586,894 active members*
4,075 visitors online*
IndustryArena Forum > CAM Software > Mastercam > POST PROCESSOR FOR PLASMA CUTTER ON MASTERCAM
Results 1 to 16 of 16
    Nov 2012
    8
    Question POST PROCESSOR FOR PLASMA CUTTER ON MASTERCAM
    HI!
    I'M NOT VERY GOOD IN EDITING OF POST PROCESSOR, SO I SEARCH A POST PROCESSOR THAT I CAN USE WITH MY HOME MADE PLASMA CUTTER,
    THE MACHINE IS NOT FINISH OF BUILDING BUT I WANT TO FIND THE POST PROCESSOR BEFORE MY FIRST RUN...
    IN PLASMA CUTTER, EACH TIME YOU START THE TORCH, THE MACHINE SHOULD "DWELL" TO LET THE PLASMA ARC CUT TROUGH THE SHEET, SO IT's POSSIBLE TO POST IT WITHOUT MANUALLY PROGRAM THE DWELL IN THE G-CODE???
    May 2012
    180
    Re: POST PROCESSOR FOR PLASMA CUTTER ON MASTERCAM
    Yes, of course it's possible. What code makes it dwell?
    May 2012
    180
    https://drive.google.com/file/d/0B2E...it?usp=sharing
    This is a link to the new .PST file with the dwell added.
    Misc real 1 is a factoring value. defaults to 1 second per mm.
    Hope this is what you required.
    May 2012
    180
    Mar 2018
    9
    Quote Originally Posted by Bm150 View Post
    do you have a new link post bro ?
    Nov 2012
    8
    THE DWELL CODE IS G04 P (TIME)
    BUT I WANT IT TO DWELL EACH TIME IT HAVE A NEGATIVE MOVEMENT ON THE Z AXES
    EX:
    G00 Z0.25
    G01 Z0.03 (POSITION OF THE TORCH FOR CUTTING)
    G04 P5 (TIME THE TORCH TAKE TO GET TROUGH THE PLATE)
    G01 X.. Y,, (SHAPE OF PART ETC.)
    May 2012
    180
    Should be able to do this, I'm thinking of a way to do it, does the dwell time need to change due to the thickness it's going through?
    If you post your .pst I'll try and have a go. Pm me if you don't want it public.
    Nov 2012
    8
    I CAN'T INSIRT THE .PST FILE IN THE REPLY... I WANT TO SEND THE "GENERIC FANUC 3X MILL" TO MODIFY IT...
    - - - Updated - - -
    sorry, the caps lock was "on"
    May 2012
    180
    If you compress it into a .zip file it will let you upload...
    Nov 2012
    8
    May 2012
    180
    Ok I will have a look tomorrow.
    Apr 2003
    3578
    Have fun BM as he only posted the PST file so what version is it for if it is for a new mastercam X series were is the Machine and condrol def.looks like an X3 post.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    May 2012
    180
    Ok done it, how do you want the p value to be controlled.
    At the moment I've done it by the z value. Eg if it's z 5. It will be p5. I've put in a factoring value so if it's factored at 0.5 _ z at 5 would give p at 2.5
    I'm guessing z values are always positive and you are cutting through to the bottom of the plate. Z0
    Can you confirm?
    May 2012
    180
    Nov 2012
    8
    YEAH, THE ZERO SET IN Z VALUE IS RIGHT ON THE TABLE (UNDER THE PLATE)
    May 2012
    180
    Ok. So how many seconds does it take to burn thru 1mm
  1. Mastercam X6 Post for Techno CNC plasma cutter
    By G&T_Machine in forum Mastercam
    Last Post: 05-10-2012, 02:44 PM
  2. Mastercam X2 post processor for X3
    By sotos in forum Syil Products
    Last Post: 07-03-2010, 07:24 AM
  3. Mastercam VTL post processor.
    By jrebel in forum Post Processors for MC
    Last Post: 12-09-2006, 11:24 PM
