586,640 active members*
2,742 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Produce 440v 3 phase power in a home shop with 220v single phase power source.
    Jul 2003
    138
    Hello, can anyone give me some advise on how to produce 440v 3 phase power in a home shop with 220v single phase power source. The goal is to power a Hardinge lathe which has a 440v volt 3 phase motor.
    Because it is a small shop I would prefer the most direct approach. Based on my research I have discovered the following options.
    1) Rewire Motor to 220v 3 phase and use a VFD.
    2) VFD Option - 220v 1 phase in 440v 3 phase out into lathe. Not sure if these exist as I have not found any on ebay.
    3) Transformer and VFD Option - 220v 1 phase into transformer, 440v 1 phase out of transformed into VFD, 440v 3 phase out of VFD into lathe
    4) VFD into Transformers configured into "Open-Delta" configuration option - 220v 1 phase into VFD, 220v 3 phase out into "Open-Delta" transformers, 440 3 phase out into late.
    Any help would be appreciated. I am also in Ontario Canada if anyone can recommend local solutions.
    Thanks!
    Feb 2009
    6028
    Re: Produce 440v 3 phase power in a home shop with 220v single phase power source.
    Re wire motor and whatever controls. Run a vfd or phase converter. Otherwise you would need to run a huge phase converter then a step up transformer. Never seen a single phase step up that goes to 440/480.
    sent from me
    Might be more cost effective to get a new motor
    Using Tapatalk
  1. Bridgeport R2E3 delima, 220v VFD 3 phase Versus 220V Single Phase
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2015, 04:01 AM
  2. Trouble with single phase power though contactors
    By pritch1986 in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2014, 05:18 PM
  3. 3 phase power in home shop?
    By xclr82xtc in forum Uncategorised MetalWorking Machines
    Last Post: 07-16-2010, 03:26 AM
  4. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  5. Replies: 8
    Last Post: 04-09-2008, 03:42 PM
