269
    N59370G1 X1.395 Z0.267
    N59380G1 X1.425 Z0.266
    N59390G1 X1.455 Z0.265
    N59400G1 X1.485 Z0.265
    N59410G1 X1.515 Z0.266
    N59420G1 X1.605 Z0.266
    N59430G1 Z0.278 A137.143
    N59440G1 Z0.289 A140.571
    N59450G1 Z0.300 A144.000
    N59460G1 Z0.311 A147.429
    N59470G1 Z0.319 A150.857
    N59480G0 Z0.700
    N59490G0 A209.143
    N59500G0 Z0.509
    N59510G1 Z0.319
    N59520G1 Z0.311 A212.571
    N59530G1 Z0.300 A216.000
    N59540G1 Z0.289 A219.429
    N59550G1 Z0.278 A222.857
    N59560G1 Z0.266 A226.286
    N59570G1 X1.515 Z0.266
    N59580G1 X1.485 Z0.265
    N59590G1 X1.455 Z0.265
    N59600G1 X1.425 Z0.266
    N59610G1 X1.395 Z0.267
    N59620G1 X1.365 Z0.269
    N59630G1 X1.335 Z0.272
    N59640G1 X1.305 Z0.277
    N59650G1 X1.275 Z0.285
    N59660G1 X1.245 Z0.297
    N59670G1 X1.215 Z0.312
    N59680G1 X1.185 Z0.328
    N59690G0 Z0.700
    N59700G0 X1.215 A137.143
    N59710G0 Z0.516
    N59720G1 Z0.319
    N59730G1 X1.245 Z0.304
    N59740G1 X1.275 Z0.291
    N59750G1 X1.305 Z0.282
    N59760G1 X1.335 Z0.278
    N59770G1 X1.365 Z0.275
    N59780G1 X1.395 Z0.274
    N59790G1 X1.455 Z0.274
    N59800G1 X1.485 Z0.275
    N59810G1 X1.515 Z0.276
    N59820G1 X1.545 Z0.277
    N59830G1 X1.575 Z0.277
    N59840G1 Z0.289 A140.571
    N59850G1 Z0.299 A144.000
    N59860G1 Z0.309 A147.429
    N59870G1 Z0.317 A150.857
    N59880G0 Z0.700
    N59890G0 A209.143
    N59900G0 Z0.509
    N59910G1 Z0.317
    N59920G1 Z0.309 A212.571
    N59930G1 Z0.299 A216.000
    N59940G1 Z0.289 A219.429
    N59950G1 Z0.277 A222.857
    N59960G1 X1.545 Z0.277
    N59970G1 X1.515 Z0.276
    N59980G1 X1.485 Z0.275
    N59990G1 X1.455 Z0.274
    N60000G1 X1.395 Z0.274
    N60010G1 X1.365 Z0.275
    N60020G1 X1.335 Z0.278
    N60030G1 X1.305 Z0.282
    N60040G1 X1.275 Z0.291
    N60050G1 X1.245 Z0.304
    N60060G1 X1.215 Z0.319
    N60070G0 Z0.700
    N60080G0 A140.571
    N60090G0 Z0.523
    N60100G1 Z0.326
    N60110G1 X1.245 Z0.309
    N60120G1 X1.275 Z0.297
    N60130G1 X1.305 Z0.287
    N60140G1 X1.335 Z0.284
    N60150G1 X1.365 Z0.282
    N60160G1 X1.395 Z0.281
    N60170G1 X1.425 Z0.282
    N60180G1 X1.455 Z0.283
    N60190G1 X1.485 Z0.285
    N60200G1 X1.515 Z0.286
    N60210G1 X1.545 Z0.287
    N60220G1 Z0.297 A144.000
    N60230G1 Z0.307 A147.429
    N60240G1 Z0.315 A150.857
    N60250G0 Z0.700
    N60260G0 A209.143
    N60270G0 Z0.509
    N60280G1 Z0.315
    N60290G1 Z0.307 A212.571
    N60300G1 Z0.297 A216.000
    N60310G1 Z0.287 A219.429
    N60320G1 X1.515 Z0.286
    N60330G1 X1.485 Z0.285
    N60340G1 X1.455 Z0.283
    N60350G1 X1.425 Z0.282
    N60360G1 X1.395 Z0.281
    N60370G1 X1.365 Z0.282
    N60380G1 X1.335 Z0.284
    N60390G1 X1.305 Z0.287
    N60400G1 X1.275 Z0.297
    N60410G1 X1.245 Z0.309
    N60420G1 X1.215 Z0.326
    N60430G0 Z0.700
    N60440G0 X1.245 A144.000
    N60450G0 Z0.512
    N60460G1 Z0.315
    N60470G1 X1.275 Z0.302
    N60480G1 X1.305 Z0.293
    N60490G1 X1.335 Z0.289
    N60500G1 X1.365 Z0.287
    N60510G1 X1.395 Z0.288
    N60520G1 X1.425 Z0.289
    N60530G1 X1.455 Z0.291
    N60540G1 X1.485 Z0.294
    N60550G1 X1.515 Z0.296
    N60560G1 Z0.304 A147.429
    N60570G1 Z0.312 A150.857
    N60580G1 Z0.319 A154.286
    N60590G0 Z0.700
    N60600G0 A205.714
    N60610G0 Z0.509
    N60620G1 Z0.319
    N60630G1 Z0.312 A209.143
    N60640G1 Z0.304 A212.571
    N60650G1 Z0.296 A216.000
    N60660G1 X1.485 Z0.294
    N60670G1 X1.455 Z0.291
    N60680G1 X1.425 Z0.289
    N60690G1 X1.395 Z0.288
    N60700G1 X1.365 Z0.287
    N60710G1 X1.335 Z0.289
    N60720G1 X1.305 Z0.293
    N60730G1 X1.275 Z0.302
    N60740G1 X1.245 Z0.315
    N60750G0 Z0.700
    N60760G0 A147.429
    N60770G0 Z0.518
    N60780G1 Z0.321
    N60790G1 X1.275 Z0.307
    N60800G1 X1.305 Z0.298
    N60810G1 X1.335 Z0.294
    N60820G1 X1.365 Z0.293
    N60830G1 X1.395 Z0.294
    N60840G1 X1.425 Z0.296
    N60850G1 X1.455 Z0.299
    N60860G1 X1.485 Z0.302
    N60870G1 Z0.309 A150.857
    N60880G1 Z0.315 A154.286
    N60890G0 Z0.700
    N60900G0 A205.714
    N60910G0 Z0.509
    N60920G1 Z0.315
    N60930G1 Z0.309 A209.143
    N60940G1 Z0.302 A212.571
    N60950G1 X1.455 Z0.299
    N60960G1 X1.425 Z0.296
    N60970G1 X1.395 Z0.294
    N60980G1 X1.365 Z0.293
    N60990G1 X1.335 Z0.294
    N61000G1 X1.305 Z0.298
    N61010G1 X1.275 Z0.307
    N61020G1 Z0.312 A209.143
    N61030G1 Z0.315 A205.714
    N61040G0 Z0.700
    N61050G0 A154.286
    N61060G0 Z0.509
    N61070G1 Z0.315
    N61080G1 Z0.312 A150.857
    N61090G1 X1.305 Z0.302
    N61100G1 X1.335 Z0.299
    N61110G1 X1.365 Z0.298
    N61120G1 X1.395 Z0.300
    N61130G1 X1.425 Z0.302
    N61140G1 X1.455 Z0.306
    N61150G1 Z0.311 A154.286
    N61160G1 Z0.317 A157.714
    N61170G0 Z0.700
    N61180G0 A202.286
    N61190G0 Z0.509
    N61200G1 Z0.317
    N61210G1 Z0.311 A205.714
    N61220G1 Z0.306 A209.143
    N61230G1 X1.425 Z0.302
    N61240G1 X1.395 Z0.300
    N61250G1 X1.365 Z0.298
    N61260G1 X1.335 Z0.299
    N61270G1 X1.305 Z0.302
    N61280G1 Z0.306 A205.714
    N61290G1 Z0.309 A202.286
    N61300G1 Z0.324 A198.857
    N61310G0 Z0.700
    N61320G0 A161.143
    N61330G0 Z0.509
    N61340G1 Z0.324
    N61350G1 Z0.309 A157.714
    N61360G1 Z0.306 A154.286
    N61370G1 X1.335 Z0.303
    N61380G1 X1.365 Z0.303
    N61390G1 X1.395 Z0.305
    N61400G1 X1.425 Z0.308
    N61410G1 Z0.314 A157.714
    N61420G0 Z0.700
    N61430G0 A202.286
    N61440G0 Z0.509
    N61450G1 Z0.314
    N61460G1 Z0.308 A205.714
    N61470G1 X1.395 Z0.305
    N61480G1 X1.365 Z0.303
    N61490G1 X1.335 Z0.303
    N61500G1 Z0.307 A202.286
    N61510G1 Z0.324 A198.857
    N61520G0 Z0.700
    N61530G0 A161.143
    N61540G0 Z0.509
    N61550G1 Z0.324
    N61560G1 Z0.307 A157.714
    N61570G1 X1.365 Z0.308
    N61580G1 X1.395 Z0.310
    N61590G1 Z0.324 A161.143
    N61600G0 Z0.700
    N61610G0 A198.857
    N61620G0 Z0.509
    N61630G1 Z0.324
    N61640G1 Z0.310 A202.286
    N61650G1 X1.365 Z0.308
    N61660G1 Z0.324 A198.857
    N61670G0 Z0.700
    N61680G0 X0.000 A0.000
    N61690G0 Z0.447
    N61700G1 Z0.250
    N61710G1 X0.375 Z0.219 F37.5
    N61720G1 X0.000 Z0.188
    N61730G1 X0.495
    N61740G1 X0.525 Z0.413 F50.0
    N61750G0 Z0.700
    N61760G0 X1.485
    N61770G0 Z0.455
    N61780G1 Z0.259
    N61790G1 X1.515 Z0.235 F37.5
    N61800G1 X1.545 Z0.210
    N61810G1 X1.575 Z0.339 F50.0
    N61820G0 Z0.700
    N61830G0 X2.055
    N61840G0 Z0.471
    N61850G1 Z0.274
    N61860G1 X2.085 Z0.192 F37.5
    N61870G1 X2.115 Z0.188
    N61880G1 X2.750
    N61890G1 A360.000
    N61900G1 X2.115
    N61910G1 X2.085 Z0.192
    N61920G1 X2.055 Z0.274 F50.0
    N61930G0 Z0.700
    N61940G0 X1.575
    N61950G0 Z0.536
    N61960G1 Z0.339
    N61970G1 X1.545 Z0.210 F37.5
    N61980G1 X1.515 Z0.235
    N61990G1 X1.485 Z0.259 F50.0
    N62000G0 Z0.700
    N62010G0 X0.525
    N62020G0 Z0.610
    N62030G1 Z0.413
    N62040G1 X0.495 Z0.188 F37.5
    N62050G1 X0.000
    N62060G1 A3.429
    N62070G1 X0.495 F50.0
    N62080G1 X0.525 Z0.413
    N62090G0 Z0.700
    N62100G0 X1.485
    N62110G0 Z0.455
    N62120G1 Z0.258
    N62130G1 X1.515 Z0.234
    N62140G1 X1.545 Z0.210
    N62150G1 X1.575 Z0.340
    N62160G0 Z0.700
    N62170G0 X2.055
    N62180G0 Z0.472
    N62190G1 Z0.275
    N62200G1 X2.085 Z0.193
    N62210G1 X2.115 Z0.188
    N62220G1 X2.745
    N62230G1 A356.571
    N62240G1 X2.115
    N62250G1 X2.085 Z0.193
    N62260G1 X2.055 Z0.275
    N62270G0 Z0.700
    N62280G0 X1.575
    N62290G0 Z0.537
    N62300G1 Z0.340
    N62310G1 X1.545 Z0.210
    N62320G1 X1.515 Z0.234
    N62330G1 X1.485 Z0.258
    N62340G0 Z0.700
    N62350G0 X0.525
    N62360G0 Z0.610
    N62370G1 Z0.413
    N62380G1 X0.495 Z0.188
    N62390G1 X0.015
    N62400G1 A6.857
    N62410G1 X0.495
    N62420G1 X0.525 Z0.413
    N62430G0 Z0.700
    N62440G0 X1.485
    N62450G0 Z0.450
    N62460G1 Z0.253
    N62470G1 X1.515 Z0.230
    N62480G1 X1.545 Z0.206
    N62490G1 X1.575 Z0.343
    N62500G0 Z0.700
    N62510G0 X2.055
    N62520G0 Z0.471
    N62530G1 Z0.274
    N62540G1 X2.085 Z0.195
    N62550G1 X2.115 Z0.188
    N62560G1 X2.715
    N62570G1 A353.143
    N62580G1 X2.115
    N62590G1 X2.085 Z0.195
    N62600G1 X2.055 Z0.274
    N62610G0 Z0.700
    N62620G0 X1.575
    N62630G0 Z0.540
    N62640G1 Z0.343
    N62650G1 X1.545 Z0.206
    N62660G1 X1.515 Z0.230
    N62670G1 X1.485 Z0.253
    N62680G0 Z0.700
    N62690G0 X0.525
    N62700G0 Z0.610
    N62710G1 Z0.413
    N62720G1 X0.495 Z0.188
    N62730G1 X0.045
    N62740G1 A10.286
    N62750G1 X0.495
    N62760G1 X0.525 Z0.413
    N62770G0 Z0.700
    N62780G0 X1.455
    N62790G0 Z0.468
    N62800G1 Z0.271
    N62810G1 X1.485 Z0.249
    N62820G1 X1.515 Z0.226
    N62830G1 X1.545 Z0.202
    N62840G1 X1.575 Z0.347
    N62850G0 Z0.700
    N62860G0 X2.055
    N62870G0 Z0.459
    N62880G1 Z0.262
    N62890G1 X2.085 Z0.196
    N62900G1 X2.115 Z0.188
    N62910G1 X2.685
    N62920G1 A349.714
    N62930G1 X2.115
    N62940G1 X2.085 Z0.196
    N62950G1 X2.055 Z0.262
    N62960G0 Z0.700
    N62970G0 X1.575
    N62980G0 Z0.544
    N62990G1 Z0.347
    N63000G1 X1.545 Z0.202
    N63010G1 X1.515 Z0.226
    N63020G1 X1.485 Z0.249
    N63030G1 X1.455 Z0.271
    N63040G0 Z0.700
    N63050G0 X0.525
    N63060G0 Z0.610
    N63070G1 Z0.413
    N63080G1 X0.495 Z0.188
    N63090G1 X0.075
    N63100G1 A13.714
    N63110G1 X0.495
    N63120G1 X0.525 Z0.413
    N63130G0 Z0.700
    N63140G0 X1.455
    N63150G0 Z0.463
    N63160G1 Z0.266
    N63170G1 X1.485 Z0.244
    N63180G1 X1.515 Z0.222
    N63190G1 X1.545 Z0.198
    N63200G1 X1.575 Z0.348
    N63210G0 Z0.700
    N63220G0 X2.055
    N63230G0 Z0.453
    N63240G1 Z0.256
    N63250G1 X2.085 Z0.196
    N63260G1 X2.115 Z0.188
    N63270G1 X2.655
    N63280G1 A346.286
    N63290G1 X2.115
    N63300G1 X2.085 Z0.196
    N63310G1 X2.055 Z0.256
    N63320G0 Z0.700
    N63330G0 X1.575
    N63340G0 Z0.545
    N63350G1 Z0.348
    N63360G1 X1.545 Z0.198
    N63370G1 X1.515 Z0.222
    N63380G1 X1.485 Z0.244
    N63390G1 X1.455 Z0.266
    N63400G0 Z0.700
    N63410G0 X0.525
    N63420G0 Z0.610
    N63430G1 Z0.413
    N63440G1 X0.495 Z0.188
    N63450G1 X0.105
    N63460G1 A17.143
    N63470G1 X0.495
    N63480G1 X0.525 Z0.413
    N63490G0 Z0.700
    N63500G0 X1.455
    N63510G0 Z0.458
    N63520G1 Z0.261
    N63530G1 X1.485 Z0.240
    N63540G1 X1.515 Z0.218
    N63550G1 X1.545 Z0.195
    N63560G1 X1.575 Z0.340
    N63570G0 Z0.700
    N63580G0 X2.025
    N63590G0 Z0.533
    N63600G1 Z0.336
    N63610G1 X2.055 Z0.240
    N63620G1 X2.085 Z0.195
    N63630G1 X2.115 Z0.188
    N63640G1 X2.625
    N63650G1 A342.857
    N63660G1 X2.115
    N63670G1 X2.085 Z0.195
    N63680G1 X2.055 Z0.240
    N63690G1 X2.025 Z0.336
    N63700G0 Z0.700
    N63710G0 X1.575
    N63720G0 Z0.536
    N63730G1 Z0.340
    N63740G1 X1.545 Z0.195
    N63750G1 X1.515 Z0.218
    N63760G1 X1.485 Z0.240
    N63770G1 X1.455 Z0.261
    N63780G0 Z0.700
    N63790G0 X0.525
    N63800G0 Z0.610
    N63810G1 Z0.413
    N63820G1 X0.495 Z0.188
    N63830G1 X0.135
    N63840G1 A20.571
    N63850G1 X0.495
    N63860G1 X0.525 Z0.413
    N63870G0 Z0.700
    N63880G0 X1.455
    N63890G0 Z0.453
    N63900G1 Z0.256
    N63910G1 X1.485 Z0.235
    N63920G1 X1.515 Z0.214
    N63930G1 X1.545 Z0.192
    N63940G1 X1.575 Z0.334
    N63950G0 Z0.700
    N63960G0 X2.025
    N63970G0 Z0.530
    N63980G1 Z0.333
    N63990G1 X2.055 Z0.229
    N64000G1 X2.085 Z0.191
    N64010G1 X2.115 Z0.188
    N64020G1 X2.595
    N64030G1 A339.429
    N64040G1 X2.115
    N64050G1 X2.085 Z0.191
    N64060G1 X2.055 Z0.229
    N64070G1 X2.025 Z0.333
    N64080G0 Z0.700
    N64090G0 X1.575
    N64100G0 Z0.531
    N64110G1 Z0.334
    N64120G1 X1.545 Z0.192
    N64130G1 X1.515 Z0.214
    N64140G1 X1.485 Z0.235
    N64150G1 X1.455 Z0.256
    N64160G0 Z0.700
    N64170G0 X0.525
    N64180G0 Z0.610
    N64190G1 Z0.413
    N64200G1 X0.495 Z0.188
    N64210G1 X0.165
    N64220G1 A24.000
    N64230G1 X0.495
    N64240G1 X0.525 Z0.413
    N64250G0 Z0.700
    N64260G0 X1.455
    N64270G0 Z0.447
    N64280G1 Z0.251
    N64290G1 X1.485 Z0.231
    N64300G1 X1.515 Z0.210
    N64310G1 X1.545 Z0.189
    N64320G1 X1.575 Z0.188 F37.5
    N64330G1 X1.605 Z0.331
    N64340G0 Z0.700
    N64350G0 X2.025
    N64360G0 Z0.478
    N64370G1 Z0.281 F50.0
    N64380G1 X2.055 Z0.223
    N64390G1 X2.085 Z0.188
    N64400G1 X2.565
    N64410G1 A336.000
    N64420G1 X2.085
    N64430G1 X2.055 Z0.223
    N64440G1 X2.025 Z0.281
    N64450G0 Z0.700
    N64460G0 X1.605
    N64470G0 Z0.528
    N64480G1 Z0.331
    N64490G1 X1.575 Z0.188 F37.5
    N64500G1 X1.545 Z0.189
    N64510G1 X1.515 Z0.210 F50.0
    N64520G1 X1.485 Z0.231
    N64530G1 X1.455 Z0.251
    N64540G0 Z0.700
    N64550G0 X0.525
    N64560G0 Z0.610
    N64570G1 Z0.413
    N64580G1 X0.495 Z0.188
    N64590G1 X0.195
    N64600G1 A27.429
    N64610G1 X0.495
    N64620G1 X0.525 Z0.413
    N64630G0 Z0.700
    N64640G0 X1.425
    N64650G0 Z0.461
    N64660G1 Z0.264
    N64670G1 X1.455 Z0.245
    N64680G1 X1.485 Z0.226
    N64690G1 X1.515 Z0.207
    N64700G1 X1.545 Z0.188
    N64710G1 X1.575
    N64720G1 X1.605 Z0.311
    N64730G0 Z0.700
    N64740G0 X2.025
    N64750G0 Z0.449
    N64760G1 Z0.252
    N64770G1 X2.055 Z0.217
    N64780G1 X2.085 Z0.188
    N64790G1 X2.535
    N64800G1 A332.571
    N64810G1 X2.085
    N64820G1 X2.055 Z0.217
    N64830G1 X2.025 Z0.252
    N64840G0 Z0.700
    N64850G0 X1.605
    N64860G0 Z0.508
    N64870G1 Z0.311
    N64880G1 X1.575 Z0.188
    N64890G1 X1.545
    N64900G1 X1.515 Z0.207
    N64910G1 X1.485 Z0.226
    N64920G1 X1.455 Z0.245
    N64930G1 X1.425 Z0.264
    N64940G0 Z0.700
    N64950G0 X0.525
    N64960G0 Z0.610
    N64970G1 Z0.413
    N64980G1 X0.495 Z0.188
    N64990G1 X0.225
    N65000G1 A30.857
