586,617 active members*
2,586 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Daewoo Puma 200M Error 2005
    Jul 2014
    Does any one know how to get fix/ get rid of the error message 2005. The screen says hydraulic pressure is down and to check the pressure switch, pressure valve leakage 0 F hydraulic. Any help is much appreciated.
    Feb 2013
    788
    Re: Daewoo Puma 200M Error 2005
    Do you have hydraulic pressure at the gauge when pressing the <Alarm Reset> and <machine ready> buttons for ten seconds (together)?
    If yes, the pressure sensing switch is faulty. Replace it.
    If no, is there fluid that is making it through a "not clogged" filter? (clean filter or fill tank as needed)
    If no pressure, and no clog, is there a massive leak that is inhibiting the ability to form pressure? (your garden hose means nothing to the flow of the grand canyon...)
    No pressure, no clog, no leak = probably the pump is damaged.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    0F is the alarm?
    Mitsubishi.
    Hell-das...
  1. Daewoo Puma 12s-3a
    By koolaidkid in forum Daewoo/Doosan
    Last Post: 03-27-2024, 08:41 PM
  2. Daewoo Puma 6 with 3tf
    By mmxmb in forum Daewoo/Doosan
    Last Post: 04-06-2011, 01:36 PM
  3. Daewoo puma 8s
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 06-14-2010, 07:58 AM
  4. I Need to buy a Daewoo Puma 8
    By gcrudgington in forum Daewoo/Doosan
    Last Post: 10-20-2008, 11:24 PM
