I am building a 4x8 router table. This is my second machine. The first was a 2 x 4 running Linux. I am running Mach 3 with may new machine.
It is running fairly well but I am having problems setting up a touch-plate. Everything works in the diagnostics screen and if I initiate the Auto Tool Zero then just touch my grounding plate to the router bit it zeros the axis and returns 1.5" like it is supposed to. The problem I think is that my router bit is not insulated from the rest of the machine. If I try to run the Auto Zero with the plate sitting on the table as soon as it touches all my motors start moving in random directions! Is there something I have wrong in my configuration?
I have pin 15 connected to the ground plate through a resistor and my alligator clip to a GND.
