586,121 active members*
3,613 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > whats wrong with my laser cutter? (no clean and smooth cuts)
    Jun 2014
    Unhappy whats wrong with my laser cutter? (no clean and smooth cuts)
    Hello,
    I have a huge 100 watts laser cutter and I use lasercut 5.3 to control it, Ive recently started cutting 6mm black plexiglass, at first I could get a clean perfect cut at speed 2 and power 100% but now when I try the same speed and power I get bumpy cuts and not smooth cuts with the same material.
    what is the problem?
    what should I do?
    Thank you
    Nov 2008
    382
    Re: whats wrong with my laser cutter? (no clean and smooth cuts)
    hi there
    there are a few things you should check:
    check you beam align up
    check your lense if it is clean and not scratched or broken
    how old is your tube
    I am cutting 6mm black plexi with a 40 W at 70% power and 4mm speed you should get with a 100W faster speed
    greetings waltfl
    and check the laser head, is it shakable?
    www.thunderlaser.com
    Feb 2012
    387
    The laser tube manufacture time is on the stick, you should check ,how long you use? and how about laser power, does it work normal? all these decide the cutting effect
    Quote Originally Posted by Bardiaesm View Post
    Hello,
    what should I do?
    Thank you
    Lucy Lee G.WEIKE LASER
    [email protected]
  1. Laser cutter nog cutting smooth
    By NatD in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-01-2014, 03:05 PM
  2. Smooth Profile Cuts
    By ecope in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-09-2012, 07:40 PM
  3. Replies: 5
    Last Post: 02-28-2010, 05:24 AM
  4. Whats the trick to clean Spar cuts?
    By Burnt Offering in forum CNC Wire Foam Cutter Machines
    Last Post: 10-20-2009, 06:16 PM
