586,915 active members*
2,831 visitors online*
Results 1 to 5 of 5
    Jun 2014
    16
    The performance of the scanner
    Main performance indexes are x, y direction of the scanner, the resolution of the color resolution (color number) and the way of scanning width
    and interfaces.All kinds of scanners are clearly indicate its optical resolution and maximum resolution.Resolution of a single
    Dpi, dpi is English Dot Per Inch, the pixel points Per Inch.
    1. What is the optical resolution?
    Optical resolution refers to the optical scanner system can collect the actual amount of information, also is the resolution of the sensor, CCD
    scanners.Such as maximum scanning range is 216 mm x 297 mm (scan) suitable for A4 paper
    Instrument can scan the maximum width of 8.5 inches (216 mm), the CCD contains 5100 units, its optical resolution of 5100 points / 8.5 inch =
    600 dpi.Common optical resolution of 300 x 600, 600 by 1200,
    1000 * 2000 or higher.
    2. What is the maximum resolution?
    Maximum resolution also known as interpolation resolution, it is between the adjacent pixels increasing number of colors or grayscale average
    method.Interpolation algorithm to increase the number, but it can't add the real image detail, because of
    This, we should attach more importance to optical resolution.
    3. What is the color resolution?
    Color resolution and color depth, color, pattern, color or color order, in a word are markers of scanner resolution color or gray degree of
    exquisite, it is the unit of bit (bit).
    Color a precise meaning is to use how many bits to represent a pixel scanning.For example: 1 bit said only black and white pixels, because the
    number in the computer using binary, 1 bit said only two values (21 = 2) and 0
    1, they represent black and white.8 bit can represent 256 grayscale (28 = 256), they represent different grey scale from black to white.24 bit
    can represent 16777216 kinds of colors (224 = 16777216), red (R
    ), green (G), blue (B) each channel occupies the first 8 bit respectively, each with 2 ^ 8 = 256 level, the general said more than 24 bit colour
    for true color, and of course use 30 bit bit, 36, 42 bit model.
    Theoretically, the more color figures, the color is more realistic, but for non-expert users, due to the computer processing power and output
    printer resolution limit, the pursuit of high color a wave will only bring to us
    Fee.
    4. What is the TWAIN?
    TWAIN (Technology Without An Interesting Name) is a common follow the specifications of the scanner manufacturer, is a standard interface
    between the application and the image capture device.As long as is to support the TWAIN driver
    Can be started in accordance with the specifications of the scanner.
    Can start the scanner in the Microsoft Word, for example, is to open the menu bar "insert" to "image", "from the scanner.Using the method of
    Adobe Photoshop can do it, too, are open
    "File" to "Import", "Select TWAIN_32 Source".
    5. What is the interface way?
    Interface way to connect (interface) refers to the scanner and the computer using the interface type.Commonly used with USB interface, SCSI
    interface and parallel printer interface.Fastest SCSI interface transmission, and use parallel printer
    The interface is more convenient.
    Apr 2004
    5742
    Re: The performance of the scanner
    This sounds like it was cribbed from a Chinese instruction manual for an old flatbed scanner and run through Google Translate. What does any of this have to do with CNC? This is all about 2D scanners; we use 3D scanners - they are entirely different.
    Andrew Werby
    Website
    Aug 2006
    143
    I've seen a few of these kind of posts in other forums as well.
    Not sure whats up
    Jun 2014
    16
    Is so ah, I just want to learn more knowledge by discussion, thank you for your guidance.
    Jun 2014
    16
    You are also looking at the 3 d printer BBS?Me too, I just want to learn more, and you?
