586,058 active members*
4,268 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Need to convert dxf to 3d file
    Jun 2014
    4
    Hi Guys I'm hoping someone can help me. I am using a program named Cadman and its for a 320 ton Press break. I have the option of inputing dxf sat iges and step files to run a simulation of the part to be pressed. However my company is on using dxfs with bend lines. Now my issue is the Cadman software sometimes crashes when using dxfs(which is getting real frustrating) so I'm trying to find a program that will convert dxf to either iges sat or step. Anyone know of a software program????
    I also am using a very old version of Cad std.
    thanks in advance
    Michael
    Jun 2014
    4
    Re: Need to convert dxf to 3d file
    Burr Man, please find attached.
    Attached Files Attached Files
    Dec 2008
    4548
    I may have misread the original post. I was going off of a "dxf is crashing my system", when you were asking about programs that will save out the different formats to try....
    Here's your dxf saved as a dxf to try... (Did that sample dxf crash your system? See if this one does... Maybe your system is looking for a 3d dxf and this one is just 2d?)
    But, on the note of a program that will convert the file? There are many. Viacad is cheap and will do it. Moi3D is a good choice.
    There are many....
    Jun 2014
    4
    DXF still crash the press software... I can open the iges file cnczone wont let me?
    Dec 2008
    4548
    I attached a zip file with your file saved out as an iges format. Download the zip and then extract the iges file... (you wont be able to open it directly from the zone)
  1. convert OE1&OE2 to #EX file
    By behco in forum Fanuc
    Last Post: 03-30-2020, 07:31 AM
  2. Convert obj or 3ds file to stl
    By adamchapman in forum Uncategorised CAM Discussion
    Last Post: 01-30-2014, 01:14 AM
  3. Convert DWG file to DSTV file
    By benamer in forum Community Club House
    Last Post: 07-02-2013, 02:34 PM
  4. convert STL file
    By dlaery in forum BobCad-Cam
    Last Post: 11-01-2011, 05:31 AM
  5. How can I convert an EPS file to DXF ??
    By Danno in forum Signmaking Topics
    Last Post: 02-28-2011, 06:00 PM