    N65010G1 X0.495
    N65020G1 X0.525 Z0.413
    N65030G0 Z0.700
    N65040G0 X1.425
    N65050G0 Z0.455
    N65060G1 Z0.258
    N65070G1 X1.455 Z0.240
    N65080G1 X1.485 Z0.222
    N65090G1 X1.515 Z0.203
    N65100G1 X1.545 Z0.188
    N65110G1 X1.575
    N65120G1 X1.605 F37.5
    N65130G1 X1.635 Z0.269
    N65140G0 Z0.700
    N65150G0 X1.995
    N65160G0 Z0.462
    N65170G1 Z0.265 F50.0
    N65180G1 X2.025 Z0.237 F37.5
    N65190G1 X2.055 Z0.208
    N65200G1 X2.085 Z0.188 F50.0
    N65210G1 X2.505
    N65220G1 A329.143
    N65230G1 X2.085
    N65240G1 X2.055 Z0.208
    N65250G1 X2.025 Z0.237 F37.5
    N65260G1 X1.995 Z0.265
    N65270G0 Z0.700
    N65280G0 X1.635
    N65290G0 Z0.466
    N65300G1 Z0.269 F50.0
    N65310G1 X1.605 Z0.188 F37.5
    N65320G1 X1.575
    N65330G1 X1.545 F50.0
    N65340G1 X1.515 Z0.203
    N65350G1 X1.485 Z0.222
    N65360G1 X1.455 Z0.240
    N65370G1 X1.425 Z0.258
    N65380G0 Z0.700
    N65390G0 X0.525
    N65400G0 Z0.610
    N65410G1 Z0.413
    N65420G1 X0.495 Z0.188
    N65430G1 X0.255
    N65440G1 A34.286
    N65450G1 X0.495
    N65460G1 X0.525 Z0.413
    N65470G0 Z0.700
    N65480G0 X1.425
    N65490G0 Z0.449
    N65500G1 Z0.252
    N65510G1 X1.455 Z0.235
    N65520G1 X1.485 Z0.218
    N65530G1 X1.515 Z0.200
    N65540G1 X1.545 Z0.188
    N65550G1 X1.605
    N65560G1 X1.635 F37.5
    N65570G1 X1.665 Z0.190
    N65580G1 X1.695 Z0.241
    N65590G1 X1.725 Z0.252 F50.0
    N65600G1 Z0.449
    N65610G1 X1.965
    N65620G1 Z0.252
    N65630G1 X1.995 Z0.241
    N65640G1 X2.025 Z0.231
    N65650G1 X2.055 Z0.204
    N65660G1 X2.085 Z0.188
    N65670G1 X2.475
    N65680G1 A325.714
    N65690G1 X2.085
    N65700G1 X2.055 Z0.204
    N65710G1 X2.025 Z0.231
    N65720G1 X1.995 Z0.241
    N65730G1 X1.965 Z0.252
    N65740G1 Z0.449
    N65750G1 X1.725
    N65760G1 Z0.252
    N65770G1 X1.695 Z0.241
    N65780G1 X1.665 Z0.190 F37.5
    N65790G1 X1.635 Z0.188
    N65800G1 X1.605
    N65810G1 X1.545 F50.0
    N65820G1 X1.515 Z0.200
    N65830G1 X1.485 Z0.218
    N65840G1 X1.455 Z0.235
    N65850G1 X1.425 Z0.252
    N65860G0 Z0.700
    N65870G0 X0.525
    N65880G0 Z0.610
    N65890G1 Z0.413
    N65900G1 X0.495 Z0.188
    N65910G1 X0.285
    N65920G1 A37.714
    N65930G1 X0.495
    N65940G1 X0.525 Z0.413
    N65950G0 Z0.700
    N65960G0 X1.395
    N65970G0 Z0.458
    N65980G1 Z0.261
    N65990G1 X1.425 Z0.246
    N66000G1 X1.455 Z0.230
    N66010G1 X1.485 Z0.213
    N66020G1 X1.515 Z0.197
    N66030G1 X1.545 Z0.188
    N66040G1 X1.665
    N66050G1 X1.695 Z0.193 F37.5
    N66060G1 X1.725 Z0.221
    N66070G1 X1.755 Z0.231
    N66080G1 X1.965 Z0.231
    N66090G1 X1.995 Z0.228
    N66100G1 X2.025 Z0.221
    N66110G1 X2.055 Z0.202 F50.0
    N66120G1 X2.085 Z0.188
    N66130G1 X2.445
    N66140G1 A322.286
    N66150G1 X2.085
    N66160G1 X2.055 Z0.202
    N66170G1 X2.025 Z0.221
    N66180G1 X1.995 Z0.228 F37.5
    N66190G1 X1.965 Z0.231
    N66200G1 X1.755 Z0.231
    N66210G1 X1.725 Z0.221
    N66220G1 X1.695 Z0.193
    N66230G1 X1.665 Z0.188
    N66240G1 X1.545 F50.0
    N66250G1 X1.515 Z0.197
    N66260G1 X1.485 Z0.213
    N66270G1 X1.455 Z0.230
    N66280G1 X1.425 Z0.246
    N66290G1 X1.395 Z0.261
    N66300G0 Z0.700
    N66310G0 X0.525
    N66320G0 Z0.610
    N66330G1 Z0.413
    N66340G1 X0.495 Z0.188
    N66350G1 X0.315
    N66360G1 A41.143
    N66370G1 X0.495
    N66380G1 X0.525 Z0.413
    N66390G0 Z0.700
    N66400G0 X1.395
    N66410G0 Z0.451
    N66420G1 Z0.254
    N66430G1 X1.425 Z0.240
    N66440G1 X1.455 Z0.225
    N66450G1 X1.485 Z0.209
    N66460G1 X1.515 Z0.194
    N66470G1 X1.545 Z0.188
    N66480G1 X1.695
    N66490G1 X1.725 Z0.208
    N66500G1 X1.755 Z0.215 F37.5
    N66510G1 X1.935 Z0.215
    N66520G1 X1.965 Z0.216
    N66530G1 X1.995 Z0.216
    N66540G1 X2.025 Z0.210 F50.0
    N66550G1 X2.055 Z0.196
    N66560G1 X2.085 Z0.188
    N66570G1 X2.415
    N66580G1 A318.857
    N66590G1 X2.085
    N66600G1 X2.055 Z0.196
    N66610G1 X2.025 Z0.210
    N66620G1 X1.995 Z0.216
    N66630G1 X1.965 Z0.216 F37.5
    N66640G1 X1.935 Z0.215
    N66650G1 X1.755 Z0.215
    N66660G1 X1.725 Z0.208
    N66670G1 X1.695 Z0.188 F50.0
    N66680G1 X1.545
    N66690G1 X1.515 Z0.194
    N66700G1 X1.485 Z0.209
    N66710G1 X1.455 Z0.225
    N66720G1 X1.425 Z0.240
    N66730G1 X1.395 Z0.254
    N66740G0 Z0.700
    N66750G0 X0.525
    N66760G0 Z0.610
    N66770G1 Z0.413
    N66780G1 X0.495 Z0.188
    N66790G1 X0.345
    N66800G1 A44.571
    N66810G1 X0.495
    N66820G1 X0.525 Z0.413
    N66830G0 Z0.700
    N66840G0 X1.365
    N66850G0 Z0.457
    N66860G1 Z0.260
    N66870G1 X1.395 Z0.248
    N66880G1 X1.425 Z0.234
    N66890G1 X1.455 Z0.220
    N66900G1 X1.485 Z0.205
    N66910G1 X1.515 Z0.191
    N66920G1 X1.545 Z0.188
    N66930G1 X1.695
    N66940G1 X1.725 Z0.198
    N66950G1 X1.755 Z0.205
    N66960G1 X1.905 Z0.205
    N66970G1 X1.935 Z0.210
    N66980G1 X1.965 Z0.216
    N66990G1 X1.995 Z0.216
    N67000G1 X2.025 Z0.209
    N67010G1 X2.055 Z0.196
    N67020G1 X2.085 Z0.188
    N67030G1 X2.385
    N67040G1 A315.429
    N67050G1 X2.085
    N67060G1 X2.055 Z0.196
    N67070G1 X2.025 Z0.209
    N67080G1 X1.995 Z0.216
    N67090G1 X1.965 Z0.216
    N67100G1 X1.935 Z0.210
    N67110G1 X1.905 Z0.205
    N67120G1 X1.755 Z0.205
    N67130G1 X1.725 Z0.198
    N67140G1 X1.695 Z0.188
    N67150G1 X1.545
    N67160G1 X1.515 Z0.191
    N67170G1 X1.485 Z0.205
    N67180G1 X1.455 Z0.220
    N67190G1 X1.425 Z0.234
    N67200G1 X1.395 Z0.248
    N67210G1 X1.365 Z0.260
    N67220G0 Z0.700
    N67230G0 X0.525
    N67240G0 Z0.610
    N67250G1 Z0.413
    N67260G1 X0.495 Z0.188
    N67270G1 X0.375
    N67280G1 A48.000
    N67290G1 X0.495
    N67300G1 X0.525 Z0.413
    N67310G0 Z0.700
    N67320G0 X1.365
    N67330G0 Z0.450
    N67340G1 Z0.253
    N67350G1 X1.395 Z0.241
    N67360G1 X1.425 Z0.229
    N67370G1 X1.455 Z0.215
    N67380G1 X1.485 Z0.202
    N67390G1 X1.515 Z0.188
    N67400G1 X1.695 Z0.188
    N67410G1 X1.725 Z0.189
    N67420G1 X1.755 Z0.196
    N67430G1 X1.875 Z0.196
    N67440G1 X1.905 Z0.198
    N67450G1 X1.935 Z0.204
    N67460G1 X1.965 Z0.209
    N67470G1 X1.995 Z0.212
    N67480G1 X2.025 Z0.205
    N67490G1 X2.055 Z0.197
    N67500G1 X2.085 Z0.188
    N67510G1 X2.355
    N67520G1 A312.000
    N67530G1 X2.085
    N67540G1 X2.055 Z0.197
    N67550G1 X2.025 Z0.205
    N67560G1 X1.995 Z0.212
    N67570G1 X1.965 Z0.209
    N67580G1 X1.935 Z0.204
    N67590G1 X1.905 Z0.198
    N67600G1 X1.875 Z0.196
    N67610G1 X1.755 Z0.196
    N67620G1 X1.725 Z0.189
    N67630G1 X1.695 Z0.188
    N67640G1 X1.515 Z0.188
    N67650G1 X1.485 Z0.202
    N67660G1 X1.455 Z0.215
    N67670G1 X1.425 Z0.229
    N67680G1 X1.395 Z0.241
    N67690G1 X1.365 Z0.253
    N67700G0 Z0.700
    N67710G0 X0.525
    N67720G0 Z0.610
    N67730G1 Z0.413
    N67740G1 X0.495 Z0.188
    N67750G1 X0.405
    N67760G1 A51.429
    N67770G1 X0.495
    N67780G1 X0.525 Z0.413
    N67790G0 Z0.700
    N67800G0 X1.335
    N67810G0 Z0.453
    N67820G1 Z0.257
    N67830G1 X1.365 Z0.246
    N67840G1 X1.395 Z0.235
    N67850G1 X1.425 Z0.223
    N67860G1 X1.455 Z0.210
    N67870G1 X1.485 Z0.198
    N67880G1 X1.515 Z0.188
    N67890G1 X1.725
    N67900G1 X1.755 Z0.189
    N67910G1 X1.845 Z0.189
    N67920G1 X1.875 Z0.190
    N67930G1 X1.905 Z0.199
    N67940G1 X1.935 Z0.205
    N67950G1 X1.965 Z0.207
    N67960G1 X1.995 Z0.207
    N67970G1 X2.025 Z0.203
    N67980G1 X2.055 Z0.197
    N67990G1 X2.085 Z0.188
    N68000G1 X2.325
    N68010G1 A308.571
    N68020G1 X2.085
    N68030G1 X2.055 Z0.197
    N68040G1 X2.025 Z0.203
    N68050G1 X1.995 Z0.207
    N68060G1 X1.965 Z0.207
    N68070G1 X1.935 Z0.205
    N68080G1 X1.905 Z0.199
    N68090G1 X1.875 Z0.190
    N68100G1 X1.845 Z0.189
    N68110G1 X1.755 Z0.189
    N68120G1 X1.725 Z0.188
    N68130G1 X1.515
    N68140G1 X1.485 Z0.198
    N68150G1 X1.455 Z0.210
    N68160G1 X1.425 Z0.223
    N68170G1 X1.395 Z0.235
    N68180G1 X1.365 Z0.246
    N68190G1 X1.335 Z0.257
    N68200G0 Z0.700
    N68210G0 X0.525
    N68220G0 Z0.610
    N68230G1 Z0.413
    N68240G1 X0.495 Z0.188
    N68250G1 X0.435
    N68260G1 A54.857
    N68270G1 X0.495
    N68280G1 X0.525 Z0.413
    N68290G0 Z0.700
    N68300G0 X1.335
    N68310G0 Z0.447
    N68320G1 Z0.250
    N68330G1 X1.365 Z0.240
    N68340G1 X1.395 Z0.229
    N68350G1 X1.425 Z0.218
    N68360G1 X1.455 Z0.206
    N68370G1 X1.485 Z0.195
    N68380G1 X1.515 Z0.188
    N68390G1 X1.845
    N68400G1 X1.875 Z0.190
    N68410G1 X1.905 Z0.199
    N68420G1 X1.935 Z0.205
    N68430G1 X1.965 Z0.205
    N68440G1 X1.995 Z0.204
    N68450G1 X2.025 Z0.202
    N68460G1 X2.055 Z0.196
    N68470G1 X2.085 Z0.188
    N68480G1 X2.295
    N68490G1 A305.143
    N68500G1 X2.085
    N68510G1 X2.055 Z0.196
    N68520G1 X2.025 Z0.202
    N68530G1 X1.995 Z0.204
    N68540G1 X1.965 Z0.205
    N68550G1 X1.935 Z0.205
    N68560G1 X1.905 Z0.199
    N68570G1 X1.875 Z0.190
    N68580G1 X1.845 Z0.188
    N68590G1 X1.515
    N68600G1 X1.485 Z0.195
    N68610G1 X1.455 Z0.206
    N68620G1 X1.425 Z0.218
    N68630G1 X1.395 Z0.229
    N68640G1 X1.365 Z0.240
    N68650G1 X1.335 Z0.250
    N68660G0 Z0.700
    N68670G0 X0.525
    N68680G0 Z0.610
    N68690G1 Z0.413
    N68700G1 X0.495 Z0.188
    N68710G1 X0.465
    N68720G1 A58.286
    N68730G1 X0.495
    N68740G1 X0.525 Z0.413
    N68750G0 Z0.700
    N68760G0 X1.305
    N68770G0 Z0.449
    N68780G1 Z0.253
    N68790G1 X1.335 Z0.244
    N68800G1 X1.365 Z0.234
    N68810G1 X1.395 Z0.224
    N68820G1 X1.425 Z0.213
    N68830G1 X1.455 Z0.203
    N68840G1 X1.485 Z0.192
    N68850G1 X1.515 Z0.188
    N68860G1 X1.845
    N68870G1 X1.875 Z0.190
    N68880G1 X1.905 Z0.199
    N68890G1 X1.935 Z0.205
    N68900G1 X1.965 Z0.205
    N68910G1 X1.995 Z0.198
    N68920G1 X2.025 Z0.199
    N68930G1 X2.055 Z0.193
    N68940G1 X2.085 Z0.188
    N68950G1 X2.265
    N68960G1 A301.714
    N68970G1 X2.085
    N68980G1 X2.055 Z0.193
    N68990G1 X2.025 Z0.199
    N69000G1 X1.995 Z0.198
    N69010G1 X1.965 Z0.205
    N69020G1 X1.935 Z0.205
    N69030G1 X1.905 Z0.199
    N69040G1 X1.875 Z0.190
    N69050G1 X1.845 Z0.188
    N69060G1 X1.515
    N69070G1 X1.485 Z0.192
    N69080G1 X1.455 Z0.203
    N69090G1 X1.425 Z0.213
    N69100G1 X1.395 Z0.224
    N69110G1 X1.365 Z0.234
    N69120G1 X1.335 Z0.244
    N69130G1 X1.305 Z0.253
    N69140G0 Z0.700
    N69150G0 X0.525
    N69160G0 Z0.610
    N69170G1 Z0.413
    N69180G1 X0.495 Z0.188
    N69190G1 A298.286 F37.5
    N69200G1 A61.714 F50.0
    N69210G1 X0.525 Z0.413
    N69220G0 Z0.700
    N69230G0 X1.275
    N69240G0 Z0.451
    N69250G1 Z0.254
    N69260G1 X1.305 Z0.246
    N69270G1 X1.335 Z0.238
    N69280G1 X1.365 Z0.229
    N69290G1 X1.395 Z0.219
    N69300G1 X1.425 Z0.209
    N69310G1 X1.455 Z0.199
    N69320G1 X1.485 Z0.189
    N69330G1 X1.515 Z0.188
    N69340G1 X1.845
    N69350G1 X1.875 Z0.189
    N69360G1 X1.905 Z0.197
    N69370G1 X1.935 Z0.204
    N69380G1 X1.965 Z0.203
    N69390G1 X1.995 Z0.197
    N69400G1 X2.025 Z0.197
    N69410G1 X2.055 Z0.191
    N69420G1 X2.085 Z0.188
    N69430G1 X2.235
    N69440G1 A161.143
    N69450G1 Z0.243 A164.571
    N69460G1 Z0.253 A168.000
    N69470G1 Z0.465
    N69480G1 A192.000
    N69490G1 Z0.253
    N69500G1 Z0.243 A195.429
    N69510G1 Z0.188 A198.857
    N69520G1 A298.286
    N69530G1 X2.085
    N69540G1 X2.055 Z0.191
    N69550G1 X2.025 Z0.197
    N69560G1 X1.995 Z0.197
    N69570G1 X1.965 Z0.203
    N69580G1 X1.935 Z0.204
    N69590G1 X1.905 Z0.197
    N69600G1 X1.875 Z0.189
    N69610G1 X1.845 Z0.188
    N69620G1 X1.515
    N69630G1 X1.485 Z0.189
    N69640G1 X1.455 Z0.199
    N69650G1 X1.425 Z0.209
    N69660G1 X1.395 Z0.219
    N69670G1 X1.365 Z0.229
    N69680G1 X1.335 Z0.238
    N69690G1 X1.305 Z0.246
    N69700G1 X1.275 Z0.254
    N69710G0 Z0.700
    N69720G0 X1.245 A65.143
    N69730G0 Z0.453
    N69740G1 Z0.256
    N69750G1 X1.275 Z0.249
    N69760G1 X1.305 Z0.242
    N69770G1 X1.335 Z0.233
    N69780G1 X1.365 Z0.224
    N69790G1 X1.395 Z0.215
    N69800G1 X1.425 Z0.206
    N69810G1 X1.455 Z0.197
    N69820G1 X1.485 Z0.188
    N69830G1 X1.875
    N69840G1 X1.905 Z0.194
    N69850G1 X1.935 Z0.200
    N69860G1 X1.965 Z0.200
    N69870G1 X1.995 Z0.197
    N69880G1 X2.025 Z0.196
    N69890G1 X2.055 Z0.190
    N69900G1 X2.085 Z0.188
    N69910G1 X2.205
    N69920G1 A154.286
    N69930G1 Z0.233 A157.714
    N69940G1 Z0.246 A161.143
    N69950G1 Z0.271 A164.571
    N69960G1 Z0.489
    N69970G1 A195.429
    N69980G1 Z0.271
    N69990G1 Z0.246 A198.857
    N70000G1 Z0.233 A202.286
    N70010G1 Z0.188 A205.714
    N70020G1 A294.857
    N70030G1 X2.085
    N70040G1 X2.055 Z0.190
    N70050G1 X2.025 Z0.196
    N70060G1 X1.995 Z0.197
    N70070G1 X1.965 Z0.200
    N70080G1 X1.935 Z0.200
    N70090G1 X1.905 Z0.194
    N70100G1 X1.875 Z0.188
    N70110G1 X1.485
    N70120G1 X1.455 Z0.197
    N70130G1 X1.425 Z0.206
    N70140G1 X1.395 Z0.215
    N70150G1 X1.365 Z0.224
    N70160G1 X1.335 Z0.233
    N70170G1 X1.305 Z0.242
    N70180G1 X1.275 Z0.249
    N70190G1 X1.245 Z0.256
    N70200G0 Z0.700
    N70210G0 A68.571
    N70220G0 Z0.449
    N70230G1 Z0.252
    N70240G1 X1.275 Z0.245
    N70250G1 X1.305 Z0.238
    N70260G1 X1.335 Z0.229
    N70270G1 X1.365 Z0.221
    N70280G1 X1.395 Z0.212
    N70290G1 X1.425 Z0.203
    N70300G1 X1.455 Z0.194
    N70310G1 X1.485 Z0.188
    N70320G1 X1.905 Z0.188
    N70330G1 X1.935 Z0.194
    N70340G1 X1.965 Z0.199
    N70350G1 X1.995 Z0.199
    N70360G1 X2.025 Z0.195
    N70370G1 X2.055 Z0.189
    N70380G1 X2.085 Z0.188
    N70390G1 X2.175
    N70400G1 A154.286
    N70410G1 Z0.245 A157.714
    N70420G1 Z0.263 A161.143
    N70430G1 Z0.544
    N70440G1 A198.857
    N70450G1 Z0.263
    N70460G1 Z0.245 A202.286
    N70470G1 Z0.188 A205.714
    N70480G1 A291.429
