586,096 active members*
3,790 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CamSoft Products > CAMSOFT WITH GALIL DMC 1866 - LIMIT SWITCH ACTIVE NOT SO RESPONSIVE
    Dec 2009
    10
    Unhappy CAMSOFT WITH GALIL DMC 1866 - LIMIT SWITCH ACTIVE NOT SO RESPONSIVE
    Can somebody give a solution for me as to how to stop the axis motion immedietely as soon as the positive edge for the limit switch got sensed. I have got the camsoft ver 17.6 and galil dmc-1866 card installed in windows xp. thing is that when ever the linear speed increase the stopping distance also increased and bangs the end point.
    Mar 2004
    1543
    Re: CAMSOFT WITH GALIL DMC 1866 - LIMIT SWITCH ACTIVE NOT SO RESPONSIVE
    Quote Originally Posted by Arul prakash View Post
    It IS HARD to defy the laws of physics
    Set your acceleration as high as you can, it will stop faster. larger servos would make it stop faster. This isn't a software issue. For that matter the Camsoft HDMI isn't involved. Galil sees a limit switch and stops motion to that axis.
    You could take a look at Camsoft soft limits and prevent a command calling to go past the limit from being issued.
    Karl
    Apr 2003
    332
    Hello Arul,
    This maybe an easy one.
    There are 3 ways to control how the axis stop when a over travel limit is hit.
    (1) By default the motion card it itself separate from Windows will disable the amp drive. The amp drive will be turned off and the motors go limp. The table will coast to a stop. You can disable this function using the CONFIGLIMITS command.
    (2) The faster your travel speed is, the more influence the weight & momentum of the table have , which may take longer to decelerate to a stop. You can set a high DECEL to stop at a quicker / faster rate.
    (3) You can use the logic command SETESTOP NODECEL NORELEASE to control how & when motion stops under both an E-STOP condition or over travel. This command with these options will stop the machine immediately and not disable the amp drives, holding the axis position steady at a dead stop using closed loop servoing.
    Use choice (3) if this is the Z axis and there is no counter balance to keep the head from falling under gravity.
    Caution: Stopping abruptly will be hard on your nuts and screws.
    To help you further, we would need more information. If you need further help please send us a History file and a current BACKUP of your CBK file.
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
  1. galil motion control active X toolkit
    By servomec04 in forum CNC Machine Related Electronics
    Last Post: 05-24-2011, 04:19 AM
  2. Galil Limit switch Homing
    By Karl_T in forum Controller Cards
    Last Post: 03-04-2011, 11:38 PM
  3. Galil & Camsoft
    By RAP in forum CamSoft Products
    Last Post: 08-04-2010, 10:39 AM
  4. Camsoft \ Galil
    By johnwaa in forum CamSoft Products
    Last Post: 09-11-2009, 09:45 AM
  5. Galil & Camsoft
    By RAP in forum Controller Cards
    Last Post: 09-09-2009, 09:31 PM
