587,067 active members*
3,480 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Amada 2415 Pulsar Fanuc 16L glass tube inspection
    Jan 2013
    37
    Hello,
    Has anyone ever tried to remove the glass tubes and inspect/replace the o-rings ? I'm getting a 4063 alarm when trying to bring the laser up and I'm suspecting an internal leak.
    Dec 2010
    4
    Re: Amada 2415 Pulsar Fanuc 16L glass tube inspection
    So if do all accurate and with patience there is nothing complicate. Do you still need help?
    Jan 2013
    37
    Found 2 cracked tubes so i replaced them and put new o-rings of the other 2 tubes. And also replaced the trigger o-rings. Did an internal leak check and it was great, no leak. From contaminants getting into the system I'm getting a mirror cleaning alarm but I made some cut condition changes till I can get an internal cleaning/alignment done.
  1. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  2. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
  3. Difference between Chinese Glass tube and RF Tube...
    By InfernusDoleo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-08-2012, 03:44 AM
  4. amada pulsar 2415 cut conditions
    By Apexengineering in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-28-2010, 02:27 AM