    N70490G1 X2.085
    N70500G1 X2.055 Z0.189
    N70510G1 X2.025 Z0.195
    N70520G1 X1.995 Z0.199
    N70530G1 X1.965 Z0.199
    N70540G1 X1.935 Z0.194
    N70550G1 X1.905 Z0.188
    N70560G1 X1.485 Z0.188
    N70570G1 X1.455 Z0.194
    N70580G1 X1.425 Z0.203
    N70590G1 X1.395 Z0.212
    N70600G1 X1.365 Z0.221
    N70610G1 X1.335 Z0.229
    N70620G1 X1.305 Z0.238
    N70630G1 X1.275 Z0.245
    N70640G1 X1.245 Z0.252
    N70650G0 Z0.700
    N70660G0 X1.215 A72.000
    N70670G0 Z0.452
    N70680G1 Z0.255
    N70690G1 X1.245 Z0.249
    N70700G1 X1.275 Z0.242
    N70710G1 X1.305 Z0.234
    N70720G1 X1.335 Z0.226
    N70730G1 X1.365 Z0.218
    N70740G1 X1.395 Z0.209
    N70750G1 X1.425 Z0.201
    N70760G1 X1.455 Z0.192
    N70770G1 X1.485 Z0.188
    N70780G1 X1.875
    N70790G1 X1.905 Z0.189
    N70800G1 X1.935 Z0.196
    N70810G1 X1.965 Z0.201
    N70820G1 X1.995 Z0.201
    N70830G1 X2.025 Z0.195
    N70840G1 X2.055 Z0.188
    N70850G1 X2.145
    N70860G1 A133.714
    N70870G1 Z0.212 A137.143
    N70880G1 Z0.263 A140.571
    N70890G0 Z0.700
    N70900G0 A219.429
    N70910G0 Z0.447
    N70920G1 Z0.262
    N70930G1 Z0.212 A222.857
    N70940G1 Z0.188 A226.286
    N70950G1 A288.000
    N70960G1 X2.055
    N70970G1 X2.025 Z0.195
    N70980G1 X1.995 Z0.201
    N70990G1 X1.965 Z0.201
    N71000G1 X1.935 Z0.196
    N71010G1 X1.905 Z0.189
    N71020G1 X1.875 Z0.188
    N71030G1 X1.485
    N71040G1 X1.455 Z0.192
    N71050G1 X1.425 Z0.201
    N71060G1 X1.395 Z0.209
    N71070G1 X1.365 Z0.218
    N71080G1 X1.335 Z0.226
    N71090G1 X1.305 Z0.234
    N71100G1 X1.275 Z0.242
    N71110G1 X1.245 Z0.249
    N71120G1 X1.215 Z0.255
    N71130G0 Z0.700
    N71140G0 A75.429
    N71150G0 Z0.449
    N71160G1 Z0.252
    N71170G1 X1.245 Z0.246
    N71180G1 X1.275 Z0.239
    N71190G1 X1.305 Z0.231
    N71200G1 X1.335 Z0.223
    N71210G1 X1.365 Z0.215
    N71220G1 X1.395 Z0.207
    N71230G1 X1.425 Z0.198
    N71240G1 X1.455 Z0.190
    N71250G1 X1.485 Z0.188
    N71260G1 X1.875
    N71270G1 X1.905 Z0.196
    N71280G1 X1.935 Z0.203
    N71290G1 X1.965 Z0.204
    N71300G1 X1.995 Z0.204
    N71310G1 X2.025 Z0.198
    N71320G1 X2.055 Z0.188
    N71330G1 X2.115
    N71340G1 A123.429
    N71350G1 Z0.207 A126.857
    N71360G1 Z0.236 A130.286
    N71370G1 Z0.250 A133.714
    N71380G0 Z0.700
    N71390G0 A226.286
    N71400G0 Z0.447
    N71410G1 Z0.251
    N71420G1 Z0.235 A229.714
    N71430G1 Z0.207 A233.143
    N71440G1 Z0.188 A236.571
    N71450G1 A284.571
    N71460G1 X2.055
    N71470G1 X2.025 Z0.198
    N71480G1 X1.995 Z0.204
    N71490G1 X1.965 Z0.204
    N71500G1 X1.935 Z0.203
    N71510G1 X1.905 Z0.196
    N71520G1 X1.875 Z0.188
    N71530G1 X1.485
    N71540G1 X1.455 Z0.190
    N71550G1 X1.425 Z0.198
    N71560G1 X1.395 Z0.207
    N71570G1 X1.365 Z0.215
    N71580G1 X1.335 Z0.223
    N71590G1 X1.305 Z0.231
    N71600G1 X1.275 Z0.239
    N71610G1 X1.245 Z0.246
    N71620G1 X1.215 Z0.252
    N71630G0 Z0.700
    N71640G0 A78.857
    N71650G0 Z0.447
    N71660G1 Z0.250
    N71670G1 X1.245 Z0.244
    N71680G1 X1.275 Z0.237
    N71690G1 X1.305 Z0.229
    N71700G1 X1.335 Z0.221
    N71710G1 X1.365 Z0.213
    N71720G1 X1.395 Z0.205
    N71730G1 X1.425 Z0.197
    N71740G1 X1.455 Z0.189
    N71750G1 X1.485 Z0.188
    N71760G1 X1.875
    N71770G1 X1.905 Z0.200
    N71780G1 X1.935 Z0.207
    N71790G1 X1.965 Z0.208
    N71800G1 X1.995 Z0.205
    N71810G1 X2.025 Z0.199
    N71820G1 X2.055 Z0.188
    N71830G1 X2.085
    N71840G1 A113.143
    N71850G1 Z0.193 A116.571
    N71860G1 Z0.213 A120.000
    N71870G1 Z0.228 A123.429
    N71880G1 Z0.237 A126.857
    N71890G1 Z0.264 A130.286
    N71900G0 Z0.700
    N71910G0 A229.714
    N71920G0 Z0.447
    N71930G1 Z0.264
    N71940G1 Z0.237 A233.143
    N71950G1 Z0.228 A236.571
    N71960G1 Z0.213 A240.000
    N71970G1 Z0.193 A243.429
    N71980G1 Z0.188 A246.857
    N71990G1 A281.143
    N72000G1 X2.055
    N72010G1 X2.025 Z0.199
    N72020G1 X1.995 Z0.205
    N72030G1 X1.965 Z0.208
    N72040G1 X1.935 Z0.207
    N72050G1 X1.905 Z0.200
    N72060G1 X1.875 Z0.188
    N72070G1 X1.485
    N72080G1 X1.455 Z0.189
    N72090G1 X1.425 Z0.197
    N72100G1 X1.395 Z0.205
    N72110G1 X1.365 Z0.213
    N72120G1 X1.335 Z0.221
    N72130G1 X1.305 Z0.229
    N72140G1 X1.275 Z0.237
    N72150G1 X1.245 Z0.244
    N72160G1 X1.215 Z0.250
    N72170G0 Z0.700
    N72180G0 X1.185 A82.286
    N72190G0 Z0.452
    N72200G1 Z0.255
    N72210G1 X1.215 Z0.248
    N72220G1 X1.245 Z0.242
    N72230G1 X1.275 Z0.235
    N72240G1 X1.305 Z0.227
    N72250G1 X1.335 Z0.219
    N72260G1 X1.365 Z0.211
    N72270G1 X1.395 Z0.203
    N72280G1 X1.425 Z0.196
    N72290G1 X1.455 Z0.188
    N72300G1 X1.635 Z0.188
    N72310G1 X1.665 Z0.190
    N72320G1 X1.695 Z0.191
    N72330G1 X1.875 Z0.191
    N72340G1 X1.905 Z0.204
    N72350G1 X1.935 Z0.210
    N72360G1 X1.965 Z0.212
    N72370G1 X1.995 Z0.206
    N72380G1 X2.025 Z0.199
    N72390G1 X2.055 Z0.188
    N72400G1 A106.286
    N72410G1 Z0.195 A109.714
    N72420G1 Z0.206 A113.143
    N72430G1 Z0.221 A116.571
    N72440G1 Z0.241 A120.000
    N72450G1 Z0.249 A123.429
    N72460G1 Z0.256 A126.857
    N72470G0 Z0.700
    N72480G0 A233.143
    N72490G0 Z0.447
    N72500G1 Z0.256
    N72510G1 Z0.249 A236.571
    N72520G1 Z0.241 A240.000
    N72530G1 Z0.221 A243.429
    N72540G1 Z0.206 A246.857
    N72550G1 Z0.195 A250.286
    N72560G1 Z0.188 A253.714
    N72570G1 A277.714
    N72580G1 X2.025 Z0.199
    N72590G1 X1.995 Z0.206
    N72600G1 X1.965 Z0.212
    N72610G1 X1.935 Z0.210
    N72620G1 X1.905 Z0.204
    N72630G1 X1.875 Z0.191
    N72640G1 X1.695 Z0.191
    N72650G1 X1.665 Z0.190
    N72660G1 X1.635 Z0.188
    N72670G1 X1.455 Z0.188
    N72680G1 X1.425 Z0.196
    N72690G1 X1.395 Z0.203
    N72700G1 X1.365 Z0.211
    N72710G1 X1.335 Z0.219
    N72720G1 X1.305 Z0.227
    N72730G1 X1.275 Z0.235
    N72740G1 X1.245 Z0.242
    N72750G1 X1.215 Z0.248
    N72760G1 X1.185 Z0.255
    N72770G0 Z0.700
    N72780G0 A85.714
    N72790G0 Z0.451
    N72800G1 Z0.254
    N72810G1 X1.215 Z0.248
    N72820G1 X1.245 Z0.241
    N72830G1 X1.275 Z0.234
    N72840G1 X1.305 Z0.226
    N72850G1 X1.335 Z0.218
    N72860G1 X1.365 Z0.210
    N72870G1 X1.395 Z0.202
    N72880G1 X1.425 Z0.195
    N72890G1 X1.455 Z0.188
    N72900G1 X1.635 Z0.188
    N72910G1 X1.665 Z0.195
    N72920G1 X1.695 Z0.196
    N72930G1 X1.875 Z0.196
    N72940G1 X1.905 Z0.210
    N72950G1 X1.935 Z0.216
    N72960G1 X1.965 Z0.216
    N72970G1 X1.995 Z0.210
    N72980G1 X2.025 Z0.199
    N72990G1 Z0.195 A89.143
    N73000G1 Z0.190 A92.571
    N73010G1 Z0.188 A96.000
    N73020G1 Z0.188 A99.429
    N73030G1 Z0.195 A102.857
    N73040G1 Z0.212 A106.286
    N73050G1 Z0.223 A109.714
    N73060G1 Z0.229 A113.143
    N73070G1 Z0.235 A116.571
    N73080G1 Z0.248 A120.000
    N73090G1 Z0.256 A123.429
    N73100G0 Z0.700
    N73110G0 A236.571
    N73120G0 Z0.447
    N73130G1 Z0.256
    N73140G1 Z0.248 A240.000
    N73150G1 Z0.235 A243.429
    N73160G1 Z0.229 A246.857
    N73170G1 Z0.223 A250.286
    N73180G1 Z0.212 A253.714
    N73190G1 Z0.195 A257.143
    N73200G1 Z0.188 A260.571
    N73210G1 Z0.188 A264.000
    N73220G1 Z0.190 A267.429
    N73230G1 Z0.195 A270.857
    N73240G1 Z0.199 A274.286
    N73250G1 X1.995 Z0.210
    N73260G1 X1.965 Z0.216
    N73270G1 X1.935 Z0.216
    N73280G1 X1.905 Z0.210
    N73290G1 X1.875 Z0.196
    N73300G1 X1.695 Z0.196
    N73310G1 X1.665 Z0.195
    N73320G1 X1.635 Z0.188
    N73330G1 X1.455 Z0.188
    N73340G1 X1.425 Z0.195
    N73350G1 X1.395 Z0.202
    N73360G1 X1.365 Z0.210
    N73370G1 X1.335 Z0.218
    N73380G1 X1.305 Z0.226
    N73390G1 X1.275 Z0.234
    N73400G1 X1.245 Z0.241
    N73410G1 X1.215 Z0.248
    N73420G1 X1.185 Z0.254
    N73430G0 Z0.700
    N73440G0 A89.143
    N73450G0 Z0.451
    N73460G1 Z0.255
    N73470G1 X1.215 Z0.248
    N73480G1 X1.245 Z0.241
    N73490G1 X1.275 Z0.233
    N73500G1 X1.305 Z0.226
    N73510G1 X1.335 Z0.218
    N73520G1 X1.365 Z0.210
    N73530G1 X1.395 Z0.203
    N73540G1 X1.425 Z0.196
    N73550G1 X1.455 Z0.190
    N73560G1 X1.485 Z0.188
    N73570G1 X1.605
    N73580G1 X1.635 Z0.193
    N73590G1 X1.665 Z0.200
    N73600G1 X1.875 Z0.200
    N73610G1 X1.905 Z0.214
    N73620G1 X1.935 Z0.220
    N73630G1 X1.965 Z0.218
    N73640G1 X1.995 Z0.212
    N73650G1 Z0.212 A96.000
    N73660G1 Z0.208 A99.429
    N73670G1 Z0.213 A102.857
    N73680G1 Z0.219 A106.286
    N73690G1 Z0.230 A109.714
    N73700G1 Z0.236 A113.143
    N73710G1 Z0.242 A116.571
    N73720G1 Z0.249 A120.000
    N73730G1 Z0.256 A123.429
    N73740G0 Z0.700
    N73750G0 A236.571
    N73760G0 Z0.447
    N73770G1 Z0.256
    N73780G1 Z0.249 A240.000
    N73790G1 Z0.242 A243.429
    N73800G1 Z0.236 A246.857
    N73810G1 Z0.230 A250.286
    N73820G1 Z0.219 A253.714
    N73830G1 Z0.213 A257.143
    N73840G1 Z0.208 A260.571
    N73850G1 Z0.212 A264.000
    N73860G1 Z0.212 A270.857
    N73870G1 X1.965 Z0.218
    N73880G1 X1.935 Z0.220
    N73890G1 X1.905 Z0.214
    N73900G1 X1.875 Z0.200
    N73910G1 X1.665 Z0.200
    N73920G1 X1.635 Z0.193
    N73930G1 X1.605 Z0.188
    N73940G1 X1.485
    N73950G1 X1.455 Z0.190
    N73960G1 X1.425 Z0.196
    N73970G1 X1.395 Z0.203
    N73980G1 X1.365 Z0.210
    N73990G1 X1.335 Z0.218
    N74000G1 X1.305 Z0.226
    N74010G1 X1.275 Z0.233
    N74020G1 X1.245 Z0.241
    N74030G1 X1.215 Z0.248
    N74040G1 X1.185 Z0.255
    N74050G0 Z0.700
    N74060G0 A92.571
    N74070G0 Z0.453
    N74080G1 Z0.256
    N74090G1 X1.215 Z0.250
    N74100G1 X1.245 Z0.242
    N74110G1 X1.275 Z0.234
    N74120G1 X1.305 Z0.227
    N74130G1 X1.335 Z0.219
    N74140G1 X1.365 Z0.211
    N74150G1 X1.395 Z0.204
    N74160G1 X1.425 Z0.198
    N74170G1 X1.455 Z0.192
    N74180G1 X1.485 Z0.188
    N74190G1 X1.605
    N74200G1 X1.635 Z0.198
    N74210G1 X1.665 Z0.205
    N74220G1 X1.875 Z0.205
    N74230G1 X1.905 Z0.214
    N74240G1 X1.935 Z0.221
    N74250G1 X1.965 Z0.219
    N74260G1 Z0.218 A96.000
    N74270G1 Z0.215 A99.429
    N74280G1 Z0.220 A102.857
    N74290G1 Z0.225 A106.286
    N74300G1 Z0.230 A109.714
    N74310G1 Z0.236 A113.143
    N74320G1 Z0.242 A116.571
    N74330G1 Z0.249 A120.000
    N74340G1 Z0.255 A123.429
    N74350G0 Z0.700
    N74360G0 A236.571
    N74370G0 Z0.447
    N74380G1 Z0.255
    N74390G1 Z0.249 A240.000
    N74400G1 Z0.242 A243.429
    N74410G1 Z0.236 A246.857
    N74420G1 Z0.230 A250.286
    N74430G1 Z0.225 A253.714
    N74440G1 Z0.220 A257.143
    N74450G1 Z0.215 A260.571
    N74460G1 Z0.218 A264.000
    N74470G1 Z0.219 A267.429
    N74480G1 X1.935 Z0.221
    N74490G1 X1.905 Z0.214
    N74500G1 X1.875 Z0.205
    N74510G1 X1.695 Z0.205
    N74520G1 X1.665 Z0.204
    N74530G1 X1.635 Z0.198
    N74540G1 X1.605 Z0.188
    N74550G1 X1.485
    N74560G1 X1.455 Z0.192
    N74570G1 X1.425 Z0.198
    N74580G1 X1.395 Z0.204
    N74590G1 X1.365 Z0.211
    N74600G1 X1.335 Z0.219
    N74610G1 X1.305 Z0.227
    N74620G1 X1.275 Z0.234
    N74630G1 X1.245 Z0.242
    N74640G1 X1.215 Z0.250
    N74650G1 X1.185 Z0.256
    N74660G0 Z0.700
    N74670G0 X1.215 A96.000
    N74680G0 Z0.449
    N74690G1 Z0.252
    N74700G1 X1.245 Z0.244
    N74710G1 X1.275 Z0.236
    N74720G1 X1.305 Z0.228
    N74730G1 X1.335 Z0.220
    N74740G1 X1.365 Z0.213
    N74750G1 X1.395 Z0.206
    N74760G1 X1.425 Z0.200
    N74770G1 X1.455 Z0.194
    N74780G1 X1.485 Z0.189
    N74790G1 X1.515 Z0.188
    N74800G1 X1.605
    N74810G1 X1.635 Z0.202
    N74820G1 X1.665 Z0.209
    N74830G1 X1.695 Z0.210
    N74840G1 X1.875 Z0.210
    N74850G1 X1.905 Z0.214
    N74860G1 X1.935 Z0.220
    N74870G1 Z0.217 A99.429
    N74880G1 Z0.220 A102.857
    N74890G1 Z0.225 A106.286
    N74900G1 Z0.230 A109.714
    N74910G1 Z0.236 A113.143
    N74920G1 Z0.242 A116.571
    N74930G1 Z0.249 A120.000
    N74940G1 Z0.256 A123.429
    N74950G0 Z0.700
    N74960G0 A236.571
    N74970G0 Z0.447
    N74980G1 Z0.256
    N74990G1 Z0.249 A240.000
    N75000G1 Z0.242 A243.429
    N75010G1 Z0.236 A246.857
    N75020G1 Z0.230 A250.286
    N75030G1 Z0.225 A253.714
    N75040G1 Z0.220 A257.143
    N75050G1 Z0.217 A260.571
    N75060G1 Z0.220 A264.000
    N75070G1 X1.905 Z0.214
    N75080G1 X1.875 Z0.210
    N75090G1 X1.695 Z0.210
    N75100G1 X1.665 Z0.209
    N75110G1 X1.635 Z0.202
    N75120G1 X1.605 Z0.188
    N75130G1 X1.515
    N75140G1 X1.485 Z0.189
    N75150G1 X1.455 Z0.194
    N75160G1 X1.425 Z0.200
    N75170G1 X1.395 Z0.206
    N75180G1 X1.365 Z0.213
    N75190G1 X1.335 Z0.220
    N75200G1 X1.305 Z0.228
    N75210G1 X1.275 Z0.236
    N75220G1 X1.245 Z0.244
    N75230G1 X1.215 Z0.252
    N75240G0 Z0.700
    N75250G0 A99.429
    N75260G0 Z0.451
    N75270G1 Z0.254
    N75280G1 X1.245 Z0.246
    N75290G1 X1.275 Z0.238
    N75300G1 X1.305 Z0.230
    N75310G1 X1.335 Z0.223
    N75320G1 X1.365 Z0.215
    N75330G1 X1.395 Z0.209
    N75340G1 X1.425 Z0.203
    N75350G1 X1.455 Z0.197
    N75360G1 X1.485 Z0.192
    N75370G1 X1.515 Z0.188
    N75380G1 X1.605 Z0.188
    N75390G1 X1.635 Z0.207
    N75400G1 X1.665 Z0.213
    N75410G1 X1.695 Z0.215
    N75420G1 X1.905 Z0.215
    N75430G1 Z0.220 A102.857
    N75440G1 Z0.225 A106.286
    N75450G1 Z0.230 A109.714
    N75460G1 Z0.236 A113.143
    N75470G1 Z0.242 A116.571
    N75480G1 Z0.249 A120.000
    N75490G1 Z0.256 A123.429
    N75500G0 Z0.700
    N75510G0 A236.571
    N75520G0 Z0.447
    N75530G1 Z0.256
    N75540G1 Z0.249 A240.000
    N75550G1 Z0.242 A243.429
    N75560G1 Z0.236 A246.857
    N75570G1 Z0.230 A250.286
    N75580G1 Z0.225 A253.714
    N75590G1 Z0.220 A257.143
    N75600G1 Z0.215 A260.571
    N75610G1 X1.695 Z0.215
    N75620G1 X1.665 Z0.213
    N75630G1 X1.635 Z0.207
    N75640G1 X1.605 Z0.188
    N75650G1 X1.515 Z0.188
    N75660G1 X1.485 Z0.192
    N75670G1 X1.455 Z0.197
    N75680G1 X1.425 Z0.203
