Originally Posted by
mariojl
There is more than one way to control the tool so it won’t cut on the outside perimeter.
If you create a profile equal to the outline of the part, and use it to set your Material Type to “Top Profile” (or Bottom Profile); in this way the tool will be contained and won’t be cutting on the outside perimeter. Of course the plunge must be set to either ramping or helical, no way to get into the material using those two openings on the sides.
Other way is to create an outside surface which represents the actual stock material and then set Material Type to “Surfaces”, the system will cut all that’s between both surfaces. Something to watch for; both surfaces ( inside and outside) must be looking at each other ( “surface orientation”)
Mario
