586,058 active members*
4,856 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > How are you attaching your Spoil Board
    Nov 2010
    92
    Hello everyone,
    I have my CRP 4848 router completed and running but I'm looking for some suggestions on how you guys are doing your Spoil Boards. I currently have a 3/4" sheet of cabinet grade plywood attached to my cross members and I plan on putting a piece of 3/4" MDF on top of that for the spoil board. I've designed the hole patten in my V-Carve Pro software for my hold down threaded inserts and I'm just waiting for my set of precision collets to arrive so I can start drilling.
    My question is, How are you attaching the MDF down?
    I'm looking forward to your suggestions.
    Chuck :rainfro:
    Apr 2010
    82
    Re: How are you attaching your Spoil Board
    I use countersunk bolts running into t-nuts on the underside of the ply.
    My MDF spoilboard with threaded inserts is glued down. I have the hole layout in CAD, so that when it get's close to the inserts, I can just glue a new piece of MDF on top, and route the holes over the inserts.
    Attachment 241912
    I am connecting the trim/bearing guards to the MDF then countersinking 9 M8 bolts through the MDF to the base frame. In all the corners and through the middle. Then I will have the CNC cut a grid of holes that I will run threaded inserts into. right not the MDF with the trim is such a tight fit you need to tap it with a block of wood and a mallet to move it.
  1. Spoil board
    By skylanehku in forum Momus Design CNC plans
    Last Post: 05-29-2013, 10:15 PM
  2. Spoil board cutter?
    By mafitch7479 in forum Commercial CNC Wood Routers
    Last Post: 08-24-2011, 04:37 AM
  3. Surfacing the spoil board
    By Rickv100 in forum Commercial CNC Wood Routers
    Last Post: 10-31-2009, 08:28 PM
  4. Spoil Board
    By lfourtner in forum Commercial CNC Wood Routers
    Last Post: 12-15-2008, 07:40 PM
  5. Resurfacing spoil board
    By avccrml in forum WoodWorking Topics
    Last Post: 08-12-2007, 02:01 PM