    N75690G1 X1.395 Z0.209
    N75700G1 X1.365 Z0.215
    N75710G1 X1.335 Z0.223
    N75720G1 X1.305 Z0.230
    N75730G1 X1.275 Z0.238
    N75740G1 X1.245 Z0.246
    N75750G1 X1.215 Z0.254
    N75760G0 Z0.700
    N75770G0 A102.857
    N75780G0 Z0.454
    N75790G1 Z0.258
    N75800G1 X1.245 Z0.249
    N75810G1 X1.275 Z0.241
    N75820G1 X1.305 Z0.233
    N75830G1 X1.335 Z0.225
    N75840G1 X1.365 Z0.218
    N75850G1 X1.395 Z0.212
    N75860G1 X1.425 Z0.206
    N75870G1 X1.455 Z0.201
    N75880G1 X1.485 Z0.197
    N75890G1 X1.515 Z0.194
    N75900G1 X1.545 Z0.190
    N75910G1 X1.575 Z0.188
    N75920G1 X1.605 Z0.188
    N75930G1 X1.635 Z0.211
    N75940G1 X1.665 Z0.218
    N75950G1 X1.695 Z0.220
    N75960G1 X1.875 Z0.220
    N75970G1 Z0.225 A106.286
    N75980G1 Z0.230 A109.714
    N75990G1 Z0.236 A113.143
    N76000G1 Z0.242 A116.571
    N76010G1 Z0.249 A120.000
    N76020G1 Z0.252 A123.429
    N76030G0 Z0.700
    N76040G0 A236.571
    N76050G0 Z0.447
    N76060G1 Z0.252
    N76070G1 Z0.249 A240.000
    N76080G1 Z0.242 A243.429
    N76090G1 Z0.236 A246.857
    N76100G1 Z0.230 A250.286
    N76110G1 Z0.225 A253.714
    N76120G1 Z0.220 A257.143
    N76130G1 X1.695 Z0.220
    N76140G1 X1.665 Z0.218
    N76150G1 X1.635 Z0.212
    N76160G1 X1.605 Z0.188
    N76170G1 X1.575 Z0.188
    N76180G1 X1.545 Z0.190
    N76190G1 X1.515 Z0.194
    N76200G1 X1.485 Z0.197
    N76210G1 X1.455 Z0.201
    N76220G1 X1.425 Z0.206
    N76230G1 X1.395 Z0.212
    N76240G1 X1.365 Z0.218
    N76250G1 X1.335 Z0.225
    N76260G1 X1.305 Z0.233
    N76270G1 X1.275 Z0.241
    N76280G1 X1.245 Z0.249
    N76290G1 X1.215 Z0.258
    N76300G0 Z0.700
    N76310G0 X1.245 A106.286
    N76320G0 Z0.450
    N76330G1 Z0.253
    N76340G1 X1.275 Z0.244
    N76350G1 X1.305 Z0.236
    N76360G1 X1.335 Z0.228
    N76370G1 X1.365 Z0.221
    N76380G1 X1.395 Z0.215
    N76390G1 X1.425 Z0.211
    N76400G1 X1.455 Z0.206
    N76410G1 X1.485 Z0.203
    N76420G1 X1.515 Z0.200
    N76430G1 X1.545 Z0.197
    N76440G1 X1.575 Z0.194
    N76450G1 X1.605 Z0.192
    N76460G1 X1.635 Z0.216
    N76470G1 X1.665 Z0.222
    N76480G1 X1.695 Z0.225
    N76490G1 X1.845 Z0.225
    N76500G1 Z0.230 A109.714
    N76510G1 Z0.236 A113.143
    N76520G1 Z0.242 A116.571
    N76530G1 Z0.246 A120.000
    N76540G1 Z0.251 A123.429
    N76550G0 Z0.700
    N76560G0 A236.571
    N76570G0 Z0.447
    N76580G1 Z0.251
    N76590G1 Z0.246 A240.000
    N76600G1 Z0.242 A243.429
    N76610G1 Z0.236 A246.857
    N76620G1 Z0.230 A250.286
    N76630G1 Z0.225 A253.714
    N76640G1 X1.695 Z0.225
    N76650G1 X1.665 Z0.222
    N76660G1 X1.635 Z0.216
    N76670G1 X1.605 Z0.192
    N76680G1 X1.575 Z0.194
    N76690G1 X1.545 Z0.197
    N76700G1 X1.515 Z0.200
    N76710G1 X1.485 Z0.203
    N76720G1 X1.455 Z0.206
    N76730G1 X1.425 Z0.211
    N76740G1 X1.395 Z0.215
    N76750G1 X1.365 Z0.221
    N76760G1 X1.335 Z0.228
    N76770G1 X1.305 Z0.236
    N76780G1 X1.275 Z0.244
    N76790G1 X1.245 Z0.253
    N76800G0 Z0.700
    N76810G0 A109.714
    N76820G0 Z0.454
    N76830G1 Z0.257
    N76840G1 X1.275 Z0.248
    N76850G1 X1.305 Z0.239
    N76860G1 X1.335 Z0.232
    N76870G1 X1.365 Z0.225
    N76880G1 X1.395 Z0.220
    N76890G1 X1.425 Z0.216
    N76900G1 X1.455 Z0.212
    N76910G1 X1.485 Z0.209
    N76920G1 X1.515 Z0.206
    N76930G1 X1.545 Z0.203
    N76940G1 X1.575 Z0.201
    N76950G1 X1.605 Z0.198
    N76960G1 X1.635 Z0.219
    N76970G1 X1.665 Z0.226
    N76980G1 X1.695 Z0.230
    N76990G1 X1.815 Z0.230
    N77000G1 Z0.236 A113.143
    N77010G1 Z0.242 A116.571
    N77020G1 Z0.246 A120.000
    N77030G1 Z0.251 A123.429
    N77040G0 Z0.700
    N77050G0 A236.571
    N77060G0 Z0.447
    N77070G1 Z0.251
    N77080G1 Z0.246 A240.000
    N77090G1 Z0.242 A243.429
    N77100G1 Z0.236 A246.857
    N77110G1 Z0.230 A250.286
    N77120G1 X1.695 Z0.230
    N77130G1 X1.665 Z0.226
    N77140G1 X1.635 Z0.219
    N77150G1 X1.605 Z0.198
    N77160G1 X1.575 Z0.201
    N77170G1 X1.545 Z0.203
    N77180G1 X1.515 Z0.206
    N77190G1 X1.485 Z0.209
    N77200G1 X1.455 Z0.212
    N77210G1 X1.425 Z0.216
    N77220G1 X1.395 Z0.220
    N77230G1 X1.365 Z0.225
    N77240G1 X1.335 Z0.232
    N77250G1 X1.305 Z0.239
    N77260G1 X1.275 Z0.248
    N77270G1 X1.245 Z0.257
    N77280G0 Z0.700
    N77290G0 X1.275 A113.143
    N77300G0 Z0.449
    N77310G1 Z0.252
    N77320G1 X1.305 Z0.243
    N77330G1 X1.335 Z0.236
    N77340G1 X1.365 Z0.231
    N77350G1 X1.395 Z0.226
    N77360G1 X1.425 Z0.222
    N77370G1 X1.455 Z0.219
    N77380G1 X1.485 Z0.215
    N77390G1 X1.515 Z0.213
    N77400G1 X1.545 Z0.210
    N77410G1 X1.575 Z0.208
    N77420G1 X1.605 Z0.206
    N77430G1 X1.635 Z0.220
    N77440G1 X1.665 Z0.228
    N77450G1 X1.695 Z0.235
    N77460G1 X1.725 Z0.236
    N77470G1 X1.785 Z0.236
    N77480G1 Z0.242 A116.571
    N77490G1 Z0.246 A120.000
    N77500G1 Z0.251 A123.429
    N77510G0 Z0.700
    N77520G0 A236.571
    N77530G0 Z0.447
    N77540G1 Z0.251
    N77550G1 Z0.246 A240.000
    N77560G1 Z0.242 A243.429
    N77570G1 Z0.236 A246.857
    N77580G1 X1.725 Z0.236
    N77590G1 X1.695 Z0.235
    N77600G1 X1.665 Z0.228
    N77610G1 X1.635 Z0.220
    N77620G1 X1.605 Z0.206
    N77630G1 X1.575 Z0.208
    N77640G1 X1.545 Z0.210
    N77650G1 X1.515 Z0.213
    N77660G1 X1.485 Z0.215
    N77670G1 X1.455 Z0.219
    N77680G1 X1.425 Z0.222
    N77690G1 X1.395 Z0.226
    N77700G1 X1.365 Z0.231
    N77710G1 X1.335 Z0.236
    N77720G1 X1.305 Z0.243
    N77730G1 X1.275 Z0.252
    N77740G0 Z0.700
    N77750G0 A116.571
    N77760G0 Z0.453
    N77770G1 Z0.256
    N77780G1 X1.305 Z0.248
    N77790G1 X1.335 Z0.241
    N77800G1 X1.365 Z0.236
    N77810G1 X1.395 Z0.232
    N77820G1 X1.425 Z0.228
    N77830G1 X1.455 Z0.225
    N77840G1 X1.485 Z0.223
    N77850G1 X1.515 Z0.220
    N77860G1 X1.545 Z0.218
    N77870G1 X1.575 Z0.216
    N77880G1 X1.605 Z0.214
    N77890G1 X1.635 Z0.221
    N77900G1 X1.665 Z0.233
    N77910G1 X1.695 Z0.239
    N77920G1 X1.725 Z0.241
    N77930G1 X1.755 Z0.242
    N77940G1 Z0.246 A120.000
    N77950G1 Z0.251 A123.429
    N77960G0 Z0.700
    N77970G0 A236.571
    N77980G0 Z0.447
    N77990G1 Z0.251
    N78000G1 Z0.246 A240.000
    N78010G1 Z0.242 A243.429
    N78020G1 X1.725 Z0.241
    N78030G1 X1.695 Z0.239
    N78040G1 X1.665 Z0.233
    N78050G1 X1.635 Z0.221
    N78060G1 X1.605 Z0.214
    N78070G1 X1.575 Z0.216
    N78080G1 X1.545 Z0.218
    N78090G1 X1.515 Z0.220
    N78100G1 X1.485 Z0.223
    N78110G1 X1.455 Z0.225
    N78120G1 X1.425 Z0.228
    N78130G1 X1.395 Z0.232
    N78140G1 X1.365 Z0.236
    N78150G1 X1.335 Z0.241
    N78160G1 X1.305 Z0.248
    N78170G1 X1.275 Z0.256
    N78180G0 Z0.700
    N78190G0 X1.305 A120.000
    N78200G0 Z0.450
    N78210G1 Z0.253
    N78220G1 X1.335 Z0.247
    N78230G1 X1.365 Z0.242
    N78240G1 X1.395 Z0.239
    N78250G1 X1.425 Z0.235
    N78260G1 X1.455 Z0.233
    N78270G1 X1.485 Z0.230
    N78280G1 X1.515 Z0.228
    N78290G1 X1.545 Z0.227
    N78300G1 X1.575 Z0.225
    N78310G1 X1.605 Z0.224
    N78320G1 X1.635 Z0.222
    N78330G1 X1.665 Z0.238
    N78340G1 X1.695 Z0.245
    N78350G1 X1.725 Z0.245
    N78360G1 Z0.251 A123.429
    N78370G0 Z0.700
    N78380G0 A236.571
    N78390G0 Z0.447
    N78400G1 Z0.251
    N78410G1 Z0.245 A240.000
    N78420G1 X1.695 Z0.245
    N78430G1 X1.665 Z0.238
    N78440G1 X1.635 Z0.222
    N78450G1 X1.605 Z0.224
    N78460G1 X1.575 Z0.225
    N78470G1 X1.545 Z0.227
    N78480G1 X1.515 Z0.228
    N78490G1 X1.485 Z0.230
    N78500G1 X1.455 Z0.233
    N78510G1 X1.425 Z0.235
    N78520G1 X1.395 Z0.239
    N78530G1 X1.365 Z0.242
    N78540G1 X1.335 Z0.247
    N78550G1 X1.305 Z0.253
    N78560G0 Z0.700
    N78570G0 X1.335 A123.429
    N78580G0 Z0.450
    N78590G1 Z0.253
    N78600G1 X1.365 Z0.249
    N78610G1 X1.395 Z0.245
    N78620G1 X1.425 Z0.243
    N78630G1 X1.455 Z0.240
    N78640G1 X1.485 Z0.239
    N78650G1 X1.515 Z0.237
    N78660G1 X1.545 Z0.236
    N78670G1 X1.575 Z0.235
    N78680G1 X1.605 Z0.233
    N78690G1 X1.635 Z0.232
    N78700G1 X1.665 Z0.239
    N78710G1 X1.695 Z0.245
    N78720G1 Z0.246 A126.857
    N78730G1 Z0.252 A130.286
    N78740G0 Z0.700
    N78750G0 A229.714
    N78760G0 Z0.447
    N78770G1 Z0.252
    N78780G1 Z0.246 A233.143
    N78790G1 Z0.245 A236.571
    N78800G1 X1.665 Z0.239
    N78810G1 X1.635 Z0.232
    N78820G1 X1.605 Z0.233
    N78830G1 X1.575 Z0.235
    N78840G1 X1.545 Z0.236
    N78850G1 X1.515 Z0.237
    N78860G1 X1.485 Z0.239
    N78870G1 X1.455 Z0.240
    N78880G1 X1.425 Z0.243
    N78890G1 X1.395 Z0.245
    N78900G1 X1.365 Z0.249
    N78910G1 X1.335 Z0.253
    N78920G0 Z0.700
    N78930G0 X1.425 A126.857
    N78940G0 Z0.447
    N78950G1 Z0.250
    N78960G1 X1.455 Z0.248
    N78970G1 X1.485 Z0.247
    N78980G1 X1.515 Z0.246
    N78990G1 X1.545 Z0.245
    N79000G1 X1.575 Z0.245
    N79010G1 X1.605 Z0.244
    N79020G1 X1.635 Z0.243
    N79030G1 X1.665 Z0.242
    N79040G1 Z0.254 A130.286
    N79050G0 Z0.700
    N79060G0 A229.714
    N79070G0 Z0.447
    N79080G1 Z0.254
    N79090G1 Z0.242 A233.143
    N79100G1 X1.635 Z0.243
    N79110G1 X1.605 Z0.244
    N79120G1 X1.575 Z0.245
    N79130G1 X1.545 Z0.245
    N79140G1 X1.515 Z0.246
    N79150G1 X1.485 Z0.247
    N79160G1 X1.455 Z0.248
    N79170G1 X1.425 Z0.250
    N79180G0 Z0.700
    N79190G0 X0.000 A0.000
    N79200G0 Z0.384
    N79210G1 Z0.188
    N79220G1 X0.375 Z0.156 F37.5
    N79230G1 X0.000 Z0.125
    N79240G1 X0.495
    N79250G1 X0.525 Z0.413 F50.0
    N79260G0 Z0.700
    N79270G0 X2.085
    N79280G0 Z0.389
    N79290G1 Z0.192
    N79300G1 X2.115 Z0.125 F37.5
    N79310G1 X2.750
    N79320G1 A360.000
    N79330G1 X2.115
    N79340G1 X2.085 Z0.192 F50.0
    N79350G0 Z0.700
    N79360G0 X0.525
    N79370G0 Z0.610
    N79380G1 Z0.413
    N79390G1 X0.495 Z0.125 F37.5
    N79400G1 X0.000
    N79410G1 A3.429
    N79420G1 X0.495 F50.0
    N79430G1 X0.525 Z0.413
    N79440G0 Z0.700
    N79450G0 X2.085
    N79460G0 Z0.390
    N79470G1 Z0.193
    N79480G1 X2.115 Z0.125
    N79490G1 X2.745
    N79500G1 A356.571
    N79510G1 X2.115
    N79520G1 X2.085 Z0.193
    N79530G0 Z0.700
    N79540G0 X0.525
    N79550G0 Z0.610
    N79560G1 Z0.413
    N79570G1 X0.495 Z0.125
    N79580G1 X0.015
    N79590G1 A6.857
    N79600G1 X0.495
    N79610G1 X0.525 Z0.413
    N79620G0 Z0.700
    N79630G0 X2.085
    N79640G0 Z0.392
    N79650G1 Z0.195
    N79660G1 X2.115 Z0.125
    N79670G1 X2.715
    N79680G1 A353.143
    N79690G1 X2.115
    N79700G1 X2.085 Z0.195
    N79710G0 Z0.700
    N79720G0 X0.525
    N79730G0 Z0.610
    N79740G1 Z0.413
    N79750G1 X0.495 Z0.125
    N79760G1 X0.045
    N79770G1 A10.286
    N79780G1 X0.495
    N79790G1 X0.525 Z0.413
    N79800G0 Z0.700
    N79810G0 X2.085
    N79820G0 Z0.393
    N79830G1 Z0.196
    N79840G1 X2.115 Z0.125
    N79850G1 X2.685
    N79860G1 A349.714
    N79870G1 X2.115
    N79880G1 X2.085 Z0.196
    N79890G0 Z0.700
    N79900G0 X0.525
    N79910G0 Z0.610
    N79920G1 Z0.413
    N79930G1 X0.495 Z0.125
    N79940G1 X0.075
    N79950G1 A13.714
    N79960G1 X0.495
    N79970G1 X0.525 Z0.413
    N79980G0 Z0.700
    N79990G0 X2.085
    N80000G0 Z0.393
    N80010G1 Z0.196
    N80020G1 X2.115 Z0.125
    N80030G1 X2.655
    N80040G1 A346.286
    N80050G1 X2.115
    N80060G1 X2.085 Z0.196
    N80070G0 Z0.700
    N80080G0 X0.525
    N80090G0 Z0.610
    N80100G1 Z0.413
    N80110G1 X0.495 Z0.125
    N80120G1 X0.105
    N80130G1 A17.143
    N80140G1 X0.495
    N80150G1 X0.525 Z0.413
    N80160G0 Z0.700
    N80170G0 X2.085
    N80180G0 Z0.392
    N80190G1 Z0.195
    N80200G1 X2.115 Z0.125
    N80210G1 X2.625
    N80220G1 A342.857
    N80230G1 X2.115
    N80240G1 X2.085 Z0.195
    N80250G0 Z0.700
    N80260G0 X0.525
    N80270G0 Z0.610
    N80280G1 Z0.413
    N80290G1 X0.495 Z0.125
    N80300G1 X0.135
    N80310G1 A20.571
    N80320G1 X0.495
    N80330G1 X0.525 Z0.413
    N80340G0 Z0.700
    N80350G0 X2.085
    N80360G0 Z0.388
    N80370G1 Z0.191
    N80380G1 X2.115 Z0.125
    N80390G1 X2.595
    N80400G1 A339.429
    N80410G1 X2.115
    N80420G1 X2.085 Z0.191
    N80430G0 Z0.700
    N80440G0 X0.525
    N80450G0 Z0.610
    N80460G1 Z0.413
    N80470G1 X0.495 Z0.125
    N80480G1 X0.165
    N80490G1 A24.000
    N80500G1 X0.495
    N80510G1 X0.525 Z0.413
    N80520G0 Z0.700
    N80530G0 X1.545
    N80540G0 Z0.386
    N80550G1 Z0.189
    N80560G1 X1.575 Z0.169 F37.5
    N80570G1 X1.605 Z0.331
    N80580G0 Z0.700
    N80590G0 X2.055
    N80600G0 Z0.420
    N80610G1 Z0.223 F50.0
    N80620G1 X2.085 Z0.187
    N80630G1 X2.115 Z0.125
    N80640G1 X2.565
    N80650G1 A336.000
    N80660G1 X2.115
    N80670G1 X2.085 Z0.187
    N80680G1 X2.055 Z0.223
    N80690G0 Z0.700
    N80700G0 X1.605
    N80710G0 Z0.528
    N80720G1 Z0.331
    N80730G1 X1.575 Z0.169 F37.5
    N80740G1 X1.545 Z0.189
    N80750G0 Z0.700
    N80760G0 X0.525
    N80770G0 Z0.610
    N80780G1 Z0.413 F50.0
    N80790G1 X0.495 Z0.125
    N80800G1 X0.195
    N80810G1 A27.429
    N80820G1 X0.495
    N80830G1 X0.525 Z0.413
    N80840G0 Z0.700
    N80850G0 X1.515
    N80860G0 Z0.404
    N80870G1 Z0.207
    N80880G1 X1.545 Z0.187
    N80890G1 X1.575 Z0.167
    N80900G1 X1.605 Z0.311
    N80910G0 Z0.700
    N80920G0 X2.055
    N80930G0 Z0.414
    N80940G1 Z0.217
    N80950G1 X2.085 Z0.184
    N80960G1 X2.115 Z0.125
    N80970G1 X2.535
    N80980G1 A332.571
    N80990G1 X2.115
    N81000G1 X2.085 Z0.184
    N81010G1 X2.055 Z0.217
    N81020G0 Z0.700
    N81030G0 X1.605
    N81040G0 Z0.508
    N81050G1 Z0.311
    N81060G1 X1.575 Z0.167
    N81070G1 X1.545 Z0.187
    N81080G1 X1.515 Z0.207
    N81090G0 Z0.700
    N81100G0 X0.525
    N81110G0 Z0.610
    N81120G1 Z0.413
    N81130G1 X0.495 Z0.125
    N81140G1 X0.225
    N81150G1 A30.857
    N81160G1 X0.495
    N81170G1 X0.525 Z0.413
    N81180G0 Z0.700
    N81190G0 X1.515
