586,119 active members*
3,594 visitors online*
Results 1 to 8 of 8
    Jul 2006
    7
    Pallet Change
    Somebody Knows how do pallet change in a machining center Tsugami FMA3, I Know that I have to use a M60 code but I can't finish like if something is missing. What is the procedure for do it?
    Thank's
    Jul 2006
    25
    On a TOYODA FA550-II we use a M90 in MDI.
    If we want to do it in the program we have to ...
    M2
    M90
    Machine will stop at the M2 and then when you hit the cycle start at the back of the machine near the pallet doors it will index the pallets.
    _
    ~ What was once an Opinion, became a Fact, to be later proven Wrong ~
    Jun 2006
    478
    How many pallets do you have? and what control?
    A.J.L.
    Jun 2006
    478
    Also do you have an m-code list it might need a clamp code etc.
    Jul 2006
    7
    Yes the control is Fanuc 16M with 10 pallets,and of course needs a clamp code the problem is there, when I want clamp the B axis an interruption in the circuit diagram appears in a address (BROF.L) by the name of the direcction I think is the signal of a limit switch but doesn't exist in the machine
    Jun 2006
    478
    Sounds like it's not making the switch fully? switch malf.? etc.
    Mar 2006
    1625
    one of the biggest problem I seen with pallet change is the limit switchs coolant over time makes them stick we hit it once a week with wd-40
    May 2010
    5
    Re: Pallet Change
    Do you follow the M60 with an M96? The M96 will call the program from the pallet number.
  1. Help NH4000 HORIZONTAL PALLET CHANGE
    By Scottyb in forum Mori Seiki Mills
    Last Post: 05-05-2016, 12:41 AM
  2. HS1 pallet change speed
    By The CNC Noob in forum Haas Mills
    Last Post: 01-28-2016, 12:00 AM
  3. In program pallet change
    By imjustakid in forum Mori Seiki Mills
    Last Post: 07-21-2014, 04:53 AM
  4. APC wont pallet change - Need help please!
    By Iownacnc in forum Okuma
    Last Post: 12-12-2011, 04:50 PM
  5. Pallet Change Speed
    By 68 SS in forum Fanuc
    Last Post: 09-19-2008, 03:36 PM