    N81200G0 Z0.400
    N81210G1 Z0.203
    N81220G1 X1.545 Z0.184
    N81230G1 X1.575 Z0.165
    N81240G1 X1.605 Z0.145 F37.5
    N81250G1 X1.635 Z0.269
    N81260G0 Z0.700
    N81270G0 X2.055
    N81280G0 Z0.405
    N81290G1 Z0.208 F50.0
    N81300G1 X2.085 Z0.182
    N81310G1 X2.115 Z0.125
    N81320G1 X2.505
    N81330G1 A329.143
    N81340G1 X2.115
    N81350G1 X2.085 Z0.182
    N81360G1 X2.055 Z0.208
    N81370G0 Z0.700
    N81380G0 X1.635
    N81390G0 Z0.466
    N81400G1 Z0.269
    N81410G1 X1.605 Z0.145 F37.5
    N81420G1 X1.575 Z0.165
    N81430G1 X1.545 Z0.184 F50.0
    N81440G1 X1.515 Z0.203
    N81450G0 Z0.700
    N81460G0 X0.525
    N81470G0 Z0.610
    N81480G1 Z0.413
    N81490G1 X0.495 Z0.125
    N81500G1 X0.255
    N81510G1 A34.286
    N81520G1 X0.495
    N81530G1 X0.525 Z0.413
    N81540G0 Z0.700
    N81550G0 X1.515
    N81560G0 Z0.397
    N81570G1 Z0.200
    N81580G1 X1.545 Z0.182
    N81590G1 X1.575 Z0.163
    N81600G1 X1.605 Z0.144
    N81610G1 X1.635 Z0.144 F37.5
    N81620G1 X1.665 Z0.190
    N81630G0 Z0.700
    N81640G0 X2.055
    N81650G0 Z0.401
    N81660G1 Z0.204 F50.0
    N81670G1 X2.085 Z0.180
    N81680G1 X2.115 Z0.125
    N81690G1 X2.475
    N81700G1 A325.714
    N81710G1 X2.115
    N81720G1 X2.085 Z0.180
    N81730G1 X2.055 Z0.204
    N81740G0 Z0.700
    N81750G0 X1.665
    N81760G0 Z0.387
    N81770G1 Z0.190
    N81780G1 X1.635 Z0.144 F37.5
    N81790G1 X1.605 Z0.144
    N81800G1 X1.575 Z0.163 F50.0
    N81810G1 X1.545 Z0.182
    N81820G1 X1.515 Z0.200
    N81830G0 Z0.700
    N81840G0 X0.525
    N81850G0 Z0.610
    N81860G1 Z0.413
    N81870G1 X0.495 Z0.125
    N81880G1 X0.285
    N81890G1 A37.714
    N81900G1 X0.495
    N81910G1 X0.525 Z0.413
    N81920G0 Z0.700
    N81930G0 X1.515
    N81940G0 Z0.394
    N81950G1 Z0.197
    N81960G1 X1.545 Z0.179
    N81970G1 X1.575 Z0.162
    N81980G1 X1.605 Z0.144
    N81990G1 X1.635 Z0.127 F37.5
    N82000G1 X1.665 Z0.169
    N82010G1 X1.695 Z0.193
    N82020G0 Z0.700
    N82030G0 X2.055
    N82040G0 Z0.399
    N82050G1 Z0.202 F50.0
    N82060G1 X2.085 Z0.178
    N82070G1 X2.115 Z0.125
    N82080G1 X2.445
    N82090G1 A322.286
    N82100G1 X2.115
    N82110G1 X2.085 Z0.178
    N82120G1 X2.055 Z0.202
    N82130G0 Z0.700
    N82140G0 X1.695
    N82150G0 Z0.389
    N82160G1 Z0.193
    N82170G1 X1.665 Z0.169 F37.5
    N82180G1 X1.635 Z0.127
    N82190G1 X1.605 Z0.144
    N82200G1 X1.575 Z0.162 F50.0
    N82210G1 X1.545 Z0.179
    N82220G1 X1.515 Z0.197
    N82230G0 Z0.700
    N82240G0 X0.525
    N82250G0 Z0.610
    N82260G1 Z0.413
    N82270G1 X0.495 Z0.125
    N82280G1 X0.315
    N82290G1 A41.143
    N82300G1 X0.495
    N82310G1 X0.525 Z0.413
    N82320G0 Z0.700
    N82330G0 X1.515
    N82340G0 Z0.390
    N82350G1 Z0.194
    N82360G1 X1.545 Z0.177
    N82370G1 X1.575 Z0.160
    N82380G1 X1.605 Z0.143
    N82390G1 X1.635 Z0.127
    N82400G1 X1.665 Z0.153 F37.5
    N82410G1 X1.695 Z0.180
    N82420G1 X1.725 Z0.208 F50.0
    N82430G0 Z0.700
    N82440G0 X2.055
    N82450G0 Z0.393
    N82460G1 Z0.196
    N82470G1 X2.085 Z0.172
    N82480G1 X2.115 Z0.125
    N82490G1 X2.415
    N82500G1 A318.857
    N82510G1 X2.115
    N82520G1 X2.085 Z0.172
    N82530G1 X2.055 Z0.196
    N82540G0 Z0.700
    N82550G0 X1.725
    N82560G0 Z0.405
    N82570G1 Z0.208
    N82580G1 X1.695 Z0.180
    N82590G1 X1.665 Z0.153 F37.5
    N82600G1 X1.635 Z0.127
    N82610G1 X1.605 Z0.143 F50.0
    N82620G1 X1.575 Z0.160
    N82630G1 X1.545 Z0.177
    N82640G1 X1.515 Z0.194
    N82650G0 Z0.700
    N82660G0 X0.525
    N82670G0 Z0.610
    N82680G1 Z0.413
    N82690G1 X0.495 Z0.125
    N82700G1 X0.345
    N82710G1 A44.571
    N82720G1 X0.495
    N82730G1 X0.525 Z0.413
    N82740G0 Z0.700
    N82750G0 X1.515
    N82760G0 Z0.387
    N82770G1 Z0.191
    N82780G1 X1.545 Z0.175
    N82790G1 X1.575 Z0.159
    N82800G1 X1.605 Z0.143
    N82810G1 X1.635 Z0.129
    N82820G1 X1.665 Z0.157
    N82830G1 X1.695 Z0.170
    N82840G1 X1.725 Z0.198
    N82850G0 Z0.700
    N82860G0 X2.055
    N82870G0 Z0.393
    N82880G1 Z0.196
    N82890G1 X2.085 Z0.173
    N82900G1 X2.115 Z0.125
    N82910G1 X2.385
    N82920G1 A315.429
    N82930G1 X2.115
    N82940G1 X2.085 Z0.173
    N82950G1 X2.055 Z0.196
    N82960G0 Z0.700
    N82970G0 X1.725
    N82980G0 Z0.395
    N82990G1 Z0.198
    N83000G1 X1.695 Z0.170
    N83010G1 X1.665 Z0.157
    N83020G1 X1.635 Z0.129
    N83030G1 X1.605 Z0.143
    N83040G1 X1.575 Z0.159
    N83050G1 X1.545 Z0.175
    N83060G1 X1.515 Z0.191
    N83070G0 Z0.700
    N83080G0 X0.525
    N83090G0 Z0.610
    N83100G1 Z0.413
    N83110G1 X0.495 Z0.125
    N83120G1 X0.375
    N83130G1 A48.000
    N83140G1 X0.495
    N83150G1 X0.525 Z0.413
    N83160G0 Z0.700
    N83170G0 X1.515
    N83180G0 Z0.385
    N83190G1 Z0.188
    N83200G1 X1.545 Z0.173
    N83210G1 X1.575 Z0.158
    N83220G1 X1.605 Z0.143
    N83230G1 X1.635 Z0.131
    N83240G1 X1.665 Z0.159
    N83250G1 X1.695 Z0.166
    N83260G1 X1.725 Z0.189
    N83270G0 Z0.700
    N83280G0 X2.055
    N83290G0 Z0.394
    N83300G1 Z0.197
    N83310G1 X2.085 Z0.173
    N83320G1 X2.115 Z0.125
    N83330G1 X2.355
    N83340G1 A312.000
    N83350G1 X2.115
    N83360G1 X2.085 Z0.173
    N83370G1 X2.055 Z0.197
    N83380G0 Z0.700
    N83390G0 X1.725
    N83400G0 Z0.386
    N83410G1 Z0.189
    N83420G1 X1.695 Z0.166
    N83430G1 X1.665 Z0.159
    N83440G1 X1.635 Z0.131
    N83450G1 X1.605 Z0.143
    N83460G1 X1.575 Z0.158
    N83470G1 X1.545 Z0.173
    N83480G1 X1.515 Z0.188
    N83490G0 Z0.700
    N83500G0 X0.525
    N83510G0 Z0.610
    N83520G1 Z0.413
    N83530G1 X0.495 Z0.125
    N83540G1 X0.405
    N83550G1 A51.429
    N83560G1 X0.495
    N83570G1 X0.525 Z0.413
    N83580G0 Z0.700
    N83590G0 X1.485
    N83600G0 Z0.395
    N83610G1 Z0.198
    N83620G1 X1.515 Z0.185
    N83630G1 X1.545 Z0.171
    N83640G1 X1.575 Z0.157
    N83650G1 X1.605 Z0.143
    N83660G1 X1.635 Z0.140
    N83670G1 X1.665 Z0.164
    N83680G1 X1.695 Z0.170
    N83690G1 X1.725 Z0.182
    N83700G1 X1.755 Z0.189
    N83710G0 Z0.700
    N83720G0 X2.055
    N83730G0 Z0.394
    N83740G1 Z0.197
    N83750G1 X2.085 Z0.173
    N83760G1 X2.115 Z0.125
    N83770G1 X2.325
    N83780G1 A308.571
    N83790G1 X2.115
    N83800G1 X2.085 Z0.173
    N83810G1 X2.055 Z0.197
    N83820G0 Z0.700
    N83830G0 X1.755
    N83840G0 Z0.386
    N83850G1 Z0.189
    N83860G1 X1.725 Z0.182
    N83870G1 X1.695 Z0.170
    N83880G1 X1.665 Z0.164
    N83890G1 X1.635 Z0.140
    N83900G1 X1.605 Z0.143
    N83910G1 X1.575 Z0.157
    N83920G1 X1.545 Z0.171
    N83930G1 X1.515 Z0.185
    N83940G1 X1.485 Z0.198
    N83950G0 Z0.700
    N83960G0 X0.525
    N83970G0 Z0.610
    N83980G1 Z0.413
    N83990G1 X0.495 Z0.125
    N84000G1 X0.435
    N84010G1 A54.857
    N84020G1 X0.495
    N84030G1 X0.525 Z0.413
    N84040G0 Z0.700
    N84050G0 X1.485
    N84060G0 Z0.392
    N84070G1 Z0.195
    N84080G1 X1.515 Z0.183
    N84090G1 X1.545 Z0.170
    N84100G1 X1.575 Z0.156
    N84110G1 X1.605 Z0.143
    N84120G1 X1.635 Z0.145
    N84130G1 X1.665 Z0.169
    N84140G1 X1.695 Z0.175
    N84150G1 X1.725 Z0.176
    N84160G1 X1.755 Z0.183
    N84170G1 X1.845 Z0.183
    N84180G1 X1.875 Z0.190
    N84190G1 Z0.402
    N84200G1 X2.055
    N84210G1 Z0.196
    N84220G1 X2.085 Z0.172
    N84230G1 X2.115 Z0.128
    N84240G1 X2.145 Z0.125
    N84250G1 X2.295
    N84260G1 A305.143
    N84270G1 X2.145
    N84280G1 X2.115 Z0.128
    N84290G1 X2.085 Z0.172
    N84300G1 X2.055 Z0.196
    N84310G1 Z0.402
    N84320G1 X1.875
    N84330G1 Z0.190
    N84340G1 X1.845 Z0.183
    N84350G1 X1.755 Z0.183
    N84360G1 X1.725 Z0.176
    N84370G1 X1.695 Z0.175
    N84380G1 X1.665 Z0.169
    N84390G1 X1.635 Z0.145
    N84400G1 X1.605 Z0.143
    N84410G1 X1.575 Z0.156
    N84420G1 X1.545 Z0.170
    N84430G1 X1.515 Z0.183
    N84440G1 X1.485 Z0.195
    N84450G0 Z0.700
    N84460G0 X0.525
    N84470G0 Z0.610
    N84480G1 Z0.413
    N84490G1 X0.495 Z0.125
    N84500G1 X0.465
    N84510G1 A58.286
    N84520G1 X0.495
    N84530G1 X0.525 Z0.413
    N84540G0 Z0.700
    N84550G0 X1.485
    N84560G0 Z0.389
    N84570G1 Z0.192
    N84580G1 X1.515 Z0.180
    N84590G1 X1.545 Z0.168
    N84600G1 X1.575 Z0.156
    N84610G1 X1.605 Z0.144
    N84620G1 X1.635 Z0.146
    N84630G1 X1.665 Z0.170
    N84640G1 X1.695 Z0.176
    N84650G1 X1.725 Z0.177
    N84660G1 X1.755 Z0.177
    N84670G1 X1.785 Z0.179
    N84680G1 X1.845 Z0.179
    N84690G1 X1.875 Z0.190
    N84700G1 Z0.402
    N84710G1 X2.055
    N84720G1 Z0.193
    N84730G1 X2.085 Z0.169
    N84740G1 X2.115 Z0.129
    N84750G1 X2.145 Z0.125
    N84760G1 X2.265
    N84770G1 A301.714
    N84780G1 X2.145
    N84790G1 X2.115 Z0.128
    N84800G1 X2.085 Z0.169
    N84810G1 X2.055 Z0.193
    N84820G1 Z0.402
    N84830G1 X1.875
    N84840G1 Z0.190
    N84850G1 X1.845 Z0.179
    N84860G1 X1.785 Z0.179
    N84870G1 X1.755 Z0.177
    N84880G1 X1.725 Z0.177
    N84890G1 X1.695 Z0.176
    N84900G1 X1.665 Z0.170
    N84910G1 X1.635 Z0.146
    N84920G1 X1.605 Z0.144
    N84930G1 X1.575 Z0.156
    N84940G1 X1.545 Z0.168
    N84950G1 X1.515 Z0.180
    N84960G1 X1.485 Z0.192
    N84970G0 Z0.700
    N84980G0 X0.525
    N84990G0 Z0.610
    N85000G1 Z0.413
    N85010G1 X0.495 Z0.125
    N85020G1 A298.286 F37.5
    N85030G1 A61.714 F50.0
    N85040G1 X0.525 Z0.413
    N85050G0 Z0.700
    N85060G0 X1.485
    N85070G0 Z0.386
    N85080G1 Z0.189
    N85090G1 X1.515 Z0.178
    N85100G1 X1.545 Z0.167
    N85110G1 X1.575 Z0.156
    N85120G1 X1.605 Z0.145
    N85130G1 X1.635 Z0.146
    N85140G1 X1.665 Z0.170
    N85150G1 X1.695 Z0.176
    N85160G1 X1.755 Z0.176
    N85170G1 X1.785 Z0.177
    N85180G1 X1.845 Z0.177
    N85190G1 X1.875 Z0.189
    N85200G1 Z0.401
    N85210G1 X2.055
    N85220G1 Z0.191
    N85230G1 X2.085 Z0.167
    N85240G1 X2.115 Z0.129
    N85250G1 X2.145 Z0.125
    N85260G1 X2.235
    N85270G1 A157.714
    N85280G1 Z0.164 A161.143
    N85290G1 Z0.243 A164.571
    N85300G1 Z0.465
    N85310G1 A195.429
    N85320G1 Z0.243
    N85330G1 Z0.164 A198.857
    N85340G1 Z0.125 A202.286
    N85350G1 A298.286
    N85360G1 X2.145
    N85370G1 X2.115 Z0.128
    N85380G1 X2.085 Z0.167
    N85390G1 X2.055 Z0.191
    N85400G1 Z0.401
    N85410G1 X1.875
    N85420G1 Z0.189
    N85430G1 X1.845 Z0.177
    N85440G1 X1.785 Z0.177
    N85450G1 X1.755 Z0.176
    N85460G1 X1.695 Z0.176
    N85470G1 X1.665 Z0.170
    N85480G1 X1.635 Z0.146
    N85490G1 X1.605 Z0.145
    N85500G1 X1.575 Z0.156
    N85510G1 X1.545 Z0.167
    N85520G1 X1.515 Z0.178
    N85530G1 X1.485 Z0.189
    N85540G0 Z0.700
    N85550G0 X1.455 A65.143
    N85560G0 Z0.393
    N85570G1 Z0.197
    N85580G1 X1.485 Z0.187
    N85590G1 X1.515 Z0.177
    N85600G1 X1.545 Z0.166
    N85610G1 X1.575 Z0.156
    N85620G1 X1.605 Z0.146
    N85630G1 X1.635 Z0.146
    N85640G1 X1.665 Z0.170
    N85650G1 X1.695 Z0.176
    N85660G1 X1.845 Z0.176
    N85670G1 X1.875 Z0.185
    N85680G1 X1.905 Z0.194
    N85690G1 Z0.397
    N85700G1 X2.055
    N85710G1 Z0.190
    N85720G1 X2.085 Z0.166
    N85730G1 X2.115 Z0.128
    N85740G1 X2.145 Z0.125
    N85750G1 X2.205
    N85760G1 A147.429
    N85770G1 Z0.150 A150.857
    N85780G1 Z0.162 A154.286
    N85790G1 Z0.233 A157.714
    N85800G1 Z0.489
    N85810G1 A202.286
    N85820G1 Z0.233
    N85830G1 Z0.162 A205.714
    N85840G1 Z0.150 A209.143
    N85850G1 Z0.125 A212.571
    N85860G1 A294.857
    N85870G1 X2.145
    N85880G1 X2.115 Z0.127
    N85890G1 X2.085 Z0.166
    N85900G1 X2.055 Z0.190
    N85910G1 Z0.397
    N85920G1 X1.905
    N85930G1 Z0.194
    N85940G1 X1.875 Z0.185
    N85950G1 X1.845 Z0.176
    N85960G1 X1.695 Z0.176
    N85970G1 X1.665 Z0.170
    N85980G1 X1.635 Z0.146
    N85990G1 X1.605 Z0.146
    N86000G1 X1.575 Z0.156
    N86010G1 X1.545 Z0.166
    N86020G1 X1.515 Z0.177
    N86030G1 X1.485 Z0.187
    N86040G1 X1.455 Z0.197
    N86050G0 Z0.700
    N86060G0 A68.571
    N86070G0 Z0.391
    N86080G1 Z0.194
    N86090G1 X1.485 Z0.185
    N86100G1 X1.515 Z0.175
    N86110G1 X1.545 Z0.166
    N86120G1 X1.575 Z0.156
    N86130G1 X1.605 Z0.147
    N86140G1 X1.635 Z0.159
    N86150G1 X1.665 Z0.172
    N86160G1 X1.695 Z0.178
    N86170G1 X1.845 Z0.178
    N86180G1 X1.875 Z0.179
    N86190G1 X1.905 Z0.188
    N86200G1 Z0.396
    N86210G1 X2.055
    N86220G1 Z0.189
    N86230G1 X2.085 Z0.165
    N86240G1 X2.115 Z0.125
    N86250G1 X2.175
    N86260G1 A144.000
    N86270G1 Z0.133 A147.429
    N86280G1 Z0.161 A150.857
    N86290G1 Z0.186 A154.286
    N86300G1 Z0.245 A157.714
    N86310G1 Z0.544
    N86320G1 A202.286
    N86330G1 Z0.245
    N86340G1 Z0.186 A205.714
    N86350G1 Z0.161 A209.143
    N86360G1 Z0.133 A212.571
    N86370G1 Z0.125 A216.000
    N86380G1 A291.429
    N86390G1 X2.115
    N86400G1 X2.085 Z0.165
    N86410G1 X2.055 Z0.189
    N86420G1 Z0.396
    N86430G1 X1.905
    N86440G1 Z0.188
    N86450G1 X1.875 Z0.179
    N86460G1 X1.845 Z0.178
    N86470G1 X1.695 Z0.178
    N86480G1 X1.665 Z0.172
    N86490G1 X1.635 Z0.159
    N86500G1 X1.605 Z0.147
    N86510G1 X1.575 Z0.156
    N86520G1 X1.545 Z0.166
    N86530G1 X1.515 Z0.175
    N86540G1 X1.485 Z0.185
    N86550G1 X1.455 Z0.194
    N86560G0 Z0.700
    N86570G0 A72.000
    N86580G0 Z0.389
    N86590G1 Z0.192
    N86600G1 X1.485 Z0.183
    N86610G1 X1.515 Z0.174
    N86620G1 X1.545 Z0.166
    N86630G1 X1.575 Z0.157
    N86640G1 X1.605 Z0.149
    N86650G1 X1.635 Z0.167
    N86660G1 X1.665 Z0.174
    N86670G1 X1.695 Z0.180
    N86680G1 X1.875 Z0.180
    N86690G1 X1.905 Z0.189
    N86700G1 Z0.398
    N86710G1 X2.025
    N86720G1 Z0.195
    N86730G1 X2.055 Z0.185
    N86740G1 X2.085 Z0.162
    N86750G1 X2.115 Z0.125
    N86760G1 X2.145
    N86770G1 A133.714
    N86780G1 Z0.212 A137.143
    N86790G0 Z0.700
    N86800G0 A222.857
    N86810G0 Z0.384
    N86820G1 Z0.212
    N86830G1 Z0.125 A226.286
    N86840G1 A288.000
    N86850G1 X2.115
    N86860G1 X2.085 Z0.162
    N86870G1 X2.055 Z0.185
    N86880G1 X2.025 Z0.195
    N86890G1 Z0.398
    N86900G1 X1.905
    N86910G1 Z0.189
    N86920G1 X1.875 Z0.180
    N86930G1 X1.695 Z0.180
    N86940G1 X1.665 Z0.174
    N86950G1 X1.635 Z0.167
    N86960G1 X1.605 Z0.149
    N86970G1 X1.575 Z0.157
    N86980G1 X1.545 Z0.166
    N86990G1 X1.515 Z0.174
    N87000G1 X1.485 Z0.183
    N87010G1 X1.455 Z0.192
    N87020G0 Z0.700
    N87030G0 A75.429
    N87040G0 Z0.387
    N87050G1 Z0.190
    N87060G1 X1.485 Z0.182
    N87070G1 X1.515 Z0.174
    N87080G1 X1.545 Z0.166
    N87090G1 X1.575 Z0.159
    N87100G1 X1.605 Z0.151
    N87110G1 X1.635 Z0.173
    N87120G1 X1.665 Z0.180
    N87130G1 X1.695 Z0.183
    N87140G1 X1.875 Z0.183
    N87150G1 X1.905 Z0.196
    N87160G1 Z0.401
    N87170G1 X2.025
    N87180G1 Z0.198
    N87190G1 X2.055 Z0.179
    N87200G1 X2.085 Z0.151
    N87210G1 X2.115 Z0.125
    N87220G1 A78.857 F37.5
    N87230G1 A120.000 F50.0
    N87240G1 Z0.138 A123.429
    N87250G1 Z0.207 A126.857
    N87260G0 Z0.700
    N87270G0 A233.143
    N87280G0 Z0.384
    N87290G1 Z0.207
    N87300G1 Z0.138 A236.571
    N87310G1 Z0.125 A240.000
    N87320G1 A284.571
    N87330G1 X2.085 Z0.151
    N87340G1 X2.055 Z0.179
    N87350G1 X2.025 Z0.198
    N87360G1 Z0.401
    N87370G1 X1.905
    N87380G1 Z0.196
    N87390G1 X1.875 Z0.183
    N87400G1 X1.695 Z0.183
    N87410G1 X1.665 Z0.180
    N87420G1 X1.635 Z0.173
    N87430G1 X1.605 Z0.151
    N87440G1 X1.575 Z0.159
    N87450G1 X1.545 Z0.166
    N87460G1 X1.515 Z0.174
    N87470G1 X1.485 Z0.182
    N87480G1 X1.455 Z0.190
    N87490G0 Z0.700
    N87500G0 A78.857
    N87510G0 Z0.386
    N87520G1 Z0.189
    N87530G1 X1.485 Z0.181
    N87540G1 X1.515 Z0.174
    N87550G1 X1.545 Z0.167
    N87560G1 X1.575 Z0.160
    N87570G1 X1.605 Z0.153
    N87580G1 X1.635 Z0.178
    N87590G1 X1.665 Z0.185
    N87600G1 X1.695 Z0.187
    N87610G1 X1.875 Z0.187
    N87620G1 X1.905 Z0.200
    N87630G1 Z0.405
    N87640G1 X2.025
    N87650G1 Z0.199
    N87660G1 X2.055 Z0.177
    N87670G1 X2.085 Z0.148
    N87680G1 Z0.144 A82.286 F37.5
    N87690G1 Z0.130 A85.714 F50.0
    N87700G1 Z0.128 A89.143
    N87710G1 Z0.125 A92.571
    N87720G1 A106.286
    N87730G1 Z0.129 A109.714
    N87740G1 Z0.152 A113.143
    N87750G1 Z0.193 A116.571
    N87760G0 Z0.700
    N87770G0 A243.429
    N87780G0 Z0.384
    N87790G1 Z0.193
    N87800G1 Z0.152 A246.857
    N87810G1 Z0.129 A250.286
    N87820G1 Z0.125 A253.714
    N87830G1 A267.429
    N87840G1 Z0.128 A270.857
    N87850G1 Z0.130 A274.286
    N87860G1 Z0.144 A277.714
    N87870G1 Z0.148 A281.143
    N87880G1 X2.055 Z0.177
    N87890G1 X2.025 Z0.199
    N87900G1 Z0.405
    N87910G1 X1.905
    N87920G1 Z0.200
    N87930G1 X1.875 Z0.187
    N87940G1 X1.695 Z0.187
    N87950G1 X1.665 Z0.185
    N87960G1 X1.635 Z0.178
    N87970G1 X1.605 Z0.153
    N87980G1 X1.575 Z0.160
    N87990G1 X1.545 Z0.167
    N88000G1 X1.515 Z0.174
    N88010G1 X1.485 Z0.181
    N88020G1 X1.455 Z0.189
    N88030G0 Z0.700
    N88040G0 A82.286
    N88050G0 Z0.385
    N88060G1 Z0.188
    N88070G1 X1.485 Z0.181
    N88080G1 X1.515 Z0.175
    N88090G1 X1.545 Z0.168
    N88100G1 X1.575 Z0.162
    N88110G1 X1.605 Z0.156
    N88120G1 X1.635 Z0.183
    N88130G1 X1.665 Z0.190
    N88140G0 Z0.700
    N88150G0 X2.025
    N88160G0 Z0.396
    N88170G1 Z0.199
    N88180G1 X2.055 Z0.176
    N88190G1 Z0.175 A85.714
    N88200G1 Z0.172 A89.143
    N88210G1 Z0.163 A92.571
    N88220G1 Z0.162 A96.000
    N88230G1 Z0.160 A99.429
    N88240G1 Z0.167 A102.857
    N88250G1 Z0.184 A106.286
    N88260G1 Z0.195 A109.714
    N88270G0 Z0.700
    N88280G0 A250.286
    N88290G0 Z0.384
    N88300G1 Z0.195
    N88310G1 Z0.184 A253.714
    N88320G1 Z0.167 A257.143
    N88330G1 Z0.160 A260.571
    N88340G1 Z0.162 A264.000
    N88350G1 Z0.162 A267.429
    N88360G1 Z0.171 A270.857
    N88370G1 Z0.175 A274.286
    N88380G1 Z0.176 A277.714
    N88390G1 X2.025 Z0.199
    N88400G0 Z0.700
    N88410G0 X1.665
    N88420G0 Z0.387
    N88430G1 Z0.190
    N88440G1 X1.635 Z0.183
    N88450G1 X1.605 Z0.156
    N88460G1 X1.575 Z0.162
    N88470G1 X1.545 Z0.168
    N88480G1 X1.515 Z0.175
    N88490G1 X1.485 Z0.181
    N88500G1 X1.455 Z0.188
    N88510G0 Z0.700
    N88520G0 A85.714
    N88530G0 Z0.385
    N88540G1 Z0.188
    N88550G1 X1.485 Z0.182
    N88560G1 X1.515 Z0.176
    N88570G1 X1.545 Z0.170
    N88580G1 X1.575 Z0.164
    N88590G1 X1.605 Z0.162
    N88600G1 X1.635 Z0.188
    N88610G0 Z0.700
    N88620G0 X2.025 A96.000
    N88630G0 Z0.384
    N88640G1 Z0.188
    N88650G1 Z0.184 A99.429
    N88660G1 Z0.195 A102.857
    N88670G0 Z0.700
    N88680G0 A257.143
    N88690G0 Z0.384
    N88700G1 Z0.195
    N88710G1 Z0.184 A260.571
    N88720G1 Z0.188 A264.000
    N88730G0 Z0.700
    N88740G0 X1.635 A274.286
    N88750G0 Z0.385
    N88760G1 Z0.188
    N88770G1 X1.605 Z0.162
    N88780G1 X1.575 Z0.164
    N88790G1 X1.545 Z0.170
    N88800G1 X1.515 Z0.176
    N88810G1 X1.485 Z0.182
    N88820G1 X1.455 Z0.188
    N88830G0 Z0.700
    N88840G0 A89.143
    N88850G0 Z0.387
    N88860G1 Z0.190
    N88870G1 X1.485 Z0.184
    N88880G1 X1.515 Z0.179
    N88890G1 X1.545 Z0.173
    N88900G1 X1.575 Z0.167
    N88910G1 X1.605 Z0.168
    N88920G1 X1.635 Z0.193
    N88930G0 Z0.700
    N88940G0 A270.857
    N88950G0 Z0.390
    N88960G1 Z0.193
    N88970G1 X1.605 Z0.168
    N88980G1 X1.575 Z0.167
    N88990G1 X1.545 Z0.173
    N89000G1 X1.515 Z0.179
    N89010G1 X1.485 Z0.184
    N89020G1 X1.455 Z0.190
    N89030G0 Z0.700
    N89040G0 A92.571
    N89050G0 Z0.389
    N89060G1 Z0.192
    N89070G1 X1.485 Z0.186
    N89080G1 X1.515 Z0.181
    N89090G1 X1.545 Z0.176
    N89100G1 X1.575 Z0.171
    N89110G1 X1.605 Z0.173
    N89120G1 X1.635 Z0.198
    N89130G0 Z0.700
    N89140G0 A267.429
    N89150G0 Z0.394
    N89160G1 Z0.198
    N89170G1 X1.605 Z0.173
    N89180G1 X1.575 Z0.171
    N89190G1 X1.545 Z0.176
    N89200G1 X1.515 Z0.181
    N89210G1 X1.485 Z0.186
    N89220G1 X1.455 Z0.192
    N89230G0 Z0.700
    N89240G0 X1.485 A96.000
    N89250G0 Z0.386
    N89260G1 Z0.189
    N89270G1 X1.515 Z0.184
    N89280G1 X1.545 Z0.180
    N89290G1 X1.575 Z0.176
    N89300G1 X1.605 Z0.178
    N89310G1 X1.635 Z0.202
    N89320G0 Z0.700
    N89330G0 A264.000
    N89340G0 Z0.399
    N89350G1 Z0.202
    N89360G1 X1.605 Z0.178
    N89370G1 X1.575 Z0.176
    N89380G1 X1.545 Z0.180
    N89390G1 X1.515 Z0.184
    N89400G1 X1.485 Z0.189
    N89410G0 Z0.700
    N89420G0 X1.515 A99.429
    N89430G0 Z0.385
    N89440G1 Z0.188
    N89450G1 X1.545 Z0.185
    N89460G1 X1.575 Z0.181
    N89470G1 X1.605 Z0.183
    N89480G1 X1.635 Z0.207
    N89490G0 Z0.700
    N89500G0 A260.571
    N89510G0 Z0.403
    N89520G1 Z0.207
    N89530G1 X1.605 Z0.183
    N89540G1 X1.575 Z0.181
    N89550G1 X1.545 Z0.185
    N89560G1 X1.515 Z0.188
    N89570G0 Z0.700
    N89580G0 X1.545 A102.857
    N89590G0 Z0.387
    N89600G1 Z0.190
    N89610G1 X1.575 Z0.187
    N89620G1 X1.605 Z0.188
    N89630G0 Z0.700
    N89640G0 A257.143
    N89650G0 Z0.385
    N89660G1 Z0.188
    N89670G1 X1.575 Z0.187
    N89680G1 X1.545 Z0.190
    N89690G0 Z0.700
    N89700G0 X0.000 A0.000
    N89710G0 Z0.322
    N89720G1 Z0.125
    N89730G1 X0.255 Z0.103 F37.5
    N89740G1 X0.000 Z0.080
    N89750G1 X0.105 Z0.071
    N89760G1 X0.000 Z0.063
    N89770G1 X0.255
    N89780G1 X0.285 Z0.068
    N89790G1 X0.315 Z0.092
    N89800G1 X0.345 Z0.098
    N89810G1 X0.495
    N89820G1 X0.525 Z0.413 F50.0
    N89830G0 Z0.700
    N89840G0 X2.085
    N89850G0 Z0.389
    N89860G1 Z0.192
    N89870G1 X2.115 Z0.101 F37.5
    N89880G1 X2.145 Z0.098
    N89890G1 X2.415
    N89900G1 X2.445 Z0.092
    N89910G1 X2.475 Z0.068
    N89920G1 X2.505 Z0.063
    N89930G1 X2.750
    N89940G1 A360.000
    N89950G1 X2.505
    N89960G1 X2.475 Z0.068
    N89970G1 X2.445 Z0.092
    N89980G1 X2.415 Z0.098
    N89990G1 X2.145
    N90000G1 X2.115 Z0.101
    N90010G1 X2.085 Z0.192 F50.0
    N90020G0 Z0.700
    N90030G0 X0.525
    N90040G0 Z0.610
    N90050G1 Z0.413
    N90060G1 X0.495 Z0.098 F37.5
    N90070G1 X0.345
    N90080G1 X0.315 Z0.092
    N90090G1 X0.285 Z0.068
    N90100G1 X0.255 Z0.063
    N90110G1 X0.000
    N90120G1 A3.429
    N90130G1 X0.255 F50.0
    N90140G1 X0.285 Z0.068
    N90150G1 X0.315 Z0.092
    N90160G1 X0.345 Z0.098
    N90170G1 X0.495
    N90180G1 X0.525 Z0.413
    N90190G0 Z0.700
    N90200G0 X2.085
    N90210G0 Z0.390
    N90220G1 Z0.193
    N90230G1 X2.115 Z0.102
    N90240G1 X2.145 Z0.098
    N90250G1 X2.415
    N90260G1 X2.445 Z0.092
    N90270G1 X2.475 Z0.068
    N90280G1 X2.505 Z0.063
    N90290G1 X2.745
    N90300G1 A356.571
    N90310G1 X2.505
    N90320G1 X2.475 Z0.068
    N90330G1 X2.445 Z0.092
    N90340G1 X2.415 Z0.098
    N90350G1 X2.145
    N90360G1 X2.115 Z0.102
    N90370G1 X2.085 Z0.193
    N90380G0 Z0.700
    N90390G0 X0.525
    N90400G0 Z0.610
    N90410G1 Z0.413
    N90420G1 X0.495 Z0.098
    N90430G1 X0.345
    N90440G1 X0.315 Z0.092
    N90450G1 X0.285 Z0.068
    N90460G1 X0.255 Z0.063
    N90470G1 X0.015
    N90480G1 A6.857
    N90490G1 X0.255
    N90500G1 X0.285 Z0.068
    N90510G1 X0.315 Z0.092
    N90520G1 X0.345 Z0.098
    N90530G1 X0.495
    N90540G1 X0.525 Z0.413
    N90550G0 Z0.700
    N90560G0 X2.085
    N90570G0 Z0.392
    N90580G1 Z0.195
    N90590G1 X2.115 Z0.102
    N90600G1 X2.145 Z0.098
    N90610G1 X2.415
    N90620G1 X2.445 Z0.092
    N90630G1 X2.475 Z0.068
    N90640G1 X2.505 Z0.063
    N90650G1 X2.715
    N90660G1 A353.143
    N90670G1 X2.505
    N90680G1 X2.475 Z0.068
    N90690G1 X2.445 Z0.092
    N90700G1 X2.415 Z0.098
    N90710G1 X2.145
    N90720G1 X2.115 Z0.102
    N90730G1 X2.085 Z0.195
    N90740G0 Z0.700
    N90750G0 X0.525
    N90760G0 Z0.610
    N90770G1 Z0.413
    N90780G1 X0.495 Z0.098
    N90790G1 X0.345
    N90800G1 X0.315 Z0.092
    N90810G1 X0.285 Z0.068
    N90820G1 X0.255 Z0.063
    N90830G1 X0.045
    N90840G1 A10.286
    N90850G1 X0.255
    N90860G1 X0.285 Z0.068
    N90870G1 X0.315 Z0.092
    N90880G1 X0.345 Z0.098
    N90890G1 X0.495
    N90900G1 X0.525 Z0.413
    N90910G0 Z0.700
    N90920G0 X2.085
    N90930G0 Z0.393
    N90940G1 Z0.196
    N90950G1 X2.115 Z0.102
    N90960G1 X2.145 Z0.098
    N90970G1 X2.415
    N90980G1 X2.445 Z0.092
    N90990G1 X2.475 Z0.068
    N91000G1 X2.505 Z0.063
    N91010G1 X2.685
    N91020G1 A349.714
    N91030G1 X2.505
    N91040G1 X2.475 Z0.068
    N91050G1 X2.445 Z0.092
    N91060G1 X2.415 Z0.098
    N91070G1 X2.145
    N91080G1 X2.115 Z0.102
    N91090G1 X2.085 Z0.196
    N91100G0 Z0.700
    N91110G0 X0.525
    N91120G0 Z0.610
    N91130G1 Z0.413
    N91140G1 X0.495 Z0.098
    N91150G1 X0.345
    N91160G1 X0.315 Z0.092
    N91170G1 X0.285 Z0.068
    N91180G1 X0.255 Z0.063
    N91190G1 X0.075
    N91200G1 A13.714
    N91210G1 X0.255
    N91220G1 X0.285 Z0.068
    N91230G1 X0.315 Z0.092
    N91240G1 X0.345 Z0.098
    N91250G1 X0.495
    N91260G1 X0.525 Z0.413
    N91270G0 Z0.700
    N91280G0 X2.085
    N91290G0 Z0.393
    N91300G1 Z0.196
    N91310G1 X2.115 Z0.102
    N91320G1 X2.145 Z0.098
    N91330G1 X2.415
    N91340G1 X2.445 Z0.092
    N91350G1 X2.475 Z0.068
    N91360G1 X2.505 Z0.063
    N91370G1 X2.655
    N91380G1 A346.286
    N91390G1 X2.505
    N91400G1 X2.475 Z0.068
    N91410G1 X2.445 Z0.092
    N91420G1 X2.415 Z0.098
    N91430G1 X2.145
    N91440G1 X2.115 Z0.102
    N91450G1 X2.085 Z0.196
    N91460G0 Z0.700
    N91470G0 X0.525
    N91480G0 Z0.610
    N91490G1 Z0.413
    N91500G1 X0.495 Z0.098
    N91510G1 X0.345
    N91520G1 X0.315 Z0.092
    N91530G1 X0.285 Z0.068
    N91540G1 X0.255 Z0.063
    N91550G1 X0.105
    N91560G1 A17.143
    N91570G1 X0.255
    N91580G1 X0.285 Z0.068
    N91590G1 X0.315 Z0.092
    N91600G1 X0.345 Z0.098
    N91610G1 X0.495
    N91620G1 X0.525 Z0.413
    N91630G0 Z0.700
    N91640G0 X2.085
    N91650G0 Z0.392
    N91660G1 Z0.195
    N91670G1 X2.115 Z0.101
    N91680G1 X2.145 Z0.098
    N91690G1 X2.415
    N91700G1 X2.445 Z0.092
    N91710G1 X2.475 Z0.068
    N91720G1 X2.505 Z0.063
    N91730G1 X2.625
    N91740G1 A342.857
    N91750G1 X2.505
    N91760G1 X2.475 Z0.068
    N91770G1 X2.445 Z0.092
    N91780G1 X2.415 Z0.098
    N91790G1 X2.145
    N91800G1 X2.115 Z0.102
    N91810G1 X2.085 Z0.195
    N91820G0 Z0.700
    N91830G0 X0.525
    N91840G0 Z0.610
    N91850G1 Z0.413
    N91860G1 X0.495 Z0.098
    N91870G1 X0.345
    N91880G1 X0.315 Z0.092
    N91890G1 X0.285 Z0.068
    N91900G1 X0.255 Z0.063
    N91910G1 X0.135
    N91920G1 A20.571
    N91930G1 X0.255
    N91940G1 X0.285 Z0.068
    N91950G1 X0.315 Z0.092
    N91960G1 X0.345 Z0.098
    N91970G1 X0.495
    N91980G1 X0.525 Z0.413
    N91990G0 Z0.700
    N92000G0 X2.085
    N92010G0 Z0.388
    N92020G1 Z0.191
    N92030G1 X2.115 Z0.098
    N92040G1 X2.415
    N92050G1 X2.445 Z0.092
    N92060G1 X2.475 Z0.068
    N92070G1 X2.505 Z0.063
    N92080G1 X2.595
    N92090G1 A339.429
    N92100G1 X2.505
    N92110G1 X2.475 Z0.068
    N92120G1 X2.445 Z0.092
    N92130G1 X2.415 Z0.098
    N92140G1 X2.115
    N92150G1 X2.085 Z0.191
    N92160G0 Z0.700
    N92170G0 X0.525
    N92180G0 Z0.610
    N92190G1 Z0.413
    N92200G1 X0.495 Z0.098
    N92210G1 X0.345
    N92220G1 X0.315 Z0.092
    N92230G1 X0.285 Z0.068
    N92240G1 X0.255 Z0.063
    N92250G1 X0.165
    N92260G1 A24.000
    N92270G1 X0.255
    N92280G1 X0.285 Z0.068
    N92290G1 X0.315 Z0.092
    N92300G1 X0.345 Z0.098
    N92310G1 X0.495
    N92320G1 X0.525 Z0.413
    N92330G0 Z0.700
    N92340G0 X2.085
    N92350G0 Z0.384
    N92360G1 Z0.187
    N92370G1 X2.115 Z0.098
    N92380G1 X2.415
    N92390G1 X2.445 Z0.092
    N92400G1 X2.475 Z0.068
    N92410G1 X2.505 Z0.063
    N92420G1 X2.565
    N92430G1 A336.000
    N92440G1 X2.505
    N92450G1 X2.475 Z0.068
    N92460G1 X2.445 Z0.092
    N92470G1 X2.415 Z0.098
    N92480G1 X2.115
    N92490G1 X2.085 Z0.187
    N92500G0 Z0.700
    N92510G0 X0.525
    N92520G0 Z0.610
    N92530G1 Z0.413
    N92540G1 X0.495 Z0.098
    N92550G1 X0.345
    N92560G1 X0.315 Z0.092
    N92570G1 X0.285 Z0.068
    N92580G1 X0.255 Z0.063
    N92590G1 X0.195
    N92600G1 A27.429
    N92610G1 X0.255
    N92620G1 X0.285 Z0.068
    N92630G1 X0.315 Z0.092
    N92640G1 X0.345 Z0.098
    N92650G1 X0.495
    N92660G1 X0.525 Z0.413
    N92670G0 Z0.700
    N92680G0 X2.085
    N92690G0 Z0.381
    N92700G1 Z0.184
    N92710G1 X2.115 Z0.098
    N92720G1 X2.415
    N92730G1 X2.445 Z0.092
    N92740G1 X2.475 Z0.068
    N92750G1 X2.505 Z0.063
    N92760G1 X2.535
    N92770G1 A332.571
    N92780G1 X2.505
    N92790G1 X2.475 Z0.068
    N92800G1 X2.445 Z0.092
    N92810G1 X2.415 Z0.098
    N92820G1 X2.115
    N92830G1 X2.085 Z0.184
    N92840G0 Z0.700
    N92850G0 X0.525
    N92860G0 Z0.610
    N92870G1 Z0.413
    N92880G1 X0.495 Z0.098
    N92890G1 X0.345
    N92900G1 X0.315 Z0.092
    N92910G1 X0.285 Z0.068
    N92920G1 X0.255 Z0.063
    N92930G1 X0.225
    N92940G1 A30.857
    N92950G1 X0.255
    N92960G1 X0.285 Z0.068
    N92970G1 X0.315 Z0.092
    N92980G1 X0.345 Z0.098
    N92990G1 X0.495
    N93000G1 X0.525 Z0.413
    N93010G0 Z0.700
    N93020G0 X2.085
    N93030G0 Z0.379
    N93040G1 Z0.182
    N93050G1 X2.115 Z0.098
    N93060G1 X2.415
    N93070G1 X2.445 Z0.092
    N93080G1 X2.475 Z0.068
    N93090G1 X2.505 Z0.063
    N93100G1 A329.143
    N93110G1 X2.475 Z0.068
    N93120G1 X2.445 Z0.092
    N93130G1 X2.415 Z0.098
    N93140G1 X2.115
    N93150G1 X2.085 Z0.182
    N93160G0 Z0.700
    N93170G0 X0.525
    N93180G0 Z0.610
    N93190G1 Z0.413
    N93200G1 X0.495 Z0.098
    N93210G1 X0.345
    N93220G1 X0.315 Z0.092
    N93230G1 X0.285 Z0.068
    N93240G1 X0.255 Z0.063
    N93250G1 A34.286
    N93260G1 X0.285 Z0.068
    N93270G1 X0.315 Z0.092
    N93280G1 X0.345 Z0.098
    N93290G1 X0.495
    N93300G1 X0.525 Z0.413
    N93310G0 Z0.700
    N93320G0 X2.085
    N93330G0 Z0.377
    N93340G1 Z0.180
    N93350G1 X2.115 Z0.098
    N93360G1 X2.415
    N93370G1 X2.445 Z0.092
    N93380G1 X2.475 Z0.068
    N93390G1 Z0.068 A37.714 F37.5
    N93400G1 Z0.068 A325.714 F50.0
    N93410G1 X2.445 Z0.092
    N93420G1 X2.415 Z0.098
    N93430G1 X2.115
    N93440G1 X2.085 Z0.180
    N93450G0 Z0.700
    N93460G0 X0.525
    N93470G0 Z0.610
    N93480G1 Z0.413
    N93490G1 X0.495 Z0.098
    N93500G1 X0.345
    N93510G1 X0.315 Z0.092
    N93520G1 X0.285 Z0.068
    N93530G1 Z0.068 A322.286 F37.5
    N93540G1 Z0.068 A37.714 F50.0
    N93550G1 X0.315 Z0.092
    N93560G1 X0.345 Z0.098
    N93570G1 X0.495
    N93580G1 X0.525 Z0.413
    N93590G0 Z0.700
    N93600G0 X2.085
    N93610G0 Z0.375
    N93620G1 Z0.178
    N93630G1 X2.115 Z0.102
    N93640G1 X2.145 Z0.098
    N93650G1 X2.415
    N93660G1 X2.445 Z0.092
    N93670G1 Z0.092 A322.286
    N93680G1 X2.415 Z0.098
    N93690G1 X2.145
    N93700G1 X2.115 Z0.102
    N93710G1 X2.085 Z0.178
    N93720G0 Z0.700
    N93730G0 X0.525
    N93740G0 Z0.610
    N93750G1 Z0.413
    N93760G1 X0.495 Z0.098
    N93770G1 X0.345
    N93780G1 X0.315 Z0.092
    N93790G1 Z0.092 A41.143
    N93800G1 X0.345 Z0.098
    N93810G1 X0.495
    N93820G1 X0.525 Z0.413
    N93830G0 Z0.700
    N93840G0 X2.085
    N93850G0 Z0.369
    N93860G1 Z0.172
    N93870G1 X2.115 Z0.110
    N93880G1 X2.145 Z0.098
    N93890G1 X2.415
    N93900G1 Z0.098 A318.857
    N93910G1 X2.145
    N93920G1 X2.115 Z0.110
    N93930G1 X2.085 Z0.172
    N93940G0 Z0.700
    N93950G0 X0.525
    N93960G0 Z0.610
    N93970G1 Z0.413
    N93980G1 X0.495 Z0.098
    N93990G1 X0.345
    N94000G1 Z0.098 A44.571
    N94010G1 X0.495
    N94020G1 X0.525 Z0.413
    N94030G0 Z0.700
    N94040G0 X2.085
    N94050G0 Z0.369
    N94060G1 Z0.173
    N94070G1 X2.115 Z0.113
    N94080G1 X2.145 Z0.098
    N94090G1 X2.385
    N94100G1 Z0.098 A315.429
    N94110G1 X2.145
    N94120G1 X2.115 Z0.113
    N94130G1 X2.085 Z0.173
    N94140G0 Z0.700
    N94150G0 X0.525
    N94160G0 Z0.610
    N94170G1 Z0.413
    N94180G1 X0.495 Z0.098
    N94190G1 X0.375
    N94200G1 Z0.098 A48.000
    N94210G1 X0.495
    N94220G1 X0.525 Z0.413
    N94230G0 Z0.700
    N94240G0 X2.085
    N94250G0 Z0.370
    N94260G1 Z0.173
    N94270G1 X2.115 Z0.114
    N94280G1 X2.145 Z0.098
    N94290G1 X2.355
    N94300G1 Z0.098 A312.000
    N94310G1 X2.145
    N94320G1 X2.115 Z0.114
    N94330G1 X2.085 Z0.173
    N94340G0 Z0.700
    N94350G0 X0.525
    N94360G0 Z0.610
    N94370G1 Z0.413
    N94380G1 X0.495 Z0.098
    N94390G1 X0.405
    N94400G1 Z0.098 A51.429
    N94410G1 X0.495
    N94420G1 X0.525 Z0.413
    N94430G0 Z0.700
    N94440G0 X2.085
    N94450G0 Z0.370
    N94460G1 Z0.173
    N94470G1 X2.115 Z0.123
    N94480G1 X2.145 Z0.098
    N94490G1 X2.325
    N94500G1 Z0.098 A308.571
    N94510G1 X2.145
    N94520G1 X2.115 Z0.123
    N94530G1 X2.085 Z0.173
    N94540G0 Z0.700
    N94550G0 X0.525
    N94560G0 Z0.610
    N94570G1 Z0.413
    N94580G1 X0.495 Z0.098
    N94590G1 X0.435
    N94600G1 Z0.098 A54.857
    N94610G1 X0.495
    N94620G1 X0.525 Z0.413
    N94630G0 Z0.700
    N94640G0 X2.115
    N94650G0 Z0.325
    N94660G1 Z0.128
    N94670G1 X2.145 Z0.098
    N94680G1 X2.295
    N94690G1 Z0.098 A305.143
    N94700G1 X2.145
    N94710G1 X2.115 Z0.128
    N94720G0 Z0.700
    N94730G0 X0.525
    N94740G0 Z0.610
    N94750G1 Z0.413
    N94760G1 X0.495 Z0.098
    N94770G1 X0.465
    N94780G1 Z0.098 A58.286
    N94790G1 X0.495
    N94800G1 X0.525 Z0.413
    N94810G0 Z0.700
    N94820G0 X2.115
    N94830G0 Z0.326
    N94840G1 Z0.129
    N94850G1 X2.145 Z0.098
    N94860G1 X2.265
    N94870G1 Z0.098 A301.714
    N94880G1 X2.145
    N94890G1 X2.115 Z0.128
    N94900G0 Z0.700
    N94910G0 X0.525
    N94920G0 Z0.610
    N94930G1 Z0.413
    N94940G1 X0.495 Z0.098
    N94950G1 Z0.098 A298.286 F37.5
    N94960G1 Z0.098 A61.714 F50.0
    N94970G1 X0.525 Z0.413
    N94980G0 Z0.700
    N94990G0 X2.115
    N95000G0 Z0.325
    N95010G1 Z0.129
    N95020G1 X2.145 Z0.098
    N95030G1 X2.235
    N95040G1 Z0.098 A157.714
    N95050G1 Z0.164 A161.143
    N95060G1 Z0.465
    N95070G1 A198.857
    N95080G1 Z0.164
    N95090G1 Z0.098 A202.286
    N95100G1 Z0.098 A298.286
    N95110G1 X2.145
    N95120G1 X2.115 Z0.128
    N95130G0 Z0.700
    N95140G0 A65.143
    N95150G0 Z0.325
    N95160G1 Z0.128
    N95170G1 X2.145 Z0.098
    N95180G1 X2.205
    N95190G1 Z0.098 A144.000
    N95200G1 Z0.116 A147.429
    N95210G1 Z0.150 A150.857
    N95220G1 Z0.489
    N95230G1 A209.143
    N95240G1 Z0.150
    N95250G1 Z0.116 A212.571
    N95260G1 Z0.098 A216.000
    N95270G1 Z0.098 A294.857
    N95280G1 X2.145
    N95290G1 X2.115 Z0.127
    N95300G0 Z0.700
    N95310G0 X2.085 A68.571
    N95320G0 Z0.362
    N95330G1 Z0.165
    N95340G1 X2.115 Z0.117
    N95350G1 X2.145 Z0.098
    N95360G1 X2.175
    N95370G1 Z0.098 A137.143
    N95380G1 Z0.101 A140.571
    N95390G1 Z0.112 A144.000
    N95400G1 Z0.133 A147.429
    N95410G0 Z0.700
    N95420G0 A212.571
    N95430G0 Z0.322
    N95440G1 Z0.133
    N95450G1 Z0.112 A216.000
    N95460G1 Z0.101 A219.429
    N95470G1 Z0.098 A222.857
    N95480G1 Z0.098 A291.429
    N95490G1 X2.145
    N95500G1 X2.115 Z0.117
    N95510G1 X2.085 Z0.165
    N95520G0 Z0.700
    N95530G0 A72.000
    N95540G0 Z0.358
    N95550G1 Z0.162
    N95560G1 X2.115 Z0.114
    N95570G1 X2.145 Z0.098
    N95580G1 Z0.098 A75.429 F37.5
    N95590G1 Z0.098 A133.714 F50.0
    N95600G1 Z0.212 A137.143
    N95610G0 Z0.700
    N95620G0 A222.857
    N95630G0 Z0.322
    N95640G1 Z0.212
    N95650G1 Z0.098 A226.286
    N95660G1 Z0.098 A288.000
    N95670G1 X2.115 Z0.113
    N95680G1 X2.085 Z0.162
    N95690G0 Z0.700
    N95700G0 A75.429
    N95710G0 Z0.348
    N95720G1 Z0.151
    N95730G1 X2.115 Z0.111
    N95740G1 Z0.107 A78.857 F37.5
    N95750G1 Z0.098 A82.286 F50.0
    N95760G1 Z0.098 A120.000
    N95770G1 Z0.138 A123.429
    N95780G0 Z0.700
    N95790G0 A236.571
    N95800G0 Z0.322
    N95810G1 Z0.138
    N95820G1 Z0.098 A240.000
    N95830G1 Z0.098 A277.714
    N95840G1 Z0.107 A281.143
    N95850G1 Z0.111 A284.571
    N95860G1 X2.085 Z0.151
    N95870G0 Z0.700
    N95880G0 A89.143
    N95890G0 Z0.322
    N95900G1 Z0.128
    N95910G1 Z0.123 A92.571
    N95920G1 Z0.115 A96.000
    N95930G1 Z0.111 A99.429
    N95940G1 Z0.108 A102.857
    N95950G1 Z0.116 A106.286
    N95960G1 Z0.129 A109.714
    N95970G0 Z0.700
    N95980G0 A250.286
    N95990G0 Z0.322
    N96000G1 Z0.129
    N96010G1 Z0.116 A253.714
    N96020G1 Z0.108 A257.143
    N96030G1 Z0.111 A260.571
    N96040G1 Z0.115 A264.000
    N96050G1 Z0.123 A267.429
    N96060G1 Z0.128 A270.857
    N96070G0 Z0.700
    N96080G0 X0.000 A0.000
    N96090G0 Z0.259
    N96100G1 Z0.063
    N96110G1 X0.255 Z0.040 F37.5
    N96120G1 X0.000 Z0.018
    N96130G1 X0.105 Z0.009
    N96140G1 X0.000 Z0.000
    N96150G1 X0.255
    N96160G1 X0.285 Z0.068 F50.0
    N96170G0 Z0.700
    N96180G0 X2.475
    N96190G0 Z0.265
    N96200G1 Z0.068
    N96210G1 X2.505 Z0.000 F37.5
    N96220G1 X2.750
    N96230G1 A360.000
    N96240G1 X2.505
    N96250G1 X2.475 Z0.068 F50.0
    N96260G0 Z0.700
    N96270G0 X0.285
    N96280G0 Z0.265
    N96290G1 Z0.068
    N96300G1 X0.255 Z0.000 F37.5
    N96310G1 X0.000
    N96320G1 A3.429
    N96330G1 X0.255 F50.0
    N96340G1 X0.285 Z0.068
    N96350G0 Z0.700
    N96360G0 X2.475
    N96370G0 Z0.265
    N96380G1 Z0.068
    N96390G1 X2.505 Z0.000
    N96400G1 X2.745
    N96410G1 A356.571
    N96420G1 X2.505
    N96430G1 X2.475 Z0.068
    N96440G0 Z0.700
    N96450G0 X0.285
    N96460G0 Z0.265
    N96470G1 Z0.068
    N96480G1 X0.255 Z0.000
    N96490G1 X0.015
    N96500G1 A6.857
    N96510G1 X0.255
    N96520G1 X0.285 Z0.068
    N96530G0 Z0.700
    N96540G0 X2.475
    N96550G0 Z0.265
    N96560G1 Z0.068
    N96570G1 X2.505 Z0.000
    N96580G1 X2.715
    N96590G1 A353.143
    N96600G1 X2.505
    N96610G1 X2.475 Z0.068
    N96620G0 Z0.700
    N96630G0 X0.285
    N96640G0 Z0.265
    N96650G1 Z0.068
    N96660G1 X0.255 Z0.000
    N96670G1 X0.045
    N96680G1 A10.286
    N96690G1 X0.255
    N96700G1 X0.285 Z0.068
    N96710G0 Z0.700
    N96720G0 X2.475
    N96730G0 Z0.265
    N96740G1 Z0.068
    N96750G1 X2.505 Z0.000
    N96760G1 X2.685
    N96770G1 A349.714
    N96780G1 X2.505
    N96790G1 X2.475 Z0.068
    N96800G0 Z0.700
    N96810G0 X0.285
    N96820G0 Z0.265
    N96830G1 Z0.068
    N96840G1 X0.255 Z0.000
    N96850G1 X0.075
    N96860G1 A13.714
    N96870G1 X0.255
    N96880G1 X0.285 Z0.068
    N96890G0 Z0.700
    N96900G0 X2.475
    N96910G0 Z0.265
    N96920G1 Z0.068
    N96930G1 X2.505 Z0.000
    N96940G1 X2.655
    N96950G1 A346.286
    N96960G1 X2.505
    N96970G1 X2.475 Z0.068
    N96980G0 Z0.700
    N96990G0 X0.285
    N97000G0 Z0.265
    N97010G1 Z0.068
    N97020G1 X0.255 Z0.000
    N97030G1 X0.105
    N97040G1 A17.143
    N97050G1 X0.255
    N97060G1 X0.285 Z0.068
    N97070G0 Z0.700
    N97080G0 X2.475
    N97090G0 Z0.265
    N97100G1 Z0.068
    N97110G1 X2.505 Z0.000
    N97120G1 X2.625
    N97130G1 A342.857
    N97140G1 X2.505
    N97150G1 X2.475 Z0.068
    N97160G0 Z0.700
    N97170G0 X0.285
    N97180G0 Z0.265
    N97190G1 Z0.068
    N97200G1 X0.255 Z0.000
    N97210G1 X0.135
    N97220G1 A20.571
    N97230G1 X0.255
    N97240G1 X0.285 Z0.068
    N97250G0 Z0.700
    N97260G0 X2.475
    N97270G0 Z0.265
    N97280G1 Z0.068
    N97290G1 X2.505 Z0.000
    N97300G1 X2.595
    N97310G1 A339.429
    N97320G1 X2.505
    N97330G1 X2.475 Z0.068
    N97340G0 Z0.700
    N97350G0 X0.285
    N97360G0 Z0.265
    N97370G1 Z0.068
    N97380G1 X0.255 Z0.000
    N97390G1 X0.165
    N97400G1 A24.000
    N97410G1 X0.255
    N97420G1 X0.285 Z0.068
    N97430G0 Z0.700
    N97440G0 X2.475
    N97450G0 Z0.265
    N97460G1 Z0.068
    N97470G1 X2.505 Z0.000
    N97480G1 X2.565
    N97490G1 A336.000
    N97500G1 X2.505
    N97510G1 X2.475 Z0.068
    N97520G0 Z0.700
    N97530G0 X0.285
    N97540G0 Z0.265
    N97550G1 Z0.068
    N97560G1 X0.255 Z0.000
    N97570G1 X0.195
    N97580G1 A27.429
    N97590G1 X0.255
    N97600G1 X0.285 Z0.068
    N97610G0 Z0.700
    N97620G0 X2.475
    N97630G0 Z0.265
    N97640G1 Z0.068
    N97650G1 X2.505 Z0.000
    N97660G1 X2.535
    N97670G1 A332.571
    N97680G1 X2.505
    N97690G1 X2.475 Z0.068
    N97700G0 Z0.700
    N97710G0 X0.285
    N97720G0 Z0.265
    N97730G1 Z0.068
    N97740G1 X0.255 Z0.000
    N97750G1 X0.225
    N97760G1 A30.857
    N97770G1 X0.255
    N97780G1 X0.285 Z0.068
    N97790G0 Z0.700
    N97800G0 X2.475
    N97810G0 Z0.265
    N97820G1 Z0.068
    N97830G1 X2.505 Z0.000
    N97840G1 A329.143
    N97850G1 X2.475 Z0.068
    N97860G0 Z0.700
    N97870G0 X0.285
    N97880G0 Z0.265
    N97890G1 Z0.068
    N97900G1 X0.255 Z0.000
    N97910G1 A34.286
    N97920G1 X0.285 Z0.068
    N97930G0 Z0.700
    N97940G0 X0.000 A0.000
    N97950G0 Z0.197
    N97960G1 Z0.000
    N97970G1 X0.255 Z-0.022 F37.5
    N97980G1 X0.000 Z-0.045
    N97990G1 X0.105 Z-0.054
    N98000G1 X0.000 Z-0.062
    N98010G1 X0.255
    N98020G1 X0.285 Z0.068 F50.0
    N98030G0 Z0.700
    N98040G0 X2.475
    N98050G0 Z0.265
    N98060G1 Z0.068
    N98070G1 X2.505 Z-0.062 F37.5
    N98080G1 X2.750
    N98090G1 A360.000
    N98100G1 X2.505
    N98110G1 X2.475 Z0.068 F50.0
    N98120G0 Z0.700
    N98130G0 X0.285
    N98140G0 Z0.265
    N98150G1 Z0.068
    N98160G1 X0.255 Z-0.062 F37.5
    N98170G1 X0.000
    N98180G1 A3.429
    N98190G1 X0.255 F50.0
    N98200G1 X0.285 Z0.068
    N98210G0 Z0.700
    N98220G0 X2.475
    N98230G0 Z0.265
    N98240G1 Z0.068
    N98250G1 X2.505 Z-0.062
    N98260G1 X2.745
    N98270G1 A356.571
    N98280G1 X2.505
    N98290G1 X2.475 Z0.068
    N98300G0 Z0.700
    N98310G0 X0.285
    N98320G0 Z0.265
    N98330G1 Z0.068
    N98340G1 X0.255 Z-0.062
    N98350G1 X0.015
    N98360G1 A6.857
    N98370G1 X0.255
    N98380G1 X0.285 Z0.068
    N98390G0 Z0.700
    N98400G0 X2.475
    N98410G0 Z0.265
    N98420G1 Z0.068
    N98430G1 X2.505 Z-0.062
    N98440G1 X2.715
    N98450G1 A353.143
    N98460G1 X2.505
    N98470G1 X2.475 Z0.068
    N98480G0 Z0.700
    N98490G0 X0.285
    N98500G0 Z0.265
    N98510G1 Z0.068
    N98520G1 X0.255 Z-0.062
    N98530G1 X0.045
    N98540G1 A10.286
    N98550G1 X0.255
    N98560G1 X0.285 Z0.068
    N98570G0 Z0.700
    N98580G0 X2.475
    N98590G0 Z0.265
    N98600G1 Z0.068
    N98610G1 X2.505 Z-0.062
    N98620G1 X2.685
    N98630G1 A349.714
    N98640G1 X2.505
    N98650G1 X2.475 Z0.068
    N98660G0 Z0.700
    N98670G0 X0.285
    N98680G0 Z0.265
    N98690G1 Z0.068
    N98700G1 X0.255 Z-0.062
    N98710G1 X0.075
    N98720G1 A13.714
    N98730G1 X0.255
    N98740G1 X0.285 Z0.068
    N98750G0 Z0.700
    N98760G0 X2.475
    N98770G0 Z0.265
    N98780G1 Z0.068
    N98790G1 X2.505 Z-0.062
    N98800G1 X2.655
    N98810G1 A346.286
    N98820G1 X2.505
    N98830G1 X2.475 Z0.068
    N98840G0 Z0.700
    N98850G0 X0.285
    N98860G0 Z0.265
    N98870G1 Z0.068
    N98880G1 X0.255 Z-0.062
    N98890G1 X0.105
    N98900G1 A17.143
    N98910G1 X0.255
    N98920G1 X0.285 Z0.068
    N98930G0 Z0.700
    N98940G0 X2.475
    N98950G0 Z0.265
    N98960G1 Z0.068
    N98970G1 X2.505 Z-0.062
    N98980G1 X2.625
    N98990G1 A342.857
    N99000G1 X2.505
    N99010G1 X2.475 Z0.068
    N99020G0 Z0.700
    N99030G0 X0.285
    N99040G0 Z0.265
    N99050G1 Z0.068
    N99060G1 X0.255 Z-0.062
    N99070G1 X0.135
    N99080G1 A20.571
    N99090G1 X0.255
    N99100G1 X0.285 Z0.068
    N99110G0 Z0.700
    N99120G0 X2.475
    N99130G0 Z0.265
    N99140G1 Z0.068
    N99150G1 X2.505 Z-0.062
    N99160G1 X2.595
    N99170G1 A339.429
    N99180G1 X2.505
    N99190G1 X2.475 Z0.068
    N99200G0 Z0.700
    N99210G0 X0.285
    N99220G0 Z0.265
    N99230G1 Z0.068
    N99240G1 X0.255 Z-0.062
    N99250G1 X0.165
    N99260G1 A24.000
    N99270G1 X0.255
    N99280G1 X0.285 Z0.068
    N99290G0 Z0.700
    N99300G0 X2.475
    N99310G0 Z0.265
    N99320G1 Z0.068
    N99330G1 X2.505 Z-0.062
    N99340G1 X2.565
    N99350G1 A336.000
    N99360G1 X2.505
    N99370G1 X2.475 Z0.068
    N99380G0 Z0.700
    N99390G0 X0.285
    N99400G0 Z0.265
    N99410G1 Z0.068
    N99420G1 X0.255 Z-0.062
    N99430G1 X0.195
    N99440G1 A27.429
    N99450G1 X0.255
    N99460G1 X0.285 Z0.068
    N99470G0 Z0.700
    N99480G0 X2.475
    N99490G0 Z0.265
    N99500G1 Z0.068
    N99510G1 X2.505 Z-0.062
    N99520G1 X2.535
    N99530G1 A332.571
    N99540G1 X2.505
    N99550G1 X2.475 Z0.068
    N99560G0 Z0.700
    N99570G0 X0.285
    N99580G0 Z0.265
    N99590G1 Z0.068
    N99600G1 X0.255 Z-0.062
    N99610G1 X0.225
    N99620G1 A30.857
    N99630G1 X0.255
    N99640G1 X0.285 Z0.068
    N99650G0 Z0.700
    N99660G0 X2.475
    N99670G0 Z0.265
    N99680G1 Z0.068
    N99690G1 X2.505 Z-0.062
    N99700G1 A34.286 F37.5
    N99710G1 A329.143 F50.0
    N99720G1 X2.475 Z0.068
    N99730G0 Z0.700
    N99740G0 X0.285
    N99750G0 Z0.265
    N99760G1 Z0.068
    N99770G1 X0.255 Z-0.062
    N99780G1 A325.714 F37.5
    N99790G1 A34.286 F50.0
    N99800G1 X0.285 Z0.068
    N99810G0 Z0.700
    N99820G0 X0.000 A0.000
    N99830G0 Z0.134
    N99840G1 Z-0.062
    N99850G1 X0.255 Z-0.085 F37.5
    N99860G1 X0.000 Z-0.107
    N99870G1 X0.015 Z-0.108
    N99880G1 X0.000 Z-0.109
    N99890G1 X0.255
    N99900G1 X0.285 Z0.068 F50.0
    N99910G0 Z0.700
    N99920G0 X2.475
    N99930G0 Z0.265
    N99940G1 Z0.068
    N99950G1 X2.505 Z-0.109 F37.5
    N99960G1 X2.750
    N99970G1 A360.000
    N99980G1 X2.505
    N99990G1 X2.475 Z0.068 F50.0
    N100000G0 Z0.700
    N100010G0 X0.285
    N100020G0 Z0.265
    N100030G1 Z0.068
    N100040G1 X0.255 Z-0.109 F37.5
    N100050G1 X0.000
    N100060G1 A3.429
    N100070G1 X0.255 F50.0
    N100080G1 X0.285 Z0.068
    N100090G0 Z0.700
    N100100G0 X2.475
    N100110G0 Z0.265
    N100120G1 Z0.068
    N100130G1 X2.505 Z-0.109
    N100140G1 X2.745
    N100150G1 A356.571
    N100160G1 X2.505
    N100170G1 X2.475 Z0.068
    N100180G0 Z0.700
    N100190G0 X0.285
    N100200G0 Z0.265
    N100210G1 Z0.068
    N100220G1 X0.255 Z-0.109
    N100230G1 X0.015
    N100240G1 A6.857
    N100250G1 X0.255
    N100260G1 X0.285 Z0.068
    N100270G0 Z0.700
    N100280G0 X2.475
    N100290G0 Z0.265
    N100300G1 Z0.068
    N100310G1 X2.505 Z-0.109
    N100320G1 X2.715
    N100330G1 A353.143
    N100340G1 X2.505
    N100350G1 X2.475 Z0.068
    N100360G0 Z0.700
    N100370G0 X0.285
    N100380G0 Z0.265
    N100390G1 Z0.068
    N100400G1 X0.255 Z-0.109
    N100410G1 X0.045
    N100420G1 A10.286
    N100430G1 X0.255
    N100440G1 X0.285 Z0.068
    N100450G0 Z0.700
    N100460G0 X2.475
    N100470G0 Z0.265
    N100480G1 Z0.068
    N100490G1 X2.505 Z-0.109
    N100500G1 X2.685
    N100510G1 A349.714
    N100520G1 X2.505
    N100530G1 X2.475 Z0.068
    N100540G0 Z0.700
    N100550G0 X0.285
    N100560G0 Z0.265
    N100570G1 Z0.068
    N100580G1 X0.255 Z-0.109
    N100590G1 X0.075
    N100600G1 A13.714
    N100610G1 X0.255
    N100620G1 X0.285 Z0.068
    N100630G0 Z0.700
    N100640G0 X2.475
    N100650G0 Z0.265
    N100660G1 Z0.068
    N100670G1 X2.505 Z-0.109
    N100680G1 X2.655
    N100690G1 A346.286
    N100700G1 X2.505
    N100710G1 X2.475 Z0.068
    N100720G0 Z0.700
    N100730G0 X0.285
    N100740G0 Z0.265
    N100750G1 Z0.068
    N100760G1 X0.255 Z-0.109
    N100770G1 X0.105
    N100780G1 A17.143
    N100790G1 X0.255
    N100800G1 X0.285 Z0.068
    N100810G0 Z0.700
    N100820G0 X2.475
    N100830G0 Z0.265
    N100840G1 Z0.068
    N100850G1 X2.505 Z-0.109
    N100860G1 X2.625
    N100870G1 A342.857
    N100880G1 X2.505
    N100890G1 X2.475 Z0.068
    N100900G0 Z0.700
    N100910G0 X0.285
    N100920G0 Z0.265
    N100930G1 Z0.068
    N100940G1 X0.255 Z-0.109
    N100950G1 X0.135
    N100960G1 A20.571
    N100970G1 X0.255
    N100980G1 X0.285 Z0.068
    N100990G0 Z0.700
    N101000G0 X2.475
    N101010G0 Z0.265
    N101020G1 Z0.068
    N101030G1 X2.505 Z-0.109
    N101040G1 X2.595
    N101050G1 A339.429
    N101060G1 X2.505
    N101070G1 X2.475 Z0.068
    N101080G0 Z0.700
    N101090G0 X0.285
    N101100G0 Z0.265
    N101110G1 Z0.068
    N101120G1 X0.255 Z-0.109
    N101130G1 X0.165
    N101140G1 A24.000
    N101150G1 X0.255
    N101160G1 X0.285 Z0.068
    N101170G0 Z0.700
    N101180G0 X2.475
    N101190G0 Z0.265
    N101200G1 Z0.068
    N101210G1 X2.505 Z-0.109
    N101220G1 X2.565
    N101230G1 A336.000
    N101240G1 X2.505
    N101250G1 X2.475 Z0.068
    N101260G0 Z0.700
    N101270G0 X0.285
    N101280G0 Z0.265
    N101290G1 Z0.068
    N101300G1 X0.255 Z-0.109
    N101310G1 X0.195
    N101320G1 A27.429
    N101330G1 X0.255
    N101340G1 X0.285 Z0.068
    N101350G0 Z0.700
    N101360G0 X2.475
    N101370G0 Z0.265
    N101380G1 Z0.068
    N101390G1 X2.505 Z-0.109
    N101400G1 X2.535
    N101410G1 A332.571
    N101420G1 X2.505
    N101430G1 X2.475 Z0.068
    N101440G0 Z0.700
    N101450G0 X0.285
    N101460G0 Z0.265
    N101470G1 Z0.068
    N101480G1 X0.255 Z-0.109
    N101490G1 X0.225
    N101500G1 A30.857
    N101510G1 X0.255
    N101520G1 X0.285 Z0.068
    N101530G0 Z0.700
    N101540G0 X2.475
    N101550G0 Z0.265
    N101560G1 Z0.068
    N101570G1 X2.505 Z-0.109
    N101580G1 A34.286 F37.5
    N101590G1 A329.143 F50.0
    N101600G1 X2.475 Z0.068
    N101610G0 Z0.700
    N101620G0 X0.285
    N101630G0 Z0.265
    N101640G1 Z0.068
    N101650G1 X0.255 Z-0.109
    N101660G1 A325.714 F37.5
    N101670G1 A34.286 F50.0
    N101680G1 X0.285 Z0.068
    N101690G0 Z0.700
    N101700M05
    N101710M30
    15362
    Re: Added a 4th axis, having a strange issue with z axis.
    G54 put this above the first move line
    G90G0 X0.000 Z0.700 A0.000 do this on the first line, it may not make any difference, but this is how it should be used
    Set your X & Y Axes 0.0 G54 then set your tool to the centre of rotation, this is how you have it programed, no Z height to set only the tool, make sure there is 0.0 in the G54 Z0.0 A0.0 just X & Y will have a number
    Set you tool to the top of your part, move the Y axes away from the part & add .5 to put your tool at 0.0 of your part , then your program should work how you have done it, check this without a part in the 4th Axes
    Found the .375 move, I will look at it some more
    Mactec54
    15362
    manyhats2007
    I see that you have Z moves that go past the 0.0 point,( Z-.109 ) center of your part, some of the moves are more than .6 deep from the top of the part, is this correct, you will have a crash if this is not correct
    Mactec54
    Jun 2014
    49
    Yep, It should go past the center in a few segments. I'm going to give it another run this evening with the changes you suggested and let you know the results. Thank you again.
    Apr 2004
    5737
    It sounds like you're losing steps in Z when plunging into the part. See if slowing down the plunge and ramping into the cut helps. To set up ramping, right-click on your machining operation to bring up the Operation Parameters. In the Roughing panel, set a ramp angle - somewhere around 5 degrees should be about right. In the Movement panel, set the lower feedrate percentage for plunge movements - try 25%. Let us know how the next try goes, okay?
    Andrew Werby
    Computersculpture "dot' com
    Andrew Werby
    Website
    15362
    awerby
    All his Z moves are already ramping down as the X axes moves,he could change the feed rate for the X Z moves, but only if his cutter can't handle what it is doing, his Z ramp moves are only .062 over the length of the X axes move
    Mactec54
    Jun 2014
    49
    Figured it out.
    It was losing steps, but on the G0 up to clear the piece before it plunged back down, so it seemed like it was gaining steps by plunging too far. (good call Gerry). I slowed the rapids down and it normalized. I never had a problem with it before. The problem probably showed up now because I added another motor to the gecko g540 without adding more power (it runs on a 40volt, 12.5 amp supply and all the motors are 3.5 amp). The z axis stepper isn't getting as much current in this configuration and so it misses steps on rapids moving up. I can slow down all the rapids to avoid this problem in the future, make another profile that cuts power to the y-axis motor when doing 3-axis rotary work as I am here, or figure out how to add more power if I can ever figure out how to do true 4-axis work (I have access to mastercam at the University I'm associated with, but not sure if it is worth the effort on my level in the hobby)
    I really want to thank everyone that helped out here. It is very nice not to be completely on my own when a problem shows up. I didn't know much about gcode before this (I just let the cam software figure it out) and I'm slowly starting to learn. Again, thanks to everyone that chimed in. I'm going to try cutting the piece tomorrow (I have to get more stock to cut) and I'll post a picture if it turns out alright.
    Apr 2004
    5737
    It's good that you figured out the problem. But cutting power to the Y axis isn't a good idea, since you need that axis held firmly while the other axes move, or else it will drift. Replacing your power supply with a more powerful one might work better. If you're using current-limiting resistors on the Geckos, they might be restricting the power too much. And if there's a heavy load on the Z axis from your spindle, it can fault on the way up. Typically, a Z axis will be set to go a bit slower than the others. You might consider adding a gas spring to the Z axis to help it with the load.
    Andrew Werby
    Website
    The G540 has a 7 amp internal fuse, and can't draw more than 7 amps. If you had a 12.5 amp supply, than you have more than enough current.
    Make sure there's no binding anywhere in the Z axis. It's possible that this particular program just stressed the Z axis more than others you've run. I ran my machine for months and never lost steps. As soon as I started doing 3D cutting, the Z started losing position. Lowering the accel fixed it. Most likely, you just don't have enough power to do the moves you're trying to do.
    Jun 2014
    49
    Well, I slowed things down and the z axis seemed to do fine, but then I had lost steps on the A-axis. I wound up unplugging the Y and clamping my gantry in place and it worked. I'll change the acceleration rates, as they are very high and test it out again with all motors plugged in. I do have resistors across all the motors. My machine is homemade and on a budget, so I'm sure things are not optimally smooth and it does bind in places. Oh well. I'm going to keep playing with it. I have to find a source for a cheap,long .25 ball endmill to try some larger pieces (theoretically, I have the room for 12" diameters, but not sure how the weight will work). Any suggestions?
    As promised, here is the first piece:
  1. Replies: 2
    Last Post: 03-02-2014, 03:22 PM
  2. Anyone ever added a 5th axis board to a VF3SS?
    By warfish3651 in forum Haas Mills
    Last Post: 12-02-2013, 06:39 PM
  3. Has anybody added 4th axis to Anilam crusader M???
    By van37725 in forum Uncategorised MetalWorking Machines
    Last Post: 04-27-2013, 09:09 PM
  4. Dual x-axis strange issue
    By forseral in forum DIY CNC Router Table Machines
    Last Post: 08-27-2011, 04:49 PM
  5. Has anyone added a C axis and live tooling?
    By pontiacg5 in forum Mini Lathe
    Last Post: 02-21-2011, 05:44 PM
